- Feb 22, 2021
- 3
- 0
- Forest, ON, Canada
- C?ID=81116
Hello, I have a 2015 golf TDI with about 164000 km with the VW emissions fix. In a basic settings scan I found the following data
Thursday,18,February,2021,18:16:32:41366
VCDS Version: 20.12.0.1 (x64)
VIN: 3VWRA7AU4FM062678
IDE05387 Exhaust gas model temperature 1 127.8 °C
IDE05388 Exhaust gas model temperature 2 120.6 °C
IDE05389 Exhaust gas model temperature 3 107.5 °C
IDE05390 Exhaust gas model temperature 4 -0.0 °C
Number 4 temperature never changes at any time. I assume this is a sensor and if so, is it a bad sensor? Or perhaps unused?
There are no engine fault codes to suggest a problem. If it is a used sensor, where is it located?
On a similar note, I have an oil temp sensor, also never changing in temperature:
IDE06391 Oil temperature sensor 2 -0.0 °C
I would appreciate any help in interpretation of the two fixed temp readings. Thank you in advance!
