I'm struggling to diagnose and repair Webasto auxiliary heating in the car. Since it's a rare piece of extra equipment, I have trouble finding a good mechanic and source of info to help with diagnosing.
Progress so far:
Went to my VW mechanic who first replaced the DSG temperature sensor, which was apparently also kaputt (and he also unlocked the heater, cleared the fault codes). This seemed to work for a few days, the driving temperatures of water/oil were back to normal, but while Webasto aux heating was "working" (it turned on and completed the 20 min heating cycle), the air inside the cabin was not hot enough - it was lukewarm at best. Meaning, something was still causing an issue. And after a few days, Webasto was locked again, same faults as the first time (above).
Another service visit, where they replaced the G18 temperature sensor (new OEM part, 1K0815111A). Cleared the fault codes and unlocked the heater unit again. Voila, now also the aux heating was working as it should, resulting in a warm car after 20 mins. But it only worked for a few days and now the same thing: Webasto is locked, only this time there are just two error codes:
I have no idea what's causing the issues now, it seems that for some reason the aux heating overheats, but the question is why? Could the VW wizards please point me into the direction how can I diagnose this with output tests and measuring blocks to determine which component(s) should be checked?
FWIW this error was present for quite a while (maybe ever since I had the car) and didn't seem to impact the aux heating, but at this point, I'm willing to consider any option.
Below is a full, fresh auto-scan, and PR codes at the bottom. FWIW the car is stock, without modifications, except of few safe-minor VCDS tweaks that shouldn't be related since this seems to be a hardware issue.
Progress so far:
- First, the aux heating didn't want to start anymore, was throwing error also on the dashboard MFD
- Other related symptoms were:
- Engine slow to warm up (both water and oil temperature), unless driving uphill, or on motorways
- Water and oil temp dropping if idling or driving slowly (city, downhill, suburban roads)
- Normally the temps are water bang at 90º C and oil between 80-105º C, but now unless driving uphill or on motorways (110+ km/h), oil stays between 65-75º C and is not at steady temp
- Error codes were the following:
01410 - Heater Over-Temp
Reset counter: 89
After-Run
Temperature: 148.0°C
Temperature: -48.0°C
Voltage: 12.00 V
01411 - Temperature Sensor (G18)
Fault Status: 00100111
Reset counter: 86
Mileage: 252297 km
Date: 2015.05.08
Time: 12:57:28
Malfunction
Temperature: 205.0°C
Temperature: 0.0°C
Voltage: 12.00 V
02251 - Heater Unit Locked
Reset counter: 89
Reset counter: 122
After-Run
Voltage: 12.07 V
Reset counter: 122
9477489 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Tuesday,26,January,2021,19:32:43:33127
VIN: VSSZZZ7NZFVxxxxxx License Plate:
Mileage: 255100km-158511mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 20 25 2E 42 44 46 4C 52 53
55 56 61 62 65 72 76 77
VIN: VSSZZZ7NZFVxxxxxx Mileage: 255100km-158511miles
65-Tire Pressure -- Status: Not registered 0011
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HM HW: 03L 906 018 M
Component: R4 2.0l TDI H28 9980
Revision: 44H28--- Serial number:
Coding: 001D003A042401080000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01103L906018HM 003013
ROD: EV_ECM20TDI01103L906018F_VW36.rod
VCID: 7CA1F518A663719B0EB-8028
Part No SW: 02E 300 062 HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4002
Revision: 05652104 Serial number: 00001406061628
Shop #: WSC 44551 111 44551
VCID: 52FD7BA058E757EBB47-8006
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 S HW: 7N0 614 109 S
Component: J104 C3 450M VD7C 0040
Revision: --H07--- Serial number: 00000008322492
Coding: 0027518
Shop #: WSC 00020 790 00000
VCID: 3D27381CF179B893795-8068
Part No SW: 7N0 907 426 CC HW: 7N0 907 426 CC
Component: AC Manuell H20 0607
Revision: 00001004
Coding: 0010004003
Shop #: WSC 00020 999 00000
VCID: 77ABEA349F4552C3639-8022
Reset counter: 162
Mileage: 254860 km
Date: 2021.01.24
Time: 11:53:54
Part No SW: 5K0 937 086 Q HW: 5K0 937 086 Q
Component: BCM PQ35 M 122 0174
Revision: BC122001
Coding: 60180A3BE9251AC4C08800C8500089EC477D9388626D2D626484C72000C1
Shop #: WSC 00020 790 12345
VCID: 42DD4BE08487C76B047-8016
Subsystem 1 - Part No SW: 7N1 955 119 A HW: 7N1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 140605 033 0044
Serial number: 140625221228
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y14M03D18H23M45S27S7
Coding: 0728DD
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 S HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0043
Revision: -------- Serial number: 56201419300487
Coding: 14830A
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_EPHVA2C000000000 002014
ROD: EV_EPHVA2C000000000.rod
VCID: 4BC366C4B34D0623F71-801E
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag002 H13 0014
Serial number: 003LGPES9JMS
Coding: 003032
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3FDB4214F7F5AA836B9-806A
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS607729281ADD$
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60CA3A281A9D.
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60783C281A9DX
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60A128281ADDT
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS600A581B1ADDN
Part No SW: 5K0 953 501 CR HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140722200410
Coding: 1992240000
Subsystem 1 - Part No SW: 1P0 959 538 B HW: 1P0 959 538 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0103
Coding: E30000
Part No SW: 7N5 920 870 L HW: 7N5 920 870 L
Component: KOMBI H03 0905
Coding: 141F01
VCID: 40D941E88A0BD57B123-8014
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 E
Component: Standheizer 044 4941
Revision: 00044000 Serial number: 09028239000000
Coding: 0031132
VCID: 372B2A34D34592C3A39-8062
Reset counter: 122
After-Run
Voltage: 12.07 V
Reset counter: 122
Part No SW: 7N0 907 530 AQ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1653
Revision: H58 Serial number: 170714F1003254
Coding: 468202
VCID: 7F5B0214B7F56A832B9-802A
01327 - Control Module for Parking Aid (J446)
Reset counter: 115
Mileage: 254780 km
Date: 2015.06.15
Time: 13:55:26
Fault Frequency: 117
Mileage: 254780 km
Date: 2015.06.15
Time: 13:55:22
Part No SW: 7N0 857 511 P HW: 8P0 857 511 C
Component: FLA H04 0012
Revision: AA001002
Coding: 0201816B74745D545420363E01
VCID: 40D941E88A8BD57B123-8014
Component: IMMO H03 0905
VCID: 6A8DC340DCF7FF2BEC7-803E
Address 2E: Media Player 3
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 G HW: 7N0 959 793 G
Component: TSG FA H03 0553
Revision: Serial number: 0000109741843
Coding: 01110720D400411011
VCID: 46D557F0A8AFFB4B28F-8012
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.324 1401
Revision: 1BH04739 Serial number: 00141890389801
Coding: 0000258
VCID: 41DF44EC8D81DC731DD-8014
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 G HW: 7N0 959 792 G
Component: TSG BF H03 0553
Revision: Serial number: 0000109123241
Coding: 01110520DE00411011
VCID: 45D750FC95A9F053215-8010
02127 - Exterior Door Handle Light / Mirror Light
Fault Status: 01101100
Reset counter: 115
Mileage: 254780 km
Date: 2015.06.15
Time: 13:55:05
02119 - Potentiometer for Vertical Mirror Adjustment
Fault Status: 00101100
Reset counter: 160
Mileage: 254988 km
Date: 2015.06.18
Time: 10:05:14
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000177048
Coding: 0024167
VCID: 38292908DE5B9DBBAA3-806C
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 068200000B000000
Shop #: WSC 00020 999 39850
VCID: 372B2A34DFC592C3A39-8062
Subsystem 1 - Part No: 1T0 941 329 B Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 1T0 941 329 B Labels: 3D0-941-329.CLB
Part No SW: 3C8 035 195 F HW: 3C8 035 195 F
Component: RCD510 H02 5017
Revision: -----17S Serial number: VWZ4Z3M1116057
Coding: 0100040004000D
VCID: 2B030644130D2623D71-807E
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1653
Coding: 030F1859
VCID: 71BFD42CF1A10CF3ADD-8024
Component: J367-BDM H07 0180
Serial number: 41195A19581491546317
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 G HW: 7N0 959 794 G
Component: TSG HL H04 0553
Revision: Serial number: 0000111223839
Coding: 010005200000411001
VCID: 47CB5AF4AFA5E243D39-8012
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 122 0821
Coding: 018705
Mileage: 252459 km
Date: 2015.05.10
Time: 21:11:26
01487 - System Function Test
Fault Status: 01100101
Reset counter: 50
Mileage: 252459 km
Date: 2015.05.10
Time: 21:11:26
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H04 0553
Revision: Serial number: 0000111229794
Address 76: Park Assist (J791) Labels:| 3AA-919-475.clb
Coding: 14830A
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666453106
Coding: 0A10000080010101
ROD: EV_UHVUMI.rod
VCID: 323D1B2034A777EB947-8066
End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.2V)-----------
