Monday,01,March,2021,10:15:04:07369
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 20.12.0.0 (x64) HEX-V2 : 0.4529.4
Data version: 20201124 DS322.0
VIN: 3VW5T7AU0HM034646 License Plate:
Mileage: 134128km-83343mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW5T7AU0HM034646 Mileage: 134128km-83343miles
03- Brakes -- Status: OK 0000
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091900122424002F0000
Shop #: 00066 790 00149
Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 372B2090AFCC4823829-8062
17178 - Databus
15202 - Actuator Module for Turbocharger 1
P00AF 00 [237] - Stuck
Mileage: 134126 km
Date: 2021.02.28
Time: 11:31:14
Engine RPM: 2895.00 /min
Normed load value: 21.2 %
Vehicle speed: 28 km/h
Coolant temperature: 52 °C
Intake air temperature: 25 °C
Voltage terminal 30: 13.671 V
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
Charge air pressure control valve uncond voltage sensor: 2.4121 V
Charge air pressure control valve position: target value: 99.99 %
Charge air pressure control valve position: actual value: 43.39 %
Charge air pressure control valve activation pulse duty factor: 58.33 %
Charge air pressure control valve voltage: position closed: 3.7146 V
STATE_BPA[0]: OPM
Address 03: Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component: ESC H62 0398
Revision: 00000000 Serial number: 52876000000708
Coding: 01FA6BA134230970407D020481C92980D62C90024081943400435050C00503
Shop #: 01383 790 50316
Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035.rod
VCID: 75B7EA98F540FA33505-8020
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 C HW: 5GM 907 426 C
Component: AC Manuell H03 1601
Revision: 00001K03
Coding: 00020004200100000000000000000002
Dataset: EV_ACManueBHBVW37X 004132
VCID: 48C9536CD23237DBFB3-801C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Component: PQ37BOSCH 028 0162
Revision: -------- Serial number: 8658201016007F
Coding: 000008464041804969E44000001407201000000000000000000000000000
Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
VCID: 7AADF9A4DC5E954B3D7-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160924 043 0581
Serial number: 161201160959
551445 - Databus
12307 - License Plate Light
B12CA 01 [008] - Electrical Failure
Fault Frequency: 104
Reset counter: 178
Mileage: 128143 km
Date: 2020.10.05
Time: 14:08:55
204546 - Remote key 2
B147A 18 [008] - Current Too Low
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR068AA6
Dataset: EV_AirbaVW20SMEVW37X 002144
VCID: 47CB5050DF2C38A3F29-8012
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000064VJI
Coding: 30305A
Subsystem 2 - Part No SW: ----------- HW: 480 001 210 16
Serial number: 357000000000619CAE1P
Subsystem 3 - Part No SW: ----------- HW: 480 003 009 16
Serial number: 3580000000092C5C8E1-
Subsystem 4 - Part No SW: ----------- HW: 480 401 510 16
Serial number: 3510002A122C8EB3D3CG
Subsystem 5 - Part No SW: ----------- HW: 480 403 009 16
Serial number: 35200029B229A2E4A1FF
Subsystem 6 - Part No SW: ----------- HW: 480 402 410 16
Serial number: 35500029D2095074B2A1
Subsystem 7 - Part No SW: ----------- HW: 480 402 410 16
Component: FrontSensor_P 001 6149
Serial number: 35600029F2095075B15%
Part No SW: 5Q0 953 521 K HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20161104400871
Coding: 0400
Shop #: 66564 385 16448
Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3A2D39A49CDE554B7D7-806E
Part No SW: 5G1 920 856 B HW: 5G1 920 856 B
Component: KOMBI 344 8311
Coding: 0BBD0902A180CF0502086A001000000000000000
Dataset: EV_DashBoardVDDMQBAB 009051
VCID: 2D0702F85D90F2F3E85-8078
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 L
Component: GW Mid 211 2265
Revision: -------- Serial number: 02111610801909
Coding: 0101000830085900FB000028080F00000001050000000000000000000000
Shop #: 00066 790 00199
Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 7BA3FCA0D364AC43261-802E
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29160001958980016404
Coding: 30FFFF
Component: FS 020 0041
Serial number: 231116060503K9
Coding: 003E03200000020000000000
Dataset: EV_DCUDriveSideEWMAXKLO 006003
VCID: 43D34440EB1414832E1-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000004654944
Coding: 011000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8102
Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
Component: BFS 020 0041
Serial number: 141116060506ZT
Dataset: EV_DCUPasseSideEWMAXKLO 006003
VCID: 42DD4144F40E1D8B257-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000004722190
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035--STD2.clb
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0751
Coding: 02730000FF00000051220001001808009F0203D40120010002
Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9SJW01M46
B11CF 53 [009] - Deactivated
Reset counter: 6
Mileage: 128080 km
Date: 2020.10.04
Time: 00:34:04
Voltage terminal 30: 12.2 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Audio Signal: available.
SDARS_tuner_status_2-Antenna current: 139 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0570
Coding: 02730002C2821A017F1E06000000
Dataset: EV_OCULowMQB 001006
ROD: EV_OCULowMQB.rod
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 160830200204
Dataset: EV_SoundActuaGen2AU64X 003010
VCID: 6B83CCE0A3043CC3B61-803E
End----(Elapsed Time: 01:12, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
