Mk5 golf instrument cluster.
TotalDiagnostics
Ireland
C?ID=423853
Hi guys, I have a mk5 golf, 2006, 1.9tdi. In from another garage with the fuel gauge not working. After diagnosing a faulty cluster I’m curious if I can code a “used” cluster in with vcds?
regards Kev.
Code it, sure. But dealing with the immobilizer that's integral with the cluster is dicey. In theory, it should be possible on a 2006 if you have PINs for for both clusters, but there are cases where it doesn't seem to work as documented.
PS: Moving to Car Repair Support.
DGMotors
C?ID=57532
2006 seems to be when they changed from immb 4 to 4a so be very careful what version you have.
TotalDiagnostics
Ireland
C?ID=423853
So basically if I have IMMo 4 then it should be straight forward?
Gone But Not Forgotten
If you have the Pin codes & wait for a channel, well do you have 050 pin codes & where is your auto-scan?
TotalDiagnostics
Ireland
C?ID=423853
I have no auto scan I’m only asking if this is do-able. If I posted an auto scan would you have a better idea?
In theory, it should be doable. In practice, it doesn't always work out.
And Auto-Scan would allow us to confirm exactly what the car is made of.
TotalDiagnostics
Ireland
C?ID=423853
I’ll get an auto scan this eve and post it. Thanks.
