VW Passat key not found
Wmwizkid
India
C?ID=374582
hello wizards.
i have here a vw passat which says key not found on the cluster but the car locks unlocks from the key fob. it even starts when the key is held near the key slot/barrel. the start stop button is in operative other wise but works when the key is held near the slot/barrel. The car starts fine. please help.
thanks in advance
the scan is as follows
Sunday,07,March,2021,22:04:41:02918
VCDS Version: 20.12.0.1 (x64)  HEX-NET CB: 0.4529.4
VIN: WVWC113C8BA000024   License Plate: PATWA
Mileage: 111600km-69345mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 36 42 44 46 4F 52 53 55
          56 61 62 6C 72 77
VIN: WVWC113C8BA000024   Mileage: 111600km-69345miles
Address 01: Engine (J623-CLLA)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 FF    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9977
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 001D0032042501080000
   Shop #: WSC 13002 938 00000
   ASAM Dataset: EV_ECM20TDI01103L906018FF 003009
   ROD: EV_ECM20TDI01103L906018FF.rod
   VCID: 73A6C81CDABE4E1C0F-8026
4519 - Radiator Fan 2 (V177)
          P1951 00 [032] - Movement Restricted / Jammed
                    Fault Frequency: 9
                    Mileage: 111601 km
                    Date: 2021.03.07
                    Time: 13:00:09
                    Engine RPM: 0.00 /min
                    Coolant temperature: 81 °C
                    Intake air temperature: 66 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 12.560 V
                    Air mass: specified value: 962.9 mg/stroke
                    Coolant temperature at radiator outlet: actual value: 103.6 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Outside temperature: 44.5 °C
                    Coolant fan 2: activation: 0.00 %
                    Coolant fan 1: activation: 10.00 %
                    Fuel temperature: 48.4 °C
   Part No SW: 02E 300 054 H    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2602
   Revision: 05351112    Serial number: 00001012012266
   Shop #: WSC 73430 790 00056
   VCID: 1B76C0BCDAAEA65CF7-804E
   Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
   Component: J104   C2 450M VD48 0005
   Revision: --H07---    Serial number: 00000003611075
   Coding: 0016316
   VCID: 383C3F304B58ED44FA-806C
   Part No SW: 5K0 907 044 EK    HW: 5K0 907 044 EK
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000001003
   Shop #: WSC 73430 115 00056
   VCID: 78BCFF30C3D82D443A-802C
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                    Reset counter: 112
                    Mileage: 111601 km
                    Date: 2021.03.07
                    Time: 13:01:27
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 0000000000000000001C0080740029F461D50088656C8560E480C7240041
   VCID: 393A3A34B052F44C05-806C
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 30091  26  0612
   Coding: 00B795
   Component: RLS 210710 05  54  0403
   Coding: 0330ED
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20441036403044
   Coding: 309305
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 3C342320B760C1641E-8068
1112084 - Front Left Center Parking Aid Sensor
          B10F8 14 [009] - Open or Short to Ground
                    Reset counter: 71
                    Mileage: 111595 km
                    Date: 2021.03.06
                    Time: 17:22:33
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__10P VW10 HI   2418
   Revision: 29020000    Serial number: 003N5P68FG5K
   Coding: 0012368
   Shop #: WSC 57803 002 1048576
   VCID: 004C97D05308658402-8054
   Subsystem 1 - Serial number: 6332MTS617903150
   Subsystem 2 - Serial number: 6342MTS637403070
   Subsystem 3 - Serial number: 6351HTS6AET089KR
   Subsystem 4 - Serial number: 6361HTS6PTC389KR
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0136
   Revision: FF010038    Serial number: 20100923300934
   Coding: 1992250001
   VCID: 6B96D07C828E96DCC7-803E
   Coding: E30000
   Part No SW: 3AA 920 880 A    HW: 3AA 920 880 A
   Component: KOMBI         H02 0206
   Coding: 160E01
   Shop #: WSC 00015 115 00056
   VCID: 312A021460223C0CBD-8064
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 211210F1000185
   Coding: 461007
   VCID: 34240B0097300924D6-8060
   Part No SW: 3AA 959 799     HW: 3AA 959 799
   Component:    IMMO         083 0399
   Revision: 00083000    Serial number: VWZCZ000000000
   VCID: 054286C44C2A40AC31-8050
01176 - Key
                    Fault Status: 01101000
                    Reset counter: 72
                    Mileage: 111601 km
                    Date: 2021.03.07
                    Time: 13:10:31
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669170800
   VCID: 281CEF705BF87DC46A-807C
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2201
   Revision: 00H05000
   Coding: 000039
   VCID: 3326081C923E0E1CCF-8066
                    Reset counter: 111
                    Mileage: 111595 km
                    Date: 2021.03.06
                    Time: 17:21:49
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0530
   Revision: 12110009    Serial number: 0001844890
   Coding: 0213FF
   VCID: 35223604944A102CE1-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000001755546
   Coding: 0002D8
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 197    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 312A0214A8223C0CBD-8064
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 01 KESSY PQ47   083 0323
   Coding: 00910A0002C60E76300494157E00DF0B00780103243498
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Reset counter: 71
                    Mileage: 111595 km
                    Date: 2021.03.06
                    Time: 15:45:59
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Reset counter: 71
                    Mileage: 111595 km
                    Date: 2021.03.06
                    Time: 15:45:59
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: 6FAEC46CBE966AFCEB-803A
   Subsystem 1 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0530
   Revision: 14110009    Serial number: 0001848630
   Coding: 0213FE
   VCID: 36203108894C1B34E8-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000001772277
   Coding: 0002D8
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000002838
   Coding: 0022067
   VCID: 3326081C523E0E1CCF-8066
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0080
   Coding: 029600000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H03 X008
   Coding: 230000
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  041 0167
   Revision: 00000001    Serial number: VWZ1Z3K3558697
   Coding: 0100040004
   VCID: 6288BD587D44D79474-8036
   Component: Batt.regelung H41 1614
   Coding: 0303115A
   VCID: 71AAC214A8A27C0CFD-8024
   Subsystem 1 - Part No SW: 3AA 915 181     HW: 3AA 915 181
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370249473
   Part No SW: 3AE 907 441     HW: 3AE 907 441
   Component: J772__Rearview      0020
   Revision: 00H08000    Serial number: 525PA8-J0Y0581
   Coding: 0020006
   Shop #: WSC 73430 790 00054
   VCID: 72A8CD186DA4471404-8026
02203 - Audio / Video Input 1
                    Reset counter: 111
                    Mileage: 111595 km
                    Date: 2021.03.06
                    Time: 17:22:35
                        Reverse OFF
                    Count: 3
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007669062841
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
9457425 - Left audio channel for speech/telephone
          B104F 11 [001] - Short to GND
9457169 - Right audio channel for speech/telephone
          B104E 11 [001] - Short to GND
End----------(Elapsed Time: 01:48, VBatt start/end: 13.4V/13.5V)-----------
ColinT
Scotland
C?ID=43234
Had this issue, never got round to doing a scan.
I suspect it's due to the car battery having a low voltage due to lack of use during the covid lockdown.
Put my smart charger on the car for a couple of days and, so far, the message hasn't reappeared.
Spacewalker
Poland
C?ID=159607
what I think - key is not kessy key , that is why working like "emergency key" , remote was match separate
dont think so driver door kessy antena give that issue , but try to fix it first
Wmwizkid
India
C?ID=374582
Can you help with the location of the antenna please
