VW Transporter T6 coding out secondary air heater
cryptrade
C?ID=425004
Hello
We had to remove the secondary air heater from a VW Transporter T6 van and I want to code the whole unit out so that it doesn't show any faults. If I go to CAN gateway and select Installation List the 0B - Sec. Air Heater is not in that list so I can't just deselect it. I went to 08-Auto HVAC but the Long Coding doesn't mention anything about a secondary air heater (On the 2020 T6.1 that's where it normally is).
If I don't code out the Secondary Air Heater sometimes I will get a faults at the Auto HVAC module saying that there is miscommunication somewhere.
Autoscan below.
Tuesday,23,February,2021,10:25:54:60393
VCDS Version: 20.12.0.1  HEX-V2 CB: 0.4529.4
VIN: WV1ZZZ7HZKH149185   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZKH149185   Mileage: 49160km-30546miles
Address 01: Engine (J623-CJKB)       Labels:. 06J-907-309-V2.clb
   Part No SW: 06J 906 021 AC    HW: 06J 907 309 C
   Component: 2.0l R4 T-FSI H03 2032
   Revision: ELH03---    Serial number: 00000000000000
   Coding: 01190013432401080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TFS01106J906021AC 001005
   ROD: EV_ECM20TFS01106J906021AC.rod
   VCID: 6694499B48E973ABE9E-8032
Readiness: 1110 0001
   Revision: 00000000    Serial number: 61469000001724
   Coding: 517E4398256684878A76C27EA48721A679F100
   Shop #: WSC 00012 790 50316
   VCID: 3FDABCFF77F302634A8-806A
   Serial number: 20051913471187
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA401FB3079CB6B01E-802A
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H23 0708
   Revision: 00001003
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 73B220CF0B3B96037E0-8026
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8602 145190534
   Coding: E0A4303A0A212031002009742C2B8C540FC0708F60444D60330400220800
   Shop #: WSC 66305 123 174617
   VCID: 2C00FBB3960589FBFFA-8078
   Subsystem 1 - Part No SW: 7E0 959 801 R    HW: 7E0 959 801 R  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  005 0653
   Serial number: KU0KU014051991340891
   Coding: 1400B1
   Subsystem 2 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU022051991420044
   Coding: 0400A1
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32931909401650
   Coding: 10800A
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 43D2B00F1B1B66832E0-8016
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 1305190439A105
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ROD: EV_ACCBEGVW361.rod
   VCID: 3634D9DB58C9C32B99E-8062
   Part No SW: 7E0 959 655 J    HW: 7E0 959 655 J
   Component: VW10Airbag021 010 0018
   Revision: --------    Serial number: 003EK0055L4T
   Coding: 000000000000000000000000000000003231
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D26C6F77DFF1073584-8068
   Part No SW: 7E0 920 971     HW: 7E0 920 971
   Component: KOMBI         H03 2050
   Coding: 450B010200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   VCID: 688847A342FD65DBDB2-803C
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 042305
   VCID: 688847A3427D65DBDB2-803C
   Component: IMMO          H03 2050
   Coding: 000002
   VCID: 6A8C3DAB5CF157CBCD6-803E
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     070 7205
   Serial number: 03061900011768
   Coding: 06570000BE00000041111101008000001F0000C60000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E04F1BBA099FBEBD1E-807A
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Reset counter: 12
                    Mileage: 49165 km
                    Date: 2021.02.23
                    Time: 10:20:13
                    Voltage terminal 30: 12.0 V
   Part No SW: 7E0 907 534     HW: 7E0 937 090 D
   Component: Batt.regelung H82 0762
   Coding: 032B7A59
   Shop #: WSC 00012 790 00020
   Subsystem 1 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 75885202001905090520
End----------(Elapsed Time: 01:10, VBatt start/end: 12.4V/12.2V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
it's a 'known' thing that on these 7E0 BCMs, the secondary air heater pops up on some autoscans.
i am not sure what to advise. is there perhaps a specific hvac unit for vehicles with a secondary heater (i assume you mean the J364 heater for the coolant, on the left hand side of the car, aft of the front wheel)
cryptrade
C?ID=425004
No I
No I mean the rear heater that is located at the right hand side (drivers side UK) at the very back of the van. This is only on the shuttle vans.
what if I pulled the fuse? Just need to find it.
iichel
Eindhoven, NB, NL
C?ID=284912
if you already physically removed the unit and removed it from the canbus gateway, you should be relatively OK.
look in any other device for coding/adaptation where you expect this device to be linked, i.e. engine, hvac
VWT6
Finland
C?ID=295527
No I
Perhaps the heater you have removed is actually just rear heat exchanger+blower unit - a part of engine coolant circulation. Possibly similar to this --> https://www.t6forum.com/threads/my-shuttle-conversion.22025/
The Air heater unit would be on right side behind/aft of the front wheel. Also your scan doesn't have overhead control unit - 6E, which would control the air heater.
cryptrade
C?ID=425004
Yes you may be right. The blower had a control panel which was fitted overhead where the first row of passenger seats is.
So it seems it is impossible to completely remove the 0B - Sec. Air Heater from the installation list? I am not able to connect to it with VCDS as it has been physically removed.
The control panel looks like this:
EDIT: I think I know what you're talking about. The Air Heater that you mention is the Webasto one, which is found only in Shuttle/Caravelle vans. We do camper van conversions and we do convert many Caravelle vans which all have the Webasto heater installed behind the left front wheel. I've never seen one have an overhead control unit but if I was to install the unit is it possible to make the Webasto heater blow heat into the cabin without starting the engine? Now we fit Eberspacher Airtronic units which are powered by a leisure battery and have a separate warm air pipe which heats the cabin if people are camping over night.
Would it be possible to make the already pre-installed Webasto heater blow hot air to the cabin without us having to install another heater which costs £600+?
