For my A1 GB 07/19 I coded the following successfully:
1. choose STG 09 (central electric)
3. enter ecurity code 31347
4. adaptation -> funktion 10
5. "ZV Autolock-Menuesteuerung ZV Autolock-Unlock" -> "adjustable" instead "not active"
Then I disabled automatic door locking at 15km/h speed within the newly shown menu in MMI.
However, the trunk lid still is automatically locked until the driver door is opend after a stop, where the engine stays running. Does anyone of you know how to disable automatic looking of the trunc lid in the same manner as for the other doors? It would be nice if the backdor lid simply ould obeyes the (above) MMI setting.
Could it be to set the option "ZV Autolock-Autolock Autounlock wirkt auf Heck" to not acitve? I only saw the option is existing in the thread 2018 Audi A3 e-tron | Page 4 | Ross-Tech Forums (ross-tech.com) and did not yet check that for my car. Any ideas?
Thanks for expertise and time.
Chris
Chris
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: AIB 20.4.2.1 HEX-NET CB: 0.4513.4
Datenstand: 20200919 DS317.0
www.vcds.de
Fahrzeug-Ident.-Nr.: WAUZXXXXXXXXXXX KFZ-Kennzeichen: xxxxxxx
Kilometerstand: xxxxxkm Reparaturauftrag:
Fahrzeugtyp: GB-AU27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75 A5
Fahrzeug-Ident.-Nr.: XXXXXXXXXXXXXXXX Kilometerstand: xxxxxxkm
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
75-Telematik -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DADA) Labeldatei:. DRV\04E-907-309-V1.clb
Teilenummer SW: 05E 906 018 AB HW: 05E 907 309
Bauteil: R4 1.5l TFS H22 9763
Revision: 81H22000
Codierung: 0225003223041D0800000000000000000000000000000000
Betriebsnr.: WSC 33396 001 1048576
ASAM Datensatz: EV_ECM15TFS01105E906018AB 003005
ROD: EV_ECM15TFS01105E906018AB_AU27.rod
VCID: E5823838E45F7BAE01-80B0
Kein(e) Fehlercode(s) gefunden.
Adresse 02: Getriebe (J743) Labeldatei: DRV\0CW-927-769.clb
Teilenummer SW: 0CW 300 043 D HW: 0AM 927 769 E
Bauteil: GSG DQ200G2_M H05 1605
Revision: 00005008 Seriennummer: CUxxxxxxxxxxxxxx
Codierung: 0014
Betriebsnr.: WSC 00049 770 00163
ASAM Datensatz: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW27.rod
VCID: B83CA14C036D36466A-80EC
Adresse 03: Bremsenelektronik (J104) Labeldatei: Umleit. fehlgeschl.!
Teilenummer SW: 2Q0 614 517 AG HW: 2Q0 614 517 N
Bauteil: ESC_base_vFGS H23 0242
Seriennummer: 085xxxxxxxxxxxxxxx
Codierung: 42094D4F354742AFB200AC1A37E123A649125126336A24582454285445ECC46592488A64CC56241A242A142AA24DD2423DB24B42BC
ASAM Datensatz: EV_Brake1BOSCHESPMQBA0 004036
ROD: EV_Brake1BOSCHESPMQBA0_004.rod
VCID: F3A656605A8B951E9F-80A6
Adresse 08: Klima-/Heizungsel. (E87) Labeldatei:* Keine
Teilenummer SW: 83A 820 047 A HW: 83A 820 047 A
Bauteil: AC Manuell el H04 0020
Revision: 20026000 Seriennummer: 000000xxxxxxxxxxxxxxx
Codierung: 230000040000000010000000000000000000000000000000
ASAM Datensatz: EV_AirCondiFrontManAU326 001003
ROD: EV_AirCondiFrontManAU326.rod
VCID: A2086324B5F14C96A4-80F6
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\5Q0-937-08X-V2.clb
Teilenummer SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Bauteil: BCM MQBAB M+ H38 0273
Seriennummer: 010xxxxxxxxxxxxx
Codierung: 000000000000000000000000000000000000000000000000000000000000
ASAM Datensatz: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019.rod
VCID: FCB47D5C77D5DA66CE-80A8
Sensor für Regen- und Lichterkennung:
Subsystem 1 - Teilenummer SW: 81A 955 559 A HW: 81A 955 559
Bauteil: G397_RLS H06 0002
Seriennummer: 20xxxxxxxxxxxxxxxxxx
Codierung: 80004D
Lichtschalter:
Subsystem 2 - Teilenummer SW: 4K1 941 501 D HW: 4K1 941 501 D
Bauteil: E1 - LTM H05 0053
Seriennummer: 1xxxxxxxxxxxxxx
Lenkstockschalter:
Subsystem 3 - Teilenummer SW: 82A 953 521 DR HW: 5Q1 953 549
Bauteil: J527 SMLS MQB 004 0070
Seriennummer: 000000xxxxxxxxxxxxxxxx
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\5Q0-919-294.clb
Teilenummer SW: 5QA 919 294 C HW: 5QA 919 294
Bauteil: PDC 8 KanalH07 0050
Seriennummer: 00xxxxxxxxxxxxx
Codierung: 0471051011
ASAM Datensatz: EV_EPHVA18AU3700000 009039
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: CCD4ED9C67F5AAE63E-8098
Adresse 13: Distanzregelung (J428) Labeldatei:| 2Q0-907-572.clb
Teilenummer SW: 2Q0 907 572 Q HW: 5Q3 907 572
Bauteil: ACCCONTIMQB H03 0342
Codierung: 3200000208F78728747C61450050A700000000000000000000
ASAM Datensatz: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: C2C8C3A455B16C96C4-8096
Adresse 15: Airbag (J234) Labeldatei:* Keine
Teilenummer SW: 2Q0 959 655 AM HW: 2Q0 959 655 AM
Bauteil: VW22Airbag 010 0351
Revision: --------
Codierung: 88CCC0C0000000005C5400DF000840A80065
Betriebsnr.: WSC 00049 770 00119
ASAM Datensatz: EV_AirbaVW22BPAVW27X 001020
ROD: EV_AirbaVW22BPAVW27X_VW37.rod
VCID: 885C118C330D86C6DA-80DC
Crashsensor für Seitenairbag Fahrerseite:
Subsystem 1 - Teilenummer SW: ----------- HW: 442 062 005 19
Bauteil: SideSensor_Df 1E2 0887
Seriennummer: 3xxxxxxxxxxxxxxxxxx
Codierung: 2D2D2D
Crashsensor für Seitenairbag Beifahrerseite:
Subsystem 2 - Teilenummer SW: ----------- HW: 442 062 005 19
Bauteil: SideSensor_Pf 1E2 0887
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Fahrerseite:
Subsystem 3 - Teilenummer SW: ----------- HW: 442 0B1 105 19
Bauteil: SideSensor_Dr 1C7 0148
Seriennummer: 35xxxxxxxxxxxx
Codierung: 2D2D2D
Crashsensor für Seitenairbag hinten Beifahrerseite:
Subsystem 4 - Teilenummer SW: ----------- HW: 442 0B1 205 19
Bauteil: SideSensor_Pr 1C7 0148
Codierung: 2D2D2D
Crashsensor für Frontairbag Fahrerseite:
Subsystem 5 - Teilenummer SW: ----------- HW: 442 133 003 19
Bauteil: FrontSensor_D 290 118A
Seriennummer: 3xxxxxxxxxxxxxxxxxxx
Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:* Keine-SRI3
Teilenummer SW: 82A 920 700 HW: 82A 920 700
Bauteil: KOMBI H13 1712
Codierung: 00840008618000080080A0001000000000000000
ASAM Datensatz: EV_DashBoardVDDMQBA0 001027
ROD: EV_DashBoardVDDMQBA0_AU27.rod
VCID: DDF210D8CC0F336ED9-8088
Adresse 19: Diagnoseinterface (J533) Labeldatei:| DRV\3Q0-907-530-V1.clb
Teilenummer SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Bauteil: GW MQB High 521 5366
Seriennummer: 05xxxxxxxxxxxxxxx
Codierung: 030100F42F0857005B000248180B00000000000000000000000000000000
ASAM Datensatz: EV_GatewNF 013025
ROD: EV_GatewNF_AU27.rod
VCID: EE90471431A9B8F670-80BA
Generator:
Bauteil: 0-00-02-00-04
Steuergerät für Multifunktionslenkrad:
Subsystem 2 - Teilenummer SW: 83A 951 523 HW: 83A 951 523
Bauteil: J453 MFL H05 0004
Seriennummer: 20xxxxxxxxxxxx xxxxx
Steuergerät für Batterieüberwachung:
Subsystem 3 - Teilenummer SW: 2Q0 915 181 HW: 2Q0 915 181
Bauteil: J367-BDMBOSCH H02 2011
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:| 5QX-959-X93-42.clb
Teilenummer SW: 5Q4 959 393 F HW: 5Q4 959 393 F
Bauteil: TSG FS 006 0246
Seriennummer: xxxxxxxxxxxxxx
Codierung: 00100320E100020000001000
ASAM Datensatz: EV_DCU2DriveSideMAXHCONT 001005
VCID: C6C0DFB4799950B6E8-8092
Türsteuergerät Fahrerseite hinten:
Subsystem 1 - Teilenummer SW: 5Q0 959 407 HW: 5Q0 959 163
Bauteil: FOND_FHSG_DRV 007 0010
Codierung: 310000
Adresse 44: Lenkhilfe (J792) Labeldatei:* Keine
Teilenummer SW: 2Q1 909 144 M HW: 2Q1 909 144 F
Bauteil: TRW_G4L_MQBA0 611 6041
Seriennummer: 1xxxxxxxxxxxxxxx
Codierung: 010000000100000001010201010001010000010101
ASAM Datensatz: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: BC34BD5C37551A668E-80E8
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei:| 5QX-959-X92-52.clb
Teilenummer SW: 5Q4 959 392 F HW: 5Q4 959 392 F
Bauteil: TSG BFS 006 0246
Seriennummer: 0xxxxxxxxxxxxx
Codierung: 00100120E100020000001000
ASAM Datensatz: EV_DCU2PasseSideMAXHCONT 001005
VCID: C5C2D8B8449F5BAEE1-8090
Türsteuergerät Beifahrerseite hinten:
Subsystem 1 - Teilenummer SW: 5Q0 959 408 HW: 5Q0 959 164
Bauteil: FOND_FHSG_PSG 007 0010
Seriennummer: 0xxxxxxxxxxxxxxxxxx
Codierung: 290000
Adresse 5F: Informationselek. I (J794) Labeldatei:* Keine
Teilenummer SW: 83A 035 842 HW: 83A 035 842
Bauteil: MU-S-D-ER 742 0051
Seriennummer:
Codierung: 01720000BE00000041111101C00800002F0007E40170000002
Betriebsnr.: WSC 23582 187 00000
ASAM Datensatz: EV_MUStdGen2pDELP 001001
ROD: EV_MUStdGen2pDELP.rod
VCID: E2882324F5710C96E4-80B6
Anzeigeeinheit 1 für Multimediasystem:
Subsystem 1 - Teilenummer SW: 82A 919 604 A HW: 82A 919 604 A
Bauteil: DU AU270 Std H42 0133
Seriennummer: Mxxxxxxxxxxxxxxxx
Lautstärkeregler 1:
Subsystem 2 - Teilenummer SW: 82A 919 616 HW: 82A 919 616
Bauteil: LSR-D5/C8 H33 0108
Seriennummer: 00ccxxxxxxxxxxxxxxxxx
Adresse 75: Telematik (J949) Labeldatei:| 5QE-035-285.clb
Teilenummer SW: 5NA 035 284 C HW: 5NA 035 284 C
Bauteil: OCULowMQBLGE H19 0833
Revision: --------
Codierung: 01720601EA370A0F05109C0000354003804651
ASAM Datensatz: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: BD32B0582C4F136EB9-80E8
Adresse A5: Front-/Vorfeldkamera (R242) Labeldatei:| DRV\3Q0-980-65X-A5.clb
Teilenummer SW: 3Q0 980 654 M HW: 3Q0 980 654 A
Bauteil: MQB_B_MFK H09 0451
Seriennummer: 2xxxxxxxxxxxxxx
Codierung: 0402070000000401002200448146480084000E00000000
ASAM Datensatz: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: C1CACCA850B7778EDD-8094
Ende--(Dauer: 01:08, Batt.-Spannung Start/Ende: 11.9V/11.9V. VIgn 11.9V)---
