Vw polo 1.6. lost its abs coding.
turandos
Pretoria, South Africa
C?ID=232762
Good morning. i have a polo 1.6 that lost its long code for abs.can any one please help.here is a complete scan report on vehicle. Tx AJ.
Tuesday,29,December,2020,00:53:52:39486
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 20.4.2.0
Dealer/Shop Name: turandos workshop
Workshop Code: 012 01966 651226
VIN: AAVZZZ6RZCU048783   License Plate: BX 25 VD GP
Mileage: 115910km-72023mi   Repair Order: paul
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: AAVZZZ6RZCU048783   Mileage: 115910km-72023miles
Address 01: Engine (J623-CLSA)       Labels: Redir Fail!
   Part No SW: 03C 906 014 AF    HW: 03C 906 014
   Component: CLSA-MM7GV    H02 8573
   Revision: --H02---    Serial number:
   Coding: 00110014020400000000
   Shop #: WSC 31414 790 31414
   VCID: 61CF47477BD3948E7C-51A0
28793 - No Communication with ABS Brake Control Module
            U0121 - 000 -  - Intermittent
                    Reset counter: 152
                    Mileage: 115913 km
                    Date: 2015.05.22
                    Time: 00:14:37
                    Bin. Bits: 00000100
                    Lambda: 0.0 %
                    Temperature: 55.0°C
                    Absolute Pres.: 846.6 mbar
Readiness: 0110 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 000000000000000000000000000000000000
   VCID: 000962C397993D8613-8054
                    Reset counter: 114
                    Mileage: 115913 km
                    Date: 2015.05.22
                    Time: 00:43:51
                    Hex Value: 0x0005
                    Hex Value: 0x0000
                    Hex Value: 0x3013
                    Hex Value: 0x14A2
                    Hex Value: 0x00FF
                    Hex Value: 0x007F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397FCF27B0C3AC4E14-806C
                    Reset counter: 152
                    Mileage: 115913 km
                    Date: 2015.05.22
                    Time: 00:14:36
   Part No SW: 6R0 937 087 K    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0254
   Revision: BF046001    Serial number: 0434 013120035
   Coding: 3DB02BBF08F3240092380800242B0CD00040410F60040000200000000000
   VCID: 4587B3D7CC3BD8AE60-8010
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU001121100012132
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU004011200017568
   Coding: 18BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0801314
   Coding: 020000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU006011200015344
   Coding: 18BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010011200017112
   Coding: 18BC32
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag028 H09 0020
   Revision: --------    Serial number: 003GX011Z56E
   Coding: 003238
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9D80EBED2537D68D-801E
   Serial number: 3575HRB40690VP463P5L
   Serial number: 3585HRB404V124B2114C
   Serial number: 3515RRB405F0TQMCKHES
   Serial number: 3525RRB40550UFQ0H9CV
12854016 - Databus
                    Fault Frequency: 15
                    Reset counter: 152
                    Mileage: 115913 km
                    Date: 2020.12.29
                    Time: 00:14:36
12656896 - Databus
                    Reset counter: 152
                    Mileage: 115913 km
                    Date: 2020.12.29
                    Time: 00:14:36
   Part No SW: 6R0 920 860 H    HW: 6R0 920 860 H
   Component: KOMBI         H03 0505
   Coding: 140800
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 397FCF27B8C3AC4E14-806C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H46 0254
   Revision: BF046001
   Coding: 002300
   VCID: 70E93203A3392D06E3-8024
                    Reset counter: 152
                    Mileage: 115913 km
                    Date: 2015.05.22
                    Time: 00:14:36
   Component: IMMO          H03 0505
   VCID: 6ADD206B8DE5D7D6AD-803E
Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 J    HW: 6RF 909 144 J
   Component: EPS_ECU       H26 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 53A39D8F3A6F761EFE-8006
0213 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 152
                    Mileage: 115913 km
                    Date: 2020.12.29
                    Time: 00:14:37
                    Voltage terminal 15: 12.140 V
                    Voltage terminal 30: 12.789 V
                    Engine speed: 0.00 /min
                    Status: Release
   Part No SW: 5M0 035 156 D    HW: 5M0 035 156 D
   Component: Radio         553 0555
   Revision: R0553006    Serial number: VWZ5Z1L0632987
   Coding: 0500040002
   Shop #: WSC 00000 000 31414
   VCID: 2A5DE06B456517D66D-807E
End-------------------------(Elapsed Time: 03:11)--------------------------
Gone But Not Forgotten
It is from Africa maybe the car caught electronics Ebola?
Revision: --------
PART NUMBERDESCRIPTIONREMARKMODEL
6R0 907 375 ADControl unit for ABS
6R0 614 117 T
6R0 907 375 AD
PR:7K0
Vehicle Identification No.AAVZZZ6RZCU048783
ModelPolo
PO
Date of production14.03.2012
Model year2012
Sales type6R13L4
Engine CodeCLSA
Transmission CodeMAB
Tailpipes0P0Rear exhaust tailpipe (standard)
Hill start assistUG0Without hill start assist/hill descent
control/comfort driving assist
Emission standard0GVEmission standard EU2
(critical vapor pressure)
Trailer hitch1D0Without trailer hitch
airbag4UFAirbag for driver and front passenger
with front passenger airbag
deactivation
Activated carbon canister/gasoline
particulate filter
1E1Activated carbon canister
Steering system setupL0RRight-hand drive
iichel
Eindhoven, NB, NL
C?ID=284912
Who cares.
OP, please try these codings:
200200E3007100BA042C00EA00D400020000
200244E3007100BA042C22EA00D400020000
20024cE3007100BA042C32EA00D400020000
20024cE3017100BA042C32EA80D400020000
200200E3017100BA042C00EA80D400020000
200244E3017100BA042C22EA80D400020000
if it's not working... show us the advanced ID of the immobiliser and the engine screens please.
turandos
C?ID=232762
The client told me that they only replaced the stork switch on vehicle due to the brights not working. dont know what they really did.
tx i will try the codes.
turandos
C?ID=232762
hi. not working . Here are the adv ids of engine immobiliser and abs.
VIN: License Plate: POLO ENGINE ADV ID
Address 01: Engine
Control Module Part Number: 03C 906 014 AF
Component and/or Version: CLSA-MM7GV H02 8573
Software Coding: 00110014020400000000
Work Shop Code: WSC 31414
VCID: 61CF47477BD3948E7C-5182
Advanced Identification
Identification: MMJ-MAN
Revision: --H02---
Date: 22.11.11
Manufacturer number: 0003
Test stand number: 2182
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Date: 0000.00.00
Misc.
Hardware number: 03C 906 014
Workshop System Name: J623
VCDS Info:
Labels: Redir Fail!
Readiness: No script available
VIN: AAVZZZ6RZCU048783 License Plate: POLO ADV IMMO INFO
Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
Component and/or Version: IMMO H03 0505
Software Coding: 000000
Work Shop Code: WSC 00000
Advanced Identification/FAZIT
Identification: VO3-041
Date: 20.01.12
Manufacturer number: 2070
Test stand number: 0039
Flash Status
Flash Date: 00.00.00
Software
OSEK-OS: 03.14.00
HiSpd Net: 01.12.01
Misc.
Hardware number: 5K0 953 234
Workshop System Name: J334
Equipment/PR Code: 2D2D2D2D2D2D2D2D
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: ------------------
ASAM Dataset Revision: A03009
Car Info
Chassis Number: AAVZZZ6RZCU048783
Immobilizer
Transponder ID (Current val.): E8E49652
Transponder ID 1: E8E49652
Transponder ID 2: E89D9D65
VCDS Info:
Labels: 5K0-920-xxx-25.clb
VIN: License Plate: POLO ABS ADV ID
Control Module Part Number: 6R0 907 379 AD
Component and/or Version: ABS8.2 front H03 0001
Software Coding: 000000000000000000000000000000000000
Identification: BPA-085
Revision: --------
Date: 05.12.11
Manufacturer number: 0032
Test stand number: 251A
Flash Status
Flash Tool Code: 00000 000 00000
Misc.
Hardware number: 6R0 907 379 AB
Workshop System Name: J104
VCDS Info:
tx for the help.
aj
