Interior lights on when turning off ignition
Andy4195
Yorkshire, UK
C?ID=426740
I have a 2017 SEL VW Tiguan. I have noticed that when I push the button to turn the car off, the interior lights do not come on, which leaves me sitting in a dark car trying to gather my stuff like keys and bag in the dark until I open the drivers door, I’ve looked on car settings but not found anything just wondering if anyone has seen anything on vcds that I can change, it really annoys me , all I want is interior lights on when I turn ignition, any help greatly appreciated on this issue.
Bruce
Near Philadelphia, PA, USA
Please post an autoscan so we can know how the specific modules in your Tiguan.
Andy4195
Yorkshire, UK
C?ID=426740
Sunday,28,February,2021,13:31:35:61337
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: WVGZZZ5NZHW414411   License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 4B 52
          5F 6D A5 BB BC CA D6 D7
VIN: WVGZZZ5NZHW414411   Mileage: 40127km-24933miles
39-Right Light -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3617
   Revision: B4H25---
   Coding: 0125001203661D083000
   ASAM Dataset: EV_ECM20TDI01104L906026HT 004003
   ROD: EV_ECM20TDI01104L906026HR_004_VW37.rod
   VCID: 0353848D3B9BE1836E0-8056
17167 - Databus
17158 - Databus
28991 - No Communications with NOX Sensor 1
          U029D 00 [032] - -
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2012
   Revision: 00H06V07
   VCID: 3333144D2BBB9103BE0-8066
   Revision: 00000000    Serial number: 60627000001365
   Coding: 0AEE929A34210B70477B070162C44950492CD0E2E046927D38625078C22A4200002F641A1B13111435351919323200
   VCID: 77ABE05D7F43BD23428-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0435174247
   Coding: 032C2C070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3C213F7106E55E7B6FA-8068
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98148664
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to temp low voltage]
                    Fault Frequency: 16
                    Reset counter: 121
                    Mileage: 39398 km
                    Date: 2020.11.30
                    Time: 10:05:48
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: On
                    Terminal_50_Kessy_actual_value: On
                    ZAT_pressed: On
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 9.367 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 151.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000E00435660
   Coding: 0012012420211001110510000010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   VCID: 4ACD69A95C31F0CBED6-801E
   Humidity sensor: exterior:
   Rear A/C control head:
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Fault Frequency: 24
                    Reset counter: 123
                    Mileage: 38793 km
                    Date: 2020.10.02
                    Time: 08:29:52
                    Voltage terminal 30: 14.2 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.val.: 2
                    Auxiliary heater: in stages-Target value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001706104738
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B087D577385630A8-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 170130  033 0372
   Serial number: 00000001701250302811
   Component: RLHS  042 0105
   Serial number: S3Y17M03D07H16M53S23
   Coding: 00A8DD
   Serial number: 000000000ZY17032197G
   Serial number: 00000000000068601356
0263 - Supply Voltage for Interior Lights
          B1314 11 [008] - Short to Ground
                    Reset counter: 123
                    Mileage: 40127 km
                    Date: 2021.02.28
                    Time: 10:16:29
          B1263 01 [008] - Electrical Failure
                    Fault Frequency: 35
                    Reset counter: 100
                    Mileage: 37943 km
                    Date: 2020.08.31
                    Time: 15:04:07
197904 - Central Locking
          B140A 4B [008] - Over temperature
                    Reset counter: 118
                    Mileage: 39854 km
                    Date: 2021.01.29
                    Time: 18:11:19
934149 - Rain/Light Recognition Sensor
          B1366 76 [008] - Wrong mounting position
                    Reset counter: 113
                    Mileage: 39735 km
                    Date: 2021.01.08
                    Time: 15:15:48
   Part No SW: 3QD 919 294 A    HW: 3QD 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 000901178877031
   Coding: 0071451811
   ASAM Dataset: EV_EPHBO18VW481CN00 001007
   ROD: EV_EPHBO18VW4810000_VW37.rod
   VCID: 4BC36CAD534BE9C3D60-801E
1112561 - Parking Sensor; Front Right Center
          B10F9 F1 [008] - Reverberation Time too Long
                    Reset counter: 113
                    Mileage: 39743 km
                    Date: 2021.01.08
                    Time: 17:36:24
10494464 - Function Limitation due to Environmental Factors
          B2022 00 [008] - -
          [Geber für Einparkhilfe - Schmutz bzw. Eisbildung]
                    Reset counter: 118
                    Mileage: 39743 km
                    Date: 2021.01.08
                    Time: 17:36:24
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320147C158FF8728749C8065804085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 3B233C6D03EB5943660-806E
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
                    Reset counter: 99
                    Mileage: 39372 km
                    Date: 2020.11.24
                    Time: 09:52:49
                    Voltage terminal 15: 14.8 V
                    Control Module temperature: 35 °C
                    Velocity_vehicle_reference: 1.08 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.66 m/s²
2071 - Databus
          [FAULT_VDIS_PLAUS_FAIL]
                    Reset counter: 120
                    Mileage: 39872 km
                    Date: 2021.02.05
                    Time: 08:46:31
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 55 °C
                    Longitudinal_acceleration_vehicle_reference: 0.16 m/s²
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Reset counter: 121
                    Mileage: 39745 km
                    Date: 2021.01.09
                    Time: 13:47:06
                    Voltage terminal 15: 9.8 V
                    Control Module temperature: 1 °C
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2PGD0%
   Coding: 98CCC0C00C0000005C5400CF008800000065
   VCID: 1079BBC17AED8A1BE32-8044
   Left seat belt tensioner:
   Serial number: 5NC857705C0048R00191
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 5NC857706C0059R01901
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 803 17
   Serial number: 357000000009B9DC202U
   Subsystem 4 - Part No SW: -----------    HW: 480 000 803 17
   Serial number: 358000000008B9DC202U
   Subsystem 5 - Part No SW: -----------    HW: 480 400 203 17
   Serial number: 3510001B3249E3C6234/
   Subsystem 6 - Part No SW: -----------    HW: 480 400 603 17
   Serial number: 35200019925ACAB3E4DR
   Subsystem 7 - Part No SW: -----------    HW: 480 402 802 17
   Serial number: 3550001C124996D1A5CC
   Subsystem 8 - Part No SW: -----------    HW: 480 400 203 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001A125ACAB553BC
   Subsystem 9 - Part No SW: -----------    HW: 480 400 203 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A125ACAB436FH
   Subsystem 10 - Part No SW: -----------    HW: 480 400 203 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A125ACAB544E8
   Subsystem 11 - Part No SW: -----------    HW: 480 000 303 17
   Serial number: I0M000000003AADCA12F
   Subsystem 12 - Part No SW: -----------    HW: 480 000 303 17
   Serial number: I0N00000000E1DC80227
   Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20170304300068
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7EA5F57950798C6B01E-802A
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         408 2170
   Coding: 23A500186F84060001886B031401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 41DF4E85610733933CC-8014
10485826 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
          [Steuergerät defekt (CRC Check ROM)]
                    Mileage: 10415 km
                    Date: 2017.11.26
                    Time: 14:27:09
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 80
                    Mileage: 39873 km
                    Date: 2021.02.05
                    Time: 10:41:33
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 122
                    Mileage: 40071 km
                    Date: 2021.02.27
                    Time: 13:06:35
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0006011697
   Coding: 030500045F087300FB07225E1E0F00010001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3B183DC793B5E3DA8-807A
   Generator:
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0661712552001266AS2B
   Coding: 2D0000
   Serial number: 2580193204
9175296 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
                    Fault Frequency: 29
                    Reset counter: 123
                    Mileage: 36412 km
                    Date: 2020.07.31
                    Time: 15:21:31
                    Terminal 30 power supply: 12.9 V
                    Terminal 15: On
   Serial number: HA1-00006.02.17
   Coding: 0101
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH07 0014
   VCID: 45D75A95752F1FB3004-8010
   Serial number: 17000050798001
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFDE451127E3138CC-8024
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 123
                    Mileage: 39570 km
                    Date: 2020.12.10
                    Time: 16:35:08
   Serial number: 210217EBK27499
   Coding: 003F1A20D001048000001000
   VCID: 43D3448D7B1B21832E0-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 18021710803227
   Coding: 000000050100085600104F010A0000000000000000000000000000000000
   VCID: 72BDD1491421D80B756-8026
13706001 - Databus
          [Kamera_FDD_Funktionsstatus_Blind received error value]
                    Reset counter: 113
                    Mileage: 39715 km
                    Date: 2020.12.30
                    Time: 20:45:32
   Serial number: 220217EBM2608A
   Coding: 003F1020DE01048000001000
   VCID: 42DD41896401288B256-8016
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF00000051110101008808001F0100E6012000008F
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 313F1E45D1A7A313CCC-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL07RAX
   Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31208900000000
   Coding: 0A28
   Serial number: 06031712K20087
   Coding: 0003070600000401000213448050A90094000E200040
1123202 - Databus
          [RLS_01_RS_Regenmenge]
                    Reset counter: 113
                    Mileage: 39735 km
                    Date: 2021.01.08
                    Time: 15:15:48
                    Control Module temperature: 6 °C
                    Outside temperature: -1.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 426.9 s
                    Voltage terminal 15: 14.2 V
                    mid: 02 C1
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1275 - Unknown Error Code
          B182E F0 [024] - Unknown Error Elaboration
                    Reset counter: 78
                    Mileage: 36403 km
                    Date: 2020.07.31
                    Time: 15:07:33
                    Control Module temperature: 60 °C
                    Outside temperature: 27.0 °C
                    Vehicle speed: 7.84 km/h
                    System run time: 1116.0 s
                    Voltage terminal 15: 13.1 V
                    mid: 01 62
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 070217EB509682
   Coding: 002A10200100048000001000
   Serial number: 080217EB61238C
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 308040732602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D2732751DFF5773584-8068
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675CDD95809642BB9E-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:18, VBatt start/end: 12.8V/12.9V)-----------
myounus
Northwest UK
C?ID=321059
Supply Voltage for Interior Lights - check your fuses!
@myounus: Maybe
Is the interior light fused on a MY17 Tiggy, or is it protected by the BCM? I don't know, but I suspect the latter given that this BCM is the newer type with a zero long-code string!
Anyhow, the "Short to Ground" in the DTC descriptor kind-of suggests the opposite, maybe?
@Andy4195: Is there a back-story to this fault? Perhaps wiring changes, or lamp replacement?
The "short-to-ground" suggests a physical problem (to me, at least)- if the interior lamp is incandescent, maybe the filament has short circuit? Otherwise, check the wiring/lamp-base for damage causing electrical failure.
Andy4195
Yorkshire, UK
C?ID=426740
Thanks for the reply but the puzzling thing is the fact as soon I open the drivers door the light illuminates , also when I unlock the car and open door light illuminates, my previous model was a key and the interior lights came on straight off the key being turned off.
South Molton, UK
The previous model will have had different electronics and firmware, seems VAG have changed the default behaviour (not for the better?).
The puzzling thing is the fact as soon I open the drivers door the light illuminates , also when I unlock the car and open door light illuminates, my previous model was a key and the interior lights came on straight off the key being turned off.
Andy: The descriptor on the DTC does say that your interior light problem is Intermittent - Confirmed - Tested Since Memory Clear.
So the fault might not manifest all the time- maybe?
Also, likely the overhead lights on your Tiggy will be made-up from the driver + passenger reading lights + the general front cabin lamp + maybe the rear cabin lamp. Are ALL these lamps illuminated?
Finally - any update on my back-story request?
Andy4195
Yorkshire, UK
C?ID=426740
Thanks for reply both lights above rear view mirror are working off the doors and manually, also the two rear lights either side are coming on and on with doors and on unlock, I’m beginning to think as someone mentioned Vw may have changed something with the models using push button start.
dark5had0w
Australia
C?ID=356542
does the same thing in my car (MY17 Skoda Superb).
interior lights don't illuminate until a door is opened. ignition off does nothing.
likewise, infotainment remains on until a door is opened.
previous MY11 Skoda Octavia would illuminate interior lights as soon as ignition is turned off.
would b nice if it behaved the same.
