Language Adaptation with unexpected consequences
Ian Claudi
Montreal
C?ID=402005
About a year ago, I imported a Mk4 Bora Variant TDI from Germany to replace my Mk4 Jetta TDI Wagon. The Bora is a fabulous car with features that VW never made available in NA ( 6MT, 4Motion, better headlights etc, etc ).
With some advice from VW I used my cable and VCDS software to change the language of displayed messages from German to English.
Their advice was to do Adaptation(10) of Instrument Cluster(17). Go to channel 04 and use one of the following numbers:
00001 German
00002 English
00003 French
00004 Italian
00005 Spanish
00006 Portuguese
00008 Czech
The change worked, "Bitte Tanken" is now "Please Refuel".
However, changing the language also disabled the 'chime' that tells you that the headlights have been left on.
I've been poking around in 17-Instruments, exploring but not changing anything, looking for something that would allow me to re-enable the chime. But I realized that I'm out of my depth with VCDS and its capabilities and need some help to re-enable the chime.
I've attached a scan from April 2020 and a scan from March 2021, after the language change was made.
April 2020 scan
Friday,10,April,2020,10:05:18:02080
VCDS Version: 20.4.0.1 (x64)
VIN: WVWZZZ1JZ3D012860   License Plate:
          76
VIN: WVWZZZ1JZ3D012860   Mileage: 270420km-168031miles
Address 01: Engine        Labels: 038-906-019-ARL.lbl
   Part No: 038 906 019 HH
   Component: 1,9l R4 EDC G000SG  1491
   Coding: 00003
   Shop #: WSC 31414
   VCID: 64C76A0AF4539FA686-4ACC
   WVWZZZ1JZ3D012860     VWZ7Z0B6037102
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 N
   Component: ESP ALLRAD MK60     0102
   Coding: 0023046
   Shop #: WSC 31414 000 00000
   VCID: 3561E74E5F49562EE1-5104
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 31414
   VCID: 2149231EABC1CA8E2D-517A
            06-10 - Signal too High - Intermittent
   Part No: 1C0 909 605 F
   Component: 02 AIRBAG VW61 0101 0001
   Coding: 12338
   Shop #: WSC 31414
   VCID: 275D3D06C5E534BE63-50E8
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 31414
   VCID: 306FD65AF02B7306B2-5198
   Part No: 1J5 920 846 C
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 21114
   Shop #: WSC 64611
   VCID: 306FD65AF02B7306B2-50E8
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 31414
   VCID: 70EF165A30AB3306F2-50E8
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
   VCID: 204F261AA0CBC38622-4AB2
Address 29: Left Light        Labels: 7M3-907-391-29.lbl
   Part No: 7M3 907 391
   Component: EVG GDL + AutoLWR   0003
   Coding: 00002
   Shop #: WSC 00001
   VCID: 74E71A4A44B30F2616-4B7C
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: Sitzverstellung     0301
   VCID: 2F6DD526BD156CFEAB-50E8
7 Faults Found:
01008 - Note; Emergency OFF Switch is Active!
00994 - Sensor for Front Height Adjustment On Drivers Seat (G215)
00995 - Sensor for Rear Height Adjustment On Drivers Seat (G216)
01009 - Sensor for Driver's Seat Position Fore/Aft (G218)
01010 - Sensor for Driver's Seat Recline (G219)
Address 39: Right Light        Labels: 7M3-907-391-39.lbl
   Coding: 00002
   Shop #: WSC 00001
01344 - HID (Xenon) Headlight
            16-00 - Signal Outside Specifications
   Part No: 1C0 959 799 B
   Component: 7G Komfortger�t HLO 0003
   Coding: 00259
   Shop #: WSC 31414
   VCID: 3663E042124F5D36E8-4AE4
   Subsystem 1 - Part No: 1C0959801B
   Component: 7G T�rsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C0959802C
   Component: 7G T�rsteuer.BF KLO 0004
   Component: 7G T�rsteuer.HL KLO 0004
   Component: 7G T�rsteuer.HR KLO 0004
            36-10 - Open Circuit - Intermittent
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
            35-10 - - - Intermittent
01359 - Internal Central Locking Switch; Passenger Side (E198)
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
   Part No: 1J0 035 186 D
   Component:  RADIO SON         0004
   Coding: 03403
   Shop #: WSC 31414
   VCID: 26433002C2EF2DB658-4AB2
Address 76: Park Assist        Labels: 1J0-919-283.lbl
   Part No: 1J0 919 283 A
   Component: Einparkhilfe        0001
   Coding: 00123
   Shop #: WSC 31414
   VCID: 2C57C22ADC0317E68E-50E8
End-------------------------(Elapsed Time: 04:15)--------------------------
March 2021 scan
Sunday,07,March,2021,13:36:52:42021
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4543.4
          76
VIN: WVWZZZ1JZ3D012860   Mileage: 289390km-179818miles
   Coding: 0023046
   VCID: 353724D4195B34F36C5-5160
   Coding: 11000
   Shop #: WSC 31414
   VCID: 211FE084B8D3A853A0D-51A8
   Coding: 12338
   Shop #: WSC 31414
   VCID: 270BFE9CD6F75663EE9-5118
   Coding: 00008
   Shop #: WSC 31414
   VCID: 303915C0E33911DB3F3-51F2
   Coding: 21114
   Shop #: WSC 64611
   VCID: 303915C0E33911DB3F3-5118
   Coding: 00006
   Shop #: WSC 31414
   VCID: 70B9D5C023B951DB7F3-5118
   VCID: 2019E580B3D9A15BAF3-4B00
No Faults Found
   Coding: 00002
   Shop #: WSC 00001
   VCID: 74B1D9D057A16DFB9BB-4B9A
   VCID: 2F3B16BCFB070E23269-5118
   Coding: 00002
   Shop #: WSC 00001
   Coding: 00259
   Shop #: WSC 31414
   VCID: 363523D8015D3FEB65F-4B00
   Coding: 03403
   Shop #: WSC 31414
   VCID: 2615F398D1FD4F6BD5F-4AE0
   Coding: 00123
   Shop #: WSC 31414
   VCID: 2C0101B0CF11753B03B-50D0
End----------(Elapsed Time: 04:12, VBatt start/end: 12.5V/12.3V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
You can check C:\Ross-Tech\VCDS\Debug, all the changes you made are recorded there. ;)
Ian Claudi
Montreal
C?ID=402005
Thank-you for the suggestion. In DEBUG it shows me the before and after values. It shows the change for the language but also a change to Channel 2 that I didn't know about. I'll see where this leads.
Best regards
Ian Claudi
Montreal
C?ID=402005
Restored the original language settings yesterday ( English back to German ). However, restoring the language settings did not re-enable the chime that says you have left the lights on when the key is removed.
The change to Channel 2 was to reset the service interval warning.
So, no further ahead.. The search continues.
MartinsX
Riga, Latvia
C?ID=268515
The lights on reminder is not tied to coding/adaptation in this age of clusters, however MK4 clusters have a lot of modifications, not all possible options may be described accordingly in VCDS label file 1J0-920-xx5-17.
Just in case make an admap of Your cluster and post it here.
But I'd check needed signals for activating warning chime first - "drivers door open" signal and "key removed" (terminal S) signal.
Ian Claudi
Montreal
C?ID=402005
MartinsX - I browsed the 1J0-920-xx5-17 label file but did not see anything that jumped out at me.
Sorry but I'm not familiar with the term 'admap'. Let me know what you need and I'll be happy to provide it.
I'll double-check the "drivers door open", whether or not the warning chime is still working.
Thanks for your interest and your post.
