- Feb 21, 2021
- 2
- 0
- Los Angeles, CA, USA
- C?ID=431648
Just purchased car, had oil and Transmission serviced, along with filters. Mechanic mentioned failed intake manifold runner flap arms (lil suckers) I ordered immediately (finally here tomorrow) last few days car idles rough and shifting isn't as smooth. Ran great after Mechanic, so before blaming him I searched forums and since air filter was done recently found the small line under air box not connected. Reattached, but still ran rough and finally my Hex-V2 arrived and ran a scan. Obviously, worried about Trans code, why all of sudden she runs rough and definitely feel less performance, but how much, not sure since car is new to me. Still powerful and strong but lil something's there. Wondering how much small intake flap arms will help, any other important codes like brakes and ESP? That warning on dash and trans light all activated after scan. Prior to that, just windshield washer fluid, parking sensor, few smaller issues. Is that normal? Oh, failed to mention clearing codes first then she lite up with dash warnings. Sorry, my first time posting but, all the electrical codes worry me. If this helps, last owner is an Engineer and known Audi Enthusiast with lots of DIY vids on YouTube so installing products like CarPlay, touch screen, kill switch for MMI retraction, Trunk motor hack (still an issue) Most of it all taken out so pretty sure reinstalling everything exactly how it was most likely not achieved. Thank you for any help with codes to look into immediately or adaptions/tests needed to get her running correct will be greatly appreciated.
Monday,22,February,2021,19:14:02:16705
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WAUML44E66N018209 License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 14 15 16 17 19 34 36 37 38 42 46
47 4F 52 53 55 56 57 61 62 65 67 6C 6D 72 76 77
VIN: WAUML44E66N018209 Mileage: 219940km-136664miles
14-Susp. Elect. -- Status: Cannot be reached 1100
34-Level Control -- Status: Not registered 0001
38-Roof Electronics -- Status: OK 0000
57-TV Tuner -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0EN780583
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E0505509C13516BD1E-807A
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
Mileage: 219556 km
RPM: 1143 /min
Load: 32.1 %
Temperature: 103.0°C
Temperature: 62.0°C
Absolute Pres.: 0.0 mbar
Voltage: 11.557 V
16485 - Mass Air Flow Sensor (G70)
P0101 - 004 - Implausible Signal - MIL ON
Fault Status: 11100100
Mileage: 219932 km
RPM: 638 /min
Load: 28.2 %
Temperature: 102.0°C
Temperature: 54.0°C
Voltage: 14.097 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Fault Status: 01101000
Fault Frequency: 11
Mileage: 219932 km
RPM: 638 /min
Load: 28.2 %
Temperature: 54.0°C
Voltage: 14.097 V
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0075167
Coding: 0000002
VCID: 2517FA7CC9E51233204-8070
009783 - Torque Management Feedback Signal A
P2637 - 000 -
Mileage: 219932 km
Date: 2021.02.19
Time: 17:00:16
RPM: 672 /min
RPM: 640 /min
(no units): 30.0
(no units): 36.0
Temperature: 68.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 221DE160D8CBE50B456-8076
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H08 0160
Revision: 01604808 Serial number: AUX3Z0EN780583
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58E98388CE177FDB6B2-800C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
Shop #: WSC 00000 785 00200
VCID: 2411E778C2DFEB3B37A-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 732 T HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346AY067529964
Coding: 0000003
Shop #: WSC 12345 111 45725
VCID: 3333142477317C83BE0-8066
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 391AX067509488
Subsystem 3 - Serial number: 7411.01.0600000000291B0225ÿ
Subsystem 4 - Serial number: 1B0225ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 E
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000083463
Coding: 0004417
VCID: 1C61DF98FAAFD3FB8FA-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO10012006065A000000000149ÿ†89
Subsystem 5 - Serial number: 000149ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO10012006065A00000000
Subsystem 7 - Serial number: 65A000000000157ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 36352D30644369AB99E-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00152621
Shop #: WSC 02313
Fault Status: 00101110
Fault Frequency: 103
Reset counter: 139
Mileage: 211300 km
Date: 2019.11.25
Time: 07:22:03
Reset counter: 136
Mileage: 219745 km
Date: 2021.02.15
Time: 12:42:18
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7264140
Address 14: Susp. Elect.
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q00043JJ
Coding: 0532707
Shop #: WSC 22145 444 61006
VCID: 2615FD70B4E3192B29E-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 3665U
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB400D44AE7Uÿ†63
Subsystem 5 - Serial number: 44AE7Uÿ†63428RB400D44999Rÿ†63
Subsystem 6 - Serial number: 44999Rÿ†63528RB400D44A5BRÿ†63
Subsystem 7 - Serial number: 44A5BRÿ†63628RB400D44A80Kÿ†63
Subsystem 8 - Serial number: 44A80Kÿ†63729RB400C68F79/ÿ†63
Subsystem 9 - Serial number: 68F79/ÿ†63829RB400C68F72Yÿ
Subsystem 10 - Serial number: 68F72Yÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 6597BA7C8965D233E04-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3F0003190
Coding: 0048263
Shop #: WSC 22145 444 67094
VCID: 323D1120882B758BB56-8066
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0830980C5
Coding: F5D5FF7730760E02
Shop #: WSC 11111 123 12345
VCID: 2D07025C91152A73E84-8078
00471 - Control Module for Elect. Regulated Dampers (J250)
Reset counter: 101
Mileage: 219932 km
Date: 2021.02.19
Time: 17:00:15
00317 - Rear Lid Control Module (J605)
Reset counter: 101
Mileage: 219932 km
Date: 2021.02.19
Time: 17:00:16
Reset counter: 101
Mileage: 219932 km
Date: 2021.02.19
Time: 17:00:19
Reset counter: 104
Mileage: 219940 km
Date: 2021.02.21
Time: 19:08:38
00467 - TV Tuner (R78)
Reset counter: 101
Mileage: 219932 km
Date: 2021.02.19
Time: 17:01:14
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A0D0940A0FB3D4B0D6-807E
Component: Sitzmemory FS H02 0010
Coding: 4071658
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H45 1100
Revision: 00000000 Serial number: 355LR057560061
VCID: 382923086E579FDB8B2-806C
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H03 0090
Serial number: 00000533500036
Coding: 0003477
VCID: 1D67D29CE1B5DAF3784-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
VCID: 2019EB68D6C7F71B532-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601040080
Coding: 0048766
VCID: 2809F348BEF70F5B1B2-807C
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000005316
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000076632
Coding: 0010111
VCID: 1E65D590ECB3C1EB61E-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T12BX05
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Reset counter: 104
Mileage: 219932 km
Date: 2021.02.19
Time: 17:11:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Reset counter: 104
Mileage: 219932 km
Date: 2021.02.19
Time: 17:12:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Fault Frequency: 0
Reset counter: 136
Mileage: 219744 km
Date: 2021.02.15
Time: 12:42:46
Fault Frequency: 0
Reset counter: 136
Mileage: 219744 km
Date: 2021.02.15
Time: 12:42:46
02116 - Mirror Adjusting Motor
Fault Status: 00100111
Fault Frequency: 0
Reset counter: 141
Mileage: 219936 km
Date: 2021.02.19
Time: 18:15:28
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
VCID: 1F1BE894EBB9C8E36A8-804A
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 235
Voltage: 9.63 V
Count: 61
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Coding: 0000018
Shop #: WSC 22145 444 105034
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH01 0010
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396AV067531459
Coding: 0000002
VCID: 313F1E2C8D2D4E93CCC-8064
Address 57: TV Tuner
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009124
Shop #: WSC 22145 444 59261
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1601100495
Coding: 344530393135313035412056413031363031313030343935
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Fault Frequency: 0
Reset counter: 136
Mileage: 219744 km
Date: 2021.02.15
Time: 12:42:46
Fault Frequency: 0
Reset counter: 136
Mileage: 219744 km
Date: 2021.02.15
Time: 12:42:46
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900036899
Coding: 0232125
VCID: 5F9BA894AB3988E32A8-800A
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000512190133
Shop #: WSC 12336 024 394758
VCID: 34311738723F7BBBA7A-8060
Address 6C: Back-up Cam.
Address 6D: Trunk Elect.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720601002754
Coding: 0221208
VCID: 2313E464C7D1EC034E0-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H11 0700
Revision: 00000000 Serial number: 00000007527136
Coding: 0010900
End----------(Elapsed Time: 02:30, VBatt start/end: 14.4V/14.3V)-----------
