Friend's S6 DSG keeps going into limp mode. He just bought the car, also looks like it may be tuned. Thoughts on what to do?
AutoScan
AutoScan
Saturday,06,February,2021,12:11:50:52815
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4513.4
Dealer/Shop Name: Andy
VIN: WAUF2AFC1DN000000 License Plate:
Mileage: 118128km-73401mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 72 8F 90 A9 BA
VIN: WAUF2AFC1DN000000 Mileage: 118128km-73401miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0009
Revision: NCH62---
Coding: 0A2500326526000E1000
Shop #: WSC 55569 001 1048576
ASAM Dataset: EV_ECM40TFS0114G0906014B 001008
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 211CEDE4F1450EFFE69-8074
4007 - Idle Control System RPM
P0507 00 [096] - Higher than Expected.
Fault Frequency: 8
Mileage: 115434 km
Date: 2021.01.03
Time: 16:52:48
Engine speed: 850.00 /min
Normed load value: 6.7 %
Coolant temperature: 95 °C
Intake air temperature: 44 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 14.182 V
Unlearning counter according OBD: 24
Engine status: COENG_RUNNING
10577 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [047] - -
Fault Frequency: 12
Mileage: 115712 km
Date: 2021.01.03
Time: 19:54:42
Engine speed: 845.00 /min
Normed load value: 5.5 %
Vehicle speed: 4 km/h
Coolant temperature: 98 °C
Intake air temperature: 56 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 14.088 V
Part No SW: 4G1 927 156 S HW: 0B5 927 156 J
Component: 0B5 40TFSINAR H01 0011
Revision: --H01---
Shop #: WSC 02391 785 00200
ROD: EV_TCMDL501021.rod
VCID: 3D2431946DFD4A1FE21-8068
18765 - Valve 3 in Transmission Part 1
P17D4 00 [232] - Mechanical Malfunction
Fault Frequency: 21
Reset counter: 40
Mileage: 116951 km
Date: 2021.01.11
Time: 16:18:24
Engine speed: 780 /min
Transmission input speed: 780 /min
Engine torque: 4 Nm
Transmission fluid temperature: 59 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Voltage terminal 30: 14.400 V
18766 - Valve 3 in Transmission Part 2
P17D5 00 [104] - Mechanical Malfunction
Fault Frequency: 21
Reset counter: 37
Mileage: 114849 km
Date: 2021.01.02
Time: 22:35:30
Engine speed: 589 /min
Transmission input speed: 589 /min
Transmission output speed: 2 /min
Engine torque: 0 Nm
Transmission fluid temperature: 54 °C
Unlearning counter according OBD: 37
Voltage terminal 30: 14.000 V
18446 - Clutch 2
P17D0 00 [096] - Slippage too High
Fault Frequency: 0
Reset counter: 0
Time: 00:00:00
Engine speed: 21.25 /min
Transmission input speed: 21 /min
Transmission output speed: 84 /min
Engine torque: -96 Nm
Transmission fluid temperature: -40 °C
Accelerator position: 12.8 %
Unlearning counter according OBD: 0
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 65B64F01A66DF2804B00
VCID: 36362EB848CB994723B-8062
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H33 0433
Coding: 0D882006000000000000
VCID: 7BA0FF8C33E9842F9C5-802E
Serial number: 2313000021277003
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0076
Serial number: 14021300040119
Coding: 688120B849
ASAM Dataset: EV_AirCondiComfoUDS 002036
VCID: 629EA2E8B4C355E7BF3-8036
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001686179
Coding: 09072011053C9FE0A90008C7A0003800CF9CD208A20802218001085C7B00
Shop #: WSC 31497 001 104857
VCID: 6FB8DBDC7791E88F20D-803A
Component: WWS57X 130203 H36 0080
Serial number: 130211151922
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20989218
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 09 02 2013 00000713
Component: USHL4.2 H30 0030
Serial number: 0000002274555R4WMS02
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000008021300010195
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000012021300010396
Coding: 110000
Subsystem 7 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA104613000002810617
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: D4E88396000000000001
Revision: 11001001 Serial number: 61061304702325
Coding: A8C10A
VCID: 71BCDDA46125FE7F369-8024
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8002SFK3
Coding: 303234373131303030314A55304C34473053
VCID: 333017AC5BB98C6F045-8066
Serial number: 6940000Y130000PX240Z
Serial number: 3575HRB400650EV49PNO
Serial number: 3585HRB40691PU921OKZ
Serial number: 3515JRB400K50EA0RP15
Serial number: 3525JRB400250FFEK12L
Serial number: 3554VRB401I50D62P18/
Serial number: 3564VRB401I50D62DP46
Revision: -------- Serial number: 90372MBE0005X
Coding: 000434
VCID: 382A2080425F6F37317-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 30 01 2013 A0150306
Part No SW: 4G0 920 981 K HW: 4G0 920 981 K
Component: TBenUsa Nv H76 0515
Revision: 28460208 Serial number: 658120213596021
Coding: 03EF09059B41D705020200
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000829009
Coding: 00E1034800
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 0728819101
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 001202130001724
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 2708F3FC9F61F0CFA8D-8072
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0086
Serial number: 14021300041490
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
VCID: 372823BC4FC1604F38D-8062
0025 - Motor for Rear Left Upper Body Vent
B10D3 22 [009] - Signal Amplitude Too High
Fault Frequency: 80
Reset counter: 242
Mileage: 115267 km
Date: 2021.01.03
Time: 13:01:43
Voltage terminal 30: 14.13 V
Outside air temperature: 26.0 °C
Left Rear Upper Body Vent Motor-Act.val.: 12006
Left Rear Upper Body Vent Motor-Specified value: 12006
Left Rear Upper Body Vent Motor-Stop open: 11405
Left Rear Upper Body Vent Motor-Stop closed: 10000
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [009] - Signal Amplitude Too High
Fault Frequency: 80
Reset counter: 242
Mileage: 115267 km
Date: 2021.01.03
Time: 13:01:45
Right Rear Upper Body Vent Motor-Act.val.: 12021
Right Rear Upper Body Vent Motor-Specified value: 12021
Right Rear Upper Body Vent Motor-Stop open: 11420
Right Rear Upper Body Vent Motor-Stop closed: 10000
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Coding: 008000
ROD: EV_AirSuspe_VW51.rod
VCID: 2E0606D8B09BA1876BB-807A
455688 - Sensor for Ride-Height
C1048 07 [008] - Mechanical Failure
Reset counter: 23
Time: 00:00:00
455690 - Sensor for Ride-Height
Reset counter: 12
Time: 00:00:00
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Reset counter: 23
Mileage: 114792 km
Date: 2021.01.02
Time: 10:15:45
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000052283630
Coding: 00581B0000002001000001010101102030303232203232
VCID: 77A8E3BC0FC1A04FF8D-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H02 0056
Revision: -------- Serial number: EJ1BPA7E00B96+
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 303A18A0A62FB777797-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0050
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F13.02.1300H03000AMS15924ÿ
Subsystem 4 - Serial number: S15924ÿ
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17005E00628002000012
VCID: 47C8537C3FA110CF48D-8012
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0023215158
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323E12A8A4A385670F3-8066
Revision: 00002001 Serial number: 0301080381
Coding: 01060E3A00FA408580B0088002050E000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000131107
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO20192570
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00002900153
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000004113
VCID: 1C62DC10D6A7231735F-8048
00529 - Engine Speed Signal Missing
Fault Status: 00110000
Fault Frequency: 9
Reset counter: 26
Mileage: 115843 km
Date: 2021.01.03
Time: 23:02:03
03994 - Noise reduction function limitation
Fault Frequency: 9
Reset counter: 26
Mileage: 115843 km
Date: 2021.01.03
Time: 23:02:03
Bin. Bits: 00000001
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: 46D65E7838AB09C7B3B-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000600355
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B000FCC8389D4AF4C5-807E
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130220-0002-024
Coding: 12216F601002A400
ROD: EV_HeadlRegulBasic.rod
VCID: 2D0401D4BD9DDA9F521-8078
Part No SW: 4G0 035 082 E HW: 4G0 035 082
Component: Radio U SIRIU H60 0121
Revision: AB001007 Serial number: 156B%0D7693077
Coding: 020007010000000001
VCID: 221EE2E8F4C315E7FF3-8076
Part No SW: 4G0 035 746 D HW: 4G0 035 746 B
Component: H-BNT-NA H50 0622
Revision: -------- Serial number: 194BU0D7524430
Coding: 060200000303F1EF55128B1E00000003100001000000000000
VCID: 280AF0C092FFFFB7A17-807C
Subsystem 1 - Part No: 8R0 060 884 BA
Component: NAR 2013 0703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDCD000SDB-
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Serial number: 90349MBE000C8
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
VCID: 49CC554429B5E6BF5E9-801C
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Revision: --H06--- Serial number: 525 PA8J31G0TA
Coding: 1080004
VCID: 2616FEF894EBE9C793B-8072
Component: TSG HR H03 0507
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313C1DA4A1A5BE7F769-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 130119200544
VCID: 2C020CD08687D39745F-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804001443504
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X_AU57.rod
VCID: 6696BEF858EB29C753B-8032
0306 - Actuator 2 for Drivetrain Mounts
C1132 13 [009] - Open Circuit
Reset counter: 165
Mileage: 114768 km
Date: 2021.01.01
Time: 18:27:34
0554 - No Basic Setting
B2010 00 [009] - -
[FC_AssemblyCheck_NotDone]
Reset counter: 165
Mileage: 114768 km
Date: 2021.01.01
Time: 18:27:33
1632 - invalid data record
B2005 00 [009] - -
[FC_Dataset_Invalid]
Reset counter: 165
Mileage: 114768 km
Date: 2021.01.01
Time: 18:27:33
End----(Elapsed Time: 02:32, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
