New Member - Hopefully a silly question
Havelin A Laugh
England
C?ID=413738
Hi all, new member here but not new to VCDS. I have US running lights activated in my golf mk5, I wanted to adjust the brightness percentage in vcds but when I change the value and click enter it just reverts back to the original value.
I think it's to do with the recent update, am I missing something and there is another way to do it now?
Many thanks in advance
Joe
South Molton, UK
You'll need to post a full unedited VCDS Auto-Scan of your Golf, and please describe EXACTLY what you tried to change (coding, adaptation,...).
Havelin A Laugh
England
C?ID=413738
Thanks for the reply, I managed to do it but only with the previous version 20.4 software. Is this something I can report to be looked at with the new 20.12 release?
@Havelin A Laugh : Hi. With my apology to Dave for stealing his thunder, the answer is that you should always use the latest release version of VCDS (not only to post on this forum, but also to undertake diagnostics).
However, in this case - since this vehicle is Golf mk5 and therefore not a "new vehicle", I suspect that ver 20.12 will answer at least some of the questions that the forum needs resolved to garner informed responses- maybe?
You will find instructions HERE regarding how to paste the auto-scan into a post
Havelin A Laugh
England
C?ID=413738
Hi thanks for the reply, please see autoscan below. Using latest VCDS software. My intention was to go into 09-Cent. Elec, long coding, byte 7 to change the brightness of my 'indicators as sidelight' value. As mentioned on previous versions I was able to do this and change the coding, this time round on the updated/latest software the value in the box cannot be changed to adjust the indicator brightness.
Sunday,28,February,2021,14:55:53:33535
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: WVWZZZ1KZ7W136887   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ7W136887   Mileage: 181210km-112598miles
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWZ7Z0F8214685
   Coding: 040300031C070160
   Shop #: WSC 00191 264 15243
   VCID: 372AD23FC345AB43828-8062
   Part No SW: 02E 300 050 H    HW: 02E 927 770 AE
   Component: GSG DSG         070 1401
   Revision: 04507000    Serial number: 00000610270871
   Shop #: WSC 01279 785 00200
   VCID: 176A32BFA3858B43A28-8042
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 60296 003 1048576
   VCID: 73B2262F97BD07637E0-8026
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 70B82923E6AB3C7B832-8024
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006384072
   Coding: E90D8E0700041500001400001400000000197F075C0001
   Shop #: WSC 12345 012 00001
   VCID: 6C803D53CA83D89BBFA-8038
   Component: Wischer 231106 020  0501
   Coding: 00038805
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     011206 020  0105
   Coding: 00208933
   Shop #: WSC 12345
   Component: 38 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0WETNI
   Coding: 0013112
   Shop #: WSC 01269 785 00200
   VCID: 3D26C017E1798113584-8068
   Subsystem 1 - Serial number: 6332MSME14083E517
   Subsystem 2 - Serial number: 6342MSME145A7347D
   Subsystem 3 - Serial number: 6352QSME1A420E15E
   Subsystem 4 - Serial number: 6362QSME19722771E
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           636 0070
   Coding: 0013122
   Shop #: WSC 00706 210 87584
   VCID: 015E7CE7DD0125F37CC-8054
   Part No SW: 1K6 920 973 X    HW: 1K6 920 973 X
   Revision: V0003000    Serial number: VWZ7Z0F8214685
   Coding: 0000403
   Shop #: WSC 38149 003 1048576
   VCID: 48C8A1C3BEBBD4BBFB2-801C
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 01110602000548
   Coding: 3F0F034007000001
   VCID: 2F3AEA5F3B156383DA8-807A
   Component: IMMO            VDD 1610
   Component: Tuer-SG         005 0968
   Coding: 0000564
   VCID: 3828D103CE5BA43B8B2-806C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 74     3501
   Revision: 00H17000
   VCID: 392ED407F551BD3374C-806C
   Component:    KSG PQ35 G2  020 0203
   Coding: 99900A085103087F2D04840D7008DAC690B800
   Shop #: WSC 19310 028 574534
   VCID: 035276EFC71D37E36E0-8056
   Subsystem 2 - Part No: 1K0 951 178
   Component: Neigungssensor  001 0101
   Subsystem 3 - Part No: 1K0 951 178
   Component: Innenraumueberw.001 0101
   Coding: 0000564
Address 56: Radio
End----(Elapsed Time: 01:00, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Please post some screen-shots showing why you think it can't be changed.
Havelin A Laugh
England
C?ID=413738
Hopefully this link works, the value I want to change is 0 to '#' for example but once I click away or click enter it just reverts back to original value.
South Molton, UK
# is not a valid number (either decimal or hexadecimal)?
Some bits are not necessarily stored by a module in all bytes, so even if you enter a valid digit it's not impossible for the software in the module (nothing to do with VCDS) to revert back to the original value.
Havelin A Laugh
England
C?ID=413738
Thanks everyone for your help. Installed the latest 21.3 and it's working perfectly.
Havelin A Laugh
England
C?ID=413738
# - I meant example of any number used.
