Control module is in European Mode
Barry Harkin
Northern Ireland
C?ID=426751
To all
I am new to this forum so not sure how to explain my issue. I got the Ross-Tech for my Audi A8 and was messing about with it. I have changed something that has altered the way that my controls inside work. I am from the uk but when I go to adjust heating etc. it is saying "Passenger" on the pop up screen. What did I change and how do I resolve this?
Barry
@Barry Harkin: Baza-Hi and welcome to the forum - I'm honored to be the first responder to your inaugural post !! :D.
For reasons related in the main to the general nature of the information in your post, it ain't possible to be too specific in answering your seminal question "What did I change and how do I resolve this?".
However, you may be able to answer this question yourself (or at the very least, you may be able to provide more information in a second post - perhaps?).
I suspect that you may not be aware, but the wizened (and very sage) code cutters that Uwe has incarcerated in the dungeons of RT's HQ have provided a facility in VCDS software that records ALL the changes that you make with your device. This facility remembers both the new and the old value - how neat is that ????
Anyhow, on the laptop that you use to run VCDS, go to the directory C:\Ross-Tech\VCDS\Debug. In this directory IGNORE entirely the misleading contents in the Readme.TXT file (it's a blatant untruth !!!). Instead, you will find 2 x files called "CodingLog.CSV and AdpLog.CSV.
Open both of these files with something like MS Notepad, or a higher level App, like MS Excel. You will find the records of your previous changes in these files - like this:
  • Adaptation channel changes are recorded in AdpLog.CSV
  • Long-code changes are recorded in CodingLog.CSV
PS: If you do write a second post, please also include an UNEDITED copy of an auto-scan for the car. It may not be entirely obvious, but the contextual data in an auto-scan report can be deceptively important in eliciting informed response from forum colleagues.
Barry Harkin
Northern Ireland
C?ID=426751
To all
I have attched my diagnostics and Log from VCDS. My car is UK but my heating etc. from drivers side of the car is showing "passenger" on my side of the car. Does anyone know how to sort this. Also there is a fault in relation to air flow and engine management light on. Can anyone give me guidance on this.
Address 424E1 910 802 Brecoded (Short coding)from
28462​
to
28462​
(02313/785/00200)Sunday
20​
December
2020​
11:13:45:53286
Address 724E0 910 802 Arecoded (Short coding)from
28462​
to
28462​
20​
December
2020​
11:16:16:53286
Address 0F4E0 910 563 Crecoded (Short coding)from
1​
to
1​
20​
December
2020​
11:28:27:53286
Address 084E0 910 043 Brecoded (Short coding)from
18449​
to
18449​
(02311/785/00200)Tuesday
29​
December
2020​
11:56:17:53286
Address 61-01000 915 105 AKrecoded (Long Coding)from303030393135313035414B56413033333130313344314D38to303030393135313035414B56413033333130313344314D37(13773/000/1048576)Tuesday
29​
December
2020​
12:04:21:53286
18449​
to
18449​
29​
December
2020​
12:09:07:53286
18449​
to
18449​
(02311/785/00200)Sunday
7​
February
2021​
11:13:04:53286
Barry
Sunday,28,February,2021,11:41:10:53286
VCDS Version: 20.12.0.1  HEX-V2 CB: 0.4529.4
Dealer/Shop Name:  011E90ECC8C0725A
VIN: WAUZZZ4E79N003563   License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 18 19 1E 28 34 36 37
          38 42 46 47 4F 52 53 55 56 61 62 67 72 76 77
VIN: WAUZZZ4E79N003563   Mileage: 269800km-167645miles
38-Roof Electronics -- Status: OK 0000
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4E0 910 402 G    HW: 4E0 907 401 D
   Component: 3.0L V6TDI  G001AG  0030
   Revision: --H05---    Serial number: AUX3Z0H5352951
   Coding: 0011973
   Shop #: WSC 02313 785 00200
   VCID: 2019EB0266CEE16B532-8074
001025 - EGR System
               P0401 - 002 - Insufficient Flow
                    Fault Status: 01110010
                    Fault Frequency: 26
                    Mileage: 267047 km
                    Date: 2021.01.03
                    Time: 10:32:19
                    RPM: 1638 /min
                    Torque: 140.4 Nm
                    Speed: 52.6 km/h
                    Duty Cycle: 60.8 %
                    Duty Cycle: 20.9 %
                    (no units): 169.2
                    Duty Cycle: 18.1 %
Readiness: 1 1 0 0 0
   Part No SW: 4E1 910 156 Q    HW: 09L 927 156 A
   Component: AG6 09L 3,0 TDI RdW 0020
   Revision: --H01---    Serial number:        4464260
   Coding: 0000001
   VCID: 313F1E463D2458E3CCC-8064
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 J    HW: 4E0 614 517 CP
   Component: ESP 5.7 allrad  H50 0540
   Coding: 0008357
   Shop #: WSC 02313 000 00000
   VCID: 2A0D092A10F22B3B0D6-807E
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 907 181 A
   Component:     FBS AUDID3  H12 0200
   Revision: 02005112    Serial number: AUX3Z0H5352951
   Coding: 0412672
   VCID: 58E983E27E1E69AB6B2-800C
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Fault Status: 00100111
                    Reset counter: 51
                    Mileage: 268784 km
                    Date: 2021.02.06
                    Time: 11:22:58
00190 - Driver's Door Handle Touch Sensor (G415)
                    Reset counter: 37
                    Mileage: 268784 km
                    Date: 2021.02.06
                    Time: 11:27:24
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
   VCID: 2411E71272D6FD4B37A-8070
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 732 P    HW: 4E0 035 729
   Component: Interfacebox    H43 5140
   Revision: 00000000    Serial number: 343F$087606699
   Coding: 0000002
   Shop #: WSC 80093 222 69422
   VCID: 2F3B183E2B104E13DA8-807A
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH01 0050
   Subsystem 2 - Serial number: 00000000068680
   Subsystem 3 - Serial number: 0123.06.080000000100010114ÿ
   Subsystem 4 - Serial number: 010114ÿ
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 246
                    Mileage: 268798 km
                    Date: 2021.02.06
                    Time: 11:22:20
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000152110
   Coding: 0018449
   Shop #: WSC 02311 785 00200
   VCID: 1C61DFF24AA6C58B8FA-8048
00065 - Rear Left Footwell Heater (Z42)
                    Reset counter: 246
                    Mileage: 268798 km
                    Date: 2021.02.06
                    Time: 11:13:49
                    Voltage: 13.50 V
00066 - Rear Right Footwell Heater (Z43)
                    Fault Status: 00101100
                    Fault Frequency: 70
                    Reset counter: 49
                    Mileage: 268798 km
                    Date: 2021.02.06
                    Time: 11:17:41
                    Voltage: 13.60 V
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 S    HW: 4E0 907 279 S
   Component: ILM Fahrer      H16 0240
   Coding: 0133121
   VCID: 38292362DE5E89AB8B2-806C
   Subsystem 1 - Part No: 4E2 910 113 C
   Component: Wischer WWS D3  H60 0440
   Coding: 00000036
   Shop #: WSC 02313
   Coding: 00139548
   Shop #: WSC 02313
   Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
   Component: MP3-Changer     H47 0390
   Revision: 00047003    Serial number: AUZ5ZBH8473569
   VCID: 1A6DD9EA4092BBBB9D6-804E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276W7301044
   Coding: 0000001
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 E    HW: 4E0 959 655 K
   Component:    Airbag 9.41  H01 4210
   Revision: 91H01421    Serial number: 003CU000FVHM
   Coding: 0431707
   VCID: 2809F3220EFE192B1B2-807C
   Subsystem 1 - Serial number: 63328RB403CA82B5T
   Subsystem 2 - Serial number: 63428RB403CA8305K
   Subsystem 3 - Serial number: 63528RB403CA8302I
   Subsystem 4 - Serial number: 63628RB403CA8359V
   Subsystem 5 - Serial number: 63729RB403F2AF2B+
   Subsystem 6 - Serial number: 63829RB403F2AFA40
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549 A    HW: 4E0 953 549 C
   Component: J0527               0410
   Revision: 00H05000    Serial number: 90055081590166
   Coding: 0112141
   VCID: 2615FD1A04EA0F5B29E-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 J    HW: 4E0 920 951 J
   Component: KOMBIINSTR. VDO H84 0620
   Revision: D03         Serial number: AUDID3H5100080
   Coding: 0032423
   VCID: 2C010F321A06350BFFA-8078
Address 18: Aux. Heat        Labels: None
   Part No SW: 4E0 910 105 A    HW: 4E0 815 069 G
   Component: Heizgeraet      H08 0140
   Revision: 0000000C    Serial number: 00000009013887
   Coding: 0000001
02072 - Control Module for Energy Management (J644)
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B086218373
   Coding: F5F99F7F707A0E00
   Shop #: WSC 00185 210 89734
   VCID: 2D070236211C3C03E84-8078
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H20 0850
   Revision: 00000000
   VCID: 2B030C2E13083233F60-807E
   Part No SW: 4E0 910 158     HW: 4E0 919 158 C
   Component: KLIMA-STG. FOND 017 0230
   Revision: 00000020    Serial number: 00000000073615
   Coding: 0000000
   VCID: 619FAE062D44A8631CC-8034
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015510
01772 - Signal from Level Control Pressure Sensor (G291)
                    Reset counter: 50
                    Mileage: 269067 km
                    Date: 2021.02.12
                    Time: 10:33:08
   Component: Sitzmemory FS  H02  0010
   Coding: 4063338
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H52 1060
   Revision: 00000000    Serial number: 364F$087799323
   Shop #: WSC 01179 210 93569
   VCID: 3B233C6EEF68A2B3660-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H05 0090
   Serial number: 00000815700099
   Coding: 0035968
   VCID: 1D67D2F651BCCC83784-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 F
   Component: Türsteuer.FS BRM005 0180
   Coding: 0028462
                    Fault Status: 01101100
                    Fault Frequency: 0
                    Reset counter: 10
                    Mileage: 269792 km
                    Date: 2021.02.27
                    Time: 10:33:50
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 E    HW: 4E0 907 289 E
   Component: Komfortgeraet   H10 0030
   Revision: 00300010    Serial number:  W040806230154
   Coding: 0004317
   VCID: 2B030C2E1F083233F60-807E
   Subsystem 1 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
00892 - Switch for Trunk Closing Cylinder (F248)
                    Reset counter: 47
                    Mileage: 269751 km
                    Date: 2021.02.26
                    Time: 12:06:39
Address 47: Sound System        Labels: Redir Fail!
   Part No SW: 4E0 910 224 B    HW: 4E0 035 223 H
   Component: Amp.-Basis      H41 0150
   Revision: 00000000    Serial number: 00000087525058
   Coding: 0000013
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 D
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000026927
   Coding: 0010101
   VCID: 1E65D5FA5CBAD79B61E-804A
                    Reset counter: 49
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 F
   Component: Türsteuer.BF BRM005 0180
   Coding: 0028462
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 D    HW: 4E0 907 801 B
   Component: EPB  A4EC0230   H03 0230
   Revision: --H03---
   Coding: 0000221
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 13
                    Voltage: 10.46 V
                    Count: 61
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0040
   Coding: 0000018
   VCID: 698FB626D574E023C4C-803C
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 396F+087598134
   Coding: 0000001
   VCID: 2E05053A2C1A471BD1E-807A
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 B    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0240
   Revision: 00000000    Serial number: 00000000004728
   Shop #: WSC 13773 000 1048576
   VCID: 1F1BE8FE5BB0DE936A8-804A
   Subsystem 1 - Part No: 000 915 105 AK
   Component: von VA0  331013D1M7
   Coding: 303030393135313035414B56413033333130313344314D37
   Shop #: WSC 13773 123 104857
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 D
   Component: Türsteuer.HL BRM005 0180
   Coding: 0028462
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H46 0630
   Revision: 00000000    Serial number: 00000806200259
   Shop #: WSC 12336 024 394758
   VCID: 36352D5AD44A7FDB99E-8062
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 D
   Component: Türsteuer.HR BRM005 0180
   Coding: 0028462
                    Fault Status: 01101000
                    Reset counter: 5
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08740817105673
   Coding: 0201008
   VCID: 2313E40E77D8FA734E0-8076
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 C    HW: 4F1 862 335
   Component: BTA             H11 0960
   Revision: 00H11000    Serial number: 00000007581176
   Coding: 0060001
End----------(Elapsed Time: 02:21, VBatt start/end: 13.1V/13.5V)---------
South Molton, UK
   Coding: 0000002
                    Reset counter: 246
                    Mileage: 268798 km
                    Date: 2021.02.06
                    Time: 11:22:20
Have you done any kind of reset on #07? It sounds like it's lost its settings?
@Barry Harkin : Thanks for posting the information.
To add to @PetrolDave comment, I must preface my response with the admission that I'm not familiar with your Audi A8 - nevertheless, based purely on your CodingLog information, it's clear from a quick glance that except for address hex61, none of the other records made actual changes to the modules.
In respect of the Address 61: Battery Regul module - here's a more readable version of the record in your table:
hex61 moduleFromFromToTo
ByteHexBinaryHexBinary
030001100003000110000
130001100003000110000
230001100003000110000
339001110013900111001
431001100013100110001
535001101013500110101
631001100013100110001
730001100003000110000
835001101013500110101
941010000014101000001
104B010010114B01001011
1156010101105601010110
1241010000014101000001
1330001100003000110000
1433001100113300110011
1533001100113300110011
1631001100013100110001
1730001100003000110000
1831001100013100110001
1933001100113300110011
2044010001004401000100
2131001100013100110001
224D010011014D01001101
2338001110003700110111
So - bottom line (and to address your original question - which related to the changes that were made) - specifically from the data provided by the VCDS history file, it appears that the ONLY effective change that was successfully implemented from your records is Byte 23, Bits 0-3 (i.e. the "lower nibble") on the hex61 module.
Now, I don't have any information about this car that identifies the purpose of the 4 x software switches that were altered (perhaps someone else can help), but if the symptoms that you describe resulted from changes made to the car on 29/12/2020 -by force of the brutal logic from my analysis, maybe try reverting Byte 23 to it's original setting?
PS: And, in respect of the hex07 question - if the search-vector "Interfacebox" is entered into the forum's search facilities, it's clear from the hits, that the Coding value 0000002 is not unusual for the hex07 module. Which of course doesn't mean that it's necessarily the correct value for this car - but it does suggest from a diagnostic perspective that this is perhaps a lower-order hypothesis to solving the riddle in this case (no offense intended to Dave)
Barry Harkin
Northern Ireland
C?ID=426751
Thanks. Not sure what I changed. I know I change a number to 1 in some settings but not sure when. I changed the battery coding which got rid of the fault that I had with battery regulation.
South Molton, UK
Have you also looked at the file that VCDS keep of adaptation changes, it's called AdpLog.csv and is located in the same folder as the CodingLog.csv that you appear to have found already.
Barry Harkin
Northern Ireland
C?ID=426751
Yes I have. It doesnt show anything that I can see.
Address 61 4E0 910 181 B channel 2 adapted from 99 to 99 Saturday 19 December 2020 10:36:24:53286
Address 61 4E0 910 181 B channel 1 adapted from 0 to 1 Saturday 19 December 2020 10:36:39:53286
Address 61 4E0 910 181 B channel 1 adapted from 0 to 1 Sunday 20 December 2020 11:25:16:53286
Address 34 4E0 910 553 J channel 1 adapted from 396 to 380 Monday 4 January 2021 13:53:19:53286
Address 34 4E0 910 553 J channel 2 adapted from 396 to 380 Monday 4 January 2021 13:53:44:53286
Address 34 4E0 910 553 J channel 3 adapted from 378 to 385 Monday 4 January 2021 13:54:11:53286
Address 34 4E0 910 553 J channel 4 adapted from 378 to 385 Monday 4 January 2021 13:54:29:53286
Address 34 4E0 910 553 J channel 5 adapted from 0 to 1 Monday 4 January 2021 13:54:59:53286
