2017 Audi A6 Allroad (C7.5)
Exie
C?ID=162093
Tuesday,16,March,2021,11:56:29:15999
VIN: WAUZZZ4G0JN0xxxxx  License Plate: MASKED
Mileage: 41600km-25849mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3B 3C 42 44 46
          52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 AC
VIN: WAUZZZ4G0JN0xxxxx  Mileage: 41600km-25849miles
Address 01: Engine (J623-CZVA)       Labels: Redir Fail!
   Part No SW: 4G2 907 311 B    HW: 4G2 907 311 A
   Component: 3.0TDI MD1    H25 0003
   Revision: C4H25---
   Coding: 32254012056609030000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G2907311B 001007
   ROD: EV_ECM30TDI0114G2907311B.rod
   VCID: 2411E6F98E5818DBCBB-8070
   Part No SW: 4G0 927 166 L    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H06 0006
   Revision: --H06---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 36352CB128C49A4B65F-8062
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 27A6CE4DE46573B29B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF4F6D710A2DF3C0D-8014
3584 - Suspension Sensors
          C104B 29 [096] - Signal Implausible
155136 - Tire Pressure Warning
          C102D 00 [040] - -
                    Mileage: 40682 km
                    Date: 2021.02.21
                    Time: 10:06:08
                    VzRef: 65
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    Uz: B6
                    Unlearning counter according OBD: 15
161536 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 4H0 907 064 JT    HW: 4H0 907 064 JT
   Component: BCM2 2.0      H44 0582
   Coding: 05B96F0E000000000000
   VCID: 045186792E18F8DBABB-8050
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 13091700040164
   Coding: 362271783D0000
   VCID: 6393A5E5CBD65FE3F21-8036
0051 - Motor for Left Side Vent Flap
          B10C9 07 [008] - Mechanical Failure
                    Reset counter: 70
                    Mileage: 41526 km
                    Date: 2021.03.09
                    Time: 12:42:20
                    Voltage terminal 30: 14.32 V
                    Outside temperature: 20.0 °C
                    Inside temperature: 21.08 °C
                    Left side vent motor-Act.val.: 11158
                    Left side vent motor-Target value: 11188
                    Left side vent motor-Stop open: 11339
                    Left side vent motor-Stop closed: 10000
                    Left side vent motor-Last active operating mode: 7
                    Left side vent motor-Active operating mode before last: 6
   Part No SW: 4H0 907 063 GG    HW: 4H0 907 063 AG
   Component: BCM1 2.0      H20 0368
   Revision: 1402003S    Serial number: 00001753326302
   Coding: 0105001440349FE2C9014087A0001800CF9D47082F08020180000894E101170200400009090000
   VCID: 73B3D5A57BB6CF63821-8026
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 170725  H38 0080
   Serial number:         170822130729
   Coding: 0045F7
   Serial number: 20395019X81A955547A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 24 08 2017  00000761
   Component: EVLS-SG  H08 0300
   Serial number: WA128914000037517794
   Coding: 020300
   Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 6A2214C800PAG0MUFU03
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0090
   Revision: --------    Serial number: 56231725000064
   Coding: B83B20
   ASAM Dataset: EV_EPHVA2CAU64X0000 001015
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 3A2D38811CDC7E2B817-806E
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 290FF7CDE97AC5B3F8D-807C
   Component: Airbag10.43   H83 0098
   Revision: --------    Serial number: 003P100ELAK8
   Coding: 30333130313730323930554A305234473053
   VCID: 3B233D8513E647239A1-806E
   Serial number: 3575HRB401259P4EG1F%
   Serial number: 3585HRB40045BEA8JPKO
   Serial number: 3515JRB40145BEP85HOH
   Serial number: 3525JRB400M5BEP8LI6Y
   Serial number: 3554VRB405551756BHBY
   Serial number: 3564VRB405N4U3TUOGJG
          B13BC F2 [008] - No function
                    Mileage: 34190 km
                    Date: 2020.06.26
                    Time: 00:01:33
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QID0000F
   Coding: 0000FD
   VCID: 372B21B52F4E63437E9-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 10 08 2017  E0012205
   Part No SW: 4G9 920 951 L    HW: 4G9 920 951 L
   Component: TDieRdwAccNv  H17 0225
   Revision: 18001312    Serial number: 658250817592013
   Coding: 338625081F510008010600
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002719589
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 002011
   VCID: 40D94A697A0024FBCF3-8014
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 8071295204
   Voltage stabilizer:
   Serial number: 17062700000000000527
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 75
                    Mileage: 34589 km
                    Date: 2020.07.11
                    Time: 20:18:34
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 13 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Fault Frequency: 145
                    Reset counter: 75
                    Mileage: 34589 km
                    Date: 2020.07.11
                    Time: 23:21:54
                    Voltage terminal 30: 12.1 V
                    Control Module temperature: 12 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 12091700040468
   Coding: 22
   VCID: 3D27339D0DF24913A45-8068
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B19D5D79EAB83269-807A
   Revision: AA000000    Serial number: 00000273589425
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77ABE1B56FCEA343BE9-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820E4H73
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0454177867
   Coding: 040312
   Shop #: WSC 04770 128 28888
   VCID: 392F278D19DA753388D-806C
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0454185958
   Coding: 040312
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F1F015E01628002080013
   VCID: 45D75B7D65A201D3FC5-8010
   Component: RCevo         H55 0202
   Revision: 00000001    Serial number: 0000096224
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   Revision: 00002001    Serial number: 0454667974
   Coding: 01000E3A20B93095C32009840E010F470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS20.403  H03 0004
   Serial number: 0000FST001R25HG00000
   Coding: 901F00
   Subsystem 2 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00036736778
   Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS20.403  H03 0004
   Serial number: 0000FST001R25ED00000
   Coding: 801F00
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0511
   Coding: 011F1F015E01628002080002
   VCID: 44D146796E9838DBEBB-8010
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002303097
   ASAM Dataset: EV_ParkiBrake 001033
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 323D10A1C4AC866B497-8066
   Coding: 04FE02202A100200
   VCID: 343116B93EB8885B5BB-8060
   Coding: E01F00
   Coding: E01F00
   Power module 1 for left matrix headlamp:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Power module 1 for right matrix headlamp:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
   Part No SW: 4G1 035 052 J    HW: 4G1 035 052 D
   Component: MU-H-LND-RW   054 0910
   Serial number: A739H0HS001011
   Coding: 017542080000000013511102000A00102F000AE6F17001045E
   VCID: 2517FBFD8562E1D3DC5-8070
   Subsystem 1 - Part No SW: V03 959 801 PT    HW: -----------
   Component: ROW 2017/2018  --- 0065
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9HY808MVK
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349QI5000WU
   Compact disc data bank:
   Component: Gracenote2  --- 4012
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Component: TSG HL        H03 0511
   Coding: 010F1D004001628002080002
   VCID: 47CB51755FAE13C30E9-8012
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0380
   Revision: 11001001    Serial number: 82330JG0433522
   Coding: 0215000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0152
   Revision: 14005001    Serial number: 242700484
   Coding: 093205C030
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0511
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 N    HW: 4G0 919 604 N
   Component: HeadUpDisplay H10 0306
   Coding: C60000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   Component: DPC-SG        H28 0081
   Coding: EA160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C010ED9E688D09B03B-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 270BF1F5FF6EF3C3EE9-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002451805177
   Coding: 04C03A180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308004240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F1FADC1AABD7330D-8064
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 172000599
   ROD: EV_RDCMA00100.rod
End----(Elapsed Time: 02:20, VBatt start/end: 11.6V/11.5V. VIgn 11.6V)-----
