Long coding questions
   #41
RBDJ
Australia
C?ID=425643
Hi Uwe
I have reset to many different combinations including your response #26, no luck always an error 31. I don't know who you guys all are and I am for form being in a position to understand your skillsets and knowledge and the efforts to date have been very kind.
Is there perhaps a VCDS technician on this site that could answer how to recode this module or is this ODIS territory, and again I'm not passing judgement on anyone on here.
Regards
Rob
   #42
South Molton, UK
No Petrol Dave it is not, the last letter is different -OLD "C" NEW "K". It is however out of an A4 and I was helped by some Audi techs in choosing this one, I had one before from a A5 that was problematic.
Even if this part was wrong I still should be able to code it. Nobody has really been able to answer - is all of this because of component protection?
It's entirely possible that the K version has a different length long coding string to the C version.
You're going to have to go to a dealer (or an independent with Fazit access) to clear the component protection at some time, so I would be very tempted to do that now - and see if they can restore the original #09 coding at the same time?
RBDJ
Australia
C?ID=425643
I do agree, but why wouldn't long coding assistant help? If I just changed from halogen to led running lights for instance in the new module the slight change of coding should be accepted surely?
Rob
   #44
South Molton, UK
I guess I'm speculating that because CP is active the module won't accept coding changes, hence why I suggested that you might consider going to the dealer now rather than keep trying to make coding changes.
   #45
Hi guys,
I'm late to this party and there were a lot of good suggestions already.
I searched our scans and both 8K0 907 063 C -and- 8K0 907 063 K use the same 27 Byte coding length so that's not the problem. The original scan (or data from the original address 09 module) would help but at this point I suspect the 09 module won't accept coding:
1) Because it considers the new coding implausible. You can rule that out by entering the same (i.e. existing) coding string of:
690040B10034A7010001000000005F5F001D420802000141000000
If that's accepted, perhaps in conjunction with non-zero WSC and similar, you know the module will not accept the specific coding change(s) you are attempting to enter.
2) Because of the CP issue. In that case a trip to the dealer is worth a shot so they can unlock CP and try to code it.
   #46
From some of the CP videos I've seen on YT (by manufacturers with software to remove it) there is a characteristic to CP that when active
it only allows very limited functions (for safety) like defrost for example but only on high setting etc. So, even if it accepted your coding, you would only have very limited functions , if any, in the function capabilities of this module.
Also, dealers can be very different , from dealer to dealer, IF you show up with your own module and it is a different part number , they may or may not get involved - especially if the correct (to your car) PN is available. So, heads up Rob, I would call the dealer first and speak to the service manager before you go on a potential wild goose chase.
I think you have learned a great deal about vcds in this process ; but the CP is the problem here as your new module is not original to the car.
Also, the software and hardware like Abrites, etc. who do address this very issue would not spend all the effort if CP had a work-around. Abrites for example (better be sitting down for this) costs , just for CP removal (ie sourcing used parts and then adapting them to another vehicle) $1500.00 for hardware and $4000.00 for software AND $350.00/year for Mandatory updates!!! If you skip a year...... its double the next time you renew! Remember, that software is only for CP removal for modules , clusters, etc. ; its not for keys, or engine ecu's . I don't think these products would exist if you could simply "recode" used parts and use them....... right?
If you find a dealer who will cooperate with you, it would only be around $150.00 usd.
Here is a company in the UK who I have spoken with several years ago on this very topic , they are retrofitters and it is quite common in the UK because they have access to the Audi servers (laws are different there regarding access) chat with them if you really want to get into it!
RBDJ
Australia
C?ID=425643
Hi guys really appreciate the feedback, I will try the original coding tomorrow. In Aus the dealers won't even think about this stuff. It's just not worth their while, which I get.
Looking forward to the geniuses at Ross-tech finding a way to get around CP......
Rob
   #48
RBDJ
Australia
C?ID=425643
Hi all
So I was able to paste the current code straight in which tells me that the module will only accept that code. I have noticed that the J519 that I have now may have different pin outs as the interior/dash lighting will not work. If I put the original module back in that is water damaged the lights work straight away. I think I'll buy another module that is exactly the same from Europe on eBay and then if I can't code that one I'll setup ODIS and get someone to login to it remotely.
Frustrating thing is I bought VCDS at full price to recode this module and it can't.
Cheers
Rob
   #49
Bruce
Near Philadelphia, PA, USA
Ross-Tech did not implement CP. VAG did. That VAG will not permit Ross-Tech VCDS to connect to their servers, limits all users. That the function you desire to change is protected by Component Protection is not something we can change.
   #50
RBDJ
Australia
C?ID=425643
I understand that, my point still exists that I purchased the hardware with an unlimited licence because I called a Ross-Tech distributor in Sydney Australia and asked, "can I recode this module" - yep was the answer so I paid up immediately.
It seems though this is unknown territory. Nobody has definitely said "If it has CP you cannot recode it", the first comments I got when querying CP was "just recode the module". If that comes from RT employees I feel this is
luck of gods stuff and best of luck. I have tried all sorts of combinations in the hope it will apply the code change but no luck. I think the product is great but this feature should not be marketed as a selling tool.
Regards
Rob
   #51
Did you tell them you were installing a replacement module?
I ask this because the folks at the distributor you bought from are generally pretty knowledgeable and I'm confident they would not intentionally mislead a customer.
Since you've only had your HEX-V2 for about one month and you seem to feel that the distributor gave you incorrect information regarding the product's capabilities, I think we can persuade them to take it back if you wish.
RBDJ
Australia
C?ID=425643
Hi Uwe, I love this product so it's going nowhere. I have been able to find a wsc etc on the scan logs, I tried the codes from the cars original water damaged J519 and also the codes associated with the new J519. I also worked out today that the new one has a different pin config so that is why the interior and dash lights are so dim. I bought another one today on eBay.
Does anyone have any tips on getting in with these numbers, I noticed that the wsc looked good, one had 000 for the importer but both had 00000 for the equipment code. I tried different combination but still get error 31, is this because the CP is active and it won't matter what codes I put in?. When I put the old J519 in I can easily change coding.
Any tips much appreciated.
RB
NEtech
Denmark
C?ID=56995
Please post an Autoscan with the original J519 installed.
RBDJ
Australia
C?ID=425643
Good Morning - see below, from what I understand this is the original J519 (9)
Thursday,25,March,2021,17:53:00:28175
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
Workshop Code: 790 33361 000070
VIN: WAUZZZ8K99A079695   License Plate: A4B88K
Mileage: 105580km-65604mi   Repair Order: original J519
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
VIN: WAUZZZ8K99A079695   Mileage: 105580km-65604miles
09-Cent. Elect. -- Status: Malfunction 1010
Address 01: Engine (-----CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 A    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H12 0002
   Revision: E1H12---
   Coding: 0104000C180F0160
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM20TFS8K2907115A A01003
   ROD: EV_ECM20TFS8K2907115A.rod
   VCID: 2D0702DCDD97DE93E84-8078
4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
          U1010 00 [047] - -
          [Invalid Data Received From Park Brake Control Moduleplease read DTC]
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:00:12
                    Engine RPM: 0.00 /min
                    Coolant temperature: 41 ∞C
                    Intake air temperature: 25 ∞C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 11.944 V
7135 - Body Control Module (Central Electric)
          U0140 00 [032] - No Communications
5558 - Body Control Module (Central Electric 2)
          U0141 00 [032] - No Communications
7786 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [039] - Malfunction
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:29
                    Coolant temperature: 53 ∞C
                    Intake air temperature: 33 ∞C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 11.567 V
   Part No SW: 8K0 907 379 AB    HW: 8K0 907 379 AB
   Component: ESP8 quattro  H04 0060
   Coding: 070500
   VCID: 79AFE68C59DFB23334C-802C
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 231
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:01:09
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0013
                    Hex Value: 0x0294
                    Hex Value: 0x00FF
                    Reset counter: 231
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:29
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0017
                    Hex Value: 0x3394
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AL    HW: 8K0 907 064 AL
   Component: BCM2 1.1      H71 0134
   Coding: 071100
   VCID: 7AADF9805CD9B92B3D6-802E
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000036336009
                    Reset counter: 231
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:02
   Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D0000000    Serial number: 0114.07.080689
   Coding: 64046000
   VCID: 42DD4160748931EB256-8016
                    Reset counter: 0
00898 - Control Circuit A/C compressor
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:40
                    Current: 0.450 A
                    Current: 0.000 A
                    Voltage: 12.90 V
01231 - Right Footwell Vent Temperature Sensor (G262)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.04
                    Time: 18:16:45
                    Temperature: 24.0∞C
                    Voltage: 11.40 V
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H22 0253
   Revision: 04022001    Serial number: 00000000186059
   Coding: 260050914034AF010001000000001D0D0F1D030800010141000000
   VCID: 2F3B18D4D71BAC83DA8-807A
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 110708  H05 0070
   Serial number: SWFBIE 0000148
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10189657
   Coding: 025028
9 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 231
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:46:00
01516 - Terminal 30; Left
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 20:12:00
00927 - Terminal 30 (Right)
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 20:12:00
00926 - Terminal 30
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 20:12:00
03123 - Terminal 30 - 2
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 20:12:00
00576 - Terminal 15
                    Reset counter: 16
                    Mileage: 103417 km
                    Date: 2021.02.09
                    Time: 16:49:00
02838 - Solenoid Valve for Servotronic (N119)
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.04
                    Time: 18:16:00
01800 - Light Switch (E1)
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.09
                    Time: 15:59:00
03280 - Switch Position of Light-Switch Knob
                    Fault Status: 01101000
                    Reset counter: 231
                    Mileage: 1048574 km
   Part No SW: 8K0 919 475 C    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0010
   Revision: 11001001    Serial number: 75240813401401
   Coding: 100102
   VCID: 392F268C195F723374C-806C
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:00:08
                    Temperature: 25.0∞C
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD17M782
   Coding: 30373434363030303030554A3052384B3053
   VCID: 3C213F9816ED471B6FA-8068
   Serial number: 6334MSME3D72050BE
   Serial number: 6344MSME3D716A3FW
   Serial number: 6352QSME757A1E1F.
   Serial number: 6362QSME770314437
   Serial number: 63732SME7673415B0
   Serial number: 63832SME6D6645737
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HGF000DP
   Coding: 000016
   VCID: 3D27329C0D774E13584-8068
                    Reset counter: 15
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:03
                    Reset counter: 231
                    Mileage: 1048574 km
   Part No SW: 8K0 920 900     HW: 8K0 920 900
   Component: KOMBIINSTR.   H16 0221
   Revision: 00200000    Serial number: 98R331J78
   Coding: AF04090002000008010000
   VCID: 678BB0F43F6B34C3D28-8032
                    Reset counter: 231
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:46:44
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G08707805E
   Coding: 000303
   VCID: 46D55D7058A10DCB09E-8012
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1802EA78010708
                    Fault Frequency: 14
                    Reset counter: 15
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:01:27
                    Reset counter: 15
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:02
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007457436
   Coding: 011C12204101410001
   VCID: 3FDB4894077B5C034A8-806A
                    Reset counter: 16
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:07
                    Fault Frequency: 91
                    Reset counter: 16
                    Mileage: 103417 km
                    Date: 2021.02.03
                    Time: 18:18:03
   Revision: 00002001    Serial number: 0112958152
   Coding: 01000E2200390445003001
   Subsystem 1 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:00:13
                    Reset counter: 15
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:02
                    Reset counter: 231
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:29
                    Reset counter: 15
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:36
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S1900000
   Coding: 0203010102
   VCID: 6E85C5D01091E58B91E-803A
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007466508
   VCID: 3E2535900071550B41E-806A
                    Reset counter: 16
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:07
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000175176
   VCID: 313F1EACC12FBA73CCC-8064
03182 - Clutch Position Sensor (G476)
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:00:08
                    Voltage: 12.00 V
                    Count: 52
                    Hex Value: 0x0263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000004
   Shop #: WSC 06324 000 00000
   VCID: 343117B8323D8F5BA7A-8060
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 195 H    HW: 8T2 035 195 H
   Component: Symphony3     H02 0210
   Revision: 00000004    Serial number: AUZ5Z4H1026630
   Coding: 0502008201018D00035B070000
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
                    Reset counter: 16
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 16:07:19
03138 - Input AUX IN
                    Reset counter: 190
                    Mileage: 104011 km
                    Date: 2021.02.24
                    Time: 19:26:49
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007445330
   Coding: 010C12204001210001
   VCID: 7F5B089447FB9C030A8-802A
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007416358
   VCID: 7EA5F59040F1950B01E-802A
   Part No SW: 8T0 862 335 A    HW: 8T0 862 335 A
   Component: FSE_256x BT     H33 0520
   Revision: 00000000    Serial number: 00000005016746
   Coding: 0010320
   Shop #: WSC 20120 822 96268
   VCID: 382923882E556B3B8B2-806C
End----(Elapsed Time: 01:26, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
Address 09,8K0 907 063 C,recoded (Long Coding),from,260050914034AF010001000000001D0D0F1D030800010141000000,to,260050914034AF010001000000001D0D0F1D030800010141000001,(33361/790/00070),
Address 09,8K0 907 063 C,recoded (Long Coding),from,260050914034AF010001000000001D0D0F1D030800010141000001,to,260050914034AF010001000000001D0D0F1D030800010141000000,(33361/790/00070),
RBDJ
Australia
C?ID=425643
Hi NEtech, does this give any clues?
Cheers
Rob
   #56
NEtech
Denmark
C?ID=56995
You use the old coding 260050914034AF010001000000001D0D0F1D030800010141000000 in other "new" installed BCM's.
I doubt the one you have installed 8K0 907 063 K is correct.
If I search for 8K0 907 063 K (23 scans), then in general all have Halogen lamps, you have xenon.
When checking on Partslink24 for your VIN, 8K0 907 063 D is shown.
RBDJ
Australia
C?ID=425643
Hi Again Guys - so the new module came. I installed it and ran the scan below. What has really bugged me is the interior lighting and dash illumination is still faulty, but if I plug the water damaged one back in it works perfectly. These modules are exactly the same part number. Coding worked perfectly so all the Xenon lights etc are working. The only issues are -
Dash interior lighting (pin config I believe)
Cruise control not working (went into engine module, tuned it off and back on still not working)
Idle is too low (can't access any channels in VCDS ENG107764-No Data Identifier Found)
Any ideas guys?
Here is the scan before coding -
Many thanks
Wednesday,07,April,2021,16:48:06:28175
Workshop Code: 552 08316 012345
VIN: WAUZZZ8K99A079695   License Plate: A4B8L8EST
Mileage: 106350km-66082mi   Repair Order:
VIN: WAUZZZ8K99A079695   Mileage: 106350km-66082miles
   Revision: E1H12---
          U1010 00 [047] - -
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:00:12
                    Coolant temperature: 41 °C
                    Intake air temperature: 25 °C
          P0070 00 [032] - Malfunction
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:29
                    Coolant temperature: 53 °C
                    Intake air temperature: 33 °C
                    Unlearning counter according OBD: 22
   Coding: 070500
                    Reset counter: 249
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:01:09
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0013
                    Hex Value: 0x0294
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 15
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:29
                    Hex Value: 0x0000
                    Hex Value: 0x0082
                    Hex Value: 0x0017
                    Hex Value: 0x3394
                    Hex Value: 0x00FF
   Coding: 071100
                    Reset counter: 33
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:02
   Coding: 64046000
                    Reset counter: 16
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:40
                    Current: 0.450 A
                    Current: 0.000 A
                    Voltage: 12.90 V
                    Fault Status: 00101010
                    Reset counter: 16
                    Mileage: 103417 km
                    Date: 2021.02.04
                    Time: 18:16:45
                    Temperature: 24.0°C
                    Voltage: 11.40 V
   Revision: 04022001    Serial number: 00000000234132
   Coding: 260050914034AF000001000000001D0D001D070800010141000000
   Shop #: WSC 06335 000 00000
   Coding: 00FD11
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001907081472
9 Faults Found:
                    Fault Status: 00101100
                    Fault Frequency: 57
                    Reset counter: 12
                    Mileage: 355161 km
                    Date: 2020.07.05
                    Time: 23:11:00
                    Reset counter: 249
                    Mileage: 106356 km
                    Date: 2021.04.07
                    Time: 17:44:00
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Reset counter: 34
                    Mileage: 360564 km
                    Date: 2020.10.19
                    Time: 13:51:00
                    Reset counter: 14
                    Mileage: 1048574 km
                    Reset counter: 34
                    Mileage: 360564 km
                    Date: 2020.10.19
                    Time: 13:07:00
                    Reset counter: 14
                    Mileage: 1048574 km
                    Reset counter: 14
                    Mileage: 1048574 km
                    Reset counter: 14
                    Mileage: 1048574 km
00908 - Control Module for Wiper Motor
                    Reset counter: 14
                    Mileage: 1048574 km
   Coding: 100102
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:00:08
                    Temperature: 25.0°C
   Coding: 000016
                    Reset counter: 33
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:03
                    Reset counter: 15
                    Mileage: 1048574 km
                    Reset counter: 15
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:46:44
   Coding: 000303
                    Fault Frequency: 16
                    Reset counter: 231
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:01:27
                    Reset counter: 33
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:02
                    Reset counter: 16
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:07
                    Fault Frequency: 120
                    Reset counter: 33
                    Mileage: 103417 km
                    Date: 2021.02.03
                    Time: 18:18:03
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:00:13
                    Reset counter: 33
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:02
                    Reset counter: 15
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:29
                    Reset counter: 15
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:47:36
   Revision: S1900000
   Coding: 0203010102
                    Reset counter: 16
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 17:45:07
                    Reset counter: 170
                    Mileage: 103417 km
                    Date: 2021.02.02
                    Time: 17:00:08
                    Voltage: 12.00 V
                    Count: 52
                    Hex Value: 0x0263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Coding: 0000004
   Component: Display
                    Reset counter: 16
                    Mileage: 105586 km
                    Date: 2021.03.25
                    Time: 16:07:19
                    Reset counter: 190
                    Mileage: 104011 km
                    Date: 2021.02.24
                    Time: 19:26:49
   Coding: 0010320
End----------(Elapsed Time: 01:28, VBatt start/end: 12.0V/12.1V)-----------
RBDJ
Australia
C?ID=425643
Hi Guys any ideas on this -
Thanks again
Rob
