Audi a4 b9 2port usb activation
Skysurferke
Belgium
C?ID=82280
Hello
i want to activate the 2 port usb 8W0 035 736 that i have retrofitted to my car .
the car originally came with 1 usb charge only and aux port.
all wiring is done ( extra power cable and cable to head unit )
i dont want the carplay activated , i would just like to be able to listen to music through the usb port .
Can someone help ?
Skysurferke
Belgium
C?ID=82280
this is the scan of the car ,
i see there is no long coding helper for module 5F
Can you guys help ?
Wednesday,31,March,2021,18:46:15:37894
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZF48JA151933   License Plate:
Mileage: 20820km-12936mi   Repair Order:
Chassis Type  F4-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 18 19 29 2B 39 3C 42 44 46 52 5F 69
          6C 6D 80 81 A5 BB BC CF D6 D7
VIN: WAUZZZF48JA151933   Mileage: 20820km-12936miles
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
80-Batt. reg. aux. accum. -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DEMA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 8W0 907 115 J    HW: 06L 907 309
   Component: R4 2.0l TFSI  H11 0003
   Revision: 1FH11000
   Coding: 1225001B2334050334282000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0118W0907115J 002003
   ROD: EV_ECM20TFS0118W0907115J_002.rod
   VCID: 408B144CDB17C5864B-8014
   Part No SW: 8W2 927 155 AG    HW: 0CJ 927 156
   Component: 0CK 20TFSIRdW H05 0003
   Revision: --H05---    Serial number: 0000001804
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 0607C254B9B32BB631-8052
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180033000169
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 K    HW: 8W0 907 379 J
   Component: ESP9 Plus     H10 0766
   Coding: 04AA089914A70A9751A7489400805292F4A5DA201028508A12004A492FA55B
   Shop #: WSC 06324 790 00001
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 4D953D781C4518EEB0-8018
12615680 - FlexRay Databus
          U0080 00 [044] - Defective
                    Mileage: 20820 km
                    Date: 2021.03.31
                    Time: 18:18:13
                    7E 00 82 00 46 00 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 Q    HW: 8W0 820 043 Q
   Component: Klima Zone 1  H40 0241
   Coding: 240940195140000500000100080000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 418D1148D01DCC8E44-8014
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002208982
   Subsystem 2 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
   Component: Humidity_Sens  H02 0007
   Serial number: ECE0961900PAG0FSA002
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501943E11800CD0505871458BF80F9110B1108000000000000000020001A810A450122025705
   Shop #: WSC 06325 790 00001
   VCID: 020FDE44959B17961D-8056
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 180208  043 0813
   Serial number: 89435300301803906103
   Coding: 5BC7F7
   Serial number: 21186275X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 25 12 2017  01235602
   Interior Light Module:
   Subsystem 4 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00703908
   Subsystem 5 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2817000306637006
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0107
   Serial number: 003UP00DDZZP
   Coding: AACCF0C00CA00000585400F3D04C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 4C93307CE75F11E6A7-8018
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 8W0857705F0053S00826
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 8W0857706G0057S01116
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 061 802 18
   Serial number: 3577Y00AB263F3B354DD
   Subsystem 4 - Part No SW: -----------    HW: 442 061 802 18
   Serial number: 3587Y00AB263F3B46155
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 802 18
   Serial number: 3517700C92987FE2A18Y
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 802 18
   Serial number: 3527700B729A78A6025F
   Subsystem 7 - Part No SW: -----------    HW: 442 0C1 802 18
   Serial number: 35575009F27C14314120
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 802 18
   Serial number: 3567500A127C1433132W
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 802 18
   Serial number: 2307500A127C1432033M
   Subsystem 10 - Part No SW: -----------    HW: 442 430 102 18
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M009927DBDF1724Z
   Subsystem 11 - Part No SW: -----------    HW: 442 430 102 18
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M009927DBDF354C3
   Part No SW: 4M0 907 129 KS    HW: 4M0 907 129 KS
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 0B11F360A2D156DE6E-805E
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0373
   Coding: 05A468D0288800080B20E9601000200000000000
   VCID: 43811B40CA01DE9E56-8016
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 4M0 265 105 D    HW: 4M0 265 105 D
   Component: HSG           H11 0090
   Coding: 0D0F01
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
   ROD: EV_AuxilParkHeateEBEAU736.rod
   VCID: 285BACEC53671DC663-807C
   Part No SW: 8W5 907 468 F    HW: 8W5 907 468 E
   Component: Gateway       H43 0123
   Revision: 7A000002    Serial number: 0287A794218303
   Coding: 020100010020064029870000005900124C180007100000000175078F10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180226071740 20958
   Subsystem 2 - Part No SW: 8W0 915 181 A    HW: 8W0 915 181 A
   Serial number: 3939307004
262659 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 61
                    Reset counter: 6
                    Mileage: 20655 km
                    Date: 2021.03.20
                    Time: 15:51:26
Address 29: Left Light
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 18000058513001
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 326F4E8465BB6716CD-8066
Address 39: Right Light
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------
   Coding: 1E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 3667729489D37B36E1-8062
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0129
   Serial number: 0000307656821
   Coding: 001F8B2040000080000010B0
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000380800000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 428F1E44D51BD7965D-8016
Address 46: Central Conv.
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0129
   Serial number: 0000306920059
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 036 B    HW: 8W5 035 036
   Component: MU-P-LN-EU    034 1177
   Serial number: A795B0JB084391
   Coding: 01940201FF00000053110001000A00102F00016501700100DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   VCID: 37797F908ED9823EFA-8062
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00122111700820842
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK121091700040362
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0473006661
   Coding: 0110000202000000
   VCID: 3565759894D5702EE8-8060
   Component: RVC Compact   H12 0250
   Coding: 0294020103002005400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 33614B809AA16E1EC6-8066
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 8W9 959 107 C    HW: 8W9 959 107
   Component: HDSG-Modul    H12 0163
   Revision: --------    Serial number: 31808198800000
   Coding: 05D0
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 4A9F3664ED2B0FD695-801E
Address 80: Batt. reg. aux. accum.
   Part No SW: 8W1 713 041 G    HW: 8W1 713 041 J
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 18022446167054
   ROD: EV_GSMWaehlZFAU736.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
   Component: BVS           H17 0050
   Coding: 0404090200000401022023A3A50000FC00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3C7360BCB7FFA16617-8068
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0129
   Serial number: 0000307273374
   Coding: 000F892000000080000010A0
   VCID: 45850558C435E0AE78-8010
   Component: TSG HBFS      005 0129
   Serial number: 0000307264111
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 05:34)--------------------------
siLc
Tallinn, Estonia
C?ID=330192
There is a reason I asked for an adaptation map of 5F ;) That contains the settings for number of USB ports.
downtime
Finland
C?ID=280813
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
Change that channel to activated and reboot your MIB. And if it's the same as in VW both USB ports will have Carplay capability, you don't need to enable that separately if it's already enabled with single port usb + aux.
Skysurferke
Belgium
C?ID=82280
Hello ,
i have changed this value but it has no effect ,
still is charge only on the 2 usb ports .
anything else what i can try ?
thx
vastechnics
C?ID=143747
Usb connection is an activation code. Code is 00030000 AMI (USB Enable)
Need to add this FeC code. I can do if you have Dlink
