Keyless entry
MGUPPY
Canada
C?ID=10607
I get the keyless defective message in my dash and no doors including the trunk work with keyless. I scanned the car as it said short to ground in drivers door antenna. Does anyone know if this is just an antenna replacement or will the whole module need to be replaced?
iichel
Eindhoven, NB, NL
C?ID=284912
Hard to say, it could be an antenna, a broken wire somewhere inbetween or a defective module.
I think it might be helpful to post an Auto-Scan for context. Right now, we don't even know what kind of car this is, much less how it is equipped or configured.
MGUPPY
Canada
C?ID=10607
2013 VOLKSWAGEN GTI
Thursday,18,March,2021,14:53:17:26875
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4543.4
VIN: WVWGV7AJ1DW120246   License Plate:
Mileage: 203220km-126275mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 15 16 17 19 1C 25 2B 2E 42 44 46 52 55 56 62
          72 77
VIN: WVWGV7AJ1DW120246   Mileage: 203220km-126275miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 1K0 907 115 AS    HW: 1K0 907 115 AA
   Revision: AAH18---    Serial number:
   Coding: 0403010A18070160
   VCID: F7A0005A83CB4B033E9-80A2
   Revision: 00H31001
   Coding: 114B600C492480FA880D06E8921F0141310800
   VCID: FDAC1272ADF76153645-80A8
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0193437623
   Coding: 030C0C
   VCID: B43AF756DEBD601BDBB-80E0
1057031 - Antenna for Keyless Entry System; Drivers Side
          B116F 11 [009] - Short to Ground
                    Reset counter: 68
                    Mileage: 203224 km
                    Date: 2021.03.17
                    Time: 15:24:19
   Part No SW: 5K0 907 044 GK    HW: 5K0 907 044 GK
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004002
   VCID: FAA6196EBC59566B417-80AE
   Part No SW: 1K0 937 087 AJ    HW: 1K0 937 087 AJ
   Component: BCM PQ35  H+  111 0708
   Revision: AC111708
   Coding: 6F180A7F80272AC4108808C07100096C488D2088575D8DB0E48420248040
   Shop #: WSC 93822 999 132232
   VCID: F9A40662B9DF5D7348D-80AC
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 08111  26  0512
   Coding: 009795
03134 - Motor for Rear Spoiler Movememt (V54)
                    Fault Status: 01101100
                    Reset counter: 68
                    Mileage: 203224 km
                    Date: 2015.08.08
                    Time: 15:24:24
                        Term 15 Off
                    Voltage: 12.15 V
                        Term 50 Off
03132 - Limit Switch for Rear Spoiler Movement (F135/F136)
                    Fault Status: 01101000
                    Reset counter: 68
                    Mileage: 203224 km
                    Date: 2015.08.08
                    Time: 15:24:25
                        Term 15 Off
                    Voltage: 12.10 V
                        Term 50 Off
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R012JJA
   Coding: 00004734
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: BC2ADF76F6EDA85B13B-80E8
   Serial number: 3572MSME65124473ZZZP
   Serial number: 3582MSME434E4473ZZZ.
   Serial number: 3512QSME5A112308ZZZL
   Serial number: 3522QSME4E562268ZZZ$
   Serial number: 35527SME7732682EZZZP
   Serial number: 35627SME7421682EZZZL
   Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20121120201337
   Coding: 100A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FDAC1272AD776153645-80A8
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 5K6 920 873     HW: 5K6 920 873
   Component: KOMBI         H05 0705
   Coding: 370F00
   VCID: F3B8344A9B332723021-80A6
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 281112F1003000
   Coding: 350002
   VCID: F4BA37569EBD201B1BB-80A0
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RLHEX07
   Coding: 0000002
   VCID: FEAE157EACF17A4B7DF-80AA
   Component: IMMO          H05 0705
   Coding: 000007
   VCID: EA86292ECCF9E6EBB17-80BE
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 12000258850003
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: AF30F83A379B43C3A69-80FA
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7663873649
   Coding: 010100
   VCID: AA06E92E0CF926EB717-80FE
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0001204
   VCID: B134FE422D2F5533B0D-80E4
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: B720C05AC34B8B03FE9-80E2
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Component: Tuer-SG         009 2105
   Coding: 0009396
   VCID: B822C366CE55847BF73-80EC
   Coding: 1446940
   VCID: B43AF756D23D601BDBB-80E0
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H04 0008
   Revision: -----08S    Serial number: VWZ4Z7M1140239
   Coding: 21000400040005
   VCID: E49A47162E5DB09B8BB-80B0
                    Reset counter: 66
                    Mileage: 197649 km
                    Date: 2015.01.12
                    Time: 21:24:48
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: B53CCA52D9477913EC5-80E0
   Coding: 0001168
   VCID: B63ECD5EC441720BE5F-80E2
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663875792
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002_VW25.rod
   VCID: BA26D96EFCD9966B017-80EE
End----(Elapsed Time: 01:24, VBatt start/end: 11.7V/11.9V. VIgn 11.8V)-----
                Address 05: Acc/Start Auth.       Labels: 5K0-959-434.clb
Control Module Part Number: 5K0 959 434 B    HW: 5K0 959 434
  Component and/or Version: VWKESSYPQ35GP 086 1101
           Software Coding: 030C0C
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_KESSYPQ35G A02013 (VW36)
                    Reset counter: 68
                    Mileage: 203224 km
                    Date: 2094.14.04
                    Time: 15:24:19
MGUPPY
Canada
C?ID=10607
I've been reading up and it sounds like it is the door handle itself. Any thoughts?
I would be mildly surprised if a fault in that one door handle disabled the entire system, but can't rule it out either.
marttimat
CT | USA
C?ID=305745
Usually the system will say the handle has a short to ground if the handle is acting up. This fault seems to be pointing to the antenna that triggers the key. I am uncertain where exactly it is located on your car. Sadly, VW is not listing the part number at all on their site for reference. I would attempt to locate the driver side antenna and confirm the ground circuit is not shorted.
Then antenna being down would prevent the rest of the system from operating. (vs a handle being shorted would only affect the 1 handle)
MGUPPY
Canada
C?ID=10607
I asked vw about the antennas and they said I have 3 one in front of the shifter, one under the rear seats and one behind the rear bumper cover. The only one I could easily access was the rear seat one which I confirmed is working properly. Could it be the one in front of the shifter?
iichel
Eindhoven, NB, NL
C?ID=284912
Prepare to be surprised because mine does this. One antenna slightly out of other? No kessy. Remotes still work, start the car by holding the key to the starter button. So I'd have a look at the door handle in the drivers door.
  • Informative
Spacewalker
Poland
C?ID=159607
Mk6 and whole PQ35 palatform with kessy have built in Antena into door handle
Door handle is a touch sensor and antena
keep looking from door loom
swap door handle from Right to Left , to check if is workng on other side to eliminate loom and focus on door handle , they are this same
keep in mind once kessy detect error ,they hold on use a door handle at all , but kessy system should work inside a car as before
so try to reset error first , and if is tem issue, should back to work
marttimat
CT | USA
C?ID=305745
That seems to line up with the parts manual link I provided above (3 antennas #6,7 and 8). Sounds like you would want to get to the one under the center console up near the shifter. It should look just like the one you found under the rear seat. I have not had a chance to do a VW console so I am not much help I am afraid.
Edit, quick search and antenna should be grey and attached to a bracket like here.
Parts Vortex sells them new Here. (once you check your wiring of course)
