Right Guys wife was driving the car all interior electrics shutdown only thing working was rev counter no MMI,DIS etc said she couldn't turn the car off at that time managed to go collect the car did full auto-scan came back with list over voltage faults saved that log cleared them without moving the started no problem then bang lot shutdown again but engine still running
hoping altenator /alt clutch fault
Here's the log for some electronic guru
Thanks in advance
Thanks in advance
Tuesday,24,March,2015,11:15:02:55366
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WAUZZZ8K2 License Plate:
Mileage: 131470km-81691mi Repair Order: 002
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 72
VIN: WAUZZZ8K2 Mileage: 131470km-81691miles
Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
Component: R4 2,0L EDC H25 9098
Revision: 25H25---
Coding: 0A194012232503080000
Shop #: WSC 00779 210 97010
ASAM Dataset: EV_ECM20TDI03L906022NP A02009
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 000F8F139BDB45216EF-8055
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Coding: 160504
Shop #: WSC 06325 000 00000
VCID: 7EF3F1EBE92F33D11C3-802B
Fault Status: 00100001
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:52
Hex Value: 0x0000
Hex Value: 0x4026
Hex Value: 0x1003
Hex Value: 0x22D4
Hex Value: 0x00FF
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:47
Hex Value: 0x0000
Hex Value: 0x5726
Hex Value: 0x1033
Hex Value: 0x03D9
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CC HW: 8K0 907 064 CC
Component: BCM2 2.0 H04 0430
Coding: 033100
VCID: 73E5D0DFD26D6EB963D-8026
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0071
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:48
Fault Status: 00101101
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:47
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Revision: D1000000 Serial number: 01120720100735
Coding: 34340000
VCID: 77FDE4CFC61502995F5-8022
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:48
Voltage: 16.30 V
Temperature: 17.0°C
RPM: 840 /min
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H29 0392
Revision: 10029001 Serial number: 00000000730365
Coding: 260052114034AF211701000300001D0D4F9D030806010141000000
Shop #: WSC 06325 123 12345
VCID: 3C773BE3BFB3E1C1727-8069
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 060710 H05 0070
Coding: 00F511
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:00
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:00
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941019406772
Coding: 100203
VCID: 489F5733FB6BBD61E6F-801D
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:47
Temperature: 17.0°C
Reset counter: 100
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:52
Temperature: 17.0°C
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0J3B0%
Coding: 30363435363030303030554A3052384B3053
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 44874303CF4399010A7-8011
Serial number: 6334MSME55633A60B
Serial number: 6344MSME5501481A8
Serial number: 6352QSME6B671730I
Serial number: 6362QSME2862253AG
Serial number: 63732SME08661622U
Serial number: 63832SME08662908$
13636096 - Supply voltage
U1012 00 [008] - Voltage too High
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:58
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315JGD000KV
Coding: 000016
VCID: 3D7136E7A4A9E8C9459-8068
Component: E221 - MFL H02 0010
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:52
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:47
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 981 D HW: 8K0 920 981 D
Component: KOMBIINSTR. H21 0258
Revision: 00000000 Serial number: EJD62597A
Coding: 2F1D080002002600010000
VCID: 346713C397E32981BA7-8061
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:47
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E1070782E6
Coding: 00CF07
VCID: 0305801F82CD5E3973D-8056
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H16 0038
02252 - Generator
Fault Status: 00101100
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:07
Bin. Bits: 01111
Voltage: 17.30 V
Count: 6
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:47
Bin. Bits: 01111
Voltage: 17.70 V
Count: 6
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C02204001410001
VCID: 53A5705F322D0EB983D-8006
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:51
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0132679566
Coding: 011F062200B904408320013680000000
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:47
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
Coding: 011C02204401410001
VCID: 52AB755B0D3707B188B-8007
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:51
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000694716
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:47
Voltage: 18.30 V
Count: 45
Hex Value: 0x0263
Hex Value: 0x0081
Hex Value: 0x1010
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H01 0010
Coding: 0000004
VCID: 397922F77081D4E9691-806C
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:43
Part No SW: 4G0 035 056 H HW: 4G0 035 056
Component: Radio U STD H51 0134
Revision: AB001007 Serial number: 469G+0A7533372
Coding: 010003020100000001
VCID: 2643F98B513F4B11343-8073
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 652 L HW: 8T2 035 652 D
Component: B-BN-EU H58 0188
Revision: -------- Serial number: 305GW0A7514096
Coding: 010101000106C1ED07000F0E000000030000
VCID: 3F8D4CEFAEA5FAD9575-806A
Subsystem 1 - Part No: 4G0 919 884 G
Component: EUR 2010 1108
Subsystem 2 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Subsystem 3 - Part No SW: 8T0 919 609 HW: 8T0 919 609
Component: E0380 Bedient H08 0100
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:49
Voltage: 18.20 V
03367 - Supply Voltage for Display Module
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:10:18
Voltage: 18.00 V
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010C02204001210001
VCID: 56A3894B21DF1B91643-8003
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:51
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H06 1401
Reset counter: 102
Mileage: 131474 km
Date: 2015.03.24
Time: 11:09:51
End-------------------------(Elapsed Time: 02:52)--------------------------
