2013 Beetle AWD swap ABS coding
racofuy
New Zealand
C?ID=197081
Update on this, had a bit of time this morning and due to the 00448 code in the AWD I removed the pump to check the screen which was clean and clear.
Tested the pump on the bench which was ok also. Reinstalled, topped off the haldex oil and then tested it with the output tests also running an adaptation on it.
Had a friend help me do the running test on the lift at 20kmh, ESP light flashes and it becomes impossible to stop the wheel I'm trying to stop turning
so it looks like it's working.
Checked for codes in AWD and ABS and both are code free, next will be some driving and see what / if anything comes back.
