- Mar 3, 2019
- 106
- 27
- New Zealand
- C?ID=197081
Used a 2010 Golf R Haldex and ABS module in this Beetle AWD swap, started out with 4 faults in ABS module (No basic setting for G85, G200 and G201) Basic settings able to be done
without issue however the ABS module has no coding and I did not scan the donor car it came from unfortunately.
Autoscan attached, the AWD has a code as well as it came from a DSG car and this Beetle is factory manual 6 speed.
I do still have the original ABS unit from the Beetle as well but was not sure if this could be changed to AWD as it was a low spec 1.4 car originally.
Wednesday,17,March,2021,13:49:20:54382
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4526.4
Workshop Code: 666 12345 054321
VIN: WVWZZZ1KZAW041997 License Plate:
Mileage: 115570km-71811mi Repair Order:
Chassis Type: 1K-VW36 (6N0)
Scan: 01 03 04 05 08 09 10 15 17 19 22 25 2B 2E 44 56 77 0B
VIN: WVWZZZ1KZAW041997 Mileage: 115570km-71811miles
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 N HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0010
Revision: AAH03--- Serial number:
Coding: 0403000C18070160
Shop #: WSC 12345 666 54321
VCID: 35372454294C3043B15-8060
012423 - Voltage Supply Relay for Engine Components
P3087 - 000 - Electrical Malfunction
Date: 2047.15.31
Time: 31:63:63
Temperature: 26.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.319 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0030 - 000 - Malfunction / Open Circuit
Mileage: 115574 km
Date: 2015.08.08
Time: 05:36:33
RPM: 644 /min
Load: 74.9 %
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 11.303 V
005709 - Oil Pressure Switch for reduced Oil Pressure
P164D - 000 - Malfunction - Intermittent
Mileage: 115574 km
Date: 2015.08.08
Time: 05:36:43
RPM: 1182 /min
Load: 18.4 %
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 12.065 V
Readiness: 1110 0101
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
VCID: 7AADF7684CD21F3B1C7-802E
Reset counter: 87
Date: 2015.08.08
Time: 05:59:47
Count: 3
Count: 20992
Count: 195
Count: 44288
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0193346989
Coding: 030C0C
Shop #: WSC 30049 959 00000
VCID: 343119502EB6294B86B-8060
Part No SW: 5C0 907 044 Q HW: 5C0 907 044 Q
Component: Climatronic H03 0304
Revision: 00001K02
Coding: 3010001002
Shop #: WSC 00066 000 00237
VCID: 313F1044D1A41C63EDD-8064
B10AB F0 [009] - Too Low
Reset counter: 87
Mileage: 115574 km
Date: 2021.03.17
Time: 05:57:57
9480469 - Control Circuit for A/C Compressor
B10A9 15 [009] - Open or Short to Plus
Reset counter: 87
Mileage: 115574 km
Date: 2021.03.17
Time: 05:58:01
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 28013180130172
Coding: 7CB869780801080001A80F916CCB86C5F8C2670F60853941B2A0140B0000
VCID: 2D070C34CD1C7883C95-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 130513 05 54 0403
Coding: 02300A
Subsystem 2 - Part No SW: 6R0 959 802 BB HW: 6R0 959 802 BB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 1060
Serial number: KU0KU022041300012293
Coding: 0DBC34
Subsystem 3 - Part No SW: 6R0 959 801 AS HW: 6R0 959 801 AS Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 1060
Serial number: KU0KU011021300015315
Coding: 0DBC34
Subsystem 4 - Part No SW: 5C0 959 442 C HW: 5C0 959 442 C
Component: E221__MFL-YVJ H02 0103
Serial number: 00000000000000720503
Coding: E20000
03428 - Activation of Left Adaptive Light
Reset counter: 87
Mileage: 115574 km
Date: 2015.08.08
Time: 05:57:56
03429 - Activation of Right Adaptive Light
Reset counter: 87
Mileage: 115574 km
Date: 2015.08.08
Time: 05:57:56
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5C5 919 475 A HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0007
Revision: -------- Serial number: 83481317500808
Coding: 108001
Shop #: WSC 00066 000 00126
ASAM Dataset: EV_EPHVA18VW3240000 001004
ROD: EV_EPHVA18VW3240000.rod
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M0AC46-
Coding: 0000424A
Shop #: WSC 00066 000 00000
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 323D1F48D4A2277B947-8066
Serial number: 3572MSME7525417AZZZY
Serial number: 3582MSME26104679ZZZT
Part No SW: 5C5 920 870 J HW: 5C5 920 870 J
Component: KOMBI H30 0204
Revision: X0030002 Serial number:
Coding: 150B01
ASAM Dataset: EV_KombiUDSMM9RM10 A04752
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 402100
VCID: 70B9D5401AAE556BA23-8024
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 43D34A8C77989EF30F1-8016
Reset counter: 138
Mileage: 115574 km
Date: 2015.08.08
Time: 05:57:56
Part No SW: 5K0 953 234 HW: 5C5 920 870 J
Component: IMMO H30 0204
Coding: 000007
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
VCID: 6A8DC7283CF2AFBBEC7-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000080755004
Coding: 4100000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X_VW31.rod
VCID: 30391540DAAE156BE23-8064
Address 2E: Media Player 3
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372B2E5C3340C253A39-8062
000 - - - MIL ON
Fault Status: 11100000
Mileage: 115574 km
Date: 2015.08.08
Time: 05:59:40
Battery Volts: 12.2 V
DU
Temperature: 28.0°C
Count: 9
Steering Angle: -11.59°
SteerAng n.Init
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3N2002817
Coding: 01000400040002
VCID: 2411E9109ED6B9CB16B-8070
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007664812085
Coding: 0A00001080010101
Shop #: WSC 01383 790 50316
ROD: EV_UHVUMI.rod
VCID: 2E050B38C09A039BF0F-807A
End----------(Elapsed Time: 02:03, VBatt start/end: 12.4V/12.4V)-----------
