- Oct 8, 2020
- 32
- 11
- Rancho Cucamonga, CA, USA
- C?ID=419570
Hi all, I'm wondering if anyone knows if it's possible to reverse the +- button functionality during adaptive cruise control.
I love my car and ACC but the plus and minus buttons used for distance control are counterintuitive to me. The - button should "back me away", thus increasing the distance from the vehicle in front of me (similar to slowing down) and the + button should "bring me closer", thus decreasing the distance to the vehicle in front of me (similar to speeding up). I have been using it for 5 months now and am still confused every time I try to adjust it.
Additionally, the ACC is way too aggressive, braking much too hard when a car is in front of me but that is a topic for another day.
A few months ago, we rented a Ford Fusion and the ACC on that car was perfect. The distance control was subtle and the buttons made sense. Not that I would buy that car but maybe we shouldn't have rented it.....
Thanks everyone.
_________________________________________________________________
Vehicle scan:
Thanks everyone.
Vehicle scan:
Wednesday,07,October,2020,21:57:57:21681
VIN: 1V2NE2CA0LC213197 License Plate:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 36 3C 42 44 47 4B 52 5F
69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NE2CA0LC213197 Mileage: 859km-533miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CDVC) Labels: None
Part No SW: 03H 906 026 AG HW: 03H 907 309 K
Component: VR6 3.6l FSI H21 9970
Revision: 52H21000
Coding: 012A003244740108F0000000000000000000000000000000
Shop #: WSC 06050 062 00200
ASAM Dataset: EV_ECM36FSI01103H906026AG 001006
ROD: EV_ECM36FSI01103H906026AG.rod
VCID: 6A8DC661CCFAA24BEC7-803E
CAN Converter 01:
22593 - Fuel Level Sensor Circuit
P0461 00 [096] - Implausible Signal
Mileage: 203 km
Date: 2020.09.20
Time: 13:54:22
Engine speed: 1495.00 /min
Normed load value: 39.6 %
Vehicle speed: 85 km/h
Coolant temperature: 83 °C
Intake air temperature: 34 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 12.740 V
Unlearning counter according OBD: 18
Outside air temperature: 31 °C
Air mass: actual value:: 17.22 g/s
Engine torque: 133.1 Nm
Fuel: tank fill level: 70.0 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Intake camshaft bank1 active operating mode-Bits 0-7: 0
Overrun cut-off-Bits 0-7: 0
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DR HW: 09G 927 158
Component: AISIN AQ8 206 3742
Coding: 0000000100000000000000000000000000000000
ROD: EV_TCMAQ450031_VW37.rod
VCID: 065592D1F8A2662B68F-8052
Part No SW: 5Q0 614 517 DL HW: 5Q0 614 517 BP
Component: ESC H35 0113
Revision: 00000000 Serial number: 50410000000867
Coding: 85FC6B8D80211A6FC5780309A2CA69A1D60158A3C045967638415058D2AA4A0B004023641C12141A1D8DDB45506CC8CF
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7EA5FA31A0723EEB20F-802A
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0536888289
Coding: 1F20000723
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D755DD8524AD33215-8010
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 14277850
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 3CM 907 044 B HW: 3CM 907 044 B
Component: Climatronic H05 2401
Revision: 00001K04
Coding: 1402002620001C0C1104010C9210D52C
ASAM Dataset: EV_ACClimaBHBVW416 002015
ROD: EV_ACClimaBHBVW416.rod
VCID: 3D273D3DEDF4E5F3795-8068
Part No SW: 5Q0 937 085 CC HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H40 0312
Serial number: 0032036602ÿÿÿÿ
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 7CA1F039B66E2CFB0EB-8028
Subsystem 1 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 051 0207
Serial number: S7Y19M12D17H18M00S56
Coding: 0018DD
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 AC HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0300070220200C200538
Seat Backrest Fan 1 Front Left:
Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0646341
Seat Cushion Fan 1 Front Left:
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0567928
Seat Backrest Fan 1 Front Right:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0935201
Seat Cushion Fan 1 Front Right:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0537213
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000259541119268
Coding: 0271267951
ASAM Dataset: EV_EPHVA2CAU3700000 009048
ROD: EV_EPHVA2CAU3700000_VW41.rod
VCID: 55F7859D75841DB3515-8000
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 320007CB58FF8728949C810530409700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D34BC58B1093030F1-8016
0858 - Databus
[FAULT_KAMERA_SYSTEMZUSTAND_KAMERA_IM_INIT]
Reset counter: 67
Mileage: 31 km
Date: 2020.04.16
Time: 18:36:25
Voltage terminal 15: 13.3 V
Control Module temperature: 43 °C
Vehicle speed: 4.16 m/s
Longitudinal acceleration: -0.03 m/s²
Adaptive distance regulation: status: ACC_StandBy
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Reset counter: 90
Mileage: 793 km
Date: 2020.10.03
Time: 18:48:31
Voltage terminal 15: 13.2 V
Control Module temperature: 74 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.03 m/s²
Part No SW: 3Q0 959 655 DB HW: 3Q0 959 655 DB
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 00310M37QVXe
Coding: 8CCCFC00000000005000001AC20840000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 015F81CDD18C41135DD-8054
Occupant Detection:
Component: Occ.Detection H14 0022
Serial number: IBH0000D19000CPOO00P
Coding: 303030
Subsystem 2 - Part No SW: ----------- HW: 454 002 711 19
Serial number: 35700000000E1B3D224M
Subsystem 3 - Part No SW: ----------- HW: 454 002 010 19
Serial number: 358000000001B8600144
Subsystem 4 - Part No SW: ----------- HW: 454 802 801 20
Serial number: 3510003CF1F1B000000O
Subsystem 5 - Part No SW: ----------- HW: 454 802 801 20
Serial number: 3520096B99E1A000000-
Subsystem 6 - Part No SW: ----------- HW: 454 802 801 20
Serial number: 355000365161B0000003
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 454 802 801 20
Component: FrontSensor_P 304 0149
Serial number: 356004160161B0000001
Part No SW: 3G0 920 890 E HW: 3G0 920 890 E
Component: KOMBI 503 4193
Coding: 00A438086F8CCF050288630B50010000A0001009
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 2B03036503807B43D71-807E
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 07022000842261
Coding: 0B0500347F087300FB03225A1E0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 70B9D409EA26589BA23-8024
Component: 4-01-0e-01-04
Subsystem 2 - Part No SW: 3G0 959 442 H HW: 3G0 959 442 H
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036015201830
Coding: 2E0B00
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 0621947100
Power Converter DC AC:
Subsystem 4 - Part No SW: 3CN 907 155 HW: 3CN 907 155
Component: U13DCAC H23 0890
Serial number: B060193
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00014.11.19
Coding: 0101
VCID: 4CC160F9A64E5C7BFEB-8018
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 E HW: 5Q0 959 760 E
Component: Sitzmemory H09 0026
Serial number: Y0007TA930554
Coding: 0010000000000500018280808080000000008100000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3FDB4735E7F8F7E36B9-806A
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0148
Serial number: 11230022775113
Coding: 62954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392F292DF9DCD9D355D-806C
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0325
Serial number: YA008TAO00GC1
Coding: 003B1B205200020000040000
VCID: 49CF59EDA93C4953C5D-801C
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000005277632
Coding: 011000
Part No SW: 3QF 909 144 B HW: 3QF 909 144 A
Component: EPS_MQB_ZFLS 570 1582
Coding: 9B1F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 47CB5FD5BF28BF23D39-8012
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD06V9D+
Coding: 2200000002A2AAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E050A7130920E6BF0F-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 27012000840740
Coding: 000000070900135202112300030000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW41.rod
VCID: 372B2F15CFC8CFA3A39-8062
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0325
Serial number: YA008TBD002X6
Coding: 003B13205E00020000040000
VCID: 48C95CE9B236B05BDA3-801C
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000005273537
Coding: 091000
Part No SW: 2GM 035 876 C HW: 2GM 035 876 C
Component: MU-S-NS-US 854 0523
Coding: 022436020000000051220002001808211F0500E40120040586
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 46D552D1B822A62B28F-8012
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 261 8214
Serial number: VWZ6ZMX0465846
Subsystem 2 - Part No SW: 5NA 919 866 AF HW: -----------
Component: NAR 2020 --- 1320
Address 69: Trailer (J345) Labels:* None
Part No SW: 5H0 907 383 HW: 5H0 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005379
Coding: 0200000200001300
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6B83C365C300BB43971-803E
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG068730
Coding: 01140600A30F20003000400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C758-8680-4
Coding: 2F88
Part No SW: 5WA 035 283 HW: 5WA 035 283
Component: OCUGen3Low H10 0295
Serial number: 0000000911NVWP6
Coding: 0241602019682C208005461160500607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW41.rod
VCID: 025D8EC1D48A5A0B447-8056
1644017 - Online Services
B1915 F1 [008] - Temporary Function Restriction due to Battery Budget
[Functional restriction due to insufficient power budget]
Reset counter: 4
Voltage terminal 30: 12.2 V
Remaining long term energy budget: 0 mAh
Remaining short term energy budget: 936 mAh
Wake up cycles counter: 115
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H11 1029
Serial number: E33417011193400
Coding: 00000A081178C020B09F00001020002000210000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW27.rod
VCID: 72BDDE01E42A6A8B547-8026
1124198 - Development code 1
B2F01 00 [008] - -
[VZF_Init]
Fault Priority: 9
Reset counter: 26
Mileage: 164 km
Date: 2020.09.17
Time: 09:19:33
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 00804074161C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B7E51D95447DB3715-8020
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 992 941 572 AA HW: 992 941 572 A
Component: LED1L H08 9002
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 629DAE4134CAFA0B247-8036
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H08 9002
End----------(Elapsed Time: 01:52, VBatt start/end: 12.2V/12.2V)-----------
