After BNS retrofit to 2009 A3 8P the battery is drained really hard. After fully lock the car the drain in somewhere between 0.2A - 1.0A.
When I put back Concert3 (which was factory fitted) the drain is around 0.05 or lower.
Read that it might be because of not compatible CAN gateway, can anyone check/confirm this?
Thanks.
Thanks.
Tuesday,19,January,2021,20:05:26:35018
VCDS Version: 20.12.0.1 (x64)
VIN: xxx License Plate: xxx
Mileage: xxx Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 55 56 62 72
77
VIN: WAUZZZ8P4AA017069 Mileage: 291700km-181253miles
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 997 021 G HW: 03L 906 022 BQ
Component: R4 2,0L EDC G000SG 0508
Revision: 13H01--- Serial number: AUX7Z0I5FNI0FO
Coding: 0000172
Shop #: WSC 66565 257 00032
VCID: 3261EE7BADA7AB14C4-8066
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 1442801209230001280B01EA902200423C00
Shop #: WSC 06314 123 12345
VCID: 000574B3938BC98402-8054
Part No SW: 8P0 820 043 BK HW: 8P0 820 043 BK
Component: KlimavollautomatH09 0130
Revision: 000355 Serial number: 8P0820043BK
VCID: 76E9126B014FF73428-8022
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 104 0541
Revision: 00104 AG
Coding: 06000A3FF0051AC0207240E02100095C477E2BAA316DD129E40008840040
VCID: 3261EE7B6DA7AB14C4-8066
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 D Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Fault Status: 00100001
Reset counter: 237
Mileage: 291346 km
Term 15 Off
Voltage: 15.50 V
Term 50 Off
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93630916503983
Coding: 000003
Shop #: WSC 06314 000 00000
VCID: 4281BEBBDD071B9454-8016
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0140
Revision: -------- Serial number: 003FB001N91K
Coding: 30314238303830303035554A304C38503053
ROD: EV_Airba10AURB4.rod
VCID: 4FA7878F1655E6FCCB-801A
Serial number: 3572DRB400008F05032J
Serial number: 3582DRB400008F350A7Z
Serial number: 35128RB400004DED203O
Serial number: 35228RB400004DEB6FB7
Serial number: 35547RB400004E3612FP
Serial number: 35647RB400004E36115F
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004042
VCID: 4689A2AB312F27B478-8012
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 C HW: 8P0 920 932 C
Component: KOMBIINSTR. VDO H02 0980
Revision: D0H02002 Serial number: 2245I002009555
Coding: 0037028
Shop #: WSC 12345 123 66697
VCID: 346DE86357B3A524D6-8060
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H16 0222
Revision: H16 Serial number: 4020K09618099A
Coding: E9A37F06400602002102
VCID: 66C9422B51EF07B498-8032
Fault Frequency: 91
Reset counter: 249
Mileage: 285850 km
Fault Frequency: 89
Reset counter: 249
Mileage: 285850 km
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 438FBBBF021D129C5F-8016
Revision: D0H02002 Serial number: AUX7Z0I5FNI0FO
Shop #: WSC 03620 001 1048576
Address 37: Navigation Labels: 8J0-035-192-RNSL.lbl
Part No SW: 8P0 035 192 P HW: 8P0 035 192 P
Component: J0503 RNS-LOW 0250
Revision: 00012000 Serial number: AUZ1Z1H8163518
Coding: 0037097
Shop #: WSC 17537 136 73459
VCID: 3C7DC0437FE36D641E-8068
02244 - Button in Control Head is Stuck
Fault Status: 00101110
Reset counter: 220
Mileage: 290786 km
Date: 2020.12.14
Time: 14:48:54
Reset counter: 73
Mileage: 285808 km
Date: 2020.08.07
Time: 22:20:57
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 M HW: 8P0 959 801 M
Component: Tuer-SG H04 0100
Coding: 0004348
VCID: 458BA5A70C292CAC71-8010
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 233 2901
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2F67E70FBE9586FCAB-807A
Part No SW: 8P0 959 802 M HW: 8P0 959 802 M
Coding: 0004348
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0050
Coding: 0000028
VCID: 69D3491740F128CCB5-803C
Subsystem 1 - Part No: 7L6 941 329 B
Component: AFS-Modul links H03 0004
Subsystem 2 - Part No: 7L6 941 329 B
Component: AFS-Modul rechtsH03 0004
Address 56: Radio Labels: 8J0-035-192-RNSL.lbl
Coding: 0037097
Reset counter: 220
Mileage: 290786 km
Date: 2020.12.14
Time: 14:48:54
Reset counter: 73
Mileage: 285808 km
Date: 2020.08.07
Time: 22:20:57
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000216
Shop #: WSC 06314 000 1012544
VCID: 4281BEBB1D071B9454-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000216
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H34 0600
Revision: 00000000 Serial number: 00000005099893
Coding: 0011422
VCID: 75EB15671C49FC2C21-8020
End-------------------------(Elapsed Time: 02:20)--------------------------
