1.9 BRM crank and sputter but no start after complete rebuild
p1muserfan
C?ID=268469
I bought this car as a project about 4 years ago. I sent the head and EGR cooler to Franks VW. I built the engine in August and installed it in January. A friend helped me prime the fuel system. I did an auto scan and cleared everything before I cranked the engine the first time. It will crank and sputter but just will not fire off. Getting black smoke from the tail pipe. Too much fuel and no air? Intake flap motor is wide open. Not sure where to start. Latest auto scan attached.
Tuesday,23,February,2021,13:35:13:40487
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: 3VWRT71K76M665570   License Plate:
Mileage: 214720km-133420mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K76M665570   Mileage: 214720km-133420miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AC    HW: 028 101 223 9
   Component: R4 1,9L EDC G000DG  7551
   Revision: --H01---    Serial number: VWZ7Z0E2543143
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 6492A48E52525D5BF7A-8030
               P1653 - 000 -
                    Mileage: 214723 km
                    Time: 00:34:06
                    Speed: 4.0 km/h
                    Voltage: 12.31 V
                    Bin. Bits: 11101000
                    Torque: 134.2 Nm
                    Bin. Bits: 00000100
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal - Intermittent
                    Fault Status: 00110000
                    Mileage: 214723 km
                    Time: 00:00:35
                    RPM: 336 /min
                    Voltage: 10.34 V
                    Bin. Bits: 00101000
                    Idle Stabilization: 0.0°KW
                    (no units): 3.0
Readiness: 1 1 0 0 1
   Part No SW: 02E 300 042 H    HW: 02E 927 770 AD
   Component: GSG DSG         070 0913
   Revision: 00007000    Serial number: 00000505070258
   VCID: 186AC07EDE9A49BBAB2-804C
18250 - Please check DTC Memory of Instrument Cluster
            P1842 - 000 -
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 214723 km
16947 - System Voltage
            P0563 - 000 - Too High - Intermittent
                    Mileage: 214723 km
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021122
   VCID: 40DA481EE68A217B332-8014
65280 - Development code 1
00000 - End of output
   Part No: 1K0 820 047 DK
   Component: Climatic PQ35   090 0505
   VCID: 70BAD8DE96AAF1FB832-8024
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
            013 - Check DTC Memory
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000000145408
   Coding: 14010E234004180000140000001400000008730B5C
   Shop #: WSC 25117 444 54387
   VCID: 2A0E0AB670F6CB2B0D6-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 25117
10 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 236
                    Mileage: 214723 km
                    Voltage: 12.10 V
                    Reset counter: 236
                    Mileage: 214723 km
                    Voltage: 12.10 V
                    Fault Status: 01101100
                    Reset counter: 196
                    Mileage: 214723 km
                    Voltage: 12.10 V
                    Reset counter: 196
                    Mileage: 214723 km
                    Voltage: 12.10 V
                    Reset counter: 236
                    Mileage: 214723 km
                    Voltage: 12.10 V
                    Reset counter: 236
                    Mileage: 214723 km
                    Voltage: 12.10 V
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00101010
                    Reset counter: 236
                    Mileage: 214723 km
                    Voltage: 12.50 V
                    Reset counter: 236
                    Mileage: 214723 km
                    Voltage: 12.50 V
                    Reset counter: 236
                    Mileage: 214723 km
                    Voltage: 12.50 V
                    Reset counter: 236
                    Mileage: 214723 km
                    Voltage: 12.50 V
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E3032367
   VCID: 2B000FB27F0CD223F60-807E
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 198
                    Mileage: 70634 km
                    Time: 00:43:25
02788 - Internal Communications Error
                    Fault Frequency: 11
                    Reset counter: 236
                    Mileage: 214723 km
                    Time: 18:55:51
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
01304 - Radio
                    Fault Status: 01101000
                    Fault Frequency: 8
                    Mileage: 214723 km
                    Time: 18:25:11
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD03C1JZ
   Coding: 0012627
   VCID: 2E0606A64C1EA70BD1E-807A
   Subsystem 1 - Part No: 1K0 959 339 E
   Component: BF-Gewichtsens. 006 0005
   Subsystem 2 - Serial number: 6332MSME0B2734413
   Subsystem 3 - Serial number: 6342MSME0B3122630
   Subsystem 4 - Serial number: 6351HSME080A077DC
   Subsystem 5 - Serial number: 6361HSME077E1D48M
   Subsystem 6 - Serial number: 63727SME07354F622
   Subsystem 7 - Serial number: 638  SME
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0010021
   VCID: 78AAE0FEFEDAA9BB4B2-802C
   Part No: 1K0 920 952 D
   Component: KOMBIINSTRUMENT 3HL 1212
   Coding: 0023203
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010570288E6
   Coding: 3F3F0B60071002
01304 - Radio
                    Fault Frequency: 50
                    Reset counter: 196
                    Mileage: 214723 km
                    Time: 18:25:16
   Component: IMMO            3HL 1212
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 36362EC6B44E9FCB99E-8062
00100 - Drivers Interior Locking Button (E308)
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 323E12D6582683EBB56-8066
00625 - Vehicle Speed Signal
                    Mileage: 4720 km
                    Temperature: 10.0°C
                    Voltage: 12.40 V
                    Voltage: 12.20 V
   Part No: 1K0 959 433 AF
   Coding: 137803281B09050F880F048051A0
   VCID: 74B2D4CEE2B2CDDB67A-8020
01312 - Powertrain Data Bus
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 372823C2B34466C3828-8062
00110 - Right Mirror Turn Signal Lamp (L132)
Address 56: Radio
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 313C1DDA5D20B8F3CCC-8064
01813 - Supply Voltage for Door Controller; Rear Left (J388)
   Part No: 1K0 959 704 D
   Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D0401AA4118DC13E84-8078
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End----------(Elapsed Time: 01:12, VBatt start/end: 12.5V/12.5V)-----------
NostraJackAss
Jef
HQ
And following up Jack's statement.... did you use the correct tools when installing the timing belt?
NostraJackAss
Was the tapered hub for cam sprocket removed from the camshaft set correct?
Is lash timing set correct for PD unit injectors for helical operation?
JPPSG
Mech minutes start your engines again this week!
p1muserfan
C?ID=268469
I have removed the timing belt covers and checked the timing. I had bought the Metalnerd kit from KermaTDI before I started the job. The crank lock I have is the one that replaced the older style, its purple/pink with the pin that slides into the hole in the block and the allen bolts that screw into the crank. With the crank at what I believe to be TDC, the cam sprocket toothed window is at about 11 o'clock the the cam lock pin slides into the hole at about 8 o'clock right into the hole in the head. Just like it did when I first timed the engine. But can I still be 180 out? I turned it over by hand numerous times after the belt was installed and it turned very smoothly.
I also redid the adjuster screw process on each injector per my Bentley manual, making sure as best I could that the roller of the rocker arm was at it's peak because I don't have the special tooling. I had a friend watch as I turned the engine to look for peak position.
But the question remains, is my timing 180 out?
p1muserfan
C?ID=268469
I had to remove the hub from the cam because some of the tabs were bent (probably the cause of the cam sensor code). That probably happened when I removed the hub from the cam years ago without the proper tooling. Today I had the correct puller. The cam and hub are notched, only 1 way to go on, so ok there.
