Cel epc esp no start
Jonathana3bpy
California, USA
C?ID=434351
Hi all,
my car died on me on the freeway and I’m trying to fix it. It cranks but doesn’t fire. Any help would be greatly appreciated.
I’ve replaced the crank, camshaft, vvt, maf sensors and battery. Still getting low voltage faults and can faults. The map fault was from disconnecting it while trying to start it w starter fluid I believe.
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.12.0(x64) Data version: 20201125 DS322.1
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Sunday,21,February,2021,07:16:59:58934
VIN: WAUNF78P98A136225 License Plate:
Mileage: 280880km-174530mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 65 72
VIN: WAUNF78P98A136225 Mileage: 280880km-174530miles
VCID: 3FDB49B82B73DF934A8-806A
Self-Diagnosis Log
Page 2
Address 01: Engine Labels:. 06F-907-115-AXX.clb
PartNoSW:8P0907115P HW:8P0907115B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H0FN40G3
Coding: 0103010A18070160
Shop #: WSC 06314 000 00000
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Mileage: 280880 km
Temperature: 13.0°C
Temperature: 15.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.446 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
005425 - Camshaft Timing Adjustment
P1531 - 004 - Open Circuit - Intermittent
Self-Diagnosis Log
RPM: 225 /min
Load: 66.2 %
Temperature: 15.0°C
Voltage: 10.922 V
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 001 - Signal too High - Intermittent
Fault Status: 00100001
Temperature: 12.0°C
Temperature: 14.0°C
Voltage: 12.319 V
Readiness: 0110 0101
Page 3
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73B3D58857BB4BF37E0-8026
Self-Diagnosis Log
Page 4
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0430
Revision: 126005 Serial number: 8P0820043AH
VCID: 72BDD08C28A142FB756-8026
Reset counter: 62
Mileage: 280880 km
Date: 2021.02.10
Time: 05:23:03
Voltage: 9.00 V
Fault Status: 01101000
Reset counter: 22
Mileage: 280880 km
Date: 2021.02.10
Time: 00:28:36
Freeze Frame: -------------------------------------------------------------------------------
Component: Wischer AU350 H01 0130
Self-Diagnosis Log
Page 5
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
PartNoSW:8P0907279K HW:8P0907279K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000008038759
Coding: 018C0F81D01410004F1818001800000000285E175C110000000000000000
Shop #: WSC 06435 000 08192
VCID: 45D75B5049AF8543004-8010
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Coding: 00062736
Shop #: WSC 06435
Address 15: Airbags Labels: 8P0-959-655-94.lbl
PartNoSW:8P0959655M HW:8P0959655M
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CQ0002NM2
Coding: 0032605
VCID: 4CC16E746AC5740BDFA-8018
Subsystem 1 - Part No: 8P0 910 339 C
Component: BF-Gewichtsens. H02 0030
Subsystem 2 - Serial number: 01WE4
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63 Subsystem 4 - Serial number: 000000ÿ†6332DRB40665551DOÿ†63 Subsystem 5 - Serial number: 5551DOÿ†6342DRB406655524Hÿ†63 Subsystem 6 - Serial number: 55524Hÿ†63528RB4036AA861Oÿ†63 Subsystem 7 - Serial number:AA861Oÿ†63628RB4036AA54CVÿ†63 Subsystem 8 - Serial number:AA54CVÿ†63747RB4035CF815Wÿ†63 Subsystem 9 - Serial number: CF815Wÿ†63847RB4035CF831Vÿ Subsystem 10 - Serial number: CF831Vÿ
No fault code found. -------------------------------------------------------------------------------
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
PartNoSW:8P0953549F HW:8P0953549F
Component: J0527 H36 0070
Coding: 0002042
VCID: 41DF4F405D87A9633CC-8014
Component: E0221 H02 0030
Self-Diagnosis Log
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
PartNoSW:8P0920981N HW:8P0920981N
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 2240H003101722
Coding: 0020288
Shop #: WSC 55437 002 1048576
VCID: 43D34548479BBB732E0-8016
Fault Frequency: 8
Mileage: 280880 km
Date: 2021.02.10
Time: 05:32:33
Page 6
Self-Diagnosis Log
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Page 7
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K081070175
Coding: E9807F071002022102
VCID: 30391A84E62D30EBC32-8064
Fault Frequency: 123
Reset counter: 146
Mileage: 261467 km
Date: 2020.07.16
Time: 18:43:24
Revision: D0H22003 Serial number: AUX7Z0H0FN40G3
Shop #: WSC 59024 001 1048576
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
PartNoSW:8P0959801K HW:8P0959801K
Component: Tuer-SG H03 0050
Coding: 0001177
Component: EPS_ZFLS Kl.079 H08 1901
Self-Diagnosis Log
Page 8
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Shop #: WSC 02069 000 90108
VCID: 35372B90194F15C3904-8060
Temperature: 11.0°C
Voltage: 6.30 V
Voltage: 6.10 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 K
Component: KSG H11 0080
Coding: 1B8022A001382D09050FCC8F0477
VCID: 44D146544295BC4B17A-8010
Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted
Temperature: 20.0°C
Self-Diagnosis Log
Page 9
Address 47: Sound System Labels: 8Px-035-382.lbl
PartNoSW:8P4035382D HW:8P4035382D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674753116274
Reset counter: 62
Mileage: 280880 km
Date: 2021.02.10
Time: 05:34:10
Reset counter: 62
Mileage: 280880 km
Date: 2021.02.10
Time: 05:33:30
Temperature: 20.0°C
PartNoSW:8P0959802K HW:8P0959802K
Coding: 0001177
Component: R Concert2+ H01 0270
Self-Diagnosis Log
Page 10
Address 56: Radio Labels: 8J0-035-1xx-56.clb
PartNoSW:8P0035186Q HW:8P0035186Q
Revision: 00H01000 Serial number: AUZ1Z3G6868960
Coding: 0330212
VCID: 40D94A44568DA06B332-8014
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
PartNoSW:8P4959801F HW:8P4959801F
Component: Tuer-SG H04 0050
Coding: 0001168
Shop #: WSC 06314 000 1012544
VCID: 42DD404C5881B27B256-8016
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Shop #: WSC 06435 000 00000
Self-Diagnosis Log
Page 11
Address 65: Tire Pressure Labels: 8J0-907-273.lbl
PartNoSW:8J0907273A HW:8J0907273A
Component: J502-RDK H02 0300
Revision: --H02-D0 Serial number: 12679776652200
Coding: 0860021
VCID: 2F3B19F8FB132F13DA8-807A
Reset counter: 62
Not Recogn.
Bin. Bits: 00001000 00000000
Voltage: 6.40 V
Text: -50°C;n.erkannt; n.erkannt
Fault Frequency: 40
Reset counter: 21
Mileage: 237236 km
Date: 2019.05.10
Time: 08:20:59
Speed: 126.7 km/h
Bin. Bits: 00001000 00000100
Voltage: 14.40 V
Text: 15 °C;n.erkannt; n.erkannt
Self-Diagnosis Log
Page 12
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
PartNoSW:8P4959802E HW:8P4959802E
Component: Tuer-SG H04 0040
Coding: 0001176
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:20, VBatt start/end: 12.1V/12.1V)-----------
Gone But Not Forgotten
Welcome to the VCDS forum OP! ;)
JPPSG
Have Basics?
Compression, fuel, spark, control of EPC, unrestricted intake/exhaust?
VOLTAGE SEEMS INCREDIBLY LOW!
Jonathana3bpy
California, USA
C?ID=434351
I’ll be checking compression this weekend. I have fuel to hpfp. I’ve checked spark on all cylinders.
I’m a newb to vcds how can I control epc and check restrictions for intake/exhaust?
How about observing them visually?
EPC on VCDS scanner ....
0x01-04-060 ADP OK
0x01-08-060 & 061 verify POTS yet?
Jonathana3bpy
California, USA
C?ID=434351
No compression on any cylinders. 40 on one the rest 0.
Jumped a tooth? It doesn’t sound abnormal.
Adp ok and visually monitored.
Jonathana3bpy
California, USA
C?ID=434351
I’m planning on tearing into it soon. Thanks for the replies
Jonathana3bpy
California, USA
C?ID=434351
Why would I alter the scan if I needed help? I cut and pasted the downloaded pdf txt from the gateway installation list auto-scan
Here is a proper way to post the scan......and your ECU is there it's just so garbled up!
