VW Transporter Speed limiter removal
Audistorm
HUC (NRRT)
hello I have had the vcds cable for quite a few years and used it successfully to fix many vehicles and make lots of adaption,, great piece of kit, I am a real VW fan and run a V6 Amarok as a family car.
One of my customers has bought a 2018 diesel VW Transporter, not sure which model it is, he bought the van and then found out it had a speed limiter set to 70.
I thought i could fix it with vcds, I have recently serviced the van and today finally got chance to do an auto scan and have a look around, please see attached.
I completed the autoscan, saved it then proceeded to go into the engine module, clicked security access, it highlighted 27971, i filled in the field and then it said :
controller refused to send a seed, Error 7F service not supported in active session,
I tried for a while and it would not accept the code. Please see the autoscan, I would also like to find the power output if that is possible from the autoscan engine code details
Thanks for reading, any help would be appreciated.
Friday,19,March,2021,16:03:17:46871
VCDS Version: 21.3.0.0 (x64)
VIN: WV1ZZZ7HZJH127708   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 09 10 13 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZJH127708   Mileage: 61940km-38487miles
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4047
   Revision: 23002001
   Coding: 00114010430401090000
   Shop #: WSC 02762 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 76E45810C9702A3BE9-8022
Readiness: N/A
   Revision: 00000000    Serial number: 60348000000436
   Coding: 557E409825648485AA7C0276A48A21E679F100
   VCID: 3F8AFD34A6CAAB73FA-806A
   Serial number: 12011813470931
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF44030E140627BB1-802A
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 030180022
   Coding: E0A4303A0A212031002009742C2B8C500F00708F60464D60330400220800
   Shop #: WSC 02762 022 347899
   VCID: 2B52B9644AB227D346-807E
   Subsystem 1 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  004 0653
   Serial number: KU0KU025011880250093
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU025011880250556
   Coding: 0400A0
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231735503891
   Coding: 11800D
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71EE6B0CA01E0D033C-8024
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 1601180438A0BB
   Coding: 00004800FE1779
   ROD: EV_ACCBEGVW361.rod
   VCID: 3664981089F06A3B29-8062
1098 - Databus
                    Reset counter: 126
                    Mileage: 60214 km
                    Date: 2021.03.08
                    Time: 11:53:01
                    Control Module temperature: 23 ∞C
                    Voltage terminal 15: 10.5 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s≤
1072 - Databus
                    Fault Frequency: 21
                    Reset counter: 150
                    Mileage: 59844 km
                    Date: 2021.03.02
                    Time: 10:58:56
                    Control Module temperature: 16 ∞C
                    Voltage terminal 15: 11.6 V
   Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
   Component: VW10Airbag021 010 0018
   Revision: --------    Serial number: 003EK0006U3X
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 3D76873CACC6B963E8-8068
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Coding: 450B010300
   VCID: 3A7C8C20BDE88E5BCD-806E
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042305
   VCID: 68D806689BC4CCCB6B-803C
   Component: IMMO          H03 1107
   VCID: 6ADC7C608DC8FEDB7D-803E
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     056 7205
   Serial number: 26011800011232
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E54B07071A052FB61-807A
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030B7A73
   Shop #: WSC 02762 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 758857000018013009FB
   Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
   Component: Towbar module H10 0110
   Revision: 3A001001    Serial number: ¿¡006789122824
   Coding: 0100000100000000
   VCID: 316EAB0C689E4D037C-8064
End-------------------------(Elapsed Time: 02:35)--------------------------
VWT6
Finland
C?ID=295527
I'm afraid your VCDS cable can't modify this engine controller.
Have a look --> https://forums.ross-tech.com/index.php?threads/22540/post-196728
Anyways, VW has an updated ECU software for this engine, so perhaps the most beneficial way to proceed would be to have ECU reprogrammed with the new software. Reprogramming should clear also the speed limiter.
CXGB engine is specified as 75 kW (102 PS) at 3000-3750 rpm, max. torque 250 Nm at 1500-2750 rpm, comes with 5-speed manual transmission.
Audistorm
HUC (NRRT)
Many thanks for the reply, shame about the fix, he will be gutted, I think it has already been remapped hence he has missed his chance of the software update from VW.
Thanks for the engine power information and the feedback, thought I was going mad?
Is that why the module wouldn't accept the security access code?
VWT6
Finland
C?ID=295527
Unfortunately your VCDS cable is not capable of coding/adapting this ECU any more. The protocol in the ECU is beyond capabilities of older VCDS. Also module 13 is beyond it's capability - see the faults.
You would need current HEX-V2 or HEX-NET interface to access T6 EU6-engines (ECUs made by Delphi) - as verified in the linked thread.
I don't think that's this issue here; in other words I don't think an interface upgrade will help with removing the speed limiter.
Check the ECU for the following Adaptation channel:
IDE02248 -- Individually adjustable top speed limit
and see what it is set to.
If it won't take 27971, check what you have in this measuring value:
IDE00323 -- Security Access: Number of invalid keys
