Correct units for yaw, pitch and roll rates
tnisov
Finland
C?ID=26492
Hi!
I was investigating crash data in SRS control unit recently.
I'm wondering - why units for yaw rate, roll rate and pitch rate are in m/s2 and not in angular acceleration unit - in rad/s2 for example?
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA42039EYH0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D12CF807C7F32EC99-8078
7340432 - Longitudinal Acceleration
C10B1 29 [108] - Signal Implausible
[ECU temporarily disturbed: Signal ACC_X]
Reset counter: 120
Mileage: 291055 km
Date: 2021.01.27
Time: 04:12:56
DCU Temperature: 12 °C
Voltage Clamp 15: 14.7 V
Voltage Clamp 30: 14.2 V
Ignition Cycle Count: 52115
Roll rate: 5.13799 m/s2
Pitch rate: 6.08956 m/s2
Yaw rate: -1.38321 m/s2
Yaw rate 2: 0.00000 m/s2
Longitudinal acceleration: -42.67595 m/s2
Lateral Acceleration: -25.73899 m/s2
Lateral acceleration 2: 0.00000 m/s2
Body acceleration: 21.69236 m/s2
7344528 - Latteral Acceleration 1
C1022 29 [108] - Signal Implausible
Reset counter: 120
Mileage: 291055 km
Date: 2021.01.27
Time: 04:12:56
Voltage Clamp 15: 14.4 V
Voltage Clamp 30: 14.1 V
Roll rate: 26.96524 m/s2
Pitch rate: 1.49112 m/s2
Yaw rate: -1.91050 m/s2
Longitudinal acceleration: -49.42278 m/s2
Lateral Acceleration: -40.24062 m/s2
Body acceleration: 38.29579 m/s2
iichel
Eindhoven, NB, NL
C?ID=284912
you're probably right, just a translation/interpretation error.
Andy
Sector 7G
HC424490
As requested via email, a controller channel map would be helpful since my understanding is that freeze frame data correlates to some measuring values. I tried in vain to cause the 3B module in our 2012 A6 to have any faults at all, including removing fuses that shut off 01,13,15, and 3B itself. I agree that rotational acceleration should be in units of degrees per second squared, or radians per second squared, not meters per second squared. That said, if they factory tool displays the same thing then that's wrong too. You may want to try checking this with ODIS.
@tnisov: Hi.
I'm not in anyway knowledgeable about crash data in a vehicle's SRS control unit - but simply from the units "m/s2", my guess is that the underlying transducer for the measurements of yaw, roll and pitch is a micromechanical type accelerometer, rather than being a piezoelectric type gyroscope.
Again, without being knowledgeable about either device type, my understanding from a quick read is that the difference between the two is that the former type transducer can measure something called "Coriolis acceleration".
I'll leave it to you to research these very arcane topics. Mercifully, I became insane-in-the-membrane many years ago - so well beyond my current pay-scale (which ain't much)!! :)
