It seems that I'm the first person in Audi history to have Oil disappear on a S6. Dealer says the breather is fine as the fuel trims are perfect.
They want to do a consumption test and if it's less than 1 quart per 1K miles, they're going to leave it as normal. Thoughts?
Andy
Andy
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Andy
VIN: WAUFFAFC7HN000000 License Plate:
Mileage: 37025mi Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 1B 22 28 34 36 3B 3C 42 44 46
52 53 55 5F 62 6C 72 8F 90 A9 BA
VIN: WAUFFAFC7HN000000 Mileage: 37025miles
Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 D HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0001
Revision: NCH63---
Coding: 0A2500326526010E3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
ROD: EV_ECM40TFS0114G0906014D.rod
VCID: 2310E7ECEB591CE36E9-8076
Part No SW: 4G0 927 166 F HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H03 0006
Revision: --H03---
ASAM Dataset: EV_TCMDL501021 001022
ROD: EV_TCMDL501021.rod
VCID: 303A18A0AAAFB77BE3B-8064
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 65BED441A67D2B821B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41DC4D6411052EF31C5-8014
Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
Component: BCM2 2.0 H61 0824
Coding: 0DA86F4E000000000000
VCID: 005A88605A0FE7FB53B-8054
Serial number: 3216000043437016
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Serial number: 11051600041072
Coding: 688130B8490000
VCID: 6A8ECAC84CF30DABEDF-803E
Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM
Component: BCM1 2.0 H20 0368
Revision: 21020001 Serial number: 00001355220801
Coding: 01050011043C9FF0B90048C780003800CF9CD208A608022180000814F110170200600034030000
VCID: 79ACE58439D5B633145-802C
Component: WWS57X 160330 H38 0080
Serial number: 160415024538
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 61790445
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 13 05 2016 00001339
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0244B951
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA123402000020181586
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0005
Serial number: A909862800PAG0MUFU01
Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
Component: Airbag10.43 H62 0086
Revision: -------- Serial number: 003G00035THU
Coding: 303331343135303334394A55304C34473053
VCID: 343214B05EB78B5B873-8060
Component: BF-Gewichtss. H15 0046
Serial number: 6940000Y160001GYEU0Q
Serial number: 3575HRB405L436HUC8Q$
Serial number: 3585HRB405J436HU29DG
Serial number: 3515JRB404P3VEM82P93
Serial number: 3525JRB405N3VEM8BORT
Serial number: 3554VRB400C570C0R91Y
Serial number: 3564VRB401I5726KD966
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Revision: -------- Serial number: 90372PDL0006G
Coding: 000434
VCID: 382A2080425F6F3BABB-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 30 03 2016 C0090592
Part No SW: 4G0 920 982 Q HW: 4G0 920 982 Q
Component: TBenUsa Nv H14 0225
Revision: 11001108 Serial number: 658170516596031
Coding: 03E70905BB41D705020200
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 3A2E3A887CD37D2B5DF-806E
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Revision: -------- Serial number: 00000002252742
Coding: C0ED074814
VCID: 3D2431946DFD4A1378D-8068
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 5913940104
Voltage stabilizer:
Serial number: 1603010000000000078F
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0E0100
VCID: 3A2E3A887C537D2B5DF-806E
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Serial number: 000305160001019
VCID: 280AF0C0927FFFBB3BB-807C
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 10051600041411
Coding: 20
VCID: 3E26369860FB510B617-806A
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Coding: 008004
ROD: EV_AirSuspe_VW51.rod
VCID: 2F381BDCB791A883FA1-807A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000199073143
VCID: 77A8E3BC0FC1A043621-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E0268B%
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 372823BC4FC16043A21-8062
Component: SWA Master H08 0070
Serial number: 0403610009
Coding: 040211
VCID: 392C258479D57633545-806C
Lane Change Assistant 2:
Component: SWA Slave H08 0070
Serial number: 0404579479
Coding: 040211
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F17015E00628002000012
VCID: 47C8537C3FA110C3D21-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000895841
Coding: 011000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Revision: 00002001 Serial number: 0404425256
Coding: 0106063A00FA418580B0088402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000348622
Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
Component: J245 PS40.402 H03 0004
Serial number: 0000FST000YXNQ800000
Coding: 101F02
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00020407468
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Serial number: 93820004
Component: TSG BF H03 0511
Coding: 011F17015E00628002000002
VCID: 46D65E7838AB09CB297-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001848136
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 313C1DA4A1A5BE73EC5-8064
Component: MxB-ECU 001 0100
Coding: 04FA0A1122200400
Coding: E01E00
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 025 C HW: 4G1 035 025 C
Component: MU-H-LNS-US 052 0671
Serial number: A741E0G7500035
Coding: 017551020000000013220002041A00102F0007E5F17001047E
VCID: 1E66D618C03B310B417-804A
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY8050M9
Multimedia Operating Unit:
Serial number: 90349PED000LB
Compact Disc Database:
Component: Gracenote2--- --- 3009
Component: TSG HL H03 0511
Coding: 010F17004000628002000002
VCID: 49CC554429B5E6B3C45-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 027500010A002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001.rod
VCID: 78AAE080025FAF3B6BB-802C
Component: TSG HR H03 0511
Component: RGS-VL H16 0080
Coding: 0006E008031F0300070308014244C8010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 323E12A8A4A3856B95F-8066
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 160225200382
VCID: 2C020CD08687D39BDF3-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813006773401
ROD: EV_AEMLearAU64X.rod
End----------(Elapsed Time: 02:15, VBatt start/end: 13.1V/13.1V)-----------
