Passat B8 2017 Discover Media Error
chr
Romania
C?ID=79671
In the last week I saw an error on my Discover Media, after software update on Address 13: Auto Dist. Reg
Friday,26,February,2021,19:03:13:64418
VCDS Version: 20.12.0.1 (x64)
Dealer/Shop Name: OGP Workshop
Workshop Code: 599 04605 001093
VIN: WVWZZZ3CZHE0xxxxx   License Plate: x04xxx
Mileage: 152409km-94702mi   Repair Order: First
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 6C
VIN: WVWZZZ3CZHE0xxxxx   Mileage: 152409km-94702miles
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0195
   Coding: 3200670351FFC428949C8045
   Shop #: WSC 01093 599 04605
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 354FEF1194BAD42320-8060
                Address 5F: Information Electr.       Labels: 5G0-035-MIB-STD2.clb
Control Module Part Number: 3Q0 035 846 A    HW: 3Q0 035 846 A
  Component and/or Version: MU-S-N-ER     H30 0363
           Software Coding: 02840101FF0000005111000100080A001F01008401200100CF
            Work Shop Code: WSC 05311 115 00090
              ASAM Dataset: EV_MUStd4CTSAT 001022 (VW48)
                       ROD: EV_MUStd4CTSAT_VW26.rod
                      VCID: 2F43DD7976E6EEFCAB-807A
          B2000 87 [009] - Missing message
                    Reset counter: 210
                    Mileage: 152634 km
                    Date: 2021.02.26
                    Time: 18:55:10
                    Voltage terminal 30: 12.1 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
Fault number (is not very different) but description is different with other scan tool and say ,,00614 [1556] B200087 - Control module. Cruise Control module (Control module, software incompatible).
Previously Address 13: Auto Dist. Reg had:
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B                   561 E
   Component: ACC BOSCH MQB H04 0194
   Shop #: WSC 05311 115 00090
   VCID: 3449D2159FC0CD24D7-8060
After clearing the error, the error reappears. Seems to be because of ADR software update. Does anyone know what needs to be done? Maybe it is necessary to make a new adaptation in 5F?
@chr : Hi. I'm not sure that a fault involving a memory check-sum error can be fixed by "mak[ing] a new adaptation in 5 F".
In your context, check-sums are a sort of mathematical verification process that is performed on a data stream when software is being loaded to make sure that the Bits in the binary code don't get flipped accidentally during transfer from one device to another.
What usually happens with this facility is that the data being transferred has its own check-sum value, which is made-up from the pattern of ones-and-zeros from ALL the Bits in the software update. When the upgrade is completed, a second check-sum is calculated from the data-stream that has been received. The two check-sum values are then compared to test that the received data faithfully reflects the sent data. In your case - the 2 x check sums haven't agreed.
So, the existence of a check-sum error suggests (to me at least) a problem with the software upgrade process. Perhaps you should make your problem the problem of the agent who installed the update. My motto when I have paid someone for a service - a problem shared is a problem abrogated !! :)
Spacewalker
Poland
C?ID=159607
CHKS error in Technisat unit is because of software (system files) corrupted
it happen after unlock, or activate function.
after "bad" hack, errors can back after coing or adaptation changes , or any changes from radio
  • Agree
Reactions: chr
chr
Romania
C?ID=79671
Indeed, Technisat was updated from SW P0356T to P0363T.
Maybe is necessary to make another update?
