Crafter 2010 CEBB 079906022G Redir Fail
gooroo
C?ID=224338
This controller was mentioned here in 2016 using VCDS 16.8.1, https://forums.ross-tech.com/index.php?threads/7547/
and here in 2018 using VCDS 17.8.1, https://forums.ross-tech.com/index.php?threads/12973/
but still redir fail today using 20.12.0
I need to carry out a DPF regeneration, could you assist please?
sorry, typo in title, please correct if possible...
Tuesday,09,February,2021,08:59:04:04425
VCDS Version: 20.12.0.0 (x64)
Data version: 20201124 DS322.0
VIN: WV1ZZZ2EZB6013823   License Plate:
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (CEB)       Labels: Redir Fail!
   Part No SW: 076 906 022 N    HW: 076 906 022 G
   Component: R5 2,5L EDC A020SG  9021
   Revision: 24H38---    Serial number: VWXDZ0J1027498
   Coding: 0003032
   Shop #: WSC 00046 000 00000
   VCID: 1E33FE7ECAA69C7411-5106
009315 - Diesel Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
                    Fault Status: 11100000
                    RPM: 3045 /min
                    Speed: 94.0 km/h
                    Pressure: 172 mbar
                    Hex Value: 0xFF00
                    Temperature: 300.0°C
                    (no units): 545.7
                    Mileage: 340 km
009304 - Diesel Particulate Filter
               P2458 - 000 - Regeneration Duration - MIL ON
                    RPM: 1890 /min
                    Speed: 43.0 km/h
                    Pressure: 46 mbar
                    Hex Value: 0xFF00
                    Temperature: 258.0°C
                    (no units): 209.1
                    Mileage: 360 km
Readiness: 1 4 0 0 1
Address 91: LT3 Engine        Labels: Redir Fail!
   Coding: 0003032
   VCID: 1E33FE7EC9A69C7411-804A
                    RPM: 3045 /min
                    Speed: 94.0 km/h
                    Pressure: 172 mbar
                    Hex Value: 0xFF00
                    (no units): 545.7
                    Mileage: 340 km
                    RPM: 1890 /min
                    Speed: 43.0 km/h
                    Pressure: 46 mbar
                    Hex Value: 0xFF00
                    (no units): 209.1
                    Mileage: 360 km
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
   Component: IMMO          0805  0815
   Revision: 00805000    Serial number: VWXDZ0J1027498
   VCID: 6DD1E9B27480B7ECD8-8038
Address 94: LT3 Airbag
   Part No HW: 9064461442
   Shop #: WSC 00117 555 00000
   ASAM Dataset: CRFT1_AB Unknown
   ROD: CRFT_AB.rod
   VCID: 55A1A15234101F2C00-8000
Address 95: LT3 ESP
   Part No SW: 9069022800    HW: 0004460153
   ASAM Dataset: CRFT2_ESP Unknown
   ROD: CRFT1_ESP.rod
   VCID: 0407AC168F0A56A427-8050
475900 - ROD - Unknown Error Code
            MIL ON - Test Complete - Stored
Address 96: LT3 Instruments
   Part No SW: 9069026400    HW: 9069012000
   ASAM Dataset: CRFT1_KOMBI Unknown
   ROD: CRFT_KOMBI.rod
910000 - ROD - Unknown Error Code
910900 - ROD - Unknown Error Code
910200 - ROD - Unknown Error Code
Address 99: LT3 Ign. Switch
   Part No HW: 9065455808
   ASAM Dataset: CRFT1_EZS Unknown
   ROD: CRFT_EZS.rod
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  0815
   Revision: 00805000    Serial number: 12345678901234
   Shop #: WSC 00536 280 97487
00172 - Key 2 not learned
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: CRFT1_FTUHR Unknown
   ROD: CRFT_FTUHR.rod
Address B4: LT3 Central Elec.
   Part No SW: 9069027500    HW: 9069011500
   ASAM Dataset: CRFT1_EZE Unknown
   ROD: CRFT_EZE.rod
   VCID: 0603B61EB93664B439-8052
90D000 - ROD - Unknown Error Code
            Test Complete - Active/Stored
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: CRFT1_SML Unknown
   ROD: CRFT_SML.rod
End-------------------------(Elapsed Time: 02:54)--------------------------
;SW:076-906-022-N   HW:076-906-022-G ---  LT3 Engine
;Component:R5 2,5L EDC A020SG  9021, Coding:0003032
;Tuesday,09,February,2021,09:01:22:04425
;VCDS Version: Release 20.12.0 (x64)  Data version: 20201124 DS322.0
;VCID: 1E33FE7EC9A69C7411-804A
;01 N/A
;02 N/A
;03 N/A
;04 N/A
;05 N/A
A06,0,
;750
A06,1,
;735 /min
A06,2,
A06,3,
;00000000
A06,4,
;0.0 %
;07 N/A
;08 N/A
;09 N/A
;10 N/A
;11 N/A
;12 N/A
A13,0,
A13,1,
;ERROR:
A13,2,
;Security
A13,3,
;access
A13,4,
;required
A14,0,
A14,1,
;ERROR:
A14,2,
;Security
A14,3,
;access
A14,4,
;required
A15,0,
A15,1,
;ERROR:
A15,2,
;Security
A15,3,
;access
A15,4,
;required
A16,0,
;0
A16,1,
;0 ml
A16,2,
;51.6
A16,3,
;26.4
A16,4,
;380 km
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
A32,0,
;930
A32,1,
;735 /min
A32,2,
;0 /min
A32,3,
;2982 /min
A32,4,
A33,0,
;499
A33,1,
;735 /min
A33,2,
;0 /min
A33,3,
;2982 /min
A33,4,
A34,0,
;3800
A34,1,
;735 /min
A34,2,
;0 /min
A34,3,
;2982 /min
A34,4,
A35,0,
;4182
A35,1,
A35,2,
A35,3,
A35,4,
;36 N/A
A37,0,
;2160
A37,1,
A37,2,
A37,3,
A37,4,
;38 N/A
;39 N/A
A40,0,
;235
A40,1,
;235
A40,2,
;65.0
A40,3,
;16.0
A40,4,
A41,0,
;65
A41,1,
;235
A41,2,
;65.0
A41,3,
;16.0
A41,4,
A42,0,
;16
A42,1,
;235
A42,2,
;65.0
A42,3,
;16.0
A42,4,
A43,0,
;162
A43,1,
;161.3 km/h
A43,2,
;161.3 km/h
A43,3,
A43,4,
A44,0,
;0
A44,1,
;161.3 km/h
A44,2,
;161.3 km/h
A44,3,
A44,4,
A45,0,
;0
A45,1,
A45,2,
A45,3,
A45,4,
A46,0,
;162
A46,1,
;161.3 km/h
A46,2,
;161.3 km/h
A46,3,
A46,4,
;47 N/A
;48 N/A
;49 N/A
A50,0,
A50,1,
;ERROR:
A50,2,
;Security
A50,3,
;access
A50,4,
;required
A51,0,
;1
A51,1,
A51,2,
A51,3,
A51,4,
A52,0,
;0
A52,1,
A52,2,
A52,3,
A52,4,
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
A62,0,
;1
A62,1,
A62,2,
A62,3,
A62,4,
;63 N/A
;64 N/A
A65,0,
;0
A65,1,
;0.0
A65,2,
;18.0 %
A65,3,
;0.0
A65,4,
;0.0
A66,0,
;65526
A66,1,
;0.0
A66,2,
;18.0 %
A66,3,
;0.0
A66,4,
;0.0
;67 N/A
;68 N/A
;69 N/A
;70 N/A
A71,0,
;8IIAAWG
A71,1,
A71,2,
A71,3,
A71,4,
A72,0,
;8R1B7IG
A72,1,
A72,2,
A72,3,
A72,4,
A73,0,
;AIACBEG
A73,1,
A73,2,
A73,3,
A73,4,
A74,0,
;6YZO35F
A74,1,
A74,2,
A74,3,
A74,4,
A75,0,
;8G8Z51G
A75,1,
A75,2,
A75,3,
A75,4,
;76 N/A
;77 N/A
;78 N/A
;79 N/A
A80,0,
;4
A80,1,
A80,2,
;-0.9°C
A80,3,
;4.0
A80,4,
A81,0,
;0
A81,1,
A81,2,
A81,3,
A81,4,
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
A91,0,
;4
A91,1,
A91,2,
A91,3,
A91,4,
;92 N/A
A93,0,
;00018259
A93,1,
;204.0 kg
A93,2,
A93,3,
A93,4,
;5100 km
;94 N/A
;95 N/A
A96,0,
;4
A96,1,
;0.0
A96,2,
;0.0
A96,3,
;-0.9°C
A96,4,
;80.0 %
A97,0,
;32767
A97,1,
A97,2,
A97,3,
A97,4,
A98,0,
;0
A98,1,
A98,2,
A98,3,
A98,4,
A99,0,
;0
A99,1,
A99,2,
A99,3,
A99,4,
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
A120,0,
;0
A120,1,
;-4.7 %
A120,2,
;3.9 %
A120,3,
;01010110
A120,4,
;1.140 V
;121 N/A
;122 N/A
A123,0,
;0
A123,1,
;-3.9 %
A123,2,
;01110110
A123,3,
;00000010
A123,4,
;3.876 V
A124,0,
;0
A124,1,
;0.0 %
A124,2,
;-0.8 %
A124,3,
;00000100
A124,4,
;4.180 V
;125 N/A
;126 N/A
;127 N/A
A128,0,
A128,1,
;ERROR:
A128,2,
;Security
A128,3,
;access
A128,4,
;required
A129,0,
A129,1,
;ERROR:
A129,2,
;Security
A129,3,
;access
A129,4,
;required
A130,0,
A130,1,
;ERROR:
A130,2,
;Security
A130,3,
;access
A130,4,
;required
A131,0,
A131,1,
;ERROR:
A131,2,
;Security
A131,3,
;access
A131,4,
;required
A132,0,
A132,1,
;ERROR:
A132,2,
;Security
A132,3,
;access
A132,4,
;required
A133,0,
A133,1,
;ERROR:
A133,2,
;Security
A133,3,
;access
A133,4,
;required
A134,0,
A134,1,
;ERROR:
A134,2,
;Security
A134,3,
;access
A134,4,
;required
A135,0,
A135,1,
;ERROR:
A135,2,
;Security
A135,3,
;access
A135,4,
;required
A136,0,
A136,1,
;ERROR:
A136,2,
;Security
A136,3,
;access
A136,4,
;required
A137,0,
A137,1,
;ERROR:
A137,2,
;Security
A137,3,
;access
A137,4,
;required
A138,0,
A138,1,
;ERROR:
A138,2,
;Security
A138,3,
;access
A138,4,
;required
A139,0,
A139,1,
;ERROR:
A139,2,
;Security
A139,3,
;access
A139,4,
;required
A140,0,
A140,1,
;ERROR:
A140,2,
;Security
A140,3,
;access
A140,4,
;required
A141,0,
A141,1,
;ERROR:
A141,2,
;Security
A141,3,
;access
A141,4,
;required
A142,0,
A142,1,
;ERROR:
A142,2,
;Security
A142,3,
;access
A142,4,
;required
A143,0,
A143,1,
;ERROR:
A143,2,
;Security
A143,3,
;access
A143,4,
;required
A144,0,
A144,1,
;ERROR:
A144,2,
;Security
A144,3,
;access
A144,4,
;required
A145,0,
A145,1,
;ERROR:
A145,2,
;Security
A145,3,
;access
A145,4,
;required
A146,0,
A146,1,
;ERROR:
A146,2,
;Security
A146,3,
;access
A146,4,
;required
A147,0,
A147,1,
;ERROR:
A147,2,
;Security
A147,3,
;access
A147,4,
;required
A148,0,
A148,1,
;ERROR:
A148,2,
;Security
A148,3,
;access
A148,4,
;required
A149,0,
A149,1,
;ERROR:
A149,2,
;Security
A149,3,
;access
A149,4,
;required
A150,0,
A150,1,
;ERROR:
A150,2,
;Security
A150,3,
;access
A150,4,
;required
A151,0,
A151,1,
;ERROR:
A151,2,
;Security
A151,3,
;access
A151,4,
;required
A152,0,
A152,1,
;ERROR:
A152,2,
;Security
A152,3,
;access
A152,4,
;required
A153,0,
A153,1,
;ERROR:
A153,2,
;Security
A153,3,
;access
A153,4,
;required
A154,0,
A154,1,
;ERROR:
A154,2,
;Security
A154,3,
;access
A154,4,
;required
A155,0,
A155,1,
;ERROR:
A155,2,
;Security
A155,3,
;access
A155,4,
;required
A156,0,
A156,1,
;ERROR:
A156,2,
;Security
A156,3,
;access
A156,4,
;required
A157,0,
A157,1,
;ERROR:
A157,2,
;Security
A157,3,
;access
A157,4,
;required
A158,0,
A158,1,
;ERROR:
A158,2,
;Security
A158,3,
;access
A158,4,
;required
A159,0,
A159,1,
;ERROR:
A159,2,
;Security
A159,3,
;access
A159,4,
;required
A160,0,
A160,1,
;ERROR:
A160,2,
;Security
A160,3,
;access
A160,4,
;required
A161,0,
A161,1,
;ERROR:
A161,2,
;Security
A161,3,
;access
A161,4,
;required
A162,0,
A162,1,
;ERROR:
A162,2,
;Security
A162,3,
;access
A162,4,
;required
A163,0,
A163,1,
;ERROR:
A163,2,
;Security
A163,3,
;access
A163,4,
;required
A164,0,
A164,1,
;ERROR:
A164,2,
;Security
A164,3,
;access
A164,4,
;required
A165,0,
A165,1,
;ERROR:
A165,2,
;Security
A165,3,
;access
A165,4,
;required
A166,0,
A166,1,
;ERROR:
A166,2,
;Security
A166,3,
;access
A166,4,
;required
A167,0,
A167,1,
;ERROR:
A167,2,
;Security
A167,3,
;access
A167,4,
;required
A168,0,
A168,1,
;ERROR:
A168,2,
;Security
A168,3,
;access
A168,4,
;required
A169,0,
A169,1,
;ERROR:
A169,2,
;Security
A169,3,
;access
A169,4,
;required
A170,0,
A170,1,
;ERROR:
A170,2,
;Security
A170,3,
;access
A170,4,
;required
A171,0,
A171,1,
;ERROR:
A171,2,
;Security
A171,3,
;access
A171,4,
;required
A172,0,
A172,1,
;ERROR:
A172,2,
;Security
A172,3,
;access
A172,4,
;required
A173,0,
A173,1,
;ERROR:
A173,2,
;Security
A173,3,
;access
A173,4,
;required
A174,0,
A174,1,
;ERROR:
A174,2,
;Security
A174,3,
;access
A174,4,
;required
A175,0,
A175,1,
;ERROR:
A175,2,
;Security
A175,3,
;access
A175,4,
;required
A176,0,
A176,1,
;ERROR:
A176,2,
;Security
A176,3,
;access
A176,4,
;required
A177,0,
A177,1,
;ERROR:
A177,2,
;Security
A177,3,
;access
A177,4,
;required
A178,0,
A178,1,
;ERROR:
A178,2,
;Security
A178,3,
;access
A178,4,
;required
A179,0,
A179,1,
;ERROR:
A179,2,
;Security
A179,3,
;access
A179,4,
;required
A180,0,
A180,1,
;ERROR:
A180,2,
;Security
A180,3,
;access
A180,4,
;required
A181,0,
A181,1,
;ERROR:
A181,2,
;Security
A181,3,
;access
A181,4,
;required
A182,0,
A182,1,
;ERROR:
A182,2,
;Security
A182,3,
;access
A182,4,
;required
A183,0,
A183,1,
;ERROR:
A183,2,
;Security
A183,3,
;access
A183,4,
;required
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
A191,0,
A191,1,
;ERROR:
A191,2,
;Security
A191,3,
;access
A191,4,
;required
A192,0,
A192,1,
;ERROR:
A192,2,
;Security
A192,3,
;access
A192,4,
;required
A193,0,
A193,1,
;ERROR:
A193,2,
;Security
A193,3,
;access
A193,4,
;required
A194,0,
A194,1,
;ERROR:
A194,2,
;Security
A194,3,
;access
A194,4,
;required
A195,0,
A195,1,
;ERROR:
A195,2,
;Security
A195,3,
;access
A195,4,
;required
A196,0,
A196,1,
;ERROR:
A196,2,
;Security
A196,3,
;access
A196,4,
;required
A197,0,
A197,1,
;ERROR:
A197,2,
;Security
A197,3,
;access
A197,4,
;required
A198,0,
A198,1,
;ERROR:
A198,2,
;Security
A198,3,
;access
A198,4,
;required
A199,0,
A199,1,
;ERROR:
A199,2,
;Security
A199,3,
;access
A199,4,
;required
A200,0,
A200,1,
;ERROR:
A200,2,
;Security
A200,3,
;access
A200,4,
;required
;201 N/A
A202,0,
A202,1,
;ERROR:
A202,2,
;Security
A202,3,
;access
A202,4,
;required
A203,0,
A203,1,
;ERROR:
A203,2,
;Security
A203,3,
;access
A203,4,
;required
A204,0,
A204,1,
;ERROR:
A204,2,
;Security
A204,3,
;access
A204,4,
;required
A205,0,
A205,1,
;ERROR:
A205,2,
;Security
A205,3,
;access
A205,4,
;required
A206,0,
A206,1,
;ERROR:
A206,2,
;Security
A206,3,
;access
A206,4,
;required
A207,0,
A207,1,
;ERROR:
A207,2,
;Security
A207,3,
;access
A207,4,
;required
A208,0,
A208,1,
;ERROR:
A208,2,
;Security
A208,3,
;access
A208,4,
;required
A209,0,
A209,1,
;ERROR:
A209,2,
;Security
A209,3,
;access
A209,4,
;required
A210,0,
A210,1,
;ERROR:
A210,2,
;Security
A210,3,
;access
A210,4,
;required
A211,0,
A211,1,
;ERROR:
A211,2,
;Security
A211,3,
;access
A211,4,
;required
A212,0,
A212,1,
;ERROR:
A212,2,
;Security
A212,3,
;access
A212,4,
;required
A213,0,
A213,1,
;ERROR:
A213,2,
;Security
A213,3,
;access
A213,4,
;required
A214,0,
A214,1,
;ERROR:
A214,2,
;Security
A214,3,
;access
A214,4,
;required
A215,0,
A215,1,
;ERROR:
A215,2,
;Security
A215,3,
;access
A215,4,
;required
A216,0,
A216,1,
;ERROR:
A216,2,
;Security
A216,3,
;access
A216,4,
;required
A217,0,
A217,1,
;ERROR:
A217,2,
;Security
A217,3,
;access
A217,4,
;required
;218 N/A
A219,0,
A219,1,
;ERROR:
A219,2,
;Security
A219,3,
;access
A219,4,
;required
A220,0,
A220,1,
;ERROR:
A220,2,
;Security
A220,3,
;access
A220,4,
;required
A221,0,
A221,1,
;ERROR:
A221,2,
;Security
A221,3,
;access
A221,4,
;required
A222,0,
A222,1,
;ERROR:
A222,2,
;Security
A222,3,
;access
A222,4,
;required
A223,0,
A223,1,
;ERROR:
A223,2,
;Security
A223,3,
;access
A223,4,
;required
A224,0,
A224,1,
;ERROR:
A224,2,
;Security
A224,3,
;access
A224,4,
;required
A225,0,
A225,1,
;ERROR:
A225,2,
;Security
A225,3,
;access
A225,4,
;required
A226,0,
A226,1,
;ERROR:
A226,2,
;Security
A226,3,
;access
A226,4,
;required
A227,0,
A227,1,
;ERROR:
A227,2,
;Security
A227,3,
;access
A227,4,
;required
A228,0,
A228,1,
;ERROR:
A228,2,
;Security
A228,3,
;access
A228,4,
;required
A229,0,
A229,1,
;ERROR:
A229,2,
;Security
A229,3,
;access
A229,4,
;required
A230,0,
A230,1,
;ERROR:
A230,2,
;Security
A230,3,
;access
A230,4,
;required
A231,0,
A231,1,
;ERROR:
A231,2,
;Security
A231,3,
;access
A231,4,
;required
A232,0,
A232,1,
;ERROR:
A232,2,
;Security
A232,3,
;access
A232,4,
;required
A233,0,
A233,1,
;ERROR:
A233,2,
;Security
A233,3,
;access
A233,4,
;required
A234,0,
A234,1,
;ERROR:
A234,2,
;Security
A234,3,
;access
A234,4,
;required
A235,0,
A235,1,
;ERROR:
A235,2,
;Security
A235,3,
;access
A235,4,
;required
A236,0,
A236,1,
;ERROR:
A236,2,
;Security
A236,3,
;access
A236,4,
;required
A237,0,
A237,1,
;ERROR:
A237,2,
;Security
A237,3,
;access
A237,4,
;required
A238,0,
A238,1,
;ERROR:
A238,2,
;Security
A238,3,
;access
A238,4,
;required
A239,0,
A239,1,
;ERROR:
A239,2,
;Security
A239,3,
;access
A239,4,
;required
A240,0,
A240,1,
;ERROR:
A240,2,
;Security
A240,3,
;access
A240,4,
;required
A241,0,
A241,1,
;ERROR:
A241,2,
;Security
A241,3,
;access
A241,4,
;required
A242,0,
A242,1,
;ERROR:
A242,2,
;Security
A242,3,
;access
A242,4,
;required
A243,0,
A243,1,
;ERROR:
A243,2,
;Security
A243,3,
;access
A243,4,
;required
A244,0,
A244,1,
;ERROR:
A244,2,
;Security
A244,3,
;access
A244,4,
;required
A245,0,
A245,1,
;ERROR:
A245,2,
;Security
A245,3,
;access
A245,4,
;required
A246,0,
A246,1,
;ERROR:
A246,2,
;Security
A246,3,
;access
A246,4,
;required
A247,0,
A247,1,
;ERROR:
A247,2,
;Security
A247,3,
;access
A247,4,
;required
A248,0,
A248,1,
;ERROR:
A248,2,
;Security
A248,3,
;access
A248,4,
;required
A249,0,
A249,1,
;ERROR:
A249,2,
;Security
A249,3,
;access
A249,4,
;required
A250,0,
A250,1,
;ERROR:
A250,2,
;Security
A250,3,
;access
A250,4,
;required
A251,0,
A251,1,
;ERROR:
A251,2,
;Security
A251,3,
;access
A251,4,
;required
A252,0,
A252,1,
;ERROR:
A252,2,
;Security
A252,3,
;access
A252,4,
;required
A253,0,
A253,1,
;ERROR:
A253,2,
;Security
A253,3,
;access
A253,4,
;required
A254,0,
A254,1,
;ERROR:
A254,2,
;Security
A254,3,
;access
A254,4,
;required
A255,0,
A255,1,
;ERROR:
A255,2,
;Security
A255,3,
;access
A255,4,
;required
;Tuesday,09,February,2021,09:00:47:04425
1,0,,
1,1,,,
;735 /min,RPM,
1,2,,,
;4.4 mg/str,Inj. Quantity,
1,3,,,
;240.0 bar,Pressure,
1,4,,,
;62.1°C,Temperature,
2,0,,
2,1,,,
;735 /min,RPM,
2,2,,,
;0.0 %,Load,
2,3,,,
;00000000,Bin. Bits,
2,4,,,
3,0,,
3,1,,,
;735 /min,RPM,
3,2,,,
;250.0 mg/str,Mass Air / Rev.,
3,3,,,
;510.0 mg/str,Mass Air / Rev.,
3,4,,,
;100.0 %,Load,
4,0,,
4,1,,,
;735 /min,RPM,
4,2,,,
;2.8 °ATDC,Ign. Timing,
4,3,,,
;430.0,(no units),
4,4,,,
5,0,,
5,1,,,
;735 /min,RPM,
5,2,,,
;18.9 mg/str,Inj. Quantity,
5,3,,,
;48.0,(no units),
5,4,,,
6,0,,
6,1,,,
;0.0 km/h,Speed,
6,2,,,
;00010000,Bin. Bits,
6,3,,,
;0.0 km/h,Speed,
6,4,,,
7,0,,
7,1,,,
;15.3°C,Temperature,
7,2,,,
;48.6°C,Temperature,
7,3,,,
;9.0°C,Temperature,
7,4,,,
8,0,,
8,1,,,
;735 /min,RPM,
8,2,,,
;0.0 Nm,Torque,
8,3,,,
;168.0 Nm,Torque,
8,4,,,
;162.0 Nm,Torque,
9,0,,
9,1,,,
;735 /min,RPM,
9,2,,,
;-1280.0 Nm,Torque,
9,3,,,
;615.0 Nm,Torque,
9,4,,,
;141.0 Nm,Torque,
10,0,,
10,1,,,
;520.0 mg/str,Mass Air / Rev.,
10,2,,,
;999.6 mbar,Absolute Pres.,
10,3,,,
;1081.2 mbar,Absolute Pres.,
10,4,,,
;0.0 %,Load,
11,0,,
11,1,,,
;735 /min,RPM,
11,2,,,
;1030.2 mbar,Absolute Pres.,
11,3,,,
11,4,,,
;100.0 %,Load,
12,0,,
12,1,,,
;11111111,Bin. Bits,
12,2,,,
;1.98 s,Time,
12,3,,,
;14.21 V,Voltage,
12,4,,,
13,0,,
13,1,,,
;-0.49 mg/str,Inj. Quantity,
13,2,,,
;0.00 mg/str,Inj. Quantity,
13,3,,,
;-0.07 mg/str,Inj. Quantity,
13,4,,,
;0.35 mg/str,Inj. Quantity,
14,0,,
14,1,,,
;0.16 mg/str,Inj. Quantity,
14,2,,,
14,3,,,
14,4,,,
15,0,,
15,1,,,
;735 /min,RPM,
15,2,,,
;33.0 Nm,Torque,
15,3,,,
;0.42 l/h,Fuel Consump.,
15,4,,,
;0.0 Nm,Torque,
16,0,,
16,1,,,
;26.8 %,Lambda,
16,2,,,
16,3,,,
;0.0,(no units),
16,4,,,
;14.21 V,Voltage,
17,0,,
17,1,,,
;0.0,(no units),
17,2,,,
;0.00,(no units),
17,3,,,
;38.6 l,Tank Cont.,
17,4,,,
;735 /min,RPM,
18,0,,
18,1,,,
;735 /min,RPM,
18,2,,,
18,3,,,
;5.0,(no units),
18,4,,,
;3.0,(no units),
19,0,,
19,1,,,
;735 /min,RPM,
19,2,,,
;-7.65,(no units),
19,3,,,
;328.0 bar,Pressure,
19,4,,,
;1024.0, ,
20,0,,
20,1,,,
;735 /min,RPM,
20,2,,,
20,3,,,
20,4,,,
;18.1 %,Lambda,
21,0,,
21,1,,,
;735 /min,RPM,
21,2,,,
21,3,,,
21,4,,,
;36.3 %,Lambda,
22,0,,
22,1,,,
;735 /min,RPM,
22,2,,,
; 0111000,Bin. Bits,
22,3,,,
22,4,,,
23,0,,
23,1,,,
;735 /min,RPM,
23,2,,,
23,3,,,
;420.0,(no units),
23,4,,,
;3.0,(no units),
24,0,,
24,1,,,
;735 /min,RPM,
24,2,,,
;0.0 °BTDC,Ign. Timing,
24,3,,,
;0.0,(no units),
24,4,,,
;232.0 bar,Pressure,
25,0,,
25,1,,,
;735 /min,RPM,
25,2,,,
;10.9 °BTDC,Ign. Timing,
25,3,,,
;235.0,(no units),
25,4,,,
26,0,,
26,1,,,
;735 /min,RPM,
26,2,,,
;4.0 °BTDC,Ign. Timing,
26,3,,,
;235.0,(no units),
26,4,,,
27,0,,
27,1,,,
;735 /min,RPM,
27,2,,,
27,3,,,
;0.0,(no units),
27,4,,,
28,0,,
28,1,,,
;735 /min,RPM,
28,2,,,
28,3,,,
;0.0,(no units),
28,4,,,
29,0,,
29,1,,,
;735 /min,RPM,
29,2,,,
29,3,,,
;0.0,(no units),
29,4,,,
30,0,,
30,1,,,
;0.228 V,Voltage,
30,2,,,
;0.152 V,Voltage,
30,3,,,
30,4,,,
;0.0 %,Load,
31,0,,
31,1,,,
;D727,Voltage,
32,0,,
32,1,,,
;735 /min,RPM,
32,2,,,
32,3,,,
32,4,,,
;92.3 %,Lambda,
33,0,,
33,1,,,
;735 /min,RPM,
33,2,,,
;114.0°C,Temperature,
33,3,,,
;1.00,(no units),
33,4,,,
;1.00,(no units),
34,0,,
34,1,,,
;735 /min,RPM,
34,2,,,
;100.0 %,Load,
34,3,,,
;99.4 %,Lambda,
34,4,,,
;92.3 %,Lambda,
35,0,,
35,1,,,
;735 /min,RPM,
35,2,,,
35,3,,,
;515.0 mg/str,Mass Air / Rev.,
35,4,,,
;100.0 %,Load,
36,0,,
36,1,,,
;735 /min,RPM,
36,2,,,
;100.0 %,Load,
36,3,,,
;94.7 %,Lambda,
36,4,,,
;0.0 %,Lambda,
38,0,,
38,1,,,
;735 /min,RPM,
38,2,,,
;100.0 %,Load,
38,3,,,
;99.4 %,Lambda,
38,4,,,
;12.6 %,Lambda,
39,0,,
39,1,,,
;735 /min,RPM,
39,2,,,
;505.0 mg/str,Mass Air / Rev.,
39,3,,,
;9.0°C,Temperature,
39,4,,,
;17.4 %,Lambda,
40,0,,
40,1,,,
;735 /min,RPM,
40,2,,,
;100.0 %,Load,
40,3,,,
;99.4 %,Lambda,
40,4,,,
;17.4 %,Lambda,
41,0,,
41,1,,,
;11 ohms,Resistance,
41,2,,,
;0.000 V,Voltage,
41,3,,,
;0.01,(no units),
41,4,,,
;1.0,(no units),
42,0,,
42,1,,,
;0.01,(no units),
42,2,,,
;45.0 %,Lambda,
42,3,,,
;0.975 V,Voltage,
42,4,,,
;6.57,(no units),
43,0,,
43,1,,,
;0.0,(no units),
43,2,,,
;-0.9°C,Temperature,
43,3,,,
;00000001,Bin. Bits,
43,4,,,
;0.975 V,Voltage,
44,0,,
44,1,,,
;735 /min,RPM,
44,2,,,
;10001000,Bin. Bits,
44,3,,,
;0.0,(no units),
44,4,,,
;0.0,(no units),
45,0,,
45,1,,,
45,2,,,
;100.0 %,Load,
45,3,,,
;0.0 %,Lambda,
45,4,,,
;0.0 %,Lambda,
46,0,,
46,1,,,
46,2,,,
46,3,,,
46,4,,,
47,0,,
47,1,,,
;89.1°C,Temperature,
47,2,,,
47,3,,,
;0.0 %,Load,
47,4,,,
;0.0 %,Lambda,
48,0,,
48,1,,,
;735 /min,RPM,
48,2,,,
;0 /min,RPM,
48,3,,,
;       1,Bin. Bits,
48,4,,,
;1270.0 Nm,Torque,
50,0,,
50,1,,,
;735 /min,RPM,
50,2,,,
50,3,,,
50,4,,,
;      10,Bin. Bits,
51,0,,
51,1,,,
;735 /min,RPM,
51,2,,,
;364 /min,RPM,
51,3,,,
;48.0,(no units),
51,4,,,
;1.4°KW,Idle Stabilization,
52,0,,
52,1,,,
;735 /min,RPM,
52,2,,,
;0xFF00,Hex Value,
52,3,,,
;0xFF00,Hex Value,
52,4,,,
;21.6°C,Temperature,
53,0,,
53,1,,,
53,2,,,
53,3,,,
53,4,,,
54,0,,
54,1,,,
;0.0,(no units),
54,2,,,
;0 /min,RPM,
54,3,,,
;0.0 mg/str,Inj. Quantity,
54,4,,,
57,0,,
57,1,,,
;735 /min,RPM,
57,2,,,
;0.0 km/h,Speed,
57,3,,,
;0.0 %,Duty Cycle,
57,4,,,
;0.0 %,Duty Cycle,
58,0,,
58,1,,,
;735 /min,RPM,
58,2,,,
;0.0 km/h,Speed,
58,3,,,
;0.0 %,Duty Cycle,
58,4,,,
;99.6 %,Duty Cycle,
59,0,,
59,1,,,
;735 /min,RPM,
59,2,,,
;36.0 Nm,Torque,
59,3,,,
;33.0 Nm,Torque,
59,4,,,
;0.0 Nm,Torque,
60,0,,
60,1,,,
;33.0 Nm,Torque,
60,2,,,
;-36.0 Nm,Torque,
60,3,,,
;18.0 Nm,Torque,
60,4,,,
;26.0 %,Lambda,
61,0,,
61,1,,,
;735 /min,RPM,
61,2,,,
;49.5°C,Temperature,
61,3,,,
;64.0 mm,Content,
61,4,,,
;76.0 mm,Content,
62,0,,
62,1,,,
;735 /min,RPM,
62,2,,,
62,3,,,
;0.0,(no units),
62,4,,,
;0.0,(no units),
63,0,,
63,1,,,
;0 /min,RPM,
63,2,,,
;0 /min,RPM,
63,3,,,
;0 /min,RPM,
63,4,,,
;0 /min,RPM,
64,0,,
64,1,,,
;0 /min,RPM,
64,2,,,
64,3,,,
64,4,,,
69,0,,
69,1,,,
69,2,,,
;00000011,Bin. Bits,
69,3,,,
69,4,,,
70,0,,
70,1,,,
70,2,,,
70,3,,,
70,4,,,
;1.00,(no units),
71,0,,
71,1,,,
71,2,,,
;00011111,Bin. Bits,
71,3,,,
71,4,,,
72,0,,
72,1,,,
;-1.60,(no units),
72,2,,,
;1.92,(no units),
72,3,,,
;-0.32,(no units),
72,4,,,
73,0,,
73,1,,,
;1.60,(no units),
73,2,,,
;3.84,(no units),
73,3,,,
;-0.64,(no units),
73,4,,,
74,0,,
74,1,,,
;-0.64,(no units),
74,2,,,
;3.84,(no units),
74,3,,,
;-5.76,(no units),
74,4,,,
75,0,,
75,1,,,
;-8.64,(no units),
75,2,,,
;-8.64,(no units),
75,3,,,
;-9.92,(no units),
75,4,,,
76,0,,
76,1,,,
;8.32,(no units),
76,2,,,
;5.12,(no units),
76,3,,,
;-1.92,(no units),
76,4,,,
77,0,,
77,1,,,
;1.92,(no units),
77,2,,,
;-0.32,(no units),
77,3,,,
;0.00,(no units),
77,4,,,
80,0,,
80,1,,,
;RB8-658 14.10.10 24H38--- 1314 0066, ,
81,0,,
81,1,,,
;WV1ZZZ2EZB6013823 VWXDZ0J1027498        , ,
82,0,,
82,1,,,
;0000000000046 00.00.00 78       79  <>  , ,
85,0,,
85,1,,,
;603110 km,Mileage,
85,2,,,
;23,Count,
85,3,,,
;6,Count,
85,4,,,
;23,Count,
86,0,,
86,1,,,
;11110000,Bin. Bits,
86,2,,,
;10111110,Bin. Bits,
86,3,,,
;11110111,Bin. Bits,
86,4,,,
87,0,,
87,1,,,
87,2,,,
87,3,,,
87,4,,,
89,0,,
89,1,,,
;10000100,Bin. Bits,
89,2,,,
;00001110,Bin. Bits,
89,3,,,
;10100000,Bin. Bits,
89,4,,,
;10000000,Bin. Bits,
90,0,,
90,1,,,
;735 /min,RPM,
90,2,,,
90,3,,,
90,4,,,
91,0,,
91,1,,,
;323.85,(no units),
91,2,,,
;-326.40,(no units),
91,3,,,
91,4,,,
;-247.35,(no units),
93,0,,
93,1,,,
93,2,,,
;0.94,(no units),
93,3,,,
;56.1,(no units),
93,4,,,
;51.0,(no units),
95,0,,
95,1,,,
95,2,,,
95,3,,,
;0.0,(no units),
95,4,,,
96,0,,
96,1,,,
96,2,,,
96,3,,,
;      00,Bin. Bits,
96,4,,,
;14.29 V,Voltage,
97,0,,
97,1,,,
;-3 mbar,Pressure,
97,2,,,
;-3 mbar,Pressure,
97,3,,,
97,4,,,
98,0,,
98,1,,,
;735 /min,RPM,
98,2,,,
;9.0°C,Temperature,
98,3,,,
98,4,,,
99,0,,
99,1,,,
;735 /min,RPM,
99,2,,,
99,3,,,
;84.0°C,Temperature,
99,4,,,
;90.0°C,Temperature,
100,0,,
100,1,,,
100,2,,,
100,3,,,
;13 mbar,Pressure,
100,4,,,
;-3 mbar,Pressure,
101,0,,
101,1,,,
;735 /min,RPM,
101,2,,,
;0.0,(no units),
101,3,,,
;0.0,(no units),
101,4,,,
;0.0,(no units),
102,0,,
102,1,,,
102,2,,,
102,3,,,
102,4,,,
103,0,,
103,1,,,
103,2,,,
103,3,,,
103,4,,,
104,0,,
104,1,,,
;0xFF01,Hex Value,
104,2,,,
;0xFF10,Hex Value,
104,3,,,
104,4,,,
105,0,,
105,1,,,
105,2,,,
;9.0,(no units),
105,3,,,
105,4,,,
;56.1,(no units),
106,0,,
106,1,,,
106,2,,,
;43.2 l,Tank Cont.,
106,3,,,
;380 km,Mileage,
106,4,,,
;996.0,(no units),
107,0,,
107,1,,,
;50.4, ,
107,2,,,
;45.6, ,
107,3,,,
;27.6, ,
107,4,,,
108,0,,
108,1,,,
;0 ml,milliliters,
108,2,,,
;51.6, ,
108,3,,,
;26.4, ,
108,4,,,
109,0,,
109,1,,,
109,2,,,
;00001000,Bin. Bits,
109,3,,,
;144.0,(no units),
109,4,,,
110,0,,
110,1,,,
110,2,,,
110,3,,,
;0.0 km/h,Speed,
110,4,,,
111,0,,
111,1,,,
;735 /min,RPM,
111,2,,,
;0.0 km/h,Speed,
111,3,,,
;0.00,(no units),
111,4,,,
;0.0,(no units),
112,0,,
112,1,,,
;0.00,(no units),
112,2,,,
;-880.0 Nm,Torque,
112,3,,,
;-1280.0 Nm,Torque,
112,4,,,
;0.0 Nm,Torque,
113,0,,
113,1,,,
113,2,,,
;0.0,(no units),
113,3,,,
;1.0,(no units),
113,4,,,
;0.0,(no units),
114,0,,
114,1,,,
;255.0,(no units),
114,2,,,
;255.0,(no units),
114,3,,,
;0.00,(no units),
114,4,,,
;0.00,(no units),
116,0,,
116,1,,,
;0.0 %,Load,
116,2,,,
116,3,,,
;192.0,(no units),
116,4,,,
;0.0,(no units),
117,0,,
117,1,,,
;0.0 %,Lambda,
117,2,,,
117,3,,,
;00010111,Bin. Bits,
117,4,,,
;7.0,(no units),
120,0,,
120,1,,,
;-4.7 %,Lambda,
120,2,,,
;3.9 %,Lambda,
120,3,,,
;01110110,Bin. Bits,
120,4,,,
;1.140 V,Voltage,
121,0,,
121,1,,,
;0.0 %,Lambda,
121,2,,,
;-12.6 %,Lambda,
121,3,,,
;00000100,Bin. Bits,
121,4,,,
;1.292 V,Voltage,
123,0,,
123,1,,,
;-3.9 %,Lambda,
123,2,,,
;3.2 %,Lambda,
123,3,,,
123,4,,,
;3.952 V,Voltage,
124,0,,
124,1,,,
;0.0 %,Lambda,
124,2,,,
;-0.8 %,Lambda,
124,3,,,
124,4,,,
;4.180 V,Voltage,
125,0,,
125,1,,,
125,2,,,
;ABS 1, ,
125,3,,,
;Instruments 1, ,
125,4,,,
127,0,,
127,1,,,
127,2,,,
127,3,,,
;El.Ign.Lock 1, ,
127,4,,,
166,0,,
166,1,,,
;0.070°,Angle,
166,2,,,
;0.022°,Angle,
166,3,,,
;0.065°,Angle,
166,4,,,
;0.070°,Angle,
167,0,,
167,1,,,
;0.061°,Angle,
167,2,,,
167,3,,,
167,4,,,
170,0,,
170,1,,,
;0.00 %, ,
170,2,,,
;0.0,(no units),
170,3,,,
;0.00 %, ,
170,4,,,
;0.0 bar, ,
172,0,,
172,1,,,
;0.0,(no units),
172,2,,,
;0.0,(no units),
172,3,,,
172,4,,,
;100.0 %,Load,
174,0,,
174,1,,,
;4.0,(no units),
174,2,,,
;0.0,(no units),
174,3,,,
;0.000 V,Voltage,
174,4,,,
;0.000 V,Voltage,
175,0,,
175,1,,,
;0.0,Ohms,
175,2,,,
;0.000 A,Current,
175,3,,,
;0.000 A,Current,
175,4,,,
;18.0°C,Temperature,
176,0,,
176,1,,,
;0 ppm, ,
176,2,,,
;0.000 V,Voltage,
176,3,,,
;0.00,(no units),
176,4,,,
177,0,,
177,1,,,
;0 ppm, ,
177,2,,,
;0.000 V,Voltage,
177,3,,,
;0.00,(no units),
177,4,,,
178,0,,
178,1,,,
;5100 km,Mileage,
178,2,,,
;1.0,(no units),
178,3,,,
178,4,,,
179,0,,
179,1,,,
;204.0 kg,Mass/Weight,
179,2,,,
179,3,,,
179,4,,,
180,0,,
180,1,,,
180,2,,,
;0 ppm, ,
180,3,,,
180,4,,,
181,0,,
181,1,,,
;0.0 bar, ,
181,2,,,
181,3,,,
181,4,,,
182,0,,
182,1,,,
182,2,,,
182,3,,,
;10.7,(no units),
182,4,,,
183,0,,
183,1,,,
;1.02,(no units),
183,2,,,
183,3,,,
183,4,,,
200,0,,
200,1,,,
;0 ppm, ,
200,2,,,
;192 ppm, ,
200,3,,,
;0 ppm, ,
200,4,,,
;8 ppm, ,
201,0,,
201,1,,,
;0.00,(no units),
201,2,,,
;1.00,(no units),
201,3,,,
;0.02,(no units),
201,4,,,
;1.00,(no units),
202,0,,
202,1,,,
;0.00,(no units),
202,2,,,
;0.95,(no units),
202,3,,,
;78.0°C,Temperature,
202,4,,,
203,0,,
203,1,,,
;0.00,(no units),
203,2,,,
;0.00,(no units),
203,3,,,
;0.0,(no units),
203,4,,,
;4 mg/s, ,
204,0,,
204,1,,,
;1.02,(no units),
204,2,,,
204,3,,,
204,4,,,
206,0,,
206,1,,,
206,2,,,
206,3,,,
206,4,,,
;25.5 l/1000km, ,
207,0,,
207,1,,,
207,2,,,
;0.0 s,Time,
207,3,,,
207,4,,,
;0.0 s,Time,
208,0,,
208,1,,,
;1.0,(no units),
208,2,,,
;0.0 s,Time,
208,3,,,
;0.0 s,Time,
208,4,,,
;0.0 s,Time,
209,0,,
209,1,,,
;2.0,(no units),
209,2,,,
;61.4 s,Time,
209,3,,,
;102.4 s,Time,
209,4,,,
;67.0,(no units),
210,0,,
210,1,,,
210,2,,,
210,3,,,
210,4,,,
;0.00 V,Voltage,
211,0,,
211,1,,,
;0.0 g, ,
211,2,,,
;0.10 g, ,
211,3,,,
211,4,,,
;1.00,(no units),
212,0,,
212,1,,,
212,2,,,
212,3,,,
;-1.04,(no units),
212,4,,,
213,0,,
213,1,,,
;0.51 mg/s, ,
213,2,,,
;0.00 mg/s, ,
213,3,,,
;0.78,(no units),
213,4,,,
;0.00,(no units),
214,0,,
214,1,,,
;-6.0°C,Temperature,
214,2,,,
214,3,,,
214,4,,,
217,0,,
217,1,,,
;0.0, ,
217,2,,,
;0.0, ,
217,3,,,
;0.0, ,
217,4,,,
;0.0, ,
218,0,,
218,1,,,
;0.0, ,
218,2,,,
;0 km,Mileage,
218,3,,,
;0.0,(no units),
218,4,,,
;0.0,(no units),
219,0,,
219,1,,,
;-276.0°C,Temperature,
219,2,,,
219,3,,,
;0.0 km/h,Speed,
219,4,,,
;0.0 km/h,Speed,
220,0,,
220,1,,,
;0.0,(no units),
220,2,,,
220,3,,,
220,4,,,
221,0,,
221,1,,,
;0.50,(no units),
221,2,,,
221,3,,,
221,4,,,
222,0,,
222,1,,,
;1.00,(no units),
222,2,,,
;1.00,(no units),
222,3,,,
;1.00,(no units),
222,4,,,
;1.03,(no units),
223,0,,
223,1,,,
;1402.5 mbar,Pressure,
223,2,,,
;1096.5 mbar,Pressure,
223,3,,,
;56.1,(no units),
223,4,,,
;51.0,(no units),
225,0,,
225,1,,,
;0.0,(no units),
225,2,,,
;1.0,(no units),
225,3,,,
;0.0,(no units),
225,4,,,
;0.0,(no units),
226,0,,
226,1,,,
;0.0,(no units),
226,2,,,
226,3,,,
;0.0,(no units),
226,4,,,
;0.0,(no units),
227,0,,
227,1,,,
;0.0,(no units),
227,2,,,
;0.0,(no units),
227,3,,,
;0.0,(no units),
227,4,,,
;0.0,(no units),
228,0,,
228,1,,,
;0.0,(no units),
228,2,,,
;0.0,(no units),
228,3,,,
;0.0,(no units),
228,4,,,
;0.0,(no units),
229,0,,
229,1,,,
229,2,,,
229,3,,,
;0.0,(no units),
229,4,,,
;0.0,(no units),
245,0,,
245,1,,,
;18.0 %,Load,
245,2,,,
;0.0,(no units),
245,3,,,
;0.0,(no units),
245,4,,,
;0.0,(no units),
246,0,,
246,1,,,
246,2,,,
246,3,,,
;989.4 mbar,Absolute Pres.,
246,4,,,
;18.0 %,Load,
247,0,,
247,1,,,
;161.3 km/h,Speed,
247,2,,,
;161.3 km/h,Speed,
247,3,,,
;0.0,(no units),
247,4,,,
;0.0 km/h,Speed,
248,0,,
248,1,,,
;235,Count,
248,2,,,
;65.0,(no units),
248,3,,,
;16.0,(no units),
248,4,,,
;161.3 km/h,Speed,
249,0,,
249,1,,,
;36.0 Nm,Torque,
249,2,,,
249,3,,,
;0.0,(no units),
249,4,,,
250,0,,
250,1,,,
;0.0 bar,Absolute Pres.,
250,2,,,
;0.0 Nm,Torque,
250,3,,,
250,4,,,
251,0,,
251,1,,,
;0 /min,RPM,
251,2,,,
;735 /min,RPM,
251,3,,,
;2982 /min,RPM,
251,4,,,
252,0,,
252,1,,,
;36.0 Nm,Torque,
252,2,,,
;0.0 Nm,Torque,
252,3,,,
252,4,,,
253,0,,
253,1,,,
;735 /min,RPM,
253,2,,,
;3.0,(no units),
253,3,,,
253,4,,,
;0.0,(no units),
  • Informative
gooroo
C?ID=224338
So it looks like you need to do:
Coding II with 27971
and then Basic Settings in Group 226.
Pre-conditions:
Ignition on, engine running at idle, fuel tank at least 1/4 full.
Set parking brake and keep hood/bonnet closed.
Once you start the Basic Setting, there should be further guidance in the measuring block fields.
gooroo
C?ID=224338
Thanks Uwe, appreciated.
Regards.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I have updated our documentation and the details you are looking for should now be included. Please download the latest VCDS version and install it.
https://www.ross-tech.com/vcds/download/current.php
Once it is installed, use the following data version updater to install the updated files (which are not included in the main installer yet).
https://ross-tech.de/downloads/upd
After that, you should be ready to go. Please let us know if this works as expected.
gooroo
C?ID=224338
Thanks Sebastian, Uwe, appreciated.
Regards.
