2013 S6 - DSG problems
SpeedRacerAZ
C?ID=312337
Friend's S6 DSG keeps going into limp mode. He just bought the car, also looks like it may be tuned. Thoughts on what to do?
AutoScan
Saturday,06,February,2021,12:11:50:52815
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
Dealer/Shop Name: Andy
VIN: WAUF2AFC1DN000000   License Plate:
Mileage: 118128km-73401mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 3C 42 44 46
          47 52 53 55 56 5F 62 6C 72 8F 90 A9 BA
VIN: WAUF2AFC1DN000000   Mileage: 118128km-73401miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0009
   Revision: NCH62---
   Coding: 0A2500326526000E1000
   Shop #: WSC 55569 001 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906014B 001008
   ROD: EV_ECM40TFS0114G0906014B.rod
   VCID: 211CEDE4F1450EFFE69-8074
4007 - Idle Control System RPM
          P0507 00 [096] - Higher than Expected.
                    Fault Frequency: 8
                    Mileage: 115434 km
                    Date: 2021.01.03
                    Time: 16:52:48
                    Engine speed: 850.00 /min
                    Normed load value: 6.7 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 14.182 V
                    Unlearning counter according OBD: 24
                    Engine status: COENG_RUNNING
10577 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [047] - -
                    Fault Frequency: 12
                    Mileage: 115712 km
                    Date: 2021.01.03
                    Time: 19:54:42
                    Engine speed: 845.00 /min
                    Normed load value: 5.5 %
                    Vehicle speed: 4 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 56 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 14.088 V
   Part No SW: 4G1 927 156 S    HW: 0B5 927 156 J
   Component: 0B5 40TFSINAR H01 0011
   Revision: --H01---
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 3D2431946DFD4A1FE21-8068
18765 - Valve 3 in Transmission Part 1
          P17D4 00 [232] - Mechanical Malfunction
                    Fault Frequency: 21
                    Mileage: 116951 km
                    Date: 2021.01.11
                    Time: 16:18:24
                    Engine speed: 780 /min
                    Transmission input speed: 780 /min
                    Engine torque: 4 Nm
                    Transmission fluid temperature: 59 °C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 14.400 V
18766 - Valve 3 in Transmission Part 2
          P17D5 00 [104] - Mechanical Malfunction
                    Fault Frequency: 21
                    Reset counter: 37
                    Mileage: 114849 km
                    Date: 2021.01.02
                    Time: 22:35:30
                    Engine speed: 589 /min
                    Transmission input speed: 589 /min
                    Transmission output speed: 2 /min
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 54 °C
                    Unlearning counter according OBD: 37
                    Voltage terminal 30: 14.000 V
18446 - Clutch 2
          P17D0 00 [096] - Slippage too High
                    Fault Frequency: 0
                    Reset counter: 0
                    Engine speed: 21.25 /min
                    Transmission input speed: 21 /min
                    Transmission output speed: 84 /min
                    Engine torque: -96 Nm
                    Transmission fluid temperature: -40 °C
                    Accelerator position: 12.8 %
                    Unlearning counter according OBD: 0
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 65B64F01A66DF2804B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 36362EB848CB994723B-8062
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H33 0433
   Coding: 0D882006000000000000
   VCID: 7BA0FF8C33E9842F9C5-802E
   Serial number: 2313000021277003
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 14021300040119
   Coding: 688120B849
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 629EA2E8B4C355E7BF3-8036
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001686179
   Coding: 09072011053C9FE0A90008C7A0003800CF9CD208A20802218001085C7B00
   Shop #: WSC 31497 001 104857
   VCID: 6FB8DBDC7791E88F20D-803A
   Component: WWS57X 130203  H36 0080
   Serial number:         130211151922
   Coding: 0045F7
   Serial number: 20989218
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 09 02 2013  00000713
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R4WMS02
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000008021300010195
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000012021300010396
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104613000002810617
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: D4E88396000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061304702325
   Coding: A8C10A
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BCDDA46125FE7F369-8024
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002SFK3
   Coding: 303234373131303030314A55304C34473053
   VCID: 333017AC5BB98C6F045-8066
   Serial number: 6940000Y130000PX240Z
   Serial number: 3575HRB400650EV49PNO
   Serial number: 3585HRB40691PU921OKZ
   Serial number: 3515JRB400K50EA0RP15
   Serial number: 3525JRB400250FFEK12L
   Serial number: 3554VRB401I50D62P18/
   Serial number: 3564VRB401I50D62DP46
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372MBE0005X
   Coding: 000434
   VCID: 382A2080425F6F37317-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 30 01 2013  A0150306
   Part No SW: 4G0 920 981 K    HW: 4G0 920 981 K
   Component: TBenUsa   Nv  H76 0515
   Revision: 28460208    Serial number: 658120213596021
   Coding: 03EF09059B41D705020200
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000829009
   Coding: 00E1034800
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 0728819101
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0013
   Serial number: 001202130001724
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 2708F3FC9F61F0CFA8D-8072
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0086
   Serial number: 14021300041490
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
   VCID: 372823BC4FC1604F38D-8062
0025 - Motor for Rear Left Upper Body Vent
          B10D3 22 [009] - Signal Amplitude Too High
                    Fault Frequency: 80
                    Reset counter: 242
                    Mileage: 115267 km
                    Date: 2021.01.03
                    Time: 13:01:43
                    Voltage terminal 30: 14.13 V
                    Outside air temperature: 26.0 °C
                    Left Rear Upper Body Vent Motor-Act.val.: 12006
                    Left Rear Upper Body Vent Motor-Specified value: 12006
                    Left Rear Upper Body Vent Motor-Stop open: 11405
                    Left Rear Upper Body Vent Motor-Stop closed: 10000
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [009] - Signal Amplitude Too High
                    Fault Frequency: 80
                    Reset counter: 242
                    Mileage: 115267 km
                    Date: 2021.01.03
                    Time: 13:01:45
                    Right Rear Upper Body Vent Motor-Act.val.: 12021
                    Right Rear Upper Body Vent Motor-Specified value: 12021
                    Right Rear Upper Body Vent Motor-Stop open: 11420
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008000
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E0606D8B09BA1876BB-807A
455688 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
                    Reset counter: 23
455690 - Sensor for Ride-Height
                    Reset counter: 12
          C10C8 00 [008] - -
                    Reset counter: 23
                    Mileage: 114792 km
                    Date: 2021.01.02
                    Time: 10:15:45
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000052283630
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77A8E3BC0FC1A04FF8D-8022
   Component: SARA 6D red   H02 0056
   Revision: --------    Serial number: EJ1BPA7E00B96+
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 303A18A0A62FB777797-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H03 0050
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F13.02.1300H03000AMS15924ÿ
   Subsystem 4 - Serial number: S15924ÿ
   Component: TSG FA        H03 0507
   Coding: 011F17005E00628002000012
   VCID: 47C8537C3FA110CF48D-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0023215158
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323E12A8A4A385670F3-8066
   Revision: 00002001    Serial number: 0301080381
   Coding: 01060E3A00FA408580B0088002050E000000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000131107
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO20192570
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00002900153
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000004113
   VCID: 1C62DC10D6A7231735F-8048
00529 - Engine Speed Signal Missing
                    Fault Status: 00110000
                    Fault Frequency: 9
                    Reset counter: 26
                    Mileage: 115843 km
                    Date: 2021.01.03
                    Time: 23:02:03
03994 - Noise reduction function limitation
                    Fault Frequency: 9
                    Reset counter: 26
                    Mileage: 115843 km
                    Date: 2021.01.03
                    Time: 23:02:03
                    Bin. Bits: 00000001
   Component: TSG BF        H03 0507
   Coding: 011F17005E00628002000002
   VCID: 46D65E7838AB09C7B3B-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000600355
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B000FCC8389D4AF4C5-807E
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 130220-0002-024
   Coding: 12216F601002A400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D0401D4BD9DDA9F521-8078
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156B%0D7693077
   Coding: 020007010000000001
   VCID: 221EE2E8F4C315E7FF3-8076
   Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
   Component: H-BNT-NA      H50 0622
   Revision: --------    Serial number: 194BU0D7524430
   Coding: 060200000303F1EF55128B1E00000003100001000000000000
   VCID: 280AF0C092FFFFB7A17-807C
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDCD000SDB-
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MBE000C8
   Component: CD-Database  4949
   Component: TSG HL        H03 0507
   Coding: 010F17004000628002000002
   VCID: 49CC554429B5E6BF5E9-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J31G0TA
   Coding: 1080004
   VCID: 2616FEF894EBE9C793B-8072
   Component: TSG HR        H03 0507
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313C1DA4A1A5BE7F769-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 130119200544
   VCID: 2C020CD08687D39745F-8078
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804001443504
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X_AU57.rod
   VCID: 6696BEF858EB29C753B-8032
0306 - Actuator 2 for Drivetrain Mounts
          C1132 13 [009] - Open Circuit
                    Reset counter: 165
                    Mileage: 114768 km
                    Date: 2021.01.01
                    Time: 18:27:34
0554 - No Basic Setting
          B2010 00 [009] - -
          [FC_AssemblyCheck_NotDone]
                    Reset counter: 165
                    Mileage: 114768 km
                    Date: 2021.01.01
                    Time: 18:27:33
1632 - invalid data record
          B2005 00 [009] - -
          [FC_Dataset_Invalid]
                    Reset counter: 165
                    Mileage: 114768 km
                    Date: 2021.01.01
                    Time: 18:27:33
End----(Elapsed Time: 02:32, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Gone But Not Forgotten
Are you going to fix mechanicals for slippage, check verify fluids and remove FOD to complete a comporting qualified repair?
JPPSG
SpeedRacerAZ
C?ID=312337
If he can figure out which FOD is in there, yes.
Start with a simple fluid and filter change and clutch adaptation?
When cross checking your oil consumption thread & that IS apparently a newer version of the car huh?
PATTERN BEHAVIOR HUH?
THESE EPA FOIA'S REALLY MAKE YOU WONDER, DO THEY NOT?
DID YOU SEE PAGE 139 OF PDF OR SECTION 21 YET, WHAT DOES IT ALL MEAN? :rolleyes:
Revision: NCH62---
Audi
PartVersion
FL_4G0906014B_0004
0006
FL_4G0906014B__0006BACKFL_4G0906014B__0006BACK
FL_4G0906014B_0007
0008
0009
ModuleCAL IDCVNTest Group
ECM4G0014B 00010A8A4E3CDADXV04.03UJ
ECM4G0014B 00028D6B9C27DADXV04.03UJ
ECM4G0906014B0004647120E9DADXV04.03UJ
ECM4G0906014B0006D0EB3855DADXV04.03UJ
ECM4G1927156S00040000E293DADXV04.03UJ
ECM4G0906014B 00075FC00CFCDADXV04.03UJ
ECM4G0014B 0009 AVAKD0AAE84FDADXV04.03UJ
ECM4G0906014E00022FDD722AEADXV04.03UJ
Revision: --H01---
Audi​
PartVersion
FL_4G1927156S_0007
0009
0010
0011
0013
0014
TCM4G1927156S0005000017ABDADXV04.03UJ
TCM4G1927156S000800005CF0DADXV04.03UJ
TCM4G1927156S000700 00 D9 C8DADXV04.03UJ
TCM4G1927156S 000900001EE8DADXV04.03UJ
TCM4G1927156S 00100000E293DADXV04.03UJ
TCM4G1927156S 00110000A9C1DADXV04.03UJ
TCM4G1927156S 00130000CF57DADXV04.03UJ
TCM4G1156S 00140000EEEEDADXV04.03UJ
TCM4G1927156S 000130000CF57DADXV04.03UJ
