2019 GTI - NEED HELP with starting vibration reduction , torque limitation on launch and esc off
Mk7.5gti2019
Los Angeles, USA
C?ID=424896
hi there guys I was wondering if anyone has figured out the long coding for the 2019 gti to do the following
1) esc off /sport selection in MIB
2) torque limitation on launch off
3) starting vibration reduction off
I have tried some older coding and I couldn’t even get access to long coding at all for my abs module so I’m not even sure how I would change the settings I want to.
Westbury, UK
Without seeing a full unedited VCDS Auto-Scan of your GTI any replies would be nothing more than guesswork :popcorn:
Mk7.5gti2019
Los Angeles, USA
C?ID=424896
Saturday,01,May,2021,17:05:59:59136
VIN: 3VW6T7AU0KM033816   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 14 15 17 19 29 2B 32 39 3C 42 44 47 4B
          52 5F 75 A9 D6 D7
VIN: 3VW6T7AU0KM033816   Mileage: 32357km-20105miles
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFS   H13 0007
   Revision: --H13---
   Coding: 092500124424012F1000
   Shop #: WSC 00066 790 00235
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001008
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C213FA266E5D7EB93B-8068
14916 - Catalyst System; Bank 1
          P0420 00 [237] - Efficiency Below Threshold
                    Mileage: 32250 km
                    Date: 2021.04.29
                    Time: 23:09:31
                    Engine RPM: 1495.50 /min
                    Normed load value: 29.4 %
                    Vehicle speed: 88 km/h
                    Coolant temperature: 102 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 14.160 V
                    Engine: operating status: PL
                    TEMP_CAT_UP_1_SAE: 595.6 °C
                    Cat. ageing: bank 1: actual: 1.203
                    LAMB_DELTA_I_LAM_ADJ[1]: -0.00165
                    Lambda probes actual: bank1: 1.0723
                    VLS_DOWN_SAE[1]: 0.040 V
                    T_AST_SAE: 1008 s
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2404
   Revision: 00H06V10
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2615FDCA88697D3BD5F-8072
   No subsystems:
   Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
   Component: ESC           H45 0108
   Revision: 00000000    Serial number: 52119000001300
   Coding: 01FA6BA15023216F807F020160C96880D60A840140061676104150D1D0894B0B0000000012121212B835351919323200
   Shop #: WSC 00066 790 00154
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 045187425E956F2BABB-8050
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0522155461
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D75A46152F9623FC5-8010
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110001000000000010004
   VCID: 4CC16F623645676B23B-8018
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86431081901QX
   Shop #: WSC 00066 790 00245
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7BA3FCBE236B10D3DA1-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190625  043 0551
   Serial number: 97022066190704214854
   Subsystem 2 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  051 0206
   Serial number: S7Y19M07D15H14M26S49
   Coding: 0008DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691600202012180052
   Coding: 181803
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300280820190C200674
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 207
                    Mileage: 31838 km
                    Date: 2021.04.25
                    Time: 15:56:34
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3500008101FFC728949C810500401600000000000000000004
   VCID: 44D147421E15AF2BEBB-8010
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 206
                    Mileage: 31805 km
                    Date: 2021.04.25
                    Time: 14:56:12
                    Control Module temperature: 26 °C
                    Voltage terminal 15: 13.2 V
   Serial number: 01071941350040
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382923B252DDFBCB773-806C
   Serial number: 003GCR0C9CLQ
   VCID: 47CB504E2F2384330E9-8012
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000BYGWAK
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 307 19
   Serial number: 35700000000257492E3I
   Subsystem 3 - Part No SW: -----------    HW: 480 001 007 19
   Serial number: 358000000008D8ECCD3D
   Subsystem 4 - Part No SW: -----------    HW: 480 401 507 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001ACF08AF85D7D/
   Subsystem 5 - Part No SW: -----------    HW: 480 401 607 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001C6F092D95527A
   Subsystem 6 - Part No SW: -----------    HW: 480 402 507 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001C8F0A2E1152DB
   Subsystem 7 - Part No SW: -----------    HW: 480 402 507 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001C6F0A2E188409
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 0BAD091AB988CF0502886B0950000000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2F3B18EEA7933C73269-807A
   Serial number: 11081900841760
   Coding: 030100047F085900FB00006B9C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C5EA6019757B6DF-803A
   Generator:
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001147540039214
   Coding: 29FFFF
   Serial number: 0625216800
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 8
                    Reset counter: 9
                    Mileage: 32039 km
                    Date: 2021.04.26
                    Time: 06:01:24
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000197473011
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1E96B1A72A8330D-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00022.05.19
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD711AD461319B697-8006
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0521564614
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2732A67DFFDEE3A45-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0525188132
   Coding: 010111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038921703184
   Coding: 003E13200000040000000000
   Shop #: WSC 01383 790 50316
   VCID: 4FFB786EC7535C73469-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000003948712
   Coding: 011000
   Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F97B12DA6D438B5F3-8004
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05RRRP
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E0505EAA099357B2DF-807A
   Component: FCM MQB Low   002 0345
   Serial number: 05081900841699
   Coding: 000000050900214A07110F00030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 35372A8645CF06A36C5-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038921802695
   VCID: 4EC5656AC059557B4DF-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000003967596
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     724 0890
   Coding: 027310000000000041220002001808009F0503F40120050002
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  254 8130
   Serial number: VWZ6ZMW2395082
   Component: OCULowMQBUS   009 0570
   ROD: EV_OCULowMQB.rod
   VCID: 43D3445E1B1BA813D21-8016
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 190415202381
   VCID: 323D119AB4A1119B497-8066
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F26B669D7E2C388D-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.2V)-----------
downtime
Finland
C?ID=280813
Can you post adaptation map from ABS module. I’ll give you ABS coding for the ESC in a minute.
EDIT:
Put this as ABS coding and it should give you ESC ON / ESC SPORT / ESC OFF
01FA6BA15023216F807F020160C96880D60A840140061676104150D1D0864B0B0000000012121212B835351919323200
Mk7.5gti2019
Los Angeles, USA
C?ID=424896
EDIT:
Hey thanks I’ve successfully done the long coding and gotten the esc off option but I’m still seeing the esc light blink at me one launches.
Is there another option I’m supposed to mess with ?
on mk7 ppl were messing with “starting vibration reduction” and “torque limitation on launch”
for mk7.5 we only have “rough road optimization” and even with that off I still see intervention on launch
any ideas
downtime
Finland
C?ID=280813
And you have turned ESC off either from MIB or by long press of ESC button?
