VW TOUAREG - AIR CONDITION PROBLEMS (BLOWER MOTOR + New fault codes eg. Auto HVAC -- Status: Malfunction 0010
adrianclyfe
British Virgin Islands
C?ID=327092
Hi VW family, I hope you are all okay. I have owned my VW Touareg 2011/12 for over 4 years now. The only issues I have had with it throughout my ownership relates to the Air Conditioning unit. When it works, it is not as powerful as many AC systems usually are. The blower motor has died 3-4 times. Literally stopped working and I had to replace a few times. Recently, the AC would turn on and then off again. It would even come on while the engine was completely off. Finally, it died off and never comes on. I screened it with the VCDS RT software and came up with several fault codes although this one stands out (Auto HVAC -- Status: Malfunction 0010). I really need your help guys ( any help ). Has anyone else experienced this?. BTW, I live and drive it in the Caribbean which is predominantly a hot place but I doubt that that has anything to do with my sustained predicament.
Many thanks
Adrian
adrianclyfe
C?ID=327092
Hi Uwe - many thanks for coming back to me. See Auto Scan posted below and let me know if you need any more information as it is a 16 page report.
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 2E 36 42 46 52 53 55 56
62 72 77 A7
VIN: WVGZZZ7PZCD Mileage: 49811km-30951miles
Engine -- Status: OK 0000
Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010 2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Cannot be reached 0100 42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000
further report information on HVAV below
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb Part No SW: 7P6 907 040 BN HW: 7P6 907 040 BN
Component: Klima 2 Zonen H20 1305 Coding: 46A6000E80
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_AirCondiFront 004001 ROD: EV_AirCondiFront_VW52.rod VCID: 015F7861B18E71C35DD-8054
9 Faults Found:
0004 - Motor for Left Temperature Flap B108C 31 [009] - No Signal
Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
0009 - Motor for Right Temperature Flap
B108D 22 [009] - Signal Amplitude Too High Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
0025 - Motor for Defroster Flap
B1090 22 [009] - Signal Amplitude Too High Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
0052 - Motor for Left Side Vent Flap B10C9 31 [009] - No Signal
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
0068 - Motor for Left Footwell Flap B10B9 31 [009] - No Signal
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
0084 - Motor for Left Center Vent Flap B10CB 31 [009] - No Signal
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
0309 - Local data bus 2
U1076 00 [009] - Electrical malfunction Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
0320 - Function Restricted due to Missing Message(s) U1111 00 [009] - -
Reset counter: 243
Mileage: 49769 km
Time: 11:55:56
0415 - Motor for Fresh Air / Recirculated Air Flap B108B 31 [009] - No Signal
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
A7-Infotain. Interface -- Status: OK 0000
adrianclyfe
C?ID=327092
62 72 77 A7
9 Faults Found:
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
Reset counter: 243
Mileage: 49769 km
Time: 11:55:56
Fault Frequency: 20
Reset counter: 248
Mileage: 49769 km
Date: 2020.11.21
Time: 11:55:56
hi there - what does this mean? thanks again
Bruce
Near Philadelphia, PA, USA
If this were my vehicle, I'd break out the wiring diagram I downloaded from the erWin website and I would look for something in common with all the flap motors. With nothing in front of me at the moment, I would be guessing you have a ground problem. Check wiring at the ground studs..
Could it be a fuse?
adrianclyfe
C?ID=327092
Thanks Bruce. I am trying to purchase a subscription so I can download the wiring diagram. My VW is a European RHD version but I suppose I will be able to figure out where the connections will be anyway. Sorry I am new to this but what do you mean by 'Ground Problem' and 'ground studs" ? Thanks again.
Regards
Bruce
Have you ever dug into the wiring of a VAG car? They often make connections to the body of the vehicle to connect to (-) or ground side of the circuit rather than running a wire back to the engine compartment and to the battery. They weld a stud the body steel and connect to the steel. While this works, it is also often subject to corrosion, abrasion and so on. When the refernce to ground is not truly a good return path, then you might see problems such you are exhibiting.
I also suggested you check the fuses.. you may not have power (+12) for these motors. If the fuse is good, could there be a relay that has to send power to these motors? Again, something in common to all of them. It is not likely to be the control module even though it is in common with all of them. The control module controls each motor individually... the WD will show that.
It is likely to be a wiring issue... IMO
By the way, the link I sent has listings for North America and rest of world. I would hope you could find your vehicle in the rest of world section.
