VW Passat 2006 ABS coding.
Ben77
Spain
C?ID=423664
Hello, I have a VW Passat 2006 that original ABS is dead, I can`t get original coding, I have installed a used ABS unit but I don't know how to get proper coding number
Saturday,27,February,2021,17:10:31:02009
VCDS Version: 20.12.0.0 (x64)  HEX-NET2 CB: 0.4529.4
Data version: 20201124 DS322.0
Dealer/Shop Name: BCPerformance electronica
Workshop Code: 000 03073 000000
VIN: WVWZZZ3CZ6E036534   License Plate:
Mileage: 200090km-124330mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ6E036534   Mileage: 200090km-124330miles
53-Parking Brake -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018     HW:
   Component: R4 2.0l PPD1.1 G    9722
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 00603 572 81509
   VCID: 6296C174984FCC8B057-8036
18057 - Powertrain Data Bus
            P1649 - 009 - Missing Message from ABS Controller - Intermittent - MIL ON
                    Fault Status: 10100100
                    Fault Frequency: 8
                    Reset counter: 72
                    Mileage: 200091 km
                    Date: 2020.11.18
                    Time: 00:57:20
                    RPM: 864 /min
                    Text:     88    Nm
                    Text:  0.0    %
                    Voltage: 12.54 V
                    Bin. Bits: 10000100
                    Text:   1016    Nm
28800 - No Communications with Parking Brake Control Module
            U0128 - 009 -  - Intermittent
                    Fault Frequency: 8
                    Reset counter: 72
                    Mileage: 200091 km
                    Date: 2020.11.18
                    Time: 00:57:20
                    RPM: 864 /min
                    Text:     88    Nm
                    Text:  0.0    %
                    Voltage: 12.54 V
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
17672 - PD Unit Injector: Cylinder 2 (N241)
            P1264 - 006 - Regulation Range Exceeded
                    Fault Status: 01100001
                    Reset counter: 73
                    Mileage: 200091 km
                    Date: 2020.11.18
                    Time: 01:00:31
                    RPM: 1344 /min
                    Text:    104    Nm
                    Load: 79.2 %
                    Text:  4.875    uF
                    Text: 14.50    mJ
                    Text:     10    mJ
                    Raw, Form. N/A: 000 000 000
17678 - PD Unit Injector: Cylinder 4 (N243)
            P1270 - 006 - Regulation Range Exceeded
                    Reset counter: 73
                    Mileage: 200091 km
                    Date: 2020.11.18
                    Time: 01:00:31
                    RPM: 1312 /min
                    Text:    112    Nm
                    Load: 83.1 %
                    Text:  4.750    uF
                    Text: 12.75    mJ
                    Text:     10    mJ
17669 - PD Unit Injector: Cylinder 1 (N240)
            P1261 - 006 - Regulation Range Exceeded
                    Reset counter: 73
                    Mileage: 200091 km
                    Date: 2020.11.18
                    Time: 01:01:04
                    RPM: 1248 /min
                    Text:    160    Nm
                    Load: 78.0 %
                    Text:  5.000    uF
                    Text: 15.25    mJ
                    Text:     12    mJ
18061 - Please check DTC Memory of ABS Controller
            P1653 - 006 -  - Intermittent
                    Reset counter: 73
                    Mileage: 200091 km
                    Date: 2020.11.18
                    Time: 21:24:48
                    RPM: 896 /min
                    Text:     80    Nm
                    Speed: 5.0 km/h
                    Text:  0.0    %
                    Voltage: 12.09 V
                    Text:      0    Nm
                    Text:    192    Nm
Readiness: N/A
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 M    HW: 3C0 614 095 M
   Component: ESP 440 C2     H015 0001
   Revision:  H015       Serial number: 0657655353
   Coding: 0010000
   Shop #: WSC 00339 572 93917
   VCID: 2C0A6F4CAA0B4AFBFFB-8078
                    Reset counter: 71
                    Mileage: 200091 km
                    Date: 2020.12.04
                    Time: 15:40:15
                    Reset counter: 71
                    Mileage: 200091 km
                    Date: 2020.12.04
                    Time: 15:40:15
02781 - ASR/ESP Button (E256)
                    Reset counter: 71
                    Mileage: 200091 km
                    Date: 2020.12.04
                    Time: 15:40:15
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 G    HW: 3C0 907 044 G
   Component: ClimatronicPQ46 041 0101
   Revision: 00041003    Serial number: 00000000000000
   VCID: 251C9A68C9E17BB3205-8070
                    Fault Frequency: 22
                    Reset counter: 114
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 15:00:28
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000001752027
   Coding: 01880F0700041A00000A00000F00000000095D435C
   Shop #: WSC 05311 000 00000
   VCID: 2B086C50AF054DC3F61-807E
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00065493
   Shop #: WSC 05311
                    Fault Status: 00101100
                    Reset counter: 113
                    Mileage: 200091 km
                    Date: 2020.12.04
                    Time: 14:53:00
                    Voltage: 13.25 V
   Part No SW: 3C0 909 605 C    HW: 3C0 909 605 C
   Component: 03 AIRBAG VW8   028 2421
   Revision: 07028000    Serial number: 0038XS8VHT7Z
   Coding: 0012339
   VCID: 261E9D64B4E770AB29F-8072
   Subsystem 1 - Serial number: 6332MSME0A0C4E21
   Subsystem 2 - Serial number: 6342MSME0A0F0B2D
   Subsystem 3 - Serial number: 6351HTS6R5A6IIN2
   Subsystem 4 - Serial number: 6361HTS6R5A22O63
   Subsystem 5 - Serial number: 6371VTS6R5AI5PN2
01312 - Powertrain Data Bus
   Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
   Component: Lenksäulenmodul 005 0010
   Revision: 00005000    Serial number: 3C5953507C
   Coding: 0000013
   VCID: 2A066954A0FF54CB0D7-807E
   Part No SW: 3C0 920 870 L    HW: 3C0 920 870 L
   Component: KOMBIINSTRUMENT VD1 3028
   Revision: V0018000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 11111 111 11111
                    Reset counter: 114
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 21:59:28
                    Reset counter: 114
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 21:59:28
   Part No: 1K0 815 071 H
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 A    HW: 3C0 907 951 A
   Component: Gateway         006 0010
   Revision: 00006000    Serial number: 0500C054300831
   Coding: 3DFD0C04CA1002
   VCID: 1F108880EBBDA1636A9-804A
                    Reset counter: 112
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 21:59:28
                    Reset counter: 112
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 21:59:28
   Part No SW: 3C0 959 433 M    HW: 3C0 959 433 M
   Component:    IMMO         042 0383
   Shop #: WSC 60107 002 1048576
   VCID: 343A772C723B123BA7B-8060
   Subsystem 1 - Part No: 3C0 905 861 A
   Component:    ELV          021 0350
   3C0905861A     ELV          021 0350
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 114
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 15:02:35
02827 - Wake-Up request via ESP
                    Fault Status: 00100111
                    Reset counter: 112
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 15:02:35
                    Reset counter: 114
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 15:02:36
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2341
   Coding: 0000181
   VCID: 363E4D246447002B99F-8062
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.12      1502
   VCID: 30327B3C86232E1BC33-8064
00625 - Vehicle Speed Signal
                    Mileage: 80 km
                    Temperature: 4.0°C
                    Voltage: 10.80 V
                    Voltage: 10.70 V
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0801860E763004941570084F0B603C00
                    Reset counter: 109
                    Mileage: 200091 km
                    Date: 2020.11.13
                    Time: 00:04:36
   Part No: 1K0 959 702 K
   Coding: 0000180
   VCID: 37204020634DF923829-8062
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0010000
   VCID: 21148E78DDC997935CD-8074
02442 - Function Lamp in Control Head
                    Fault Status: 00101001
                    Reset counter: 112
                    Voltage: 14.08 V
                    Count: 65
02779 - Databus for Electric Parking Brake
                    Fault Status: 00101110
                    Reset counter: 112
                    Voltage: 10.66 V
                    Count: 223
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 23
                    Reset counter: 72
                    Voltage: 12.21 V
                    Count: 171
                    Fault Frequency: 14
                    Reset counter: 112
                    Voltage: 12.21 V
                    Count: 221
02443 - Control Head
                    Fault Status: 00111100
                    Fault Frequency: 18
                    Reset counter: 112
                    Voltage: 11.28 V
                    Count: 40
   Part No: 1K0 035 186 P
   Component: Radio BVX       016 0023
   Coding: 0040400
   VCID: 3338743077351503BE1-8066
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2417
   Coding: 0000144
   Part No: 1K0 959 704 F
   Coding: 0000144
End----------(Elapsed Time: 01:16, VBatt start/end: 14.0V/13.9V)-----------
Ben77
Spain
C?ID=423664
Hello, first thank you very much for the support.
ABS is the same reference, I have checked to be sure.
I have Spare abs plugged and coding is accepted, but after put ignition off and on I get this error about codding
Monday,01,March,2021,21:52:08:02009
   Coding: 0000072
Readiness: N/A
   Coding: 0013614
   Shop #: WSC 03073 000 00000
                    Reset counter: 74
                    Mileage: 200091 km
                    Date: 2020.12.08
                    Time: 03:32:55
                    Reset counter: 74
                    Mileage: 200091 km
                    Date: 2020.12.08
                    Time: 03:32:55
                    Reset counter: 74
                    Mileage: 200091 km
                    Date: 2020.12.08
                    Time: 03:32:55
   Coding: 00065493
   Shop #: WSC 05311
   Coding: 0012339
   Coding: 0000013
   Coding: 0007105
   Coding: 0000011
   Coding: 0000181
   Coding: 0000180
   Revision:   013
   Coding: 0000012
   Coding: 0040400
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:50, VBatt start/end: 12.2V/12.2V)-----------
NEtech
Denmark
C?ID=56995
Maybe try: 0013602
South Molton, UK
Ben77
Spain
C?ID=423664
Seems second coding number was correct, thank you very much!!
Jef
HQ
Bah... I pulled up the wrong 6 speed manual transmission. :banghead:
  • Informative
Ben77
Spain
C?ID=423664
No problem, thank you very much for your effort
