2013 Beetle AWD swap ABS coding
iichel
Netherlands, eastern part
C?ID=284912
why not put the golf immo data in your Beetle cluster? but perhaps you also need a BL ABS unit
   #22
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
That VIN on the VCDS scan is not correct, the car was originally a 1.4 twin charge so in doing the AWD swap a 2.0TSI and corresponding ECU (de-immo) was installed hence its showing the Golf VIN in the scan.
The Beetle vin is WVWZZZ16ZEM601444
The ABS module shown in the scan was removed from a 2010 Golf R along with the haldex from the same vehicle.
Like was said above Both VIN has to match to get ABS coding to work . Just go to ECU coding and see is there option for AWD , maybe you can chnage coding vs replacing ECU.
Tiguan ECU may not work , But I think Golf R should .
   #23
racofuy
New Zealand
C?ID=197081
Yes there is option for AWD in ECU but ecu does not accept the change.
Golf R is med9 so will not work.
Had not considered Tiguan electric parking brake, back to drawing board.
   #24
m87a
Bosnia and Herzegovina
C?ID=156900
find someone to pair cluster and ecu, he should be able to flash your ecu for 4motion
   #25
racofuy
New Zealand
C?ID=197081
Getting back on this again, sourced an 8P Quattro ECU.
Same CCZB engine, mechanical park brake and also AWD.
Now I need to find someone to do immo defeat and put Beetle VIN in the ECU
If you do this type of work please IM me and I'll send you the ECU.
   #26
racofuy
New Zealand
C?ID=197081
Been busy with other things but time to try and get this resolved, sourced an 8P Audi AWD ecu (same CCZ engine as what is now in the Beetle) Sent that to the US to have Immo defeated
and Beetle VIN put in to it.
Installed that yesterday and tried coding the ABS, we tried the 3 suggestions in this thread (including the Beetle's original ABS coding) but none worked unfortunately. (Golf R AWD ABS unit)
Any further suggestions greatly appreciated, latest scan below.
Friday,03,December,2021,20:18:11:21714
VCDS Version: 21.9.0.2 (x64)  HEX-NET CB: 0.4555.4
VIN: WVWZZZ16ZEM601444   License Plate:
Mileage: 115570km-71811mi   Repair Order:
Chassis Type: 16-VW32 (6N0)
Scan: 01 03 04 05 08 09 10 15 17 19 22 25 2B 2E 44 56 77
VIN: WVWZZZ16ZEM601444   Mileage: 115570km-71811miles
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 8P0 907 115 BA    HW: 8P0 907 115 Q
   Revision: AAH18---    Serial number:
   Coding: 0103004C180F0160
   Shop #: WSC 06314 123 12345
   VCID: 72A80A356DFBF31947-8026
   VINID: 9E69EAAAA046A95746001104108CB0F005
012423 - Voltage Supply Relay for Engine Components
               P3087 - 000 - Electrical Malfunction
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 24.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.462 V
Readiness: 1110 0101
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   VCID: 7AB82215F58B8B590F-802E
03306 - Coding Not Valid
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.04.25
                    Time: 01:05:54
                    Count: 3
                    Count: 28672
                    Count: 4161
                    Count: 47104
                    Count: 1280
                    Reset counter: 87
                    Date: 2016.04.25
                    Time: 00:04:42
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 44800
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0193346989
   Coding: 030C0C
   Shop #: WSC 30049 959 00000
   VCID: 3424CC2D9F6FBD2995-8060
   Part No SW: 5C0 907 044 Q    HW: 5C0 907 044 Q
   Component: Climatronic   H03 0304
   Revision: 00001K02
   Coding: 3010001002
   Shop #: WSC 00066 000 00237
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 312AC539607D8801FE-8064
          U1111 00 [008] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 32
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.05
                    Time: 00:02:26
          B10AB F0 [009] - Too Low
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2021.10.17
                    Time: 05:57:57
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [008] - Open or Short to Plus
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.10.17
                    Time: 05:58:01
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0712
   Revision: B9074001    Serial number: 28013180130172
   Coding: 7CB869780801080001A80F916CCB86C5F8C2670F60853941B2A0140B0000
   Shop #: WSC 12345 666 54321
   VCID: 2D12D9497445ECE1DA-8078
   Component: RLS 130513 05  54  0403
   Coding: 02300A
   Subsystem 2 - Part No SW: 6R0 959 802 BB    HW: 6R0 959 802 BB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 1060
   Serial number: KU0KU022041300012293
   Coding: 0DBC34
   Subsystem 3 - Part No SW: 6R0 959 801 AS    HW: 6R0 959 801 AS  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 1060
   Serial number: KU0KU011021300015315
   Coding: 0DBC34
   Subsystem 4 - Part No SW: 5C0 959 442 C    HW: 5C0 959 442 C
   Component: E221__MFL-YVJ  H02 0103
   Serial number: 00000000000000720503
   Coding: E20000
03428 - Activation of Left Adaptive Light
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.04.25
                    Time: 00:05:32
03429 - Activation of Right Adaptive Light
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.04.25
                    Time: 00:05:32
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C5 919 475 A    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0007
   Revision: --------    Serial number: 83481317500808
   Coding: 108001
   Shop #: WSC 00066 000 00126
   ASAM Dataset: EV_EPHVA18VW3240000 001004
   ROD: EV_EPHVA18VW3240000.rod
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [008] - Open Circuit
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.10.18
                    Time: 02:56:20
12666403 - Databus
          [Diagnose-Interface für Datenbus-J533 - mBSG_Last - kein Signal/keine Kommunikation]
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.05
                    Time: 00:02:25
12670224 - Databus
          [Steuergerät für Schalttafeleinsatz-J285 - mKombi_2 - kein Signal/keine Kommunikation]
                    Fault Frequency: 154
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.05
                    Time: 00:02:25
12666400 - Databus
          [Diagnose-Interface für Datenbus-J533 - mGate_Komf_1 - kein Signal/keine Kommunikation]
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.05
                    Time: 00:02:25
12666402 - Databus
          [Diagnose-Interface für Datenbus-J533 - mDiagnose_1 - kein Signal/keine Kommunikation]
                    Fault Frequency: 190
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.05
                    Time: 00:02:25
12666401 - Databus
          [Diagnose-Interface für Datenbus-J533 - mGate_Komf_2 - kein Signal/keine Kommunikation]
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.05
                    Time: 00:02:25
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6M0AC46-
   Coding: 0000424A
   Shop #: WSC 00066 000 00000
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3228CA35657BB31987-8066
   Serial number: 3572MSME7525417AZZZY
   Serial number: 3582MSME26104679ZZZT
   Part No SW: 5C5 920 870 J    HW: 5C5 920 870 J
   Component: KOMBI         H30 0204
   Revision: X0030002    Serial number:
   Coding: 150B01
   ASAM Dataset: EV_KombiUDSMM9RM10 A04752
   ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0712
   Revision: B9074001
   Coding: 402100
   VCID: 70AC003DA3F7C109B1-8024
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43C69FF102C10A911C-8016
                    Reset counter: 138
                    Mileage: 115574 km
                    Date: 2016.04.25
                    Time: 00:18:07
   Part No SW: 5K0 953 234     HW: 5C5 920 870 J
   Component: IMMO          H30 0204
   Coding: 000007
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   VCID: 6A9812558D2B3BD9FF-803E
   Revision: 00000000    Serial number: 13000080755004
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 302CC03D6B778109F1-8064
Address 2E: Media Player 3
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 373EFB2146195631B0-8062
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 115574 km
                    Date: 2016.04.25
                    Time: 00:18:38
                    Battery Volts: 12.4 V
                        DD
                    Temperature: 28.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0236
   Revision: 00000001    Serial number: VWZ1Z3N2002817
   Coding: 01000400040002
   VCID: 24043C6D278F2DA905-8070
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.04.25
                    Time: 00:20:15
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.04.25
                    Time: 00:20:15
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007664812085
   Coding: 0A00001080010101
   Shop #: WSC 01383 790 50316
   ROD: EV_UHVUMI.rod
   VCID: 2E10DE45714397F9E3-807A
End----------(Elapsed Time: 01:48, VBatt start/end: 13.0V/13.0V)-----------
   #27
jettarv
Canada
C?ID=345286
try this
F43B80F8092200FB2F0F01E8901D0081251000 Beetle , R brake , RHD
   #28
racofuy
New Zealand
C?ID=197081
Thanks jettarv, just tried your one but get coding rejected Error 00: Unknown 00x00)
I'm at least seeing the Beetle vin now at the top of the scan so the ECU, cluster and ABS should be happy together but finding a code string that works is the next step.
   #29
jettarv
Canada
C?ID=345286
i noticed that your new ecu is audi coding, maybe try to change to vw. I don't think it's possible, but you can try.
0403004C180F0160 (04 vs 01 in Byte 0 )
or
A3 8P ABS RHD coding with your VIN 143B8012092200FB280F01E8901D0081390000
   #30
jettarv
Canada
C?ID=345286
And if you want to remove the dsg error code in the haldex module.
You have to do a basic settings in the haldex module 22, unfortunately i did not take note of the group number, but it is one of them: 97, 50, 41, 40 or 20. click on go and then on-off.
I had the same error code with my GTI 2013 manual 4motion swap of an A3 2.0T 2009 DSG Quattro.
   #31
racofuy
New Zealand
C?ID=197081
Some results achieved, we did the basic setting in the Haldex which eliminated the code we had there.
Changed the ECU coding to 04 (VW) which it accepted.
[/IMG]
Then on to the ABS again, no luck there. Same out of range error.
Now that the coding is changed to VW is it worth trying the other code strings we have in this thread again?
Or would it possibly be that the module is just not compatible? ( we still have the original unit from the Beetle also)
[/IMG]
   #32
jettarv
Canada
C?ID=345286
you can try these. but maybe it is impossible to do since the beetle does not exist in 4x4, I saw on the net the same problem on a 2011 scirocco swap 4x4. The guy finally install a golf r cluster to make it work.
F63B60F8092200FB6F0F06E8901D0081251800
F63B80F8092201FB6F0F01E8901D8081251800
F63B80F8092200FB6F0F01E8901D0081251800
F63B80F8092200FB6F0F01E8901D0081351800
F63B80F8092200FB6F0F01E8901D0081A51800
racofuy
New Zealand
C?ID=197081
No luck with those unfortunately, the only thing I can think of now is to put the Beetle ABS unit back in and run a stand alone controller for the Haldex.
   #34
iichel
C?ID=284912
I read somewhere that in a different thread that someone used an emulator to mask the 22 AWD unit, and avoid errors this way.
I cannot seem to figure out a correct coding for your ABS unit, I'm sorry.
   #35
NEtech
Denmark
C?ID=56995
Maybe try these:
F63B60F8192200FB6F0F06E8981D0080251C00
F63B60F8212200FB6F0F06E8841D0080351C00
racofuy
New Zealand
C?ID=197081
Thank you for all your suggestions and help guys, unfortunately it doesn't seem to like any of them.
NEtech, your 2 suggestions also resulted in out of range errors.
Also did another auto scan making sure the engine ecu coding to VW stuck and AWD was clear of errors.
I don't have the coding what was originally in this ABS module so have not been able to try that.
[/IMG]
Sunday,12,December,2021,19:53:37:21714
   Coding: 0403004C180F0160
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 21.0°C
                    Temperature: 24.0°C
                    Voltage: 12.192 V
   Revision: 00H30001
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.05.04
                    Time: 01:05:54
                    Count: 3
                    Count: 28672
                    Count: 4161
                    Count: 47104
                    Count: 1280
                    Reset counter: 87
                    Date: 2016.05.04
                    Time: 00:04:42
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 44800
   Coding: 030C0C
   Revision: 00001K02
   Coding: 3010001002
          U1111 00 [008] - -
                    Fault Frequency: 32
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.14
                    Time: 00:02:26
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2021.10.26
                    Time: 05:57:57
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.10.26
                    Time: 05:58:01
   Coding: 02300A
   Coding: 0DBC34
   Coding: 0DBC34
   Coding: E20000
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.05.04
                    Time: 00:05:32
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.05.04
                    Time: 00:05:32
   Coding: 108001
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.10.27
                    Time: 02:56:20
12666403 - Databus
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.14
                    Time: 00:02:25
12670224 - Databus
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.14
                    Time: 00:02:25
12666400 - Databus
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.14
                    Time: 00:02:25
12666402 - Databus
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.14
                    Time: 00:02:25
12666401 - Databus
                    Reset counter: 127
                    Mileage: 115574 km
                    Date: 2021.11.14
                    Time: 00:02:25
   Coding: 0000424A
   Coding: 150B01
   Revision: B9074001
   Coding: 402100
   Coding: 0000005
   Coding: 000007
   Revision: 00H22000
            000 - - - MIL ON
                    Mileage: 115574 km
                    Date: 2016.05.04
                    Time: 00:18:38
                        DD
                    Temperature: 28.0°C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.05.04
                    Time: 00:20:15
                    Reset counter: 87
                    Mileage: 115574 km
                    Date: 2016.05.04
                    Time: 00:20:15
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.3V)-----------
   #37
etz2k
C?ID=69430
Are you making progress?
I think you can't coding the old ABS (-AJ) unit from 2010 with the plattform info Byte 0(Ex or Fx) and 8 of the Beetle 2012+, because it's to new and the old SW doesen't know it. I think you need a ABS unit that was also used in the Beetle. Because i also can't code my Audi A3(RDW) to NAR or anything that not match the VIN.
Byte 0,1,3,8 must fit the Vin of the intrument cluster, if i unplug the engine & haldex ECU i can code the ABS unit, so i don't think it's relevant.
   #38
racofuy
New Zealand
C?ID=197081
Hi etz2k, sorry I missed your reply.
Due to covid and other priorities this car got mothballed but have made lots of progress this week.
I could not make the other ABS unit work so in order to get the car certified and road legal I re fitted the original ABS unit to get all the lights out which is all ok.
My question is can the original unit be re coded for the AWD?
The Audi ecu fitted is from an AWD car and the vin has been matched so that all seems happy.
Autoscan below, this is after a full clear and save.
Thursday,16,March,2023,09:23:23:54382
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
Workshop Code: 666 12345 054321
Mileage: 115640km-71855mi   Repair Order:
VIN: WVWZZZ16ZEM601444   Mileage: 115640km-71855miles
   VCID: 72BDDF4818A2677A097-8026
Readiness: 0110 0001
   Part No SW: 5C0 907 379 C    HW: 5C0 907 379 C
   Component: ESP MK60EC1   H31 0156
   Revision: 00H31001
   Coding: F63B60F8092200FB6F0F06E8901D0080251800
   VCID: 2E050B38C01A039AADF-807A
   Revision: 00086000    Serial number: 0193346989 Dataset Number: 5K0116v____ 5C08
   Coding: 030C0C
   VCID: 343119502EB6294ADBB-8060
   Revision: 00001K02
   Coding: 3010001002
   VCID: 313F1044D1A41C62B0D-8064
                    Reset counter: 101
                    Mileage: 115644 km
                    Date: 2023.03.16
                    Time: 22:09:53
   Coding: 7CB869780801080001A80F912CCB86C5F8C2670E60013941B2A0140B0000
   VCID: 2D070C34CD1C7882945-8078
   Coding: 02300A
   Coding: 0DBC34
   Coding: 0DBC34
   Coding: E20000
   Coding: 108001
   Serial number: 003G6M0AC46-   Dataset Number: 5C5003v____ 0103
   Coding: 0000424A
   VCID: 323D1F48D4A2277AC97-8066
   Coding: 150B01
   ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
   Revision: B9074001
   Coding: 402100
   VCID: 70B9D5401AAE556AFF3-8024
   Coding: 0000005
   VCID: 43D34A8C77989EF2521-8016
00448 - Haldex Clutch Pump (V181)
                    Fault Status: 11000000
                    Fault Frequency: 57
                    Reset counter: 48
                    Mileage: 3618101 km
                    Time Indication: 4
                    Count: 768
                    Raw, Form. N/A: 000 000 000
   Coding: 000007
   VCID: 6A8DC7283CF2AFBAB17-803E
   VCID: 30391540DAAE156ABF3-8064
   Revision: 00H22000
   VCID: 372B2E5C3340C252FE9-8062
   VCID: 2411E9109ED6B9CA4BB-8070
   Revision: 1B001001    Serial number: 00007664812085 Dataset Number: 5N0035729A  0001
   ROD: EV_UHVUMI.rod
   VCID: 2E050B38C09A039AADF-807A
End----------(Elapsed Time: 01:45, VBatt start/end: 14.0V/14.0V)-----------
   #39
etz2k
C?ID=69430
No, it isn't possible to code for AWD with the MK60EC1, it seems to use the AWD settings automaticly, if it found the Haldex ECU.
You only should try to enable AWD in engine ecu.
For a test you can only use a car workshop lift, so that the wheels can turn free. Now if you start the engine and rise the engine rpm a bit and let turn the wheels, you can try to stop one rear wheel by hand. If all is ok the EDS should brake the other rear wheel, which will make it impossible for you to hold/stop your wheel.
You can also use this MK60EC1 lable i made, with a desciption for all Coding bytes/bits, MVB, etc. So you can see what's possible to code or not.
racofuy
New Zealand
C?ID=197081
Interesting, thanks for your reply.
I added AWD address 22 to the gateway which is probably why its visible. The engine ecu is coded for AWD.
I'll try your suggestion in the next couple of days when it is on the lift again.
