Hi DrPeter,
Thanks for your response
My background is primarily industrial electronics
PLC (programmable logical controllers)
control and automation.
These devices are similar to the in modern vehicles only much
more powerful.
The reason i have started to investigate this problem is due to the
vast number of failures and issues associated with the system.
Fault codes P0407 and P046C make reference to Sensor 1 & 2 i have totally convinced myself only one sensor exists physically.
I will accept this sensor could be labelled sensor 1 on the Bosch platform and possibly sensor 2 on the Delphi platform and that there could be many different fault codes associated with a particular sensor that’s not an issue. How i identify the device is by fault simulation simply unplug it and see what fault code is generated works 100%. If you unplug the you will get either Sensor 1 or Sensor 2 depending on what platform. I have went through all sensors one at a time to check the fault codes all of which were accurate and correct.
The positioner has only one output (feedback) to the
an analog signal in the range of approximately
0.8V (closed) to 3.9V (open) generated from the little hall effect magnetic pickup IC as in photo. I am aware other sensors values may be taken into consideration when calculating the overall performance and operation of the eg, mass air flow, charge pressure & temp, ambient temp, exhaust gas temp, oxygen % fuel injection quantity, throttle position, etc,etc. But all these devices generate their own unique individual fault codes.I think only the guys who write the code for these fault will know the true source of sensor 1 and sensor 2 appearing on the same platform.
Many Thanks
Regards VW1
