- Mar 2, 2021
- 2
- 1
- Helsinki, Finland
- C?ID=287891
Hello all!
My first (finally) post on these forums. Apologies if I forget something.
We are working on our customers 2011 Skoda Octavia 1.4 TSI which has quite an interesting problem. The car came to us with a stretched timing chain (surprise) which was changed with no trouble. After the mechanic was done with the timing chain and was about to go for a test ride - the dashboard was completely dead. He checked all the basic things like fuses and so on, which were ok. He then had this kind of weird idea, that he'll take a dashboard from another octavia which we were working with and see if it works in this car. Well it worked. He then installed back the original dashboard which started to work as well. Weird enough, after this the ABS-unit had lost it's coding (the other dashboard has something to do with this?). Obviously he didn't have autoscan from this car before he started to work with the timing chain. I gave the car to another mechanic with a bit more VCDS experience, who then found some working code from the internet. We got the car up and running, but our problem now is that the new code he found doesn't have Start & Stop system in it and the car is giving us Start & Stop system error all the time (and the customer is not happy). He has tried different codings with no luck.
So, I was wondering that could I get any help from here before I have to take the car to Skoda. Millions of thanks in advance.
Here's the autoscan (with the wrong abs-unit coding):
Tuesday,02,March,2021,18:05:56:58505
VCDS Version: 21.3.0.0 (x64)
VIN: TMBHJ61Z7C2059829 License Plate: GKH
Mileage: 176250km-109516mi Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 69 77
VIN: TMBHJ61Z7C2059829 Mileage: 176250km-109516miles
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 CL HW: 03C 906 016 CL
Component: 1.4l R4/4V TS H15 0914
Revision: L5H15--- Serial number:
Coding: 00190032002401000000
Shop #: WSC 73430 031 00066
ASAM Dataset: EV_ECM14TFS01103C906016CL 001004
ROD: EV_ECM14TFS01103C906016CL.rod
VCID: 6BD44252826179D306-803E
Readiness: 0000 0100
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 113B201C09270003881304E690220040300000
Shop #: WSC 73430 790 00066
VCID: 7BF47212FA01E95396-802E
03306 - Coding Not Valid
Reset counter: 179
Mileage: 176252 km
Date: 2015.07.24
Time: 17:52:54
Count: 3
Count: 2
Count: 12800
Count: 4161
Count: 51968
Count: 253
Reset counter: 179
Mileage: 176252 km
Date: 2015.07.24
Time: 17:40:57
Count: 3
Count: 2
Count: 29184
Count: 8192
Count: 52224
Count: 253
Part No SW: 3T0 820 047 AD HW: 3T0 820 047 AD
Component: AC Manuell H19 0502
Revision: 00001010
Coding: 0000000003
ROD: EV_ACManueBHBVW36X_VW46.rod
VCID: 71E8503AA04D93033C-8024
Part No SW: 1K0 937 087 R HW: 1K0 937 087 R
Component: BCM PQ35 H+ 110 0651
Revision: 00110 AC
Coding: 40000AB8E005089040080080510001E4437000AE626D8D605C85C7000041
VCID: 408EC5FED3674A8B83-8014
Subsystem 1 - Part No: 1Z1 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 06091 26 0601
Coding: 00D7B7
Component: RLS 310811 05 54 0403
Coding: 0730ED
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32901125300579
Coding: 11000E
Shop #: WSC 13765 790 00066
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000_001.rod
VCID: 33649A329AD1E1130E-8066
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2SSXLW
Coding: 0020790
VCID: 3D70BC0A64952763E8-8068
Subsystem 1 - Serial number: 6332MSME6226347FG
Subsystem 2 - Serial number: 6342MSME62260B649
Subsystem 3 - Serial number: 6351HSME28776F15I
Subsystem 4 - Serial number: 6361HSME28781B5AK
Part No SW: 5K0 953 521 BL HW: 5K0 953 569 C
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110913301346
Coding: 5080140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 77FC6E22CE29CD33F2-8022
Part No SW: 1Z0 920 843 Q HW: 1Z0 920 843 Q
Component: KOMBI H05 0607
Coding: 110E01
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 4682D3E6F94364BBB9-8012
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 260811F2000756
Coding: 352302
VCID: 377CAE2286A90D3332-8062
Component: IMMO H05 0607
VCID: 6ADA47568D9B60DB7D-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2119
Coding: 0131188
VCID: 489EDDDE3B5772CB4B-801C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 68 3201
Revision: 00H20000
VCID: 3466992E57DFE62B17-8060
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131188
VCID: 479CDEE236497DB342-8012
Part No SW: 1Z0 035 161 M HW: 1Z0 035 161 M
Component: Radio-SWING 001 0003
Revision: -----03S Serial number: SKZ4Z2L1376462
Coding: 0D0004000001
VCID: 387EAD1E8BB7024B3B-806C
Reset counter: 206
Mileage: 176069 km
Date: 2015.07.13
Time: 09:23:14
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 032B7864
VCID: 71E8503AA84D93033C-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900182731
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000155226978
Coding: 410D000100000000
VCID: 306E953E63C7DA0B73-8064
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660792535
Coding: 0201000000010110
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA_A01_VW25.rod
VCID: 275C7E625E099DB3A2-8072
End-------------------------(Elapsed Time: 02:26)--------------------------
