Hello
I would like to tweak my DRL on my VW Polo 6R 2010 CAYB.
I don't have auto ligfhts so my current default configuration is:
Light switch off (0) - Sidelights & Main lights (Headlights + Rear lights) on as DLR
Ligth Switch Position 1 - Sidelights on and instruments lit.
Light Switch Position 2 - Sidelights & mainlights on and instruments lit.
and I want to change to:
Light switch off (0) - Rear Lights and Sidelights only on as DRL
So I basically want to turn off headlights when light switch is off (0) and keep only sidelights and rear lights. Is there any way to achieve this with VCDS coding?
Here is the auto scan (please ignore faults, these have been sorted out):
Monday,18,January,2021,19:08:16:46225
VIN: WVWZZZ6RZBY056090 License Plate:
Mileage: 133350km-82859mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZBY056090 Mileage: 133350km-82859miles
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BC HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 6909
Revision: -------- Serial number:
Coding: 00114014000500080000
Shop #: WSC 124697 483 00190
ASAM Dataset: EV_ECM16TDI02103L906023BC 003005
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 6889BA3D92F8925BFA3-803C
7397 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [032] - Short to GND
Engine speed: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 8 °C
Intake air temperature: 10 °C
Voltage terminal 30: 11.181 V
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 9.04 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 8.30 g
Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 2 km
Zähler der Regenerationszeit des Partikelfilters-T_INT_RGN_ACT_INI_PF_ENVD_H: 0.0000 s
Particle filter: difference pressure-DIP_PF: 0.00 hPa
Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
Sensor for temp after charge air cooler: raw value-TBA_MES: 10 °C
7347 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [101] - Implausible Signal
Mileage: 133344 km
Date: 2021.01.16
Time: 15:43:13
Engine speed: 889.50 /min
Normed load value: 7.5 %
Coolant temperature: 71 °C
Intake air temperature: 22 °C
Voltage terminal 30: 13.779 V
Particle filter: offset for differential press.-DIP_PF_AD[0]: 80.02 hPa
Outside air temperature-Ambient temperature: 9.00 °C
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 10.06 g
Air mass: actual value:: 8.43 g/s
7346 - Diesel Particle Filter; Differential Pressure Sensor
P2453 00 [237] - Implausible Signal
Coolant temperature: 69 °C
Intake air temperature: 19 °C
Voltage terminal 30: 13.101 V
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 4.33 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 10.42 g
Air mass: actual value:: 5.62 g/s
Readiness: 0100 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 230228E3417200B8C42514EB82D100821300
Shop #: WSC 02069 000 00000
VCID: 06559485B86C642B68F-8052
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 35372349954A3FB3B15-8060
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0345 196101793
Coding: 25B029BF08E12400922000003D2B0CD00000410F60060000200000000000
Shop #: WSC 00631 210 91765
VCID: 42DD4895D484980B047-8016
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0912
Serial number: KU0-KU030.06.1011032
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0912
Serial number: KU0-KU001.07.1011838
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H11 9004
Subsystem 5 - Part No: 1K8 951 171 A
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag00A H09 0020
Revision: -------- Serial number: 003GX004AVS$
Coding: 003041
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD60B5EC34404BCC7-801E
Serial number: 3572SRB40000C31D41F7
Serial number: 3582SRB40000C291419/
Serial number: 3515RRB40696Q5E6BGS
Serial number: 3525RRB405D6R0C291RE
Part No SW: 6R0 920 961 F HW: 6R0 920 961 F
Component: KOMBI H04 0304
Coding: 440A00
VCID: 392F2F79B9D2DBD355D-806C
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 002100
VCID: 70B9D25DAAA85A9BA23-8024
Component: IMMO H04 0304
VCID: 6A8DC0358CF4A04BEC7-803E
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668265792
VCID: 270BF9015FE65D23339-8072
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F3B11217E560563FB9-807A
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5516
Revision: -------- Serial number: VWZZZ4J6278413
Coding: 16000400040005
Shop #: WSC 127395 840 08317
VCID: 46D55485F8ACA42B28F-8012
Fault Status: 00110100
Reset counter: 100
Mileage: 133289 km
Date: 2015.06.01
Time: 01:59:50
End----(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
Monday,18,January,2021,19:11:24:46225
P2453 00 [036] - Implausible Signal
Coolant temperature: 64 °C
Intake air temperature: 18 °C
Voltage terminal 30: 11.972 V
Air mass: actual value:: 0.64 g/s
Readiness: 1110 1000
Revision: --------
Revision: 00 11 25
Coding: 08BC30
Coding: 08BC30
Coding: 003041
Coding: 440A00
Coding: 002100
Coding: 11230
Shop #: WSC 00788
Reset counter: 104
Mileage: 133355 km
Date: 2015.06.11
Time: 19:08:18
00877 - Treble Speaker Rear Right (R16)
Reset counter: 104
Mileage: 133355 km
Date: 2015.06.11
Time: 19:08:18
End----------(Elapsed Time: 01:32, VBatt start/end: 14.0V/14.1V)-----------
