[Audi A6 C7] close trunk with foot gesture (motion sensor)
yelonek
Poland
C?ID=421197
Hi,
is there a way to enable close the trunk with foot gesture, motion sensor?
Right now there is no problem to open trunk this way but I would love the option to close it same way.
kczach
C?ID=123637
Trying to resurrect this post. I would also like to be able to close the trunk with a foot gesture. Anyone figured this out??
I'll give you one guess :popcorn:as to what you should do next if you would like the membership to evaluate your vehicle.
kczach
C?ID=123637
This has been asked by others with autoscans. Use has commented in the past regarding my posts. Just curious if any progress has been made. I know you are probably of no help stefdds but here you go. You get more accomplished if you ask nicely instead of being a smart ass.
License Plate: 12345
Mileage: 35997km-22367mi Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
44 46 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 A9 BA
VIN: WAUHFAFC4HN122204 Mileage: 35997km-22367miles
Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 D HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0002
Revision: NCH63---
Coding: 0A2500326546010E3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
ROD: EV_ECM40TFS0114G0906014D.rod
VCID: 234F11CC2A14479C3F-8076
Part No SW: 4G0 927 166 F HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H06 0007
Revision: --H06---
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 3065EE806BE2EC04B2-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 65BED449A67D2B929B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 4183BB44D048758C4D-8014
Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
Component: BCM2 2.0 H61 0825
Coding: 0DA86F4E000000000000
VCID: 00057E4093C2BC8402-8054
Serial number: 3217000044182016
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 05041700040969
Coding: 688130B85D0000
VCID: 6AD13CE88DBE56D4BC-803E
Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0368
Revision: 2102003S Serial number: 00001631940501
Coding: 018D0033003C9FF2F98148C7A0003800CF9CD208AE08022180000884F10017020060002D0B0000
VCID: 79F313A4F018ED4C45-802C
Component: WWS57X 170301 H38 0080
Serial number: 170308110529
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20172518X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AN HW: 4G0 941 531 AN
Component: E1 - LDS H07 0044
Serial number: 29 03 2017 00000451
Component: USHL4.2 H30 0030
Serial number: 00000000095Z02D5DBEB
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA127015000030971731
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 37284C9800PAG0MUFU03
Component: ACC3 H21 0055
Coding: 7E01010102
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
VCID: 295303E448389DCC75-807C
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0092
Revision: -------- Serial number: 003G0003ZU67
Coding: 303331343135303334354A55304C34473053
VCID: 346DE2909FFAD024D6-8060
Component: BF-Gewichtss. H15 0046
Serial number: 6940000Y170001L1E40G
Serial number: 3575HRB405T4CVFI58VM
Serial number: 3585HRB405T468HIC91H
Serial number: 3515JRB400U599TUIH3A
Serial number: 3525JRB4014599TUE0TY
Serial number: 3554VRB400659I8MP24H
Serial number: 3564VRB400459I8MS96S
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372QD40000S
Coding: 0004FC
VCID: 3875D6A08B923444FA-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 11 01 2017 C0010692
Part No SW: 4G0 920 982 S HW: 4G0 920 982 S
Component: TBenUsaAccNv H15 0225
Revision: 15001309 Serial number: 658050417596017
Coding: 03CF0905BF51D705020200
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 3C7DCAB0B7AA18641E-8068
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Revision: -------- Serial number: 00000002573622
Coding: C0ED074814
VCID: 3D7BC7B4ACB0116C29-8068
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 0986723504
Voltage stabilizer:
Serial number: 17012100000000000169
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0E0100
VCID: 3A71CCA8B59E26540C-806E
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
VCID: 67D745DC96AC6BBCA3-8032
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H19 0200
Serial number: 003003170001009
VCID: 285506E05332A4C46A-807C
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 04041700041266
Coding: 20
VCID: 3E79C0B8A1B60A7430-806A
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008006
ROD: EV_AirSuspe_VW51.rod
VCID: 2F67EDFC76DCF3FCAB-807A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000250158008
VCID: 77F7159CC60CFB3C33-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02RDES
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3777D59C8E8C3B3CF3-8062
Component: SWA Master H08 0070
Serial number: 0437049975
Coding: 040211
VCID: 3973D3A4B8982D4C05-806C
Component: SWA Slave H08 0070
Serial number: 0436831968
Coding: 040211
Component: TSG FA H04 0511
Coding: 011F17015E00628002000013
VCID: 458BAF54CC6059AC71-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000689500
Coding: 011001010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A71CCA8BD9E26540C-806E
Revision: 00002001 Serial number: 0437268663
Coding: 0106063A00FA718581B0088402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000392588
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST001J0OFN00000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00032177956
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 6600213=
Component: TSG BF H03 0511
Coding: 011F17015E00628002000002
VCID: 4689A858F16652B478-8012
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002154574
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
VCID: 3261E48865EEDE14C4-8066
Component: MxB-ECU 001 0100
Coding: 04FA0A1122600400
Coding: E01E00
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 D HW: 4G1 035 025 C
Component: MU-H-LNS-US 053 0902
Serial number: A741C0H7535311
Coding: 017551020000000013220002041A00102F0007E5F17001047E
VCID: 1F471D3C067C637C1B-804A
Subsystem 1 - Part No SW: V03 959 802 DM HW: -----------
Component: NAR 2019/2020 --- 0072
Multimedia System 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9HY807NQ1
Serial number: 90349QD60002J
Compact disc data bank:
Component: Gracenote2--- --- 3011
Component: TSG HL H03 0511
Coding: 010F17004000628002000002
VCID: 4993A364E078BDCC95-801C
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0380
Revision: 11001001 Serial number: 82330JG0394149
Coding: 0212000101010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
Part No SW: 4G5 959 107 C HW: 4G5 959 107 A
Component: HDSG-Modul H02 0049
Revision: 13002001 Serial number: 056700456
Coding: 111104C120
ASAM Dataset: EV_HDSGAu571 001022
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0511
Address 82: Heads Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H09 0306
Coding: C60000
ASAM Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7.rod
VCID: 356BDF949480C92CE1-8060
Component: DPC-SG H28 0081
Coding: EA060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C5DFAF047CA88E48E-8078
Coding: 7E01010102
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
VCID: 275705DC5E2CABBC63-8072
Component: BV-SG H34 0090
Serial number: 005002450204177
Coding: 04C1BA1B0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H16 0080
Coding: 0066E608031F0376070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3163EB8460E8E50CBD-8064
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 170307200507
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813008226001
ROD: EV_AEMLearAU64X.rod
End-------
