D4 Audi A8 VCDS Codes
Jack88
California, USA
C?ID=242298
I posted this list over at a different forum, but I thought some people here might appreciate it as well. I tested some of the ones intended for other models, as well as playing with the VCDS to check for anything not included and added them to the list. Some options available for other models still show up in the computer, but don't appear to have any effect (like the lap timer.) Here's what I've found so far, I have tested the functionality of most of these.
Disable After-wipe of windscreen wipers
[09 – Cent. Elect.] [Coding - 07] -> Byte 1
Bit 3 - Remove check mark (1 = active)
________________________________________
Disable amber corner lights
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Submodule 0
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
Disable Key warning
[46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
Disable "Lights are on" Warning
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
Disable NAV & Phone warning messages while entering data at speed
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
Disable Seatbelt Chime
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning inactive
Adjust Date display
[17 – Instruments]
[Coding - 07] -> Long Code Helper ->
Byte 7 – Use dropdown to select date format
Upshift Display
[17 – Instruments]
[Adaption - 10] -> Upshift Display in center panel ->
Use dropdown to activate/deactivate
(untested)
Enable Adaptive brake lights
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
__________________________________________
Enable Double Disarm Beep
[46 - Central Conv.] [Adaptation - 10] -> Channel 63
Add 4
Enable/Disable Auto Locking
Byte 5 – 0=off/1=on
Bit 4 – Auto lock
Bit 5 – Auto Unlock
Enable DRL to include the following:
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL with Front Side markers
Bit 2 = DRL with High Beams
Bit 3 = DRL with Fog lights
Bit 4 = DRL with LEDs
Bit 6 = DRL with Side markers
Bit 7 = DRL with Tail lights
Enable Euro parking lights that turn on signal at night
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 0 - Set to 1
Enable fog lamp to come on for the same side as that turn signal
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Check the box or change :Bit 0 set to 1
Enable Front Turn Signals as Parking lights
Bit 0- Check the box or change :Bit 0 to 1
Enable Gauge Test/Needle Sweep
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
Enable Hidden menu in MMI
change 0 to 1
Use this hidden menu at your own risk.
Caution: Keep away from the "Bootloader", if it appears as an option
Enable Import CDs to MMI's HD
[Hidden menu]
Main/Diagnose/Settings
Import Media
Set to 4 of 4 "Copy/Ripping"
Note: CD must be inserted in player below the mmi, not the changer in the glovebox to be able to rip it.
Enable Independent Fogs control with high beams
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to ______________________________________
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
________________________________________________
Enable Release Parking Brake without putting foot on Brake
[53 - Parking Brake][Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 4 Set to 0
Enable Release Parking Brake without putting seatbelt
[Adaptation - 10] -> Channel 7 Set to 0
Enable Reverse mirror tilt
[52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 4 and Bit 2 set to 1
Enable VIM on MMI
[5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
[Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
[Adaptation - 10] -> Channel 48
Set to 255
Reset MMI
Set ADS to specific preset Comfort, Auto, Dynamic or Individual
[09 – Cent. Elect.][Security Access - 16](VCDS will have popup telling you the access code, mine was 20113)
Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
[Adaptation - 10] -> Channel 64
[Adaptation - 10] -> Channel 65
[Adaptation - 10] -> Channel 66
*Note all four channels needs to be set to the same value. (Uncomfirmed)
Set Headlight washer – Duration (values in milliseconds)
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 6
change to e.g. 500
Set Headlight washer – Activation Delay
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 25
change to e.g. 3000
Set Headlight washer – Delay (How many times you can activate the regular washers without activating the headlight washers)
[09 – Cent. Elect.]
change to e.g. 3000
Set Coming Home Time– Duration
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 43
change to e.g. 30
Activate/Deactivate Leaving Home Function
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 46
change to 0=off / 1=on
Coming Home – Ambient Light Threshold for activation
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 37
change from 0-7
Enable/Disable Coming Home and Leaving Home Function
[09 – Cent. Elect.]
Byte 6 – 0=off/1=on
Bit 1 – Coming Home
Bit 2 – Leaving Home
Enable/Disable Parking Lights
[09 – Cent. Elect.]
Byte 9 – 0=off/1=on
Bit 0 – Parking Light Function
Adjust LED brightness
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
Set between 5 and 100
I have some fiddling with VCDS to do, I'm sure that there's more to find. I will provide updates when I find anything new.
Note: Thanks to kczach at Audiworld for the starting point
mohd606
Bahrain
C?ID=408746
Hello
Which model is your car? Is it pre facelift and you have done facelift conversion??
Or just you changed the headlights to the higher full led option?
I have similar problem
My Car is 2011 d4 and I have done full facelift conversion
None matrix headlights and I need the codes to get rid of the DTC on dash
Westbury, UK
Jack88 hasn't visited this site for over 2 years and his post in this thread is over 5 years old, so you may not get a reply from him.
  • Agree
Vagdiag123
Romania
C?ID=393055
enable Easy Entry ?
Timo
Finland
C?ID=344842
I have A8 D4 2011 with xenon headlamps and the fog lamps are integrated with the main headlights (equipped with adaptive cruise control). I am trying to get the fog lamps to turn on as cornering lamp but for some reason this coding does not work:
Any idea how to get the cornering lamps working?
GlynH
C?ID=75902
Rather than start a new thread I thought I'd post here to keep everything A8 D4 related in the same place.
I modded the massage intensity some years ago from;
Level 1: 56->58%
Level 2: 61->68%
Level 3: 68->78%
Level 4: 75->88%
Level 5: 82-98%
Since then I have been meaning to alter the temperature levels but I looked today and don't see anything temperature related at Multicont addresses 88 Front DS, 89 Front PS, 8A Rear DS or 8D Rear PS which was where I adjusted the massage intensity from.
I also looked under 08 HVAC and couldn't find it there either.
Assuming the temperatures for Levels 1, 2 & 3 can be adjusted does anybody know where they might be hidden please?
When set to 3 it is almost too hot but luckily the stepdown from 3->2 kicks in after 10 minutes but then I can barely feel the heat when set to Level 2 and have to keep toggling back to 3 which is annoying!
What I would like to do is reduce the heat on Level 3 a little but increase the temperature on Level 2 and possibly Level 1 also if only I knew where to look.
I increased the temperature of the steering wheel at address 16 from 28-30c way back when I adjusted the massage intensity so I am guessing the seat temperatures can be adjusted also.
Any ideas please?
Thanks & kind regards,
-=Glyn=-
GlynH
C?ID=75902
Yup...it's the same car Uwe.
Seems odd that I can alter stepdown timers for seat heating (along with things like pressures in various seat bolsters) and even steering wheel temperature but not seat temperature.
Ah well I'll have to put up with sunburn on level 3 and wondering whether the heat is working at all on level 2 I suppose.
Thanks for taking the time to take a look & reply Uwe.
Kind regards,
-=Glyn=-
Timo
Finland
C?ID=344842
Got the cornering lamps working after coding 4 times.... :rolleyes:
