Retrofitting MK60EC1 in frankencar VW Polo 6R / VW Golf mk6 1.6 TDI CAYC DSG
iichel
Eindhoven, NB, NL
C?ID=284912
So I'm fitting parts where they don't belong. Again.
In this case it's a Polo 6R which comes with a Bosch ESP8.2i from factory.
Being fitted is a TRW MK60EC1 from the PQ35 platform.
The link is that the MK60CE1 was definitely fitted to PQ25, for example, the Beetle 5C and the Jetta had this ABS computer.
So gateway should be fine and G85 should be fine. 7E0 + 6R0 G85 are a match.
The ECU and immobiliser data are from a Golf MK6, so the Polo ABS nopes out because it cannot understand the MK6 1K VIN.
So I fitted a MK60EC1 ABS unit provisionally, meaning I only connected +30, +15, GND and canbus.
Is this enough to throw codings at it? Or will it refuse any coding unless the wheel speed sensors are connected?
So:
VIN WVWZZZ1KZBW544382
Engine CAYC 1.6 TDI
Gearbox DSG
brake sizes don't really matter
LHD
20 byte code length
So to the net to find some codings, a topic in which I ironically found some codings myself:
some more:
https://forums.ross-tech.com/index.php?threads/8153/ --> ABS 113B200D092200FA880F04E4901A0051310000
https://www.golfv.de/thread/123402-problem-with-kufatec-bi-xenon-on-golf-vi/ --> ABS 113B200D09290000881304E990200051350000
I came up with some codings:
113B200D492600FE880E04EC921B005131000000 refused
to try:
113B200D092600FE880E04EC901B005131000000
Any other suggestions will be appreciated
And if it requires to connect the wheel speed sensors, let me know
Tuesday,16,March,2021,11:29:55:11868
Dealer/Shop Name: iichel retrofitting
Workshop Code: 470 31889 031889
VIN: WVWZZZ1KZBW544382   License Plate:
Mileage: 181690km-112896mi   Repair Order:
Chassis Type: 1K-VW36 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 55 56 69 77 0B
VIN: WVWZZZ1KZBW544382   Mileage: 181690km-112896miles
   Part No SW: 03L 906 023 DR    HW: 03L 906 023 A
   Component: R4 1.6l TDI   H23 9978
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00254036032401080000
   ASAM Dataset: EV_ECM16TDI02103L906023DR 003016
   ROD: EV_ECM16TDI02103L997557Q.rod
   VCID: 79AF10A5095BB703C8D-802C
9 Faults Found:
7286 - Turbocharger Boost Control Position Sensor Circuit
          P2563 00 [167] - Implausible Signal
                    Mileage: 181669 km
                    Date: 2021.03.15
                    Time: 02:01:39
                    Engine RPM: 1068.50 /min
                    Normed load value: 31.8 %
                    Vehicle speed: 44 km/h
                    Coolant temperature: 53 ∞C
                    Intake air temperature: 26 ∞C
                    Voltage terminal 30: 14.005 V
                    Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 7.208 %
                    Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 85.001 %
                    High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 84.998 %
                    High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 0.723 V
                    Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
                    Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.501 V
                    High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 12
6141 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Engine RPM: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 58 ∞C
                    Intake air temperature: 10 ∞C
                    Voltage terminal 30: 12.649 V
                    Engine RPM: 0 /min
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 7 ∞C
                    Sensor for engine block temperature: raw value-Coolant temperature: 5 ∞C
                    Outside temperature-Ambient temperature: 6.75 ∞C
                    Coolant fan 1: activation-Radiator fan 1: activation: 9.8 %
6408 - Park/Neutral Switch Input Circuit
          P0850 00 [039] - Open or Short to Plus
                    Mileage: 181669 km
                    Date: 2021.03.15
                    Time: 00:21:48
                    Coolant temperature: 70 ∞C
                    Intake air temperature: 25 ∞C
                    Voltage terminal 30: 9.374 V
                    Engine RPM: 0 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 12.6 V
                    Coolant temperature: -40 ∞C
                    Intake air temperature: -40 ∞C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Mileage: 181669 km
                    Date: 2021.03.15
                    Time: 00:21:48
                    Engine RPM: 0 /min
                    Battery voltage: 10.8 V
10131 - Fuel Pressure Sensor (G247)
          P0193 00 [032] - Short to Plus
                    Intake air temperature: 94 ∞C
                    Voltage terminal 30: 11.181 V
                    Supply voltage of analog output 1-VCC_1: 5.02 V
                    Fuel high pressure sensor: unconditioned voltage-VP_PFU: 4.9927 V
                    Fuel pressure: 200000 kPa rel
                    Fuel high-pressure: actual value-FUP_FIL: 199.997 MPa
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 0.000 kPa
                    ECM system status-Binary 16 Bit: 00000000 00000000
10113 - Fuel Pressure Regulator Valve (N276)
          P2294 00 [032] - Open Circuit
                    Intake air temperature: 93 ∞C
                    Battery voltage: 11.2 V
                    Fuel pressure regulator valve actual value-CFB_PCV_MES: 0.073 A
                    Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV: 3.2877 V
                    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
                    Fuel Pressure Regulator Valve-PCV: 0.000 %
                    Fuel Metering Valve-VCV: 0.000 %
10453 - Output for Starter Relay
          P0615 00 [039] - Open Circuit
                    Mileage: 181669 km
                    Date: 2021.03.15
                    Time: 00:21:46
                    Voltage terminal 30: 9.826 V
                    Engine RPM: 0 /min
                    Battery voltage: 9.8 V
                    Starter activation: status-FRF_ST_RL: 1
                    Sensor for engine block temperature: raw value-Coolant temperature: 70 ∞C
                    Number of resets of main unit-CTR_RST_MC: 0
10457 - Control Circuit for Starter Relay 2
          P3049 00 [039] - Open Circuit
                    Mileage: 181669 km
                    Date: 2021.03.15
                    Time: 00:21:46
                    Engine RPM: 0 /min
13911 - Implausible Data Received from ABS Control Module
          U0415 00 [167] - -
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:51
                    Intake air temperature: 7 ∞C
                    Voltage terminal 30: 10.955 V
                    Cruise Control System (CCS): status-Binary 8 Bit: 01100000
                    Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 10000001
Address 02: Auto Trans
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: 0000000000000000000000000000000000000000
   Shop #: WSC 33361 790 00120
   VCID: 045171517E19FAEBABB-8050
10 Faults Found:
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:52
                    Count: 16391
                    Count: 512
                    Count: 128
                    Count: 39424
                    Count: 64768
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:50
                    Count: 16391
                    Count: 4608
                    Count: 195
                    Count: 39936
                    Count: 65022
                    Fault Status: 01100101
                    Reset counter: 140
                    Date: 2035.00.00
                    Time: 16:04:46
                    Count: 256
                    Count: 50076
                    Count: 256
                    Count: 212
                    Count: 195
                    Count: 257
                    Count: 9100
                    Count: 257
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:39
                    Count: 16391
                    Count: 512
                    Count: 279
                    Count: 44032
                    Count: 65022
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:39
                    Count: 16391
                    Count: 512
                    Count: 270
                    Count: 44032
                    Count: 65022
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:39
                    Count: 16391
                    Count: 512
                    Count: 291
                    Count: 44032
                    Count: 65022
                    Fault Status: 01101100
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:50
                    Count: 16391
                    Count: 4608
                    Count: 80
                    Count: 39936
                    Count: 65022
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:50
                    Count: 16391
                    Count: 4608
                    Count: 64
                    Count: 39936
                    Count: 65022
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:50
                    Count: 16391
                    Count: 4608
                    Count: 48
                    Count: 39936
                    Count: 65022
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Reset counter: 140
                    Mileage: 327940 km
                    Date: 2001.08.03
                    Time: 16:32:11
                    Count: 2563
                    Count: 286
                    Count: 35840
                    Count: 32
                    Count: 257
                    Count: 3585
                    Count: 128
                    Count: 35841
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 3537DC95654393636C5-8060
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:56
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 097180864
   Coding: 3CB02BBF68EB2C0093380EB17FEB9FD15A80670F600530C1200000000000
   Shop #: WSC 31889 123 05683
   VCID: 2B03FAEDB307D5930A1-807E
   Component: RLS 240111 05  54  0403
   Coding: 03302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0-KU021.01.1116042
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0-KU028.01.1110654
   Coding: 08BC30
   Subsystem 4 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 1K8 951 171 A
   Subsystem 7 - Part No SW: 5G0 959 442 H    HW: 5G0 959 442 H
   Component: E221__MFL-DC1  H17 0103
   Serial number: 46170001001030017151
   Coding: A5FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0-KU012.01.1115045
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0-KU019.01.1112796
   Coding: 08BC32
03433 - Terminal 30 for Backup Lights and Adaptive Lights
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:51
01516 - Terminal 30; Left
                    Reset counter: 140
04194 - Vehicle Status with Under-Voltage
                    Reset counter: 180
                    Mileage: 181669 km
                    Date: 2021.03.15
                    Time: 00:08:48
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 B    HW: 7E0 919 475
   Component: PARKHILFE 4K  H10 0012
   Revision: --------    Serial number: 12801102200011
   Coding: 118101
   ASAM Dataset: EV_VW250ParkiAssis2 S01008
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3D27C4B55DF34B23A45-8068
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag01M H09 0020
   Revision: --------    Serial number: 003GX00ETS2$
   Coding: 00314D
   Shop #: WSC 00788 648 00255
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC9B117-801E
   Serial number: 3575HRB404V0ATOC80M4
   Serial number: 3585HRB404R0ATOCFGVX
   Serial number: 3515RRB4055058P0D0DS
   Serial number: 3525RRB404T0BEE6MOG9
12854016 - Databus
          [Kombi1 DLC Error]
                    Fault Frequency: 56
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:51
12850432 - Databus
          [Bremse8 DLC Error]
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:51
   Part No SW: 6JA 920 840 X    HW: 6JA 920 840
   Component: KOMBI         H16 1009
   Coding: 140A210000
   Shop #: WSC 00046 000 00000
   VCID: 50F98D01FA61D64B5F3-8004
13637376 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [009] - -
          [Steuerger‰t f¸r Bremse: bitte Fehlerspeicher auslesen]
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:31:10
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 002200
   VCID: 688945E162713E8B273-803C
   Component: IMMO          H16 1009
   VCID: 6A8D3FE97CFD0C9B317-803E
   Part No SW: 1T0 035 680 F    HW: 1T0 035 680 F
   Component: RNS-MID       H61 3970
   Revision: AB001001    Serial number: VWZ6Z7R5312684
   Coding: 00000400000000200001
   Shop #: WSC 05314 123 12345
   VCID: 313FE885912BBF4330D-8064
                    Reset counter: 179
                    Mileage: 181669 km
                    Date: 2021.03.15
                    Time: 00:21:55
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 12345
   VCID: 2F3BEEFD8E5FA9B3269-807A
            79-00 - Please Check Fault Codes
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Coding: 0112000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
   ROD: EV_HeadlRegulVWLWRPt_VW32.rod
   VCID: 77AB169D3F4FA173BE9-8022
13705984 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_VL]
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:56
13705985 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HL]
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:56
13705986 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_VR]
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:56
13705987 - Databus
          [Fehlerwert im Signal BR3_Rad_kmh_HR]
                    Reset counter: 140
                    Mileage: 181699 km
                    Date: 2021.03.16
                    Time: 17:28:56
                    Reset counter: 179
                    Mileage: 181669 km
                    Date: 2021.03.15
                    Time: 00:21:55
Address 69: Trailer
   Part No SW: 7E0 035 730 A    HW: 7E0 035 730 A
   Component: TELEFON       H05 0550
   Revision: 1B001001    Serial number: 00007669233345
   Coding: 0800000000000210
   ASAM Dataset: UHVNA A01009
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 1F1B1E3DF73F3933969-804A
13635840 - Supply voltage
          U1011 00 [000] - Voltage too Low
          [Klemme 30: unterer Grenzwert unterschritten]
          U1400 00 [000] - -
End----------(Elapsed Time: 02:20, VBatt start/end: 13.9V/13.9V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
Hm I noted that the BS is not the suitable ABS module for the 1K Golf. It must be BL (or newer?). This might also be a reason the ABS coding is not sticking.
iichel
Eindhoven, NB, NL
C?ID=284912
So two questions:
- Can a MK60EC1 be coded 'on the bench' with i.e. wheel speed sensors disconnected?
- Anyone would like to have a guess at a possible ABS coding for this setup?
m87a
Bosnia and Herzegovina
C?ID=156900
this is just a speculation but i dont think so...
whenever i have tried to code mk60ec1 and even when i knew original code i had to do at least g85 in order for code to be remembered, as for abs sensors i dont know
i can post some guesses if you need them...
iichel
Eindhoven, NB, NL
C?ID=284912
Yes please have a go at some codings :)
dnoermann
C?ID=358118
So two questions:
For the MK100 from T6 i can say, i was able to do coding on Bench in your setup.
But when i tried Basic-Settings it refused.
Later i found out that "brake" pressed Signal needs to be "not pressed" for Basic Settings and with nothing connected it is pressed.
m87a
C?ID=156900
try
143B400D092600FE280E02EC901B004131080000
iichel
Eindhoven, NB, NL
C?ID=284912
I was successful with
113B200D092600FE880E04EC901B0051350000
Next step is basic settings, of course it was on the bench-ish so I could not show the car I was driving.
Is there any way to code out the power steering? It's complaining that it cannot communicate to the power steering module, which makes sense-ish since the car has a different rack fitted than the Golf Mk6 does.
iichel
Eindhoven, NB, NL
C?ID=284912
So some progress, fitted the entire set to my other Polo with an electromechanical steering rack rather than a electrohydraulic rack. So I managed to produce my longest VCDS autoscan (over 1200 lines) so far:
Sunday,21,March,2021,16:27:18:11868
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
          57 61 65 69 6C 77 0B
20-High Beam Assist. -- Status: Malfunction 0010
10 Faults Found:
          P2563 00 [237] - Implausible Signal
                    Mileage: 181669 km
                    Date: 2021.03.19
                    Time: 02:01:39
                    Coolant temperature: 53 °C
                    Intake air temperature: 26 °C
                    Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 7.074 %
                    High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 0.718 V
7300 - Throttle Position Sensor (G69)
          P0123 00 [165] - Signal too High
                    Coolant temperature: -40 °C
                    Intake air temperature: 96 °C
                    Voltage terminal 30: 11.068 V
                    Throttle valve adapter: actual value-ANG_THR[0]: 99.997 %
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
                    Throttle valve: activation-PWM_HBR_THR[0]: 0.000 %
                    Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.990 V
                    Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.698 V
                    Throttle valve adapter: offset open-V_THR_TOL[0]: 4.600 V
                    Throttle valve adapter: status-LF_STATE_THR_DISP[0]: 0
7344 - EGR Sensor 2
          P0408 00 [165] - Signal too High
                    EGR Solen.val.: actual value-ANG_EGRV[0]: 99.997 %
                    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                    High pressure EGR actuator: activation-PWM_HBR_EGRV[0]: -100.000 %
                    High press EGR actuator: actual unconditioned volt val-V_EGRV[0]: 5.000 V
                    EGR valve: offset closed-V_EGRV_BOL[0]: 1.001 V
                    EGR valve: offset open-V_EGRV_TOL[0]: 3.999 V
                    Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0]: 0
7411 - Turbocharger Boost Control Position Sensor Circuit
          P2564 00 [165] - Signal too Low
                    Charge air pressure actuator: acknowledgment-ANG_BPA[0]: -13.025 %
                    Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
                    High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 95.001 %
                    High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 0.000 V
                    High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 0
6086 - No Communication with ABS Brake Control Module
          U0121 00 [036] - -
                    Mileage: 174031 km
                    Date: 2028.08.03
                    Time: 02:50:18
                    Coolant temperature: 8 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 9.600 V
                    Driver intention torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 22 °C
          P0193 00 [165] - Short to Plus
                    Fault Frequency: 11
                    Supply voltage of analog output 1-VCC_1: 5.01 V
                    Fuel high pressure sensor: unconditioned voltage-VP_PFU: 4.9940 V
10231 - Valve for Fuel Metering (N290)
          P0090 00 [165] - Open Circuit
                    Valve for fuel metering: feedback value measured-CFB_VCV_MES: 0.073 A
                    Voltage equivalent of valve for fuel metering-VP_CFB_VCV: 3.2877 V
                    Fuel high-pressure: actual value-FUP_FIL: 0.000 MPa
          P2294 00 [165] - Open Circuit
9874 - Boost Pressure Control Valve/Solenoid (Bank 1)
          P0045 00 [165] - Open Circuit
                    Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 93.335 %
                    Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 0.002 %
                    High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 3.799 V
                    Charge air pressure: actual value-MAP_MMV: 200.00 hPa
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 96 °C
          U0415 00 [165] - -
                    Mileage: 181699 km
                    Date: 2021.03.20
                    Time: 17:28:51
                    Coolant temperature: 5 °C
                    Intake air temperature: 7 °C
                    Cruise Control System (CCS): status-Binary 8 Bit: 10100000
Readiness: 1 1 0 0 0
   Revision: 00H31001
   Coding: 113B200D092600FE880E04EC901B0051350000
   Shop #: WSC 31889 470 31889
   VCID: 7DA704B51DF38B23E45-8028
10 Faults Found:
                    Reset counter: 220
                    Mileage: 393988 km
                    Date: 2002.00.04
                    Time: 16:40:12
                    Count: 258
                    Count: 180
                    Count: 56320
                    Count: 212
                    Count: 288
                    Count: 769
                    Count: 291
                    Count: 56321
                    Reset counter: 220
                    Mileage: 2556161 km
                    Date: 2055.00.00
                    Time: 16:04:28
                    Count: 256
                    Count: 20700
                    Count: 256
                    Count: 279
                    Count: 80
                    Count: 256
                    Count: 16604
                    Count: 256
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:09
                    Count: 16391
                    Count: 14
                    Count: 4608
                    Count: 295
                    Count: 41472
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:09
                    Count: 16391
                    Count: 14
                    Count: 4608
                    Count: 270
                    Count: 41472
                    Fault Status: 01101000
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:09
                    Count: 16391
                    Count: 14
                    Count: 4608
                    Count: 266
                    Count: 41472
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:09
                    Count: 16391
                    Count: 14
                    Count: 4608
                    Count: 8195
                    Count: 41472
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:09
                    Count: 16391
                    Count: 14
                    Count: 4608
                    Count: 80
                    Count: 41472
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:09
                    Count: 16391
                    Count: 14
                    Count: 4608
                    Count: 64
                    Count: 41472
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:09
                    Count: 16391
                    Count: 14
                    Count: 4608
                    Count: 48
                    Count: 41472
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:09
                    Count: 16391
                    Count: 14
                    Count: 4608
                    Count: 32
                    Count: 41472
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   Shop #: WSC 31889 047 31889
   VCID: 372BD69D7FCF61737E9-8062
65826 - No Basic Setting
          B2010 00 [009] - -
                    Date: 2021.03.21
                    Time: 00:00:06
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E0B773-806C
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:11
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3EB82FBF68E32400B33807E0FFEB9FF0F08067EF608D78D071E400030800
   Subsystem 1 - Part No: 5K7 955 547
   Component: RLHS 220816 0  42  0106
   Coding: 0214DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027011200011418
   Coding: 58BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
03444 - Ignition Starter Switch
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:12
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391528804191
   Coding: 0031195141
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
12718592 - Databus
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:11
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
12854016 - Databus
          [Kombi1 DLC Error]
                    Fault Frequency: 33
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:12
12850432 - Databus
          [Bremse8 DLC Error]
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:12
   Coding: 140A210000
          U1017 00 [009] - -
          [Steuergerät für Bremse: bitte Fehlerspeicher auslesen]
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:11
   Revision: B9082001
   Coding: 042204
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 7E0 857 511 G    HW: 7E0 857 511 E
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0404000000000000010000
   ASAM Dataset: EV_HighBeamAssisAU316 001004
   ROD: EV_HighBeamAssisAU316.rod
   VCID: 2E05F3F98095A0BB2DF-807A
13241856 - Databus
          [Data bus received erroneous signal]
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:11
                    Communication status of data bus 1-ABS Control Module: No communication
                    Communication status of data bus 1-Data Bus On Board Diagnostic Interface: Communication
                    Communication status of data bus 1-Engine Control Module: No communication
                    Communication status of data bus 1-Vehicle Electrical System Control Module: Communication
                    Communication status of data bus 1-Steering column electronic systems control module: Communication
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BEEFD879FA9B3269-807A
13637376 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Errorvalue GWB_FzgGeschw]
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:10
                    ELV State: 04
                    Information Clamps: 40 00
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Vehicle speed: 327.42 km/h
                    Voltage: 64
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB997845987B65F-8062
   Subsystem 1 - Part No: 1T0 051 859 AS
   Component: EU West V17  8557
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9B3269-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ÿ
   Subsystem 4 - Serial number: H21982ÿ
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2013.01.01
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 000300
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
1053952 - Databus
          [DEM_VEH_SPD_INVALID_FAULT]
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:11
                    Engine RPM: 0 /min
                    Vehicle speed: 41.56 km/h
                    System status: Driving mode
                    Terminal 15 status: Terminal 15 on
                    Voltage terminal 30: 11.76 V
                    Power steering current consumption: 0.50 A
                    max.value: 0.62 A
                    End stage temperature: 22 °C
                    Steering assistance: engine output: 100.00 %
                    Engine angle: 20 °
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.00 Nm
                    Steering torque: 0.05 Nm
                    Status: OK
1057792 - Databus
          [DEM_WHEEL_SPD_INVALID_FAULT]
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:11
                    Engine RPM: 0 /min
                    max.value: 0.62 A
                    Engine angle: 20 °
                    Status: OK
1094656 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:10
1062912 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [DEM_CODING_PLAUSIBILITY_CHECK_FAILED_FAULT]
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:10
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE8BE73-807C
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Coding: 0D4A000001000000
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2DCFA94CDD7C1B817-806E
13705985 - Databus
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:10
13705987 - Databus
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:10
13705984 - Databus
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:10
13705986 - Databus
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:10
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE8BE73-807C
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030F1A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 40000000058319
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 152
                    Mileage: 65434 km
                    Date: 2023.11.24
                    Time: 13:29:33
                    Vehicle speed: 54 km/h
                    Outside temperature: 9.0 °C
                    Reception level antenna 1: 580 mV
                    Offset level antenna 1: 270 mV
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 152
                    Mileage: 65434 km
                    Date: 2023.11.24
                    Time: 13:29:33
                    Reception level antenna 1: 590 mV
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 152
                    Mileage: 65434 km
                    Date: 2023.11.24
                    Time: 13:29:33
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Reset counter: 152
                    Mileage: 65434 km
                    Date: 2023.11.24
                    Time: 13:29:33
                    Reception level antenna 1: 600 mV
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9B3269-807A
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323E31C5-8030
03006 - Back-up Camera System not calibrated
                    Reset counter: 220
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:03:08
                        Reverse OFF
                    Count: 3
                    Reset counter: 220
                    Mileage: 181699 km
                    Date: 2021.03.21
                    Time: 00:07:39
                        Reverse OFF
                    Count: 3
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3E3DC5-8070
End----(Elapsed Time: 02:53, VBatt start/end: 11.6V/11.6V. VIgn 11.4V)-----
BUT
The ABS is coded
ABS is showing steering angle
Steering angle is calibrating
AND
The ABS is not complaining about a missing power steering rack.
So the list of unhappy modules, I've greened the grouped the modules by unhappiness
So we have some happy modules next to some non-ABS related unhappiness:
04-Steering Angle -- Status: OK 0000 -- Happy
05-Acc/Start Auth. -- Status: Malfunction 0010 -- Unhappy because of a different VIN in the immobiliser
09-Cent. Elect. -- Status: Malfunction 0010 -- Unhappy because I've 'shorted' terminal 15 since no valid kessy key for this setup.
10-Park/Steer Assist -- Status: Malfunction 0010 -- Started unhappy
19-CAN Gateway -- Status: OK 0000 -- Happy
25-Immobilizer -- Status: OK 0000 -- Happy
2E-Media Player 3 -- Status: OK 0000 -- Happy
37-Navigation -- Status: OK 0000 -- Happy
44-Steering Assist -- Status: Malfunction 0010 -- Unhappy because of G85 --> calibrated
47-Sound System -- Status: OK 0000 -- Happy
56-Radio -- Status: OK 0000 -- Happy
57-TV Tuner -- Status: OK 0000 -- Happy
61-Battery Regul. -- Status: OK 0000 -- Happy
65-Tire Pressure -- Status: Malfunction 0010 -- Started unhappy
69-Trailer -- Status: OK 0000 -- Happy
6C-Back-up Cam. -- Status: Malfunction 0010 -- Started unhappy
77-Telephone -- Status: OK 0000 -- Happy
So it appears that some errors are simply unhappy because they simply don't have a speed signal:
2B-Steer. Col. Lock -- Status: Malfunction 0010 -- Unhappy because of ABS (no speed signal)
55-Headlight Range -- Status: Malfunction 0010 -- Unhappy because of ABS (no speed signal)
Then we have some modules that are simply unhappy since the ABS is unhappy, either directly or indirectly:
08-Auto HVAC -- Status: Malfunction 0010 -- Unhappy because of IC --> Unhappy because of an unhappy ABS
15-Airbags -- Status: Malfunction 0010 -- Unhappy because of IC --> Unhappy because of an unhappy ABS
17-Instruments -- Status: Malfunction 0010 -- Unhappy because of an unhappy ABS
3C-Lane Change -- Status: Malfunction 0010 -- Unhappy because of an unhappy ABS
Which just leaves these modules as a set of unhappy modules:
01-Engine -- Status: Malfunction 0010 -- Various errors due to T60 for engine wiring loom/ABS
03-ABS Brakes -- Status: Malfunction 0010 -- needs a basic setting + wheel sensors
20-High Beam Assist. -- Status: Malfunction 0010 -- Unhappy because of no comms to ABS/Engine
So... perhaps this will end with a non-functioning high beam assist because I'm not sure this error will go away. But otherwise I'm feeling confident this might actually be doable :)
iichel
Eindhoven, NB, NL
C?ID=284912
New test with a Beetle 5C cluster + Beetle ECU + BS MK60EC1 ABS controller
The good news is... it works and I managed to code the ABS controller.
The bad new is... it will require some work :)
Tuesday,06,April,2021,11:00:24:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 21.3.0.0 (x64)  HEX-V2 CB: 0.4544.4
Data version: 20210318 DS325.0
VIN: WVWZZZ16ZDM8000xx   License Plate:
Mileage: 1520km-944mi   Repair Order:
Chassis Type: 16-VW32 (7E0)
VIN: WVWZZZ16ZDM8000xx   Mileage: 1520km-944miles
Address 01: Engine (J623-CAYC)       Labels: None
   Part No SW: 03L 906 023 KC    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 5963
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114036032401080000
   Shop #: WSC 00066 000 00062
   ASAM Dataset: EV_ECM16TDI02103L906023KC 003001
   ROD: GV_ECM16TDI021VW32X.rod
   VCID: 71BF2885512BFF4370D-8025
10 Faults Found:
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:50
                    Intake air temperature: 4 °C
                    Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.684 V
7344 - EGR Sensor 2
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:50
                    EGR valve: offset closed-V_EGRV_BOL[0]: 0.957 V
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [165] - Signal too High
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:50
                    Engine RPM: 0 /min
                    Air mass: specified value-MAF_SP_MMV: 269.94 mg/stroke
                    Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:50
                    Charge air pressure actuator: acknowledgment-ANG_BPA[0]: -8.649 %
                    Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.345 V
6548 - Engine Control Module Incorrectly Coded
          P1612 00 [165] - -
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:52
                    Voltage terminal 30: 11.746 V
                    Coding in the engine control module-FRF_VARCOD: 4
                    Control Module temperature-TECU: 11 °C
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:50
                    Supply voltage of analog output 1-VCC_1: 4.99 V
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:50
                    Battery voltage: 11.7 V
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:50
9867 - Coolant Pump 2
          P261A 00 [037] - Open circuit
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:02:14
                    Coolant temperature at radiator outlet: actual value-TCO_2: 3 °C
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:50
                    Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 97.711 %
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 4 °C
Readiness: 1110 0000
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: F63B40F8092200FA6F0B02E790220071A1100013
   VCID: 7EF4749BE9CA557470-802A
   Revision: V0000000
   VCID: 3537DC95654393636C5-8061
                    Fault Status: 00101101
                    Reset counter: 194
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:02:46
                    Reset counter: 194
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:02:49
   VCID: 2B03FAEDB307D5930A1-807F
   Coding: 03302D
   Coding: 18BC30
   Coding: 08BC30
   Coding: A5FFFF
   Coding: 08BC32
   Coding: 08BC32
   Coding: 118101
   VCID: 3D27C4B55DF34B23A45-8069
   Coding: 00314D
   VCID: 4ACD9F691C3DEC9B117-801F
12854016 - Databus
          [Kombi1 DLC Error]
                    Reset counter: 194
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:02:46
12656896 - Databus
          [Bremse8 Time Out Error]
                    Reset counter: 194
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:04:01
   Part No SW: 5C3 920 870 A    HW: 5C3 920 870 A
   Component: KOMBI         H13 0016
   Revision: X0013004    Serial number:
   Coding: 151B01
   Shop #: WSC 00066 000 00124
   ASAM Dataset: EV_KombiUDSMM9RM10 A04305
   ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
   VCID: 26150BD9A865E8FBD5F-8073
          [Supply voltage too low]
                    Reset counter: 60
                    Mileage: 1512 km
                    Date: 2021.01.16
                    Time: 00:00:55
          U1400 00 [008] - -
                    Reset counter: 60
13673472 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für ELV: keine Kommunikation]
                    Reset counter: 154
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:58
13634048 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Zugang- und Startberechtigung: keine Kommunikation]
                    Reset counter: 154
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:01:53
   Revision: B9082001
   Coding: 002200
   VCID: 688945E162713E8B273-803D
   Part No SW: 5K0 953 234     HW: 5C3 920 870 A
   Component: IMMO          H13 0016
   Coding: 000007
   Shop #: WSC 00066 000 00063
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
   VCID: 6A8D3FE97CFD0C9B317-803F
9456681 - Key
          B104C 29 [009] - Implausible Signal
                    Reset counter: 154
                    Mileage: 1522 km
                    Date: 2021.04.06
Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
   Part No SW: 3C0 035 270 B    HW: 3C0 035 270
   Component: RNS310        H20 0358
   Revision: 10000000    Serial number: VWZ1Z2P0302125
   Coding: 000004410200010400008000
   ASAM Dataset: VW_RNS310 A02007
   ROD: EV_VWRNS310UDS.rod
   VCID: 196F3025E91B570368D-804D
   Coding: 11220
   Shop #: WSC 12345
   VCID: 2F3BEEFD8E5FA9B3269-807B
01312 - Powertrain Data Bus
            37-10 - Faulty - Intermittent
   VCID: 77AB169D3F4FA173BE9-8023
13705472 - Databus
          [Timeout mBremse_3]
                    Reset counter: 194
                    Mileage: 1522 km
                    Date: 2021.04.06
                    Time: 00:02:46
Address 69: Trailer
   VCID: 1F1B1E3DF73F3933969-804B
End----------(Elapsed Time: 01:58, VBatt start/end: 11.5V/11.4V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
I'm sharing with you a little victory. And a very big relief.
HAVE A LOOK HERE
What his means is very significant. You see, this is a cluster with immo data from my 1.2 TDI.
With the ECU for a 1.6 TDI. And it's happy. It's very happy. Key is found and immobiliser is MATCHED.
Story time!
So I want to tell you the significance of this. Having a matched immo for ECU/cluster helps a lot in starting your car.
And it has been a struggle to find the right solution.
You see, I'm putting a 1.6 TDI engine in a car that was born with a 1.2 TDI engine. Why? Because I can. Should I? No.
But why would you do such a thing? Because that's what I like to do.
Swapping an engine is easy. On my Karmann Ghia, it takes an hour to put in a new engine. And that includes taking out the old one.
And then it goes. Like nothing happened.
On a modern car, this is not so easy. My car is a Polo 6R 1.2 TDI from 2011. It has electronics, it has an immobiliser. It is complicated.
Let's start with the basics. Because I have kessy, I need the ECU to start the engine, not the ignition lock directly.
The Polo 6R has 1.6 TDI DSG (CAYB), only in the PR-7L3 (non-bluemotion) version. So the terminal 50 goes directly from T6 (ignition lock) to the starter motor. Terminal 50 is the Bosch name for the signal to start the engine. Like terminal 15 is the ignition (literally, as it powered the ignition coil), 30 is permanently live, 31 is ground. The list is very long. 45, 51, 52, 53, 54, 56, 56a, 58, 58a, 58d, 75.....
The Polo 6R 1.2 TDI PR-7L6 has a different construction.
In this case, the ignition lock goes to the ECU via a small wire. The ECU then operates two starter relays, that send power to the starter motor.
So you cannot start until the clutch is depressed. AND you can do a little click of the starter position with the key, and the engine takes care of it all.
Now the kessy also utilizes this construction. You press the start button, ELV (steering column lock) tells the ECU to start, ECU closes the two relays and off we go, starter motor goes round.
So, for this reason, it's not possible to use the Polo 6R 03L906023MG (1.6 TDI CAYB + PR-7L3 + PR-G1C) ECU. It doesn't have the software to operate the starter relays.
So it's never going to start. And the PQ25-polo PR-7L6 ECU is only PR-G0C. So for manual. PR-G1C is for DSG.
I'm in trouble now, aren't I? So why don't you just take off the kessy? Well, that's not what I do. Sorry. So let's get complicated. So what can I do?
Well, I had a solution. I got myself a matching set of a KC ECU (beetle 5C) --> PR-7L6 + PR-G0C! With a cluster, ELV, 2 keys and kessy module.
Wait, didn't I just say G0C was manual? Yes... I can flash it with KE firmware. I have that. No issue. But such a FW doesn't exist for the 6R0 ECU (different hardware). Bummer.
So I could bolt the ELV to my car, transfer the immo data to my cluster and be a happy man. I have the man for this job, mr Slavik himself.
You see, mr. Slavik is a hero, he helped me to figure out a lot of things and he is paid not in euro's but in crates of beer. This is a fact.
I visited him a few times and even though my ideas are crazy, he never said no.. This is the kind of people I need.
So I can have all the things I like to have:
- PQ25 ECU for 1.6 TDI CAYC = TDI
- Kessy
- DSG gearbox
- 7L6
- GRA high
So I connected all the parts to my polo.
Fuck, my dash is a fucking christmas tree.
The ABS was very unhappy. My Bosch ESP9.0i of course doesn't understand what is happening. It is expecting a Polo 6R, Fabia 5J, Ibizia 6J or an Audi A1 8X pre-facelift.
And it is seeing a 2013 VW Beetle 5C (WVWZZZ16ZDM800039 is not a Polo VIN, definitely not my VIN).
So, out we go with the ABS coding. It's all zeros. And I could not come up with a new ABS coding, something I'm usually very good at.
So I was having a bad day.
And I went, fuck it, I'm having a Beetle ABS. So I bought a Beetle ABS unit, 1K0907379BS, from my favourite shop happyparts.
And I put it on the bench, connected cluster and ECU and I did find a code for it. I like coding ABS units. I never owned a car with a Mk60EC1 but I do know how to code it.
So that was the plan. My Polo was becoming a Beetle. All I had to do was...
- Put in the ECU
- Flash the ECU from KC to KE firmware for the DSG gearbox
- Swap ELV
- Transfer the immo data to my Amarok cluster
- Swap or code kessy unit
- Learn the keys
- Swap the ABS unit (so different plug, wheel sensors). I have it all here, by the way.
- Learn the ABS (I already verified that it will work with all my other systems like power steering, steering angle sender, etc).
Hey, small effort, right? I already put in the engine and gearbox, this is no hassle. I'm kessiichel, I can fix this... Just some wires and some coding. No big deal.
Then Mr Slavik (I already noted that he is paid in beer, right?) told me about a program to re-calculate the immo data of an ECU.
Until now I've always been told that this is not possible for Siemens PCR2.1. Only for Bosch EDC, where you can edit immo or make it immo-off.
PCR2.1 is more difficult and until now, everyone told me it's not possible. Or to fuck off.
But, there is a solution. It's this --> https://skodapilot.com/2020/04/20/vag-immo-calculator/
So I got a sole KE ECU, send it to someone to read the flash (Slavik's KESS couldn't do it), send the flash to the developer of the program along with my immo data.
Then I got back the flash with my immo data in it, I sent the flash to the ECU reader and he flashed the flash to my ECU.
Are we still following?
Good.
So, now, let's see what we have:
- My Amarok cluster with Polo FW (already had that)
- Kessy ELV matched to Amarok cluster
- My own keys
- My own BCM
- My own kessy module
- My own ESP9.0i
- My own 1.6 TDI ECU with my own VIN. And GRA_High enabled in ECU flash.
I'm even as brave as I can say... this new ECU... is more or less plug and play :twisted:
(I probably still need to adjust the injectors and some basic settings)
So I only bought a few spare parts that I don't need anymore, all matching sets...
- 6R0 1.2 TDI ECU + cluster + key
- 5K0 1.6 TDI (DSG) ECU + cluster + key
- 8X0 1.6 TDI (DSG) ECU + cluster + BCM + gateway + key
- 5C0 1.6 TDI (manual) ECU + cluster + ELV + ABS + key (anyone willing to do their own kessy project?)
I guess I'll be selling a lot of stuff shortly
krisv
Poland
C?ID=326234
Why did you not went for a 2.0 TDI engine, higher power output and you could get easy over 200 hp:) ??
Nice work :)
iichel
Eindhoven, NB, NL
C?ID=284912
Maybe later, but the 2.0 TDI does not have a type approval. And it will probably destroy a DQ200 gearbox with ease. So then you need DQ250, and that comes with custom drive shafts, gearbox mounts, software, etc...
ED30R
C?ID=70060
That’s a serious amount of work but if you enjoy learning it’s an ideal project 😎
iichel
Eindhoven, NB, NL
C?ID=284912
Did I already tell you I finished the project? The 1.6 TDI engine and DSG gearbox have been retrofitted to my 1.2 TDI car
So now my car doesn't have a single of its factory control modules anymore.
Friday,20,August,2021,14:33:16:11868
VIN:   License Plate:
Mileage:   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55
          56 57 61 65 69 6C 77 0B
VIN:   Mileage:
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Coding: 21DD2885412500C5841A146E825500521504
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: N/A
   VCID: 0F7B4E7D27DF89B3069-805A
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW36)
   Coding: 030C0C
   Revision: V0000000
   Coding: 3EB82BBFA8EB3400B33807F0BFCB9FF0FF8067EFE08D78D031E400030800
   Coding: 0214DD
   Coding: 0200A3
   Coding: 1000AB
   Coding: 58BC32
   Coding: 08BC32
   Coding: 0031195101
12718592 - Databus
                    Reset counter: 246
                    Mileage: km
                    Date: 2021.08.20
                    Time: 14:30:19
   Coding: 00314D
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140F01
   VCID: 3333E28D6BB78D53421-8066
   Revision: B9082001
   Coding: 042204
   Revision: AA001001
   Component: IMMO          H04 0709
   Coding: 000007
   Coding: 4900000000000000
   Coding: 010100
   Coding: 0010161
   Coding: 001F00
   Coding: 0000816
   Coding: 030F7A5A
   Coding: 0030115
End----------(Elapsed Time: 02:50, VBatt start/end: 12.8V/12.8V)-----------
01-Engine -- Status: OK 0000 --> CFWA to CAYC
02-Auto Trans -- Status: OK 0000 --> manual to DSG7 DQ200
03-ABS Brakes -- Status: OK 0000 --> ESP8.2i to ESP9.0i
04-Steering Angle -- Status: OK 0000 --> 6R0 to 6C0
05-Acc/Start Auth. -- Status: OK 0000 --> retrofitted kessy
08-Auto HVAC -- Status: OK 0000 --> manual to climatronic
09-Cent. Elect. -- Status: OK 0000 --> 6R0 937 088B to 7E0 937 090 C
+ WRM front, to folding mirror
+ WRM rear, from manual to electric
+ RLS retrofitted
+ DWA retrofitted
+ MFSW retrofitted
10-Park/Steer Assist -- Status: Malfunction 0010 --> retrofitted
15-Airbags -- Status: OK 0000 --> changed for passenger airbag deactivation
17-Instruments -- Status: OK 0000 --> 6R0 midline to 2H0 highline
19-CAN Gateway -- Status: OK 0000 --> 6R0 to 7E0
20-High Beam Assist. -- Status: OK 0000 --> retrofitted
25-Immobilizer -- Status: OK 0000 --> from normal to kessy
2B-Steer. Col. Lock -- Status: OK 0000 --> retrofitted kessy
2E-Media Player 3 -- Status: OK 0000 --> retrofitted
37-Navigation -- Status: OK 0000 --> RCD210 to RNS510 DAB
3C-Lane Change -- Status: OK 0000 --> retrofitted
44-Steering Assist -- Status: OK 0000 --> from electrohydraulic to electromechanic
47-Sound System -- Status: OK 0000 --> retrofitted dynaudio
4B-Multifunc. Module -- Status: Malfunction 0010 --> retrofitted
55-Headlight Range -- Status: OK 0000 --> retrofitted AFS
56-Radio -- Status: OK 0000 --> RCD210 to RNS510 DAB
57-TV Tuner -- Status: OK 0000 --> retrofitted
61-Battery Regul. -- Status: OK 0000 --> 6R0 to 7E0
+ BDM J367 from 6R0 to 6C0 GTI
65-Tire Pressure -- Status: OK 0000 --> retrofitted
69-Trailer -- Status: OK 0000 --> retrofitted
6C-Back-up Cam. -- Status: OK 0000 --> retrofitted
77-Telephone -- Status: OK 0000 --> retrofitted
And it has fewer fault codes than some brand new cars we see scans of! :thumbs:
iichel
Eindhoven, NB, NL
C?ID=284912
admittedly, i did cheat a little bit by clearing some errors before i made the scan. the engine keeps going into overboost mode, i need to find a way to adapt the turbocharger.
I guess you have already tried this Basic Setting?
IDE00897 -- Adaptation of the turbocharger
iichel
Eindhoven, NB, NL
C?ID=284912
Yes, I have indeed tried it. It shows some funny behaviour. It increases engine revs from 850 to about 1300 rpm, and it displays 'not running'.
And it just keeps there until you stop it.
No message to depress brake pedal, release brake pedal, depress accelerator pedal, running etc. In the meanwhile I can simply play with the accelerator.
lwf
C?ID=421906
Did you ever solve this problem i have the same with 1.6 tdi checked everything and still showing p2563 but only while idle and not while driving
