Superb start/stop deactivation not possible
Dixon
Serbia
C?ID=418067
Guys, does anyone know solution for start/stop deactivation? Start stop voltage limit in gateway adaptations set to 12.1V, but ss still turns off the car... Also tried changing start-stop temperatures but received error via vcds that request is out of range. Then tried via vcp OCF procedure for ss deactivation, went ok. Read gateway adaptations and found that OCF set voltage limit to 12.1, and temperatures to 70C. Test drive, and car still turns off (ss works)... ANY solutions welcome...
Auto-scan:
Friday,05,February,2021,11:34:31:52361
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: TMBCJ9NP7G7018209   License Plate: F-002_3
Mileage: 109530km-68058mi   Repair Order:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 52
          55 57 5F 6C 6D A5 CA
VIN: TMBCJ9NP7G7018209   Mileage: 109530km-68058miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FP    HW: 04L 907 309 M
   Component: R4 2,0L EDC   H22 1196
   Revision: B4H22---
   Coding: 011D0032046601083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026FP 002001
   ROD: EV_ECM20TDI01104L906026FN_002_SK48.rod
   VCID: 7DA7FD428D7DA673184-8028
   Part No SW: 0D9 300 011 T    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4801
   Revision: 06253104    Serial number: TFK01508042008
   ROD: EV_TCMDQ250021.rod
   VCID: 2615F22E386BC5AB29E-8072
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 62285000000468
   Coding: 1D076A9C34210B740779070041CC49B8562CD0E0E08292F538615078C289
   VCID: 7AADF65E9C53914B3D6-802E
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0709
   Revision: 00036000    Serial number: 0377207948
   Coding: 030C0C0703
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3A2D365EDCD3514B7D6-806E
   Subsystem 1 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65029876
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 AN    HW: 3V0 907 044 AN
   Component: AC Automat    H32 3702
   Revision: 20K04000    Serial number: 00000B00017162
   Coding: 11010104000400011005100100101102
   ASAM Dataset: EV_ACClimaPrehVW37X 002012
   VCID: 005984B6FA8FCB9B732-8054
   Rear A/C control head:
   Subsystem 1 - Part No SW: 3V0 907 049 C    HW: 3V0 907 049 C
   Component: E265KlimaHeck  H02 0101
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Fault Frequency: 13
                    Reset counter: 166
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:21:14
                    Outside temperature: 23.5 °C
                    Voltage terminal 30: 12.3 V
                    Air quality status: Malfunction
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061523201600
   Coding: 0C919B66C0C722FB17A44086B11C172C0800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9992C9B58AD324C-805C
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 150724  032 0121
   Serial number: 00000001507210310263
   Coding: 1E5DFD
   Component: RLHS  037 0059
   Serial number: S5Y15M08D28H10M24S08
   Coding: 0688DF
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY151951ZR2
   Serial number: 00000000000063156723
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0036923
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0034194
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0035738
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0036068
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183615237
   Coding: 0271165851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 0D47AD82BDDD96F3084-8058
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 320067C351FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311866FEB7A73BA7A-8060
   Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
   Component: AirbagVW21    005 0130
   Serial number: 003NSR111LU6
   Coding: 98FCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   VCID: 03538BBAEB99D0836E0-8056
   Left seat belt tensioner:
   Serial number: 3V0857701C0238P00538
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3V0857702C0238P00277
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 708 15
   Serial number: 357000000003F6013617
   Subsystem 4 - Part No SW: -----------    HW: 480 001 808 15
   Serial number: 35800000000FB184E51W
   Subsystem 5 - Part No SW: -----------    HW: 480 401 808 15
   Serial number: 3510002A31CF2D8372BC
   Subsystem 6 - Part No SW: -----------    HW: 480 401 808 15
   Serial number: 3520002A31CF2D8480FH
   Subsystem 7 - Part No SW: -----------    HW: 480 401 108 15
   Serial number: 35500029D1C1EFA530BN
   Part No SW: 3Q0 953 521 BD    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20150820400977
   Coding: 6410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73B3DB7ABB39E0037E0-8026
   Part No SW: 3V0 920 751     HW: 3V0 920 751
   Component: KOMBI         312 6421
   Coding: 07A5001AAF800008018A6A095001000000000000
   VCID: 71BFD172C125D2138CC-8024
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 24081510801639
   Coding: 0B0100384E087300EB00025E9C0F00010001070000000000000000000000
   Shop #: WSC 26088 002 104857
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E562B54DFE33504-8020
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B0326060815
   Serial number: 8218807503
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: WECHSELRICHTE  H53 0033
   Serial number: 0142565
0769 - Analog Measuring Input
          C1155 31 [009] - No Signal
                    Reset counter: 165
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:21:15
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00017.06.15
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 46D552AE982B25AB09E-8012
   Serial number: 15000045163014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OGH13844
   Coding: 001000000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_001.rod
   VCID: 3B23335AD3E96843660-806E
   Serial number: 0401586950
   Coding: 02011103
   Shop #: WSC 55584 002 1048576
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C213046D6E76F7B6FA-8068
   Serial number: 0392910364
   Coding: 020111
   Serial number: 210715BGK11893
   Coding: 001D0820DE00048000001100
   VCID: 43D34BBAAB1910832E0-8016
   Serial number: 00000000000006925797
   Coding: 110200
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2033
   Revision: 00000000    Serial number: 0000333706
   Coding: 01010010005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 A    HW: 3Q0 035 466 A
   Component: MIB2_amp_P_SK H02 0110
   Revision: 00000001    Serial number: SKZ8Z1FAS00H93.
   Coding: 0384010000AA002FAA0000000000
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: 2D070D021D9DF6F3E84-8078
   Serial number: 240715BGO04221
   Coding: 001D0220DE00048000001100
   VCID: 42DD4EBEB403198B256-8016
   Serial number: 00000000000007032006
   Coding: 090200
   Coding: 06EA00003F010000
   VCID: 40D944B6BA0F0B9B332-8014
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B20000
Address 57: TV Tuner (R78)       Labels:* None
   Part No SW: 8V0 919 191 C    HW: 8V0 919 191 B
   Component: DVB-DTV       H09 1800
   Coding: 0304200000000100000000
   ASAM Dataset: EV_TVMELC 001033
   ROD: EV_TVMELC_VW37.rod
   VCID: 3FDB474AC7F174634A8-806A
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 A    HW: 3V0 035 020
   Component: MU-H-ND-EU    H42 0318
   Serial number: A435H0F7515687
   Coding: 038401010000000011111202008008202F0001E401208100FE
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 2411E8264E5737BB37A-8070
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H44 1028
   Serial number: SKZ8Z9RAM006JP
   Subsystem 2 - Part No SW: V03 959 801 JJ    HW: -----------
   Component: ECE 2015/2016  --- 0122
   Compact disc data bank:
   Component: Gracenote2  --- 1011
13 Faults Found:
1585 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for ASAM/ODX MUX]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
                    Voltage terminal 30: 12.6 V
1586 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for speed shutoff thresholds]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
1587 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for language]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
1588 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for visible MMI system languages]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
1589 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for power management timer]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
1590 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for sound audio parameters]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
1592 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for DAB frequency tables]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
1595 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for audio management HMI constants]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
1652 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for eco HMI]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
1655 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for sound announcement audio parameters (optional)]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
1656 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for sound cabriolet audio parameters (optional)]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
1657 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for sound configuration audio parameters (optional)]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
1603 - invalid data record
          B2005 00 [008] - -
          [Control module (data record download) - invalid data record for speech signal enhancement - telephone/voice recognition signal processing (SSE)]
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 04840101A600201F000040
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
   VCID: 77ABEF6AAF418C23428-8022
   Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Component: HDSG-Modul    H12 0250
   Revision: --------    Serial number: 30212613700000
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU736 001011
   ROD: EV_DeckLidCONTIAU736_AU73.rod
   Part No SW: 3Q0 980 654     HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0010
   Serial number: 28081511P11377
   Coding: 020408010000010100262346C040A10000000E100020
   VCID: 74B1D866BE37E73B67A-8020
   Part No SW: 4M0 907 594 E    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 608000648101
   VCID: 38292C56E2DF435B8B2-806C
End----------(Elapsed Time: 02:21, VBatt start/end: 12.4V/12.4V)-----------
Now saw that batt voltage was 12.4 when car the car was scanned. Now I figure out that voltage is higher than 12.1V and because of it, car still turns off when stopped. How to disable ss on this car? Also I tried putting 12.5 when coded just to view if higher limit can solve it but received error that request is out of range...
TBAx
C?ID=287144
the only currently known way is to downgrade the Gateway, as far as I remember.
Dixon
Serbia
C?ID=418067
How do you mean to downgrade? There is no lower version than this one that is on car? Talking about skoda erwin flash files...
dark5had0w
Australia
C?ID=356542
I fitted a Start-stop memory device in my Superb (MY17).
It's perfect for me. It remembers the last state of the start-stop when u turn off the car.
So the next time u start the car, start-stop retains the previous state.
No fluffing around with voltages.
I can still use the start-stop function if I choose to.
Highly recommended.
They have one for all the different MQB models.
al capone
France
C?ID=312591
Auto-scan:
   Revision: B4H22---
          P1734 00 [002] - -
   Coding: 030C0C0703
                    Fault Frequency: 13
                    Reset counter: 166
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:21:14
   Coding: 1E5DFD
   Coding: 0688DF
   Coding: 0271165851
   Coding: 80000D
   Coding: 80000D
   Coding: 6410
   Generator:
                    Reset counter: 165
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:21:15
                    Terminal 15: On
   Coding: 0301
   Coding: 02011103
   Coding: 020111
   Coding: 110200
   Coding: 090200
   Coding: B20000
   Coding: B20000
13 Faults Found:
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:31
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
          B2005 00 [008] - -
                    Reset counter: 205
                    Mileage: 109440 km
                    Date: 2021.02.04
                    Time: 11:24:32
   Jeu de données ASAM: EV_CamSysRVRVCPANAMQBAB 005007
   TIGE: EV_CamSysRVRVCPANAMQBAB_005.rod
Aucun code d'erreur trouvé.
Adresse 6D: Trunk Elect. (J605) Étiquettes: | 5Q0-959-107.clb
   No.pièce SW: 5Q0 959107 G Mat: 5Q0 959107 G
   Composant: HDSG-Modul H12 0250
   Révision: -------- Numéro de série: 30212613700000
   Codage: 1008
   N ° boutique: WSC 33361790 00063
   Jeu de données ASAM: EV_DeckLidCONTIAU736 001011
   TIGE: EV_DeckLidCONTIAU736_AU73.rod
Adresse A5: Frt Sens. Drv. Assist (R242) Étiquettes: | 3Q0-980-65X-A5.clb
   No.pièce Log: 3Q0 980654 Mat: 3Q0 980654
   Composant: MQB_B_MFK H04 0010
   Numéro de série: 28081511P11377
   Codage: 020408010000010100262346C040A10000000E100020
   Jeu de données ASAM: EV_MFKBoschMQBB 001001
   TIGE: EV_MFKBoschMQBB_001_VW36.rod
Adresse CA: Toit ouvrant (J245) Étiquettes: | 4M0-907-594.clb
   No.pièce SW: 4M0 907594 E Mat: 4M0 907594
   Composant: SAD_STG_1 011 0003
   Codage: 608000648101
   N ° boutique: WSC 73430790 00063
   Jeu de données ASAM: EV_SunRoofCONTIAU736 004008
   TIGE: EV_SunRoofCONTIAU736_004.rod
Fin ---------- (Temps écoulé: 02:21, VBatt début / fin: 12.4V / 12.4V) -----------
Maintenant, j'ai vu que la tension de la nappe était de 12,4 lorsque la voiture a été scannée. Maintenant, je comprends que la tension est supérieure à 12,1 V et à cause de cela, la voiture s'éteint toujours lorsqu'elle est arrêtée. Comment désactiver les ss sur cette voiture? J'ai également essayé de mettre 12,5 lorsqu'il était codé juste pour voir si une limite supérieure pouvait le résoudre mais que j'avais reçu une erreur indiquant que la demande était hors de portée ...vv avec VCDS 21.3.0 - (10 ) assitance de stationement - adaptation 10 - canal IDE 04159 - désactivation de la fonction START - STOP ( active / inactive )
Maintenant, j'ai vu que la tension [....]
@al capone: Hi!
Et lorsque vous soumettez un post révisé (en anglais) comme demandé par @Uwe, veuillez également inclure un autoscan pour la voiture (également en anglais).
La version anglaise du logiciel VCDS coexistera volontiers avec la version française
à votre santé
al capone
France
C?ID=312591
with VCDS 21.3.0 - (10) stationing assitance - adaptation 10 - channel IDE 04159 - disable START - STOP function (active/ inactive)
@al capone: hmmm.......... your post above is unfortunately a tad too cryptic to understand! (for me, at least)!
So, alas I'm not sure what point you are making - but, taking a large leap of assumption, there ain't nothing special about IDE04159; this channel often appears in multiple modules on MQB platform vehicles. I'm also not sure that identifying a particular instance of the adaptation channel on the hex10 module will advance your objective.
Fact is that there are 4 x established methods for deactivating Start Stop on MQB platform cars via coding changes:
  1. Voltage method
  2. Temperature method
  3. Gateway method
  4. Prohibition method (which uses IDE04159 -but on the hex19 module)
These methods notwithstanding, it appears that VW/Audi/Seat has clamped-down on the ability to tweak SS on later model cars. So depending on the build date of your car - it's entirely possible that none of the methods listed above will work. On cars that fall into this category, the ONLY alternative is to install a physical, electronic device across the native SS switch that automatically sends a SS kill signal to the BCM shortly after ignition switch-on. Of course, if the car uses "capacitive" type soft-switches, even this solution won't work
But - it ALL starts with you posting a FULL, unedited auto-scan of the vehicle in question - in English, please!!
