Golf R Line Diesel Control Cruise through MFSW
LONZO
Chile
C?ID=134566 (NRRT)
Hi, my name is Alonso, I'm a car enthusiast, I've had some VAG in my life and have done some retrofits to my cars and my friends car.
Some months ago I've bought a 2018 Golf Rline Diesel. this unit didn't come with CC, so I decide to buy the MFSW to do the retrofit, have read the instructions in the Wiki Ross Tech page and the following step it couldn't be done by me, so I'm asking for some help with these. I'm attaching the autoscan. Maybe you can tell me what is not working.
The car originally had a MFSW but without the CC buttons.
Friday,26,February,2021,21:56:51:00162
VCDS Version: 20.12.0.1 (x64)
VIN: WVWZZZAUZHW012159   License Plate:
Mileage: 33414km-20762mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 3C 42 44 52 55 5F
VIN: WVWZZZAUZHW012159   Mileage: 33414km-20762miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BP    HW: 04L 907 309 R
   Component: R4 2,0L EDC   X23 1198
   Revision: B5X23---
   Coding: 011D0012030401083000
   Shop #: WSC 26214 051 12345
   ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
   ROD: EV_ECM20TDI01104L906026BP_002_VW37.rod
   VCID: 79D73DA0F8D9F04C45-802C
17165 - Databus
          U1123 00 [038] - Received Error Message
                    Mileage: 33414 km
                    Date: 2021.02.26
                    Time: 21:46:17
                    Engine RPM: 0.00 /min
                    Coolant temperature: 78 °C
                    Intake air temperature: 71 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 12.180 V
                    ACC variants-Bits 0-7: 0
                    CCS Switch-Bits 0-7: 1
                    Cruise control switch actuation-Bits 0-7: 33
                    Cruise control switch actuation-Bits 0-7: 128
                    ACC variants (coding)-Bits 0-7: 2
                    Acceleration: 0.000 m/s²
17919 - Cruise Control Switch (E45)
          P0568 00 [038] - Implausible Signal
                    Mileage: 33414 km
                    Date: 2021.02.26
                    Time: 21:46:18
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [038] - -
                    Mileage: 33414 km
                    Date: 2021.02.26
                    Time: 21:46:17
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 4
   Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4902
   Revision: 06254004    Serial number: TFK01605270297
   ROD: EV_TCMDQ250021.rod
   VCID: 1D1F09300CB16C6C09-8048
          P1734 00 [002] - -
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 91476000001307
   Coding: 01FA62A12421096E4578060541CC2980462490A26082947300625078C28203
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 7AD522ACFDDFFB544C-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0405331698
   Coding: 032C0C
   VCID: 3B5BE7A8B265025C17-806E
   Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 00020114200100011005000000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 72C50A8CA5AF831404-8026
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Serial number: 01061615301610
   Coding: 00111A46C24122FB4AE44000000C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04295C548F1BBDA426-8050
   Component: WWS    160511  043 0551
   Serial number:         160519154610
   Component: RLHS  037 0059
   Serial number: S5Y16M06D01H07M17S11
   Coding: 90A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST000ZFKSQ00000
   Coding: 181901
   Revision: --------    Serial number: 39331615307571
   Coding: 0031155011
   VCID: 43AB9F48CA957A9C5F-8016
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR1TD72$
   VCID: 7F23D3B8E6FDDE7C7B-802A
   Left seat belt tensioner:
   Serial number: 34169667D01061691016
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169668D02061650200
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 106 16
   Serial number: 35767000000538A8AA1/
   Subsystem 4 - Part No SW: -----------    HW: 480 000 106 16
   Serial number: 35867000000E6955BB15
   Subsystem 5 - Part No SW: -----------    HW: 480 403 105 16
   Serial number: 3516502BF2076355D26B
   Subsystem 6 - Part No SW: -----------    HW: 480 402 405 16
   Serial number: 3526502A52057292831Y
   Subsystem 7 - Part No SW: -----------    HW: 480 402 805 16
   Serial number: 3556502C5205729181D5
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 01061608490463
   Coding: 0410
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 07334B58BE2D96BC43-8052
   Part No SW: 5G1 920 641 B    HW: 5G1 920 641 B
   Component: KOMBI         202 9630
   Coding: 07AD19182B08080E02084B085400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009007
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 256F21D024E1A4AC51-8070
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0004956498
   Coding: 030100041F086800FB00024E1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CD924B4F7EBC5645E-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29180001703990098317
   Coding: 29FFFF
   Serial number: 8824950104
8782090 - Cruise Control Switch
          B1154 96 [009] - Component internal failure
                    Reset counter: 100
                    Mileage: 33414 km
                    Date: 2021.02.26
                    Time: 21:47:55
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: On
   Revision: 00000000    Serial number: 16000094143009
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3449CC949F3BCD24D6-8060
   Serial number: 0405306982
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C59E4B4B76B05641E-8068
   Serial number: 0405047694
   Coding: 020111
   Serial number: 090516EE804925
   Coding: 003B1320D000048000001000
   Serial number: 00000000000010269490
   Coding: 110000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45AF8150C4A144AC71-8010
   Serial number: 120516EEB11179
   Coding: 003B1120DE00048000801000
   VCID: 42A59A4CD58F739454-8016
   Serial number: 00000000000010239736
   Coding: 090000
   Coding: 029A00000B010200
   VCID: 40A19044DB83618442-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3G0 035 051     HW: 3G0 035 051
   Component: MU-H-N-KR     H51 0753
   Serial number: A756E0GB002724
   Coding: 02730000FF0000005014000100102800000207940100010010
   VCID: 589158242313C9441A-800C
   Subsystem 1 - Part No SW: 5G0 919 606 C    HW: 5G0 919 606 C
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9RKM0002R
   Compact disc data bank:
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2---  --- 2010
6726 - Databus
                    Reset counter: 100
                    Mileage: 33414 km
                    Date: 2021.02.26
                    Time: 21:28:58
                    Voltage terminal 30: 12.6 V
                    Network diagnosis-Status: Enabled
End-------------------------(Elapsed Time: 03:57)--------------------------
This is the steering wheel that I 've retrofit. (https://cdn11.bigcommerce.com/s-16g.../4942/5G0419091JF_1__79049.1548748580.JPG?c=2)
thanks,
best regards,
Zagor
Italy
C?ID=96696
In your case, the cruise control upgrade (as others upgrade) is only possible with a code provided (and purchased) from Seat dealer
LONZO
Chile
C?ID=134566 (NRRT)
Did you mean VW dealer? What do i have to ask in the dealer? And upgrade? Or something else?
Best regards,
Best regards,
Zagor
Italy
C?ID=96696
Ask for a "Cruise Control activation code"
siLc
Tallinn, Estonia
C?ID=330192
VW group made the retrofit of cruise control on MQB platform cars not as easy as on previous platforms. You will need to pay them for it - essentially buy the official retrofit kit with the stalk-mounted cruise controls and have a dealership activate cruise control with ODIS and a connection to the VW group mothership server.
It has been repeatedly discussed before over the years.
LONZO
Chile
C?ID=134566 (NRRT)
Hi, Well, after taking the car to the dealer, they told me that it was activated but it didn't work. So I started checking everything in the car and have the crazy idea to check how the buttons were working, there is one that says Malfunction (maybe I had bad luck with the buttons and they came broken), so I have the following question, it is possible that coding is giving the malfunction error or I can really have that bad luck. Tomorrow I'll be posting some pictures of the VCDS Screen.
Thanks,
Zagor
Italy
C?ID=96696
Coding give malfunction, yes, but only whithout activation code
Thanks,
@LONZO :Hi. From your auto-scan, I note that the long-code string for the ECU is like this:
BYTEHEXBINARY
00100000001
11D00011101
20000000000
31200010010
40300000011
50400000100
60100000001
70800001000
83000110000
90000000000
So, I've highlighted Byte 5 because the software switches in Bit 5-6 on this byte tells the ECU to operate Cruise Control - I think (see my caveat below). As you can see, currently Byte 5 =hex04, which means that Bits 5-6 = hex00
Given that you don't have access to the "yellow" long-code helper screens (because you don't have a HEX-NET dongle), I've provided the traditional helper screen for Byte 5 below:
Note: the picture above is from the ECU on a petrol engine, but I'm assuming that the CC descriptors also apply to your TDI. If I'm correct, then perhaps you might try setting Bit 5 so that Byte 5 =hex24 after the change. It's an easy try - so worth a shot IMO
LONZO
Chile
C?ID=134566 (NRRT)
Thanks, DV52, I'll give it a try and will post results, hope I'll have a green light,
Many thanks,
best regards,
BYTEHEXBINARY
00100000001
11D00011101
20000000000
31200010010
40300000011
50400000100
60100000001
70800001000
83000110000
90000000000
golfi_vend
Tartu, Estonia
C?ID=195131
Partslink24 says:
cruise control system8T0Without cruise control system (CCS)
So You don't have cruise.
YOU CAN'T ADD CRUISE JUST BY BUYING PARTS.
It needs to be activted by dealer. And They need to be sure it got activated. By VW means You need to buy whole VW retrofit kit.
I THINK!!! it is this code for You: 5G1 054 691 A
And once again, licence needs to be transfered to car.
Read here my strory of adding cruise to car with stalk cruise:
