Throttle body adaptation no longer supported?
Ape Factory
C?ID=321067
Hi team,
I've run throttle body adaptation on my RS5 in the past after cleaning or any time I need to remove them. But it looks like with the latest update (or one of the past updates) the functionality is no longer there? There seems to be a method to check to see if adaption was run successfully but I no longer see throttle body calibration in any of the drop down menus.
Assuming the car needs to be at operating temp. When I log, car cold, the throttle body percentage, foot off the gas, left and right, is not matching. Same for WOT. I have a bit of a rough cold idle issue that I think is related to the calibration. Once it idles for a minute or two, it's fine. Also if I back out of the garage in reverse, it's rough until I put the car into D and move forward a bit. Once I've done that and the car is even somewhat warm, it idles like a well-running V12, just buttery smooth.
Santos
Can you post an autoscan using the latest software? We need to see what files load and part numbers.
Ape Factory
C?ID=321067
I can, give me a bit, working the day job at the moment. I'll do some screen grabs of what's available now as well.
Ape Factory
C?ID=321067
Ok so even though the wording is different now, the function is still the same, correct?
Correct, any option that mentions throttle valve adaptation is the TBA group.
