Successful battery change and coding - 2016 Skoda Fabia 1.2MPi
Chris1.21GW
England
C?ID=426851
I wanted to replace the battery in my 2016 Skoda Fabia 1.2 MPi. I changed the battery to a non VAG after market type and coded the car using VCDS. Here are some notes that may benefit others to do similar :)
  • The symptoms of the old battery failing were the start/stop function only working very infrequently and the car nagging about '12V battery almost empty'.
  • Old battery was a 59Ah EFB MOLL.
  • New battery was a 60Ah AGM YUASA. The change to AGM wasn't my original intention, but my motor factors had a good deal on. My understanding is that AGM technology provides superior performance for start/stop over EFB.
  • Whilst I changed the battery I didn't keep the 12V held up. The car didn't lose anything e.g. the radio code.
  • I disconnected the battery current sensor plug whilst I performed the battery change.
  • Looking at the auto-scan results I determined my J367 battery module was accessed through the can gateway 19 and using the UDS protocol.
  • I adapted the following channels:
    • UDS Adaptation Channel (15B): IDE03256-MAS06107-Battery adaptation-Battery manufacturer Stored value MLA (I left this set to MLA because I didn't know if there was a 3 letter code for YUASA, and I also suspect this doesn't actually change anything the J367 module does).
    • UDS Adaptation Channel (15B): IDE03256-MAS06108-Battery adaptation-Battery Serial Number Stored value MLA160318I (I incremented that last numeric to read MLA160319I - my understanding is this tells the J367 module to learn about the new battery).
    • UDS Adaptation Channel (15B): IDE03256-MAS06106-Battery adaptation-Battery technology Stored value EFB (Changed to Binary - AGM).
    • UDS Adaptation Channel (15B): IDE03256-MAS06105-Battery adaptation-Rated battery capacity Stored value 59 Ah (Changed this to 60Ah).
  • I test drove the car with the new battery and no J367 adaptation - result was the start/stop didn't work, however the car cranked a lot quicker at key-start.
  • I test drove the car with the new battery after J367 adaptation - result was start/stop worked after 0.6miles/3mins town driving. I think this before/after adaptation test shows the process has worked.
  • Thanks to Ross-Tech for their high quality product & support :thumbs:
Mika_M
Finland
C?ID=183725
FYI, factory setting in this channel for AGM batteries is "Fleece". Don't know if there is any difference or not between those.
  • Agree
That's my understanding as well, and I have no clue what "Binary - AGM" is.
Chris1.21GW
England
C?ID=426851
Thanks Mika_M & Uwe. I'll re-code as suggested.
rawrmcrawrrawr
C?ID=286791
Can I offer a suggestion to Ross-Tech? I see a lot of people selecting "Binary - AGM", when the correct setting for AGM batteries is "Fleece". In some of your competitors' products, "Binary - AGM" is listed as "Bipolar - AGM" instead. Is it possible to change the translation in VCDS from Binary to Bipolar so less people will make this mistake?
I suspect people will still focus on "AGM", not whether it's "Binary" or "Bipolar".
