Polo mk 8 2014 1.0 bluemotion ESP 9.0i abs coding
Greg2021
Preston, UK
C?ID=194531 (NRRT)
Hello
Please would anyone be able to help me out with getting the correct coding for my abs control unit. I have recently changed the ecu with a full ecu kit of a different vehicle same model (unfortunately haven't got an autoscan of the coding prior to changing) all part numbers for the ecu, comfort control module and instrument cluster on the new ecu kit all matched. I have checked in the advanced ID function that the vin numbers for the engine, immo, and ccm all match which they do. The car runs perfect but i am having issues coding the abs in i have provided an autoscan of the vehicle. The VIN number of the vehicle prior to changing the ecu kit was WVWZZZ6RZFU061370, any help is very much appreciated Thanks
Sunday,07,February,2021,11:31:52:49432
VCDS Version: 20.12.0.1 (x64)
VIN: WVWZZZ6RZFU102524   License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFU102524   Mileage: 35067km-21789miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 A    HW: 04C 907 309 J
   Component: R3 1.0l MPI   H24 8994
   Revision: 31H24000
   Coding: 01110052020401080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM10MPI01104C906057A 001015
   ROD: EV_ECM10MPI01104C906057_VW26.rod
   VCID: 234503172A14E09C3F-8076
          U0428 00 [047] - -
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:33:05
                    Engine RPM: 0.00 /min
                    Coolant temperature: 12 �C
                    Intake air temperature: 12 �C
                    Voltage terminal 30: 11.355 V
                    selected gear-Bits 0-7: 0
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [175] - -
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:33:05
                    Mass flow through throttle valve: 0.0 kg/h
                    Engine operating condition: Idle
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08501589141209
   Coding: 0000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3365F3579AF4701CCF-8066
0943 - ABS/ESP Control Module
          U10C5 00 [137] - No or Incorrect Basic Setting
                    Reset counter: 38
                    Mileage: 35064 km
                    Date: 2020.01.06
                    Time: 00:14:10
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:33:11
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:33:11
0887 - Control Module
          C104A F0 [008] - Incorrect VIN
                    Reset counter: 78
                    Mileage: 35064 km
                    Date: 2020.01.06
                    Time: 00:14:10
0883 - Control module not coded
          U1013 00 [137] - -
                    Reset counter: 38
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0108
   Serial number:  1412041B-0658
   Coding: 200000001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1D3135EF0C70D66C09-8048
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 B    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H07 0065
   Serial number: 001098151113
   Coding: 03000840425300530BA44080B10703880000580257010000000000000000
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_MQBA0.rod
   VCID: 2F6DFF2776DC54FCAB-807A
   Driver door control module:
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU019111443238689
   Coding: 1400A0
   Front passenger door control module:
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU020111443243654
   Coding: 0400A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1430724T0
   Serial number: 00000000000031339388
   Subsystem 5 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8611
   Serial number: KU0KU018111443221393
   Coding: 1400A0
   Subsystem 6 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8611
   Serial number: KU0KU025111443293363
   Coding: 0400A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag011 001 0330
   Revision: --------    Serial number: 003LM006XY8+
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3169F95F60E8420CBD-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 821 011 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H009D16CCCB1D1ED
   Subsystem 2 - Part No SW: -----------    HW: 410 821 011 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00C916483B2433I
   Subsystem 3 - Part No SW: -----------    HW: 442 151 711 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A001A283FF68E91W
   Subsystem 4 - Part No SW: -----------    HW: 442 150 712 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C71746240E1CB
          B13BC F2 [137] - No function
                    Mileage: 35064 km
                    Date: 2020.01.06
                    Time: 00:19:28
          U1101 00 [137] - Active
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:32:49
   Part No SW: 6C0 920 940 A    HW: 6C0 920 940 A
   Component: KOMBI         211 0290
   Coding: 272409002180260001082A001000000000000000
   VCID: 224B0613350EE99434-8076
16776973 - Databus
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:32:48
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001098151113
   Coding: 030100047F0A640071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 65C15D0F64A0DEAC91-8030
   Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H04 0019
   Serial number: 3191411021901196AB1B
   Coding: 240000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 51324955392821095095
          U1101 00 [009] - Active
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:32:49
                    Terminal 30 power supply: 11.4 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3211
   Serial number: CEBS0078
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
1094656 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:33:12
   Part No SW: 3Q0 035 820     HW: 3Q0 035 820
   Component: MU-S-D-ER     H11 0135
   Serial number: VWZAZ2P4636739
   Coding: 02620000BE00000011111201000808001F0100C60120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 66C35A0399A6D5B498-8032
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H43 1017
   Serial number: VWZ8Z9PH001DKB
15360768 - Component Protection
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:32:48
                    Voltage terminal 30: 11.4 V
0012 - Digital Radio Antenna
          B1103 11 [009] - Short to Ground
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:32:49
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: electrically OK
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: electrically OK
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
          U1111 00 [009] - -
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:32:52
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 38
                    Mileage: 35066 km
                    Date: 2020.01.06
                    Time: 15:32:51
End-------------------------(Elapsed Time: 02:35)--------------------------
myounus
Northwest UK
C?ID=321059
Well the scan is saying
C104A F0 [008] - Incorrect VIN and
For CP removal you’ll need ODIS online which should also be able to recode the ABS to your VIN.
secondly, I’d strongly recommend getting a genuine V2 cable
iichel
Eindhoven, NB, NL
C?ID=284912
do you also have the ABS coding prior to changing the ECU/clocks?
Greg2021
Preston, UK
C?ID=194531 (NRRT)
Thanks for your replies, unfortunately i don't have the abs coding prior to changing the ecu kit, is there any way i can get the correct coding without going down the route of odis online? I know my head unit will have component protection and will not work, the main thing is getting the abs coded so i can clear the warning lights and use the car as it is just out of mot. any help/advice is greatly appreciated i am struggling with this one
iichel
Eindhoven, NB, NL
C?ID=284912
Well I could have a go at guessing your coding but you need to find an ODIS person anyway. While you're at it you can retrieve your ABS coding as well.
Greg2021
Preston, UK
C?ID=194531 (NRRT)
Could I ask why I need Odis online? would the VCDS not code the abs if I could get the correct code? sorry for all the questions I haven’t had much to do with coding on Volkswagen before Thanks
iichel
Eindhoven, NB, NL
C?ID=284912
You need odis for the component protection of your airbag computer
