- Jan 13, 2021
- 7
- 0
- North Wales, UK
- C?ID=431457
Hi all..got myself a 2017 Startline Caddy just before xmas, I've had GTi bumper put on and would like to utilise the foglamps as DRLs. I wanted to do it properly and not just hijack a feed from the current DRL's so set out on a voyage of discovery, bought the service manual, found the Fog lamp feeds on the BCM, wired up a quick test circuit in the footwell and..nothing. Scratched my head for a while then snapped a pic of the pins on the BCM, and of course the Fog feeds were absent. I snapped up a new Highline BMC, PN:5K0937087AC and have reviewed a few guides on swapping them, non specific to mine however, so to cut a long story short, does anyone know definitively whether the new one will have Component Protection? I've had mixed feedback from various sources.
I've upgraded the original MFSW to one with ACC controls with a view to getting that working, but after some research that seems a tougher nut to crack than Foglights so I'll save that for another day
Apologies for the scan format too, If someone would be kind enough to share the correct technique for attaching the data.
Address 16,5K0 953 521 GE,recoded (Long Coding-exp),from,1002C60100,to,9000C60100,(12345/123/61029)
Friday,22,January,2021,16:33:54:51394
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
VIN: WV1ZZZ2KZJX022745 License Plate: GJ67
Mileage: 61710km-38344mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 13 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZJX022745 Mileage: 61710km-38344miles
Address 01: Engine (J623-DFSD) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 MH HW: 04L 907 309 K
Component: R4 2.0l TDI H20 4090
Revision: 8AH20---
Coding: 01110010040509090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01104L906016MH 001001
ROD: EV_ECM20TDI01104L906016MH.rod
VCID: 7BA208130369ECF3260-802E
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 62207000002015
Coding: 1079409B9264A480087C027A498725E379F100
VCID: 3FDABC0357F130D34A8-806A
Part No SW: 5K0 937 085 AD HW: 5K0 937 085 AD
Component: BCM PQ35 B+ 122 0186
Revision: BB122001
Coding: 5F1A583A802B086A48CA0000B500006407610008424F0160648087000045
Shop #: WSC 12345 123 61029
VCID: 75B61E2B25CDBA83504-8020
Subsystem 1 - Part No: 2K2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 19071 26 0512
Coding: 009795
01800 - Light Switch (E1)
Reset counter: 248
Mileage: 61656 km
Date: 2021.01.18
Time: 15:58:29
Term 15 Off
Voltage: 12.10 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 209
Mileage: 61652 km
Date: 2021.01.17
Time: 14:41:58
Voltage: 10.85 V
Fault Status: 00101010
Reset counter: 249
Mileage: 61656 km
Date: 2021.01.18
Time: 16:48:24
Term 15 Off
Voltage: 12.00 V
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Serial number: 0708170464A17C
Coding: 00080002FE133B
ROD: EV_ACCBEGVW361.rod
VCID: 3634D92778CBF19B99E-8062
Part No SW: 2K5 959 655 B HW: 2K5 959 655 B
Component: VW10Airbag00K H08 0018
Revision: -------- Serial number: 003V100535NS
Coding: 00000000000000000000000000000000304B
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3B22C81343E92CF3660-806E
Serial number: 3497ARB40614PCOCMHE/
Serial number: 3507ARB40594S60GHHB8
Part No SW: 5K0 953 521 GE HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20170807200177
Coding: 1002C60100
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 75B61E2B254DBA83504-8020
Subsystem 1 - Part No SW: 5TA 959 442 B HW: 5TA 959 442 B
Serial number: 2131702215000206AP2B
Coding: 2F0000
97284 - Databus
Reset counter: 206
Mileage: 61649 km
Date: 2021.01.14
Time: 11:33:11
Part No SW: 2K5 920 976 E HW: 2K5 920 976 E
Component: KOMBI H04 1107
Coding: 410A200200
VCID: 3828D71F72DF07EB8B2-806C
13654544 - Databus
[Steuergerät für Telefon keine Kommunikation]
Fault Frequency: 56
Reset counter: 209
Mileage: 61644 km
Date: 2021.01.12
Time: 15:12:02
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 080817F1000548
Coding: 357421
Shop #: WSC 35110 377 08192
VCID: 7BA2081303E9ECF3260-802E
Reset counter: 206
Mileage: 61647 km
Date: 2021.01.13
Time: 12:42:47
Component: IMMO H04 1107
VCID: 6A8C3D577CF3657BCD6-803E
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2144
Coding: 0131632
VCID: 71BE2A3B5DA596A38CC-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 392ED21B45551EE374C-806C
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0131632
VCID: 72BC253758A3ADBB756-8026
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: 030F7873
VCID: 71BE2A3B51A596A38CC-8024
Subsystem 1 - Part No SW: 2K0 915 181 HW: 2K0 915 181
Serial number: 75885800001708120AB1
End----------(Elapsed Time: 00:59, VBatt start/end: 12.0V/12.0V)-----------
