Dashboard message: Gearbox malfunction (No reverse) but you may continue to drive. (It is not possible to drive at all).
The two circuit boards are replaced. Main electrical connector (female) replaced. Water cooling valve replaced.
Basic settings are not possible to conduct.
Can anybody advice me what to do next?
I got the following error codes:
Sunday,28,February,2021,20:25:13:63392
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4543.4
Address 02: Auto Trans Labels: 0B5-927-156.clb
Control Module Part Number: 4G1 927 156 B HW: 0B5 927 156 F
Component and/or Version: 0B5 30 TDIRdW H10 0003
Software Coding: 000001
Work Shop Code: WSC 02311 785 00200
ASAM Dataset: EV_TCMDL501 A02196 (AU57)
ROD: EV_TCMDL501.rod
VCID: 2C0100DA66844D6BFFA-8078
18003 - Gear Selector 2
P187B 00 [175] - Engagement not successful
Mileage: 309004 km
Date: 2021.02.27
Time: 05:18:19
Engine RPM: 1016 /min
Transmission input speed: 1016 /min
Engine torque: -4 Nm
ATF temperature: 54 °C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
18014 - Gear Selector 1
P187A 00 [101] - Engagement not successful
Mileage: 309004 km
Date: 2021.02.27
Time: 05:31:39
Engine RPM: 993 /min
Transmission input speed: 993 /min
Engine torque: 8 Nm
ATF temperature: 63 °C
8069 - Main Pressure Valve
P179C 00 [175] - Electrical Malfunction
Mileage: 309004 km
Date: 2021.02.27
Time: 05:18:15
Engine RPM: 122 /min
Transmission input speed: 122 /min
Engine torque: -44 Nm
ATF temperature: 55 °C
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 28 3B 3C 42 44 46 47
52 53 55 56 5F 62 69 6C 72 85 8B 8E 8F 90
VIN: WAUZZZ4G9CN160651 Mileage: 309004km-192006miles
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0005
Revision: 53H37---
Coding: 1225401A057601020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907401F 001005
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2615F2F27868773B29E-8072
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [036] - -
[Transmission control moduleplease read DTC]
Mileage: 309004 km
Date: 2021.02.27
Time: 05:31:39
Engine RPM: 1030.00 /min
Normed load value: 28.6 %
Coolant temperature: 71 °C
Intake air temperature: 16 °C
Voltage terminal 30: 13.280 V
Accelerator pedal: sensor voltage 1: 757.4 mV
Accelerator pedal: sensor voltage 2: 381.0 mV
Accelerator pedal: switch positions-Bits 0-7: 72
Starter control: Interlock- or P/N-signal-Bits 0-7: 161
Limitation: torque: 147.8 Nm
Control Module temperature: 26.9 °C
Part No SW: 4G1 927 156 B HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0003
Revision: --H10--- Serial number: 0000000912
Shop #: WSC 02311 785 00200
Mileage: 309004 km
Date: 2021.02.27
Time: 05:18:19
Mileage: 309004 km
Date: 2021.02.27
Time: 05:31:39
Engine torque: 8 Nm
Mileage: 309004 km
Date: 2021.02.27
Time: 05:18:15
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 27A68701E465E180FB00
ASAM Dataset: EV_ESPPremiAU57X 004028
VCID: 38292C8AA2DCF1CB8B2-806C
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0333
Coding: 01A93006000000000000
VCID: 76B5E2B2E8C847BB59E-8022
Serial number: 2312000058292010
No Faults Found
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H12 0064
Serial number: 30031200041378
Coding: 3612007824
ASAM Dataset: EV_AirCondiComfoUDS 002036
VCID: 270BFFF67F626E33128-8072
Part No SW: 4H0 907 063 BN HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0111
Revision: 20012002 Serial number: 00000001268370
Coding: 2600E01040349FE28181008320001D0CCF9CE70826090101000008602100
VCID: 75B7E5BEF5CE4CA3504-8020
Component: WWS57X 120223 H35 0080
Serial number: 120317134152
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 20116530
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 30 03 2012 00000822
Component: AQ_Hum_Sensor H02 0002
Serial number: 08288026000000000001
No Faults Found
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 Q HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0060
Revision: 11001001 Serial number: 55901207904061
Coding: 292B08
ASAM Dataset: EV_EPHVA18AU57X0000 004005
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 40D9446AFA0CB90B332-8014
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
VCID: 2809FCCA727C614B1B2-807C
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_TSK_FAIL]
Reset counter: 34
Mileage: 309004 km
Date: 2021.02.27
Time: 05:31:41
Control Module temperature: 22 °C
Voltage terminal 15: 13.427 V
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG007VH18
Coding: 30323436313330303433554A304C34473053
VCID: 363522B2A8C807BB99E-8062
Serial number: 3575HRB405V173JOCGP7
Serial number: 3585HRB40631872O4GAW
Serial number: 3515JRB40144UHL8AQ4S
Serial number: 3525JRB40164UHL8G91H
Serial number: 3554VRB405R18AICP16V
Serial number: 3564VRB405R18AIC8OOD
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LCS000MA
Coding: 0000DD
VCID: 372B2FB6AF42FEB3828-8062
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Serial number: 22 12 2011 C0060689
No Faults Found
Part No SW: 4G8 920 931 R HW: 4G8 920 931 R
Component: TDieRdwAcc H79 0416
Revision: 28460177 Serial number: 658260312596034
Coding: 138611000F110008010000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K_AU57.rod
VCID: 3D273D9E8DFED4E3584-8068
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 G HW: 4H0 265 105 G
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20140630115534
Coding: 5D3F01
Shop #: WSC 39769 001 1048576
VCID: 2615F2F278E8773B29E-8072
No Faults Found
Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000461480
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: 70B9D4AA8A2C698B832-8024
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790566906
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 090112000000000001E6
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0064
Serial number: 05041200040114
Coding: 01
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
VCID: 2F3B17D657923673DA8-807A
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0009
Revision: -------- Serial number: EJ1BPA4204EMHE0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: 2D070DDE5D9E4463E84-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-03
Coding: 0010102
VCID: 303914AA462C298BC32-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F31.03.1200H020003CF25227ÿ
Subsystem 4 - Serial number: F25227ÿ
No Faults Found
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F16205000628002080013
VCID: 41DF416EF186B0033CC-8014
No Faults Found
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0020455961
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1EA244A01B9BB56-8066
Revision: 00002001 Serial number: 0174293630
Coding: 013A062020B90480832009842C0104000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Serial number: 0000000AP00001020658
No Faults Found
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000042333
Coding: 030000
VCID: 1D67DD1E2DBEB4E3784-8048
No Faults Found
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F16205000628002080002
No Faults Found
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000305507
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D06C26C70535B0D6-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 120404-0002-034
Coding: 1122A6101002A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G1 035 053 E HW: 4G1 035 053
Component: Radio U Basic H41 0093
Revision: AB001007 Serial number: 227C80C7558699
Coding: 010003010000000001
VCID: 211FE1EE11C690035CC-8074
No Faults Found
Part No SW: 4G0 035 666 H HW: 4G0 035 666 H
Component: H-BN-EU H49 0526
Revision: -------- Serial number: 189CP0C7500103
Coding: 050100010003EBEF3D10EB3E00000003E00001020000000000
VCID: 2D070DDE5D1E4463E84-8078
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC94019SG
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LD30005N
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
No Faults Found
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204000628002080002
VCID: 44D1487AEE94A52B17A-8010
No Faults Found
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H09 0100
Revision: 5G001001 Serial number: 00000174175365
Coding: 0109080000000000
VCID: 71BFD1AE81A660838CC-8024
No Faults Found
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J23G3FR
Coding: 1090005
VCID: 2615F2F274E8773B29E-8072
No Faults Found
Component: TSG HR H04 0212
No Faults Found
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 7F04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
U1113 00 [008] - -
Reset counter: 34
Mileage: 309004 km
Date: 2021.02.27
Time: 05:31:41
Control Module temperature: 18 °C
Voltage terminal 15: 13.310 V
Velocity_vehicle_reference: -0.00 m/s
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000052703127
Coding: 04C0B81C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F11AE41A62083CCC-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:25, VBatt start/end: 14.0V/14.6V)-----------
