why i can get blockmaps only from all blocks in my car?
R0nald
Pirate
Krakow, Ukraine
VCDS — Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
why i can get blockmaps only from 09 and 19 blocks?
other blocks return adpmaps.
for example information about block 01-Engine:
Removed.  Data from a clone/pirate copy of VCDS is not acceptable here
Santos
From the VCDS Manual :
For modules using UDS, a modern HEX-NET or HEX-V2 interface is required to make channel maps of Measuring Values (the supporting ROD file for the module must be present as well).
I recommend dumping your pirated system and purchase a real V2/HEX-NET. Locked for pirated content.
R0nald
Pirate
Krakow, Ukraine
Good day.
Gearbox dq381.
Why does the IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum fall into IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1, and the time shows that she also went in higher temperatures.
Same with IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum and IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum.
Maximum temperatures greater than IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3.
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,5892.4, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,1829619.5, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,731788.5, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,13566.2, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,0.0, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,108, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,1817223.4, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,732038.0, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,24649.9, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,4245.0, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,328, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,2048119.8, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,523269.6, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,5665.5, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,920.6, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,397, °C
