this is long [redacted]Yes, that's the short serial number.
Right. Now you have everything you need to fill out the registration form.this is long [redacted]
What I have to do more about verify me, and get help about this long coding?
Hello, Can you make for me this long code? radvilasandrius@gmail.com. Not for free
Hello. Everithing fine, today I am more lucky than another day fill this form. I Hope it is was the last step to verifi?Dear friend,
You don't need blue certificate, at all. Forget the blue certificate.
Just fill form with data you already have. HC number, long number and another data in fields for that. Need about 1 minute for do that.
Become verified and you can ask for help whenever you need it. For verified users, we are here to help. Always. Selfless and free.
If there’s a reason you don’t want to do it, we’ll accept it.
Thank you, I will try today in the morning, and let you knowHere, try. If the verification did not go well, I accept the guilt.
Ver. 1: Vacuum sensor NO: 143B6012092500FB280C06E490200040340800
Ver. 2: Vacuum sensor YES: 143B6012092500FB280C06E490200041340800
Old ABS/ESP module 1K0907397AD long coding 113B2012092500FB880C04F4902000413400
Exaly second with +00 in the end. I used old coding until I faind out what is to short for this modul in the end AH I used for this car, old was AD and coding was shorter. Many thanks for yours all helps.I see an issue there. That coding contains an error related to the 16th digit of the VIN. I'm pretty sure the factory coding was:
113B2012092500FB880C04E5902000413400
rather than:
Next, the coding length has changed so even if you used 113B2012092500FB880C04E5902000413400 it would be rejected by the installed module. For this reason you can try adding a pair of 00's to the end of the factory coding. Doing so may allow you to code this 2010 MY ABS module to your car. The experimental/new coding would be:
113B2012092500FB880C04E590200041340000
If that's accepted the MK60EC1 replacement steps here apply:
MK60EC1 ABS FAQ
MK60EC1 ABS modules use a complex soft coding structure that varies from vehicle to vehicle. We strongly suggest everyone run an Auto-Scan BEFORE information is lost. VCDS automatically saves Auto-Scans. If an Auto-Scan was performed prior to the soft coding being lost, you can retrieve that...forums.ross-tech.com
Hello, coding was acepted with the old code just entered +00 in the end. For old Abs module AD was shorter coding than in the new with AH. Many thanks.Here, try. If the verification did not go well, I accept the guilt.
